posted 03-30-2004 03:06 PM ET (US)
About a year ago one of the guys here emailed me with some info on his 22OR powered by a 250 Yamaha OX66 bored over and probably producing 260hp. He said that after much experimentation the best results he had were with a 15 1/4" X 19 Saltwater series prop. Also in the last year I have seen Sal talk about the virtues of a Stilleto prop. I might be a slo lerner but after seeing that about a half dozen times I figured I'd go that route.
Assuming he has 10 more horsepower than I do how much difference would there be in optimum pitch?
How about the difference between a whaler drive and notched transom? Would they use same diameter and pitch?
How much difference between a boat with a T top and without?
I have seen much discussion about props on a 22'Revenge WD How much difference between a 22'revenge WD and a 22'outrage WD assuming both boats powered with 250hp and set up identically?
Would there be much difference between between prop brands? In other words assuming a stock OX66 prop is working for me would the stilleto use the same diameter and pitch?
There seems to be a wide range of diameters and pitches that different people are using. What are the advantages and disadvantages of larger diameter / decreased pitch vs smaller diameter/increased pitch?
Thanks for any assistance ; Sorry about the shotgun method of questions asked.
Greg
