  Low End Power Missing
Author Topic:   Low End Power Missing
k2163 posted 08-30-2004 12:56 PM ET (US)   Profile for k2163   Send Email to k2163
I have a 140 V-4 Johnson powering my 1986 18 foot Outrage.
I beleive the motor came with the boat.
I am having trouble with the low-end power. When I push the throttle forward, I get up to about 2000 rpm then nothing at full throttle. Then, after about 15-20 seconds of this, the rpms suddenly lift, the boat gets up on plane and away we go at 4500+. I can trottle back faily well without falling off plane and the rpms suddenly droppting.
I've also noticed some very slow speed idling problems. I have to idle out for about 1/2 an hour between getting bait and getting out past the speed zones. When I am in foward with the speed cut all the way back the motor will often stall.
Any ideas what might be causing this delay?
Bigshot posted 08-30-2004 03:35 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Change the spark plugs and have the carbs adjusted, run Techron in the tank....start there.
k2163 posted 08-30-2004 04:02 PM ET (US)     Profile for k2163  Send Email to k2163
Bigshot
Thanks for the advice.
By Techron I assume you mean Chevron gasoline? High Octaine?
