  Prop for 21' Outrage with 150 Evinrude?
Author Topic:   Prop for 21' Outrage with 150 Evinrude?
Kingsteven18 posted 04-04-2004 07:25 AM ET (US)   Profile for Kingsteven18   Send Email to Kingsteven18
What do you have or recommend? Thanks.
Kingsteven18 posted 04-06-2004 09:36 PM ET (US)     Profile for Kingsteven18  Send Email to Kingsteven18
please ???!!!!!!!
ryanwhaler posted 04-06-2004 09:38 PM ET (US)     Profile for ryanwhaler  Send Email to ryanwhaler
Maybe someone who learned from you will sarcastic useless reply.
Sal DiMercurio posted 04-06-2004 10:20 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Depending on how strong that 150 is.
I'd say either a 14.25 x 15 or 14.25 x 17.
That engine needs to be mounted up on either the 2nd set of holes or the 3rd.
If it's mounted all the way down, you will need the 15p for sure.
You don't say what year boat or engine they are, as it makes a big difference if it's an older 21 [ banana style ].
Sal
Bigshot posted 04-07-2004 11:08 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
We need to know what 21' you own and what 150 as well. Your info is useless.
Kingsteven18 posted 07-30-2007 06:29 AM ET (US)     Profile for Kingsteven18  Send Email to Kingsteven18
OK guys, I'm reviving this post; your help will be appreciated. Actually, it's a Wahoo 21' Offshore, similar to an Outrage. The hull is 1900 lbs. The motor is a 155hp OMC Commercial outboard, which I understand is designed with a different gear ratio and lower compression, both for durability. It is mounted directly on the transom (not any holes up). I have a 15x17 and a 14 1/4x19 prop. Neither worked correctly. The tach is not working. I'm selling this boat and I'm just trying to find the right prop for the new owner. Thanks. Steve
