| Author | Topic: E-TEC 225-HP: Under the Cowling |
I had a chance to take a close-up look under the cowling of a E-TEC 225-HP Engine. If you have questions related to the photographs shown in my article, please post them here. |
There were some links mentioned two months ago to similar photographs, but those were of a prototype engine. As far as I know, these are the first photographs published that show the details of a stock, production engine as delivered from the factory. |
| macfam |
jimh, Nice write up, and great pics of the 225 E-TEC. Looks like BRP has done a top notch job with this E-TEC line. I've only seen(and heard)the new 40hp E-TEC. It was mounted on a Classic 13'. It appears a bit weighty in the rear, but not a whole lot different than my 2000 Johnson 40hp. Very quiet,and NO smoke. The owner was very pleased with performance. The competition in the 200-250hp range is really getting heated now that the E-TEC's, Verado and Optimax, Yamaha HPDI and 4-strokes, Suzuki(Johnson), and Honda are available. Great for the consumer. What choices! When I need to replace my current 250hp OX66, I'll really have to do my homework. (Shhh, don't let my wife know that my 250 won't last FOREVER. I don't even want to THINK of that conversation!!!!!) |
| gss036 |
Very good article. I noticed the spin on fuel filter. Would this eliminate the use of other types of filters (water seperator types) or used in conjunction? The engine looks very compact, but then again, all new auto engines do also. I guess the owner maintence would only be changing the sparks plugs when needed. Did you ever find an oil tank? You mentioned the flush connection was on the rear w/tell-tale. Is this a hose bib connection to flush w/o running the engine? I run all saltwater so that would be a definate plus. |
| Joe Kriz |
jimh, I read the other article on the E-Tec 90 you posted awhile back. As most of us know the E-Tec 90 has the Oil reservoir under the cowling, Where's the Oil reservoir on the 225? Did I miss it in the photos? |
| Peter |
Nice write-up and photos. Thanks for sharing. As compared to my Ficht 225s, this is the next generation of DFI from BRP. Judging by the fact that the E-TEC 225 uses the Magnum gearcase, the E-TEC 225 is about the same size as my Ficht 225s although the mid-section is a bit thicker. Under the cowl, it's clearly different than the 225 Ficht/DIs that I have but in some respects it appears the same. The spin-on fuel filter is not a new feature. The Ficht/DI 225 uses a spin-on fuel filter. I use a boat mounted spin-on fuel filter in addition to the motor's spin-on filter on my 225s. Unlike the 2 and 3 cylinder E-TECs, there is no oil reservoir under the cowl in the V6. There is no oil reservoir on the Ficht/DI 225 either. Hopefully they have improved the flush port connection by adding a quick connect/disconnect fitting. The picture doesn't show that very well. Owner maintenance on the E-TEC is likely to consist of changing plugs, the spin-on fuel filter and the gear case oil. This would be no different than is the case for the Ficht/DI. Unlike the Ficht/DI, winterizing should be a simple matter of pushing a button. |
| Joe Kriz |
I think we all know the current line of OMC/Bombardier Outboards have external Oil Reservoirs including the Ficht 225... It is too bad that the new E-Tec 225 does not have the under the cowling Oil Reservoir like the new 90hp E-tech. If the someday to be released 150hp E-Tec does not have the under the cowling Oil Reservoir, then I am definetley going to switch to a 4 Stroke.. |
| Peter |
Joe, sorry if I pointed out what might be the obvious but there may be some who don't know the make-up of a Ficht/DI or think the the resevoir to which you refer is like the small one used by Yamaha and Mercury to regulate oil delivery. Why in your case would the fact that there is no oil reservoir under the cowl (assuming that is the case for the 150 as well) be the deciding factor to go 4-stroke? I assume it must be a tank location/space problem you'd like to solve. |
