posted 10-04-2004 03:07 PM ET (US)
Here's how I winterize:1. Run stabilized gas mixture through motor. The recipe is about 1 pint of Marvel Mystery Oil: enough fuel stabilizer to treat 5 gallons of fuel (about 1 ounce) and 5 gallons of fuel). You can scale this up or down as you need to. I need to winterize three motors so 5 gallons is good.
2. After this stabilized mixture has run through the motor, I fog the motor using fogging oil sprayed back and forth through the carburetor or air throats until the motor barely runs and is spewing out white smoke like nobody's business.
3. Shut motor off in this state.
4. Remove plugs and spray fogging oil into cylinders.
5. Drain and replace gearcase oil.
6. Lube all grease zirks.
7. Remove propeller, grease propeller shaft, reinstall propeller if in secure area. If not, leave propeller off then clean shaft and regrease in spring.
Done.
The problem with A is you don't get the fogging oil on the intake side of the motor which is where you also want it. Stabilized fuel in the carbs shouldn't be a problem.
