  Temp gauge pins against the side after a few mins
Author Topic:   Temp gauge pins against the side after a few mins
videorov posted 07-15-2004 12:42 AM ET (US)   Profile for videorov   Send Email to videorov
After startup temp gauge pins over to right side after
a few mins on. The motor is running cool and pump is working fine. The guy ran a seperate wire to the gauge
and did not use the old temp sensors wires. The old sensors
has been removed and not hooked up.
One guy told me that to be sure there is a resistor in line
on the 12volt power line.
I wonder if it does need a resistor in line to make things
work right?
Something is causing it to pin across to the left even
though the engine is running cool.
Chuck Tribolet posted 07-15-2004 09:44 PM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
What motor?
John O posted 08-12-2004 11:38 PM ET (US)     Profile for John O
try the temp gauge SENDER.
