  Propeller MONTAUK 170
Author Topic:   Propeller MONTAUK 170
imko posted 07-11-2004 05:10 AM ET (US)   Profile for imko   Send Email to imko
The first propeller on my Montauk 170 with a 90-HP 4-stroke was a Vengeance 13.25 x 18 . The maximum RPM was 6200 WOT (2nd mounting hole). The second propellor is a 4-blade Trophy Plus 13.75 x 19 . The maximum RPM was 5400 WOT (3 mounting hole). This propeller is giving too much lift when the motor is on WOT. The boat is very difficult to handle at WOT.
Is a Laser II (13.25 x 20) the right propeller for this boat? The 2003 Mercury 90-HP 4-stroke has a gear ratio 2.33:1.
jimh posted 07-11-2004 07:39 AM ET (US)     Profile for jimh  Send Email to jimh
Do you have the speed numbers to go with this data?
imko posted 07-11-2004 01:18 PM ET (US)     Profile for imko  Send Email to imko
The vengeance 13,25 x 18: 42,0 mph
The trophy plus 13,75 x 19: 43,1 mph, but its very hard to handle and has a slow hole shot. The midrange is perfect!!
(3000-4500 rpm).
Barney posted 07-11-2004 02:23 PM ET (US)     Profile for Barney  Send Email to Barney
I have the same boat, same 90 HP 4-Stroke outboard and same factory provided Vengeance prop and hit 41 MPH at 5500 RPM WOT. Maybe one or both of our Tachs are off. Jim
imko posted 07-12-2004 01:28 PM ET (US)     Profile for imko  Send Email to imko
The tacho-meter is oke !! There are more whit this problem.
Youre rpm is to low (prop / engine)
What propeller can i use best for this engine?
(13,25 x 19 or 20" in SS)
LHG posted 07-12-2004 01:46 PM ET (US)     Profile for LHG
Those Trophy props are mostly recommended for Flats and Bass boats. The pitch rating is usually deceptive, and they seem to have an effective pitch much higher. A 17" pitch would be better in that line.
Whether or not the engine could turn up a Laser II in 20" (lowest available) I don't know, but it is a "tamer" prop than the Trophy 4 blade.
Another alternative would be a 19" Michigan Wheel SS Rapture. These will fit the Mercury interchangeable hub system.
jimh posted 07-12-2004 08:28 PM ET (US)     Profile for jimh  Send Email to jimh
The duplicate article posted to this forum on this same subject has been deleted.
imko posted 07-14-2004 05:06 PM ET (US)     Profile for imko  Send Email to imko
Thanks for the info!
I try the laser II (13,25 x 20).
What vent plugs can i use the best for this propeller?
LHG posted 07-14-2004 06:51 PM ET (US)     Profile for LHG
Mercury generally recommends the medium size vent plugs for outboard use. Laser's come shipped with small size vents.
Try those out first.
MantyMonty posted 07-14-2004 11:07 PM ET (US)     Profile for MantyMonty  Send Email to MantyMonty
I also use the 13.25 x 20 Laser II on my '04 Montauk. I have the 90 2 stroke and a 27 Pate. With two adults and one seven year old, calm seas and fishing gear, we can go at least 42mph. This speed is shown on my Garmin 188C. The RPM is at approx. 5300-5400 at this speed.
imko posted 07-20-2004 04:33 PM ET (US)     Profile for imko  Send Email to imko
Manty,
What vent plugs are you using?
