  RAGE 15 Performance
Author Topic:   RAGE 15 Performance
BCT posted 07-10-2004 10:35 PM ET (US)   Profile for BCT   Send Email to BCT
I have a Boston Whaler RAGE 15. What can I do to help [the boat reach hydroplane] besides putting my wife on the bow?
Bigshot posted 07-11-2004 10:20 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Put somebody else on the bow?
You may want to have her looked over, they should not be that bad out of the hole with 2 people.
maxdevon posted 07-11-2004 11:59 AM ET (US)     Profile for maxdevon  Send Email to maxdevon
Just curious, but at full throttle, can you reach Max RPM range? (Not sure what your motor would be) If not, then you may have too large a pitch prop.
When I was proping my 13' Whaler w/40HP 4-stroke Yammie, my first prop had too much pitch. Only got about 4800 RPM, was really fast, but very slow to plane out. My 2nd prop has too little pitch. Maxed RPM 6000 at 2/3 throttle, really slow, but would jack-rabbit to plane. The 3rd selection was the perfect compromise.
Good luck.
JohnJ80 posted 07-11-2004 03:10 PM ET (US)     Profile for JohnJ80  Send Email to JohnJ80
check your engine height on the transom. if it is down too low, you will get lots of bow rise plus have tons more drag in the water. Both will inhibit getting on a plane.
J
greyg8r posted 07-11-2004 09:05 PM ET (US)     Profile for greyg8r
Max and John:
BCT has a Rage with an inboard and an impeller, not an ouboard with a prop.
BCT: My 1993 Rage with the weaker (50hp Yamaha) pops right up on a plane with my lard--- (205 lbs) at the helm. The main complaint I have with my Rage is that it porpoises when empty, possibly because the nozzle is aimed a little too high. Your 115hp OMC should have no problem getting on a plane. Does the engine run properly?
Richard
BCT posted 07-11-2004 10:33 PM ET (US)     Profile for BCT  Send Email to BCT
I'm not sure if it runs properly (have nothing to compare it too). It is very cold natured, I always seem to have to choke it to start, and always hearing the overheat warning.
It seems if I let it idle a bit after I run WOT it does OK.
As far as the plaing off it just doesnt seem to want to plain very quikly.
Thanks for yalls help
BCT
Bigshot posted 07-12-2004 01:17 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
A couple things. The jet pump on these is what circulates the water in the engine(no water pump). On my old Jet ski, I had a planing issue and an overheat one as well because my impeller was screwed up ALONG with my pump. There has to be VERY tight tolerances between the two or else you get MAJOR slip.
jimh posted 07-12-2004 08:14 PM ET (US)     Profile for jimh  Send Email to jimh
[Changed TOPIC; was a misspelling of hydroplane.]
