ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Small Whaler Outboard Mounting
Author | Topic: Small Whaler Outboard Mounting |
Barney |
posted 05-16-2004 08:18 PM ET (US)
After reading this forum for a few years, I realize that proper mounting of the outboard on a Whaler is key to the best performance. My question has to do with the 11 foot Whaler. http://myweb.cableone.net/barney9014/images/11/5.jpg When I mount my 15 HP Yamaha "short" outboard all the way down on my 1980 11 foot Whaler, the cavitation plate is a few inches below the bottom of the boat. Now I am considering bolting on the outboard. My young Nephew will be in training on the boat this summer so I would prefer to get the outboard back with the boat. Also if I permanently mount the outboard I would like to get the best performance when I take it out. :) Thanks JimB |
posted 05-17-2004 08:41 AM ET (US)
If bolting the motor on the transom, I'd verify that you can use a standard hole pattern. If that is workable, drill the transom with the standard outboard engine mounting hole position. This should permit some adjustment of the engine mounting height, assuming the 15-HP Yamaha has the necessary multiple holes in its transom bracket. Raising the motor to have its anti-ventilation plate flush or just above the hull bottom at the transom is probably the recommendation for initial height. |
Barney |
posted 05-17-2004 06:07 PM ET (US)
jimh, Thanks for the reply, JimB |
