Topic: SAKONNET Re-Power with 100-HP OMC
perkunas170 |
posted 06-16-2004 12:31 PM ET (US)
Hi Folks. I'm a long-time lurker (thanks for all of the indispensable info over the last few years!)I just repowered my 68 Sakonnet with a slightly unusual motor - a 2000 Johnson Commercial 100hp (not FICHT, thing's got 4 carbs). I got it as a new leftover, still in the crate, last week for $5,235. Did I get a deal, as I think? Anyway, my main question is around one of prop confusion. Dealer wanted me to put on a 15x17 but I insisted on trying a 14.25 x 19 for starters, considering the motor I replaced was turning a 13x19 and seemed pretty good. On the maiden testing run last night, with me 210 lbs and a *large* friend (350+), this boat LEAPT out of the water, and at cruising speed, if you goosed the trottle a little, acted like it wanted to "do a wheelie in 2nd gear" to use a motorcycle analogy. Do I need to go to a 14 x 21 prop? Unfortunatly, I don't have a funtioning tach (hopefully today). Any thoughts? Joe
JBCornwell
posted 06-16-2004 01:10 PM ET (US)
Borrow a tach, Joe.The only way that I know to select the correct prop for a boat is to run it at WOT and get near the upper end of the operating range. Don't know about your 100C, but I would guess it at 5500rpm. If you have too little pitch you risk over-revving the engine. If you have too much pitch you will lug the engine. Good luck. :) Red sky at night. . . JB |
lerker
whether you need (or can run) a higher pitch prop or not will depend on your WOT rpm. post that data after you get your tach installed. |
perkunas170
posted 06-16-2004 01:31 PM ET (US)
I didn't even get close to WOT last night. Do I need to wait until I've finished the 10 hour break in (any break-in advice appreciated too!) before I properly (pun intended) assess this screw?Joe |
Bigshot
posted 06-17-2004 10:58 AM ET (US)
Get a tach but I doubt a 21". The commercial should have a V6 gearcase but not sure about newer ones. As far as a deal goes, depends on what that $5200 included. you can buy a new 2004 90hp Johnson all day for about $4500(just motor). |
posted 06-20-2004 11:57 PM ET (US)
[Changed TOPIC; was "Thoughts and comments on my recent repower?"]I want to go outboard shopping with Big'. Next time I buy a new outboard I want Nick making the deal! |
Bigshot
posted 06-21-2004 10:15 AM ET (US)
My bad....Just checked Ed's & 2005's are up to:90 HP 20" JOHNSON $4,899. Yamaha is $4,999, and E-tec is $6299. The 2004's were $4499 or $4599 I believe. Ed's has good deals but many here have beaten their prices....they are a good place to start. |
