  self bailing Sport 13?
Author Topic:   self bailing Sport 13?
larpad posted 08-17-2004 10:05 PM ET (US)   Profile for larpad   Send Email to larpad
I have a 1971 Sport 13 and get a lot of water in the boat in rough water. Is their anyway that this boat can self bail?
DCM posted 08-17-2004 10:11 PM ET (US)     Profile for DCM  Send Email to DCM
Larpad,
I'll answer this one!
Yes! While underway, reach back & remove the plug in the bilge, and watch as the water slowly drains out. Don't forget to replace the plug when its done.
Cheers
Dan
ps- there are a couple old photos in the Reference section that show a guy completely filling his Whaler with water using a hose, than starting up & draining all the water out using this method. Its amazing, really.
nFL_Bosn69 posted 08-18-2004 09:50 AM ET (US)     Profile for nFL_Bosn69  Send Email to nFL_Bosn69
Tempo makes a flapper scupper that can be fit into your drain tube. I have one in my aft drain, then leave the fwd tube unplugged. The flapper doesn't allow water into the boat but lets it out, when moving. They're about $25 at WestMarine. Kind of much for a piece of rubber, but that's boating.;) I think so far it has been worth it, though, not having to hassle with playing musically drain plugs. Plus it's pretty thick rubber so it should hold up a while.
Ryan
dburton posted 08-22-2004 02:05 PM ET (US)     Profile for dburton  Send Email to dburton
For various reasons I have dri-dek on the floor of my 13’ sport. I cable tied a bilge pump to the dri-dek at the stern. I wired the pump to a switch on the console. It is very convenient and easy to get rid of any water.
Doug
Royboy posted 08-27-2004 02:00 PM ET (US)     Profile for Royboy  Send Email to Royboy
I drilled and tapped holes to install a bilge pump right next to my aft drain plug for dewatering. No wood under that, but I used a lot of sealant around/in/under the screws.
I bought the biggest pump they has at Boaters World, a 1500 GPH unit. I wired it to a switch on the console so we don't have to goof around with the drain plug when it's rough, which is when we get any appreciable ammount of water in her. I filled it to the engine bolts with a hose and it took 15 seconds to drain it with the bilge pump. It would be a long 15 seconds on the water, but at least we don't have to risk falling overboard if we take on a little water.
Roy