I changed the caption for the Under the Cowling picture to point out the electrical connector for attaching a diagnostic tool. My understanding is Bombardier will sell you (at moderate cost) the software necessary to connect a laptop to this communication port. This will allow you to retrieve data from the engine. Precisely what can be done is a bit sketchy, but I am sure you can extract information like hours of use, highest speeds, error codes, and so on. This port also appears to be critical for service and diagnostic by the dealer. The label on the EMM contains this warning: --- WARNING • You MUST use Engine Diagnostic Software to • Fuel injectors on this engine MUST NEVER be moved • Only use a SERVICE REPLACEMENT fuel injector to Failure to follow these guidelines can result in a --- |
I did not pay much attention to the oil system! The only evidence I see of it is a piece of clear hose visible in the Left Front picture. I added a new picture which shows the flushing port connection. I do not recall the details of the connector, but I am sure that it must mate to a standard water hose fitting, either directly or through a short adapter. I think you have to unscrew something to connect to it. A stout hose runs from the flushing port right into the engine block water jacket. |
| Peter |
Thanks for adding a picture of the flush port. The flush port appears to be the same as has been used by OMC/BRP for the past 10 years or so. Unfortunately, this design is cumbersome to use because it requires unthreading the plug and threading in the male end of a garden hose or a fitting of some sort. Fortunately, TH Marine has solved the problem by coming up with a permanent quick connect/disconnect fitting that literally makes connecting a hose to the flush port a "snap". It's worth every penny of the $15 they charge for it and something I highly recommend for those folks who put an E-TEC 225 on their transom. Looks like the E-TEC will have a diagnostics software offering similar to what is available for the Ficht/DI. With the current Ficht/DI diagnostic software, you can: -actuate individual fuel injectors Much of this is likely to be more than what the typical consumer/user needs. |
| Joe Kriz |
Excellent photos jimh... I am however disappointed that all the E-Tec engines do not have the Oil reservoir under the cowling. After seeing that the 90hp and below had the oil reservoir under the cowling, I guess I assumed that the entire line-up would be that way. I thought I heard that all the E-Tec would have it under the cowling, but obviously, this was not correct. I guess engine manufacturers assume that if you are installing a 225hp engine, then you have a large boat and a place to put an external oiler. Yes, I am very tired of having the Oil reservoir either in the console of my prior Montauk or even in the splaswell of my 18.. As we all know, space is at a premium in our Whalers. |
| Whalerific |
Is anyone on the forum considering these big E-TECs for repowering the bigger 25-27 Whalers? They would look great on WhalerDrive or a bracket! |
| Jim Bennett |
jimh, Just wanted to extend my compliments for a well-conceived, well-written and well-illustrated article which should be of interest to anyone looking at new engines. I am not looking and am basically a Mercury man but would be great if such articles on various engines were provided for all interested persons. |
| rehenderson |
First rate, Jim. Thanks. |
| erik selis |
As always, a fine job Jim. I'm really starting to like these E-TEC engines. It may sound strange but I know a few fisherman who own 4-stroke engines on their Alumacraft boats who will be re-powering with the smaller E-TEC engines soon. Erik |
| Salmon Tub |
Jimh, do they give a reason why they wrap the plug wires in the nylon mesh? I have never seen that before, but that does not mean it is not standard technology on most of the newer motors. I would think that for the saltwater environment, a solid type of insulation material would be a little better. I would imagine they use it to prevent spark jump? |
RE: Wrapping spark plug high-tension leads in nylon mesh tubing: My guess is perhaps it has been done for heat protection. The insulation of the spark plug wire is sufficient to protect against any voltage breakdown or current leakage. Perhaps the nylon adds some additional heat resistance. The plug wires pass near the cylinder heads where the operating temperature could be high. I did not think the method used to terminate the ends of the nylon tubing was quite right. They looked like they would fray easily. Usually the end of the nylon mesh tubing is turned under itself and then fixed with a ty-wrap. |
| rbruce |
Jimh: Will we ever see a portable E-Tec such as a 25 or 20HP, or is this in the league of the four stroke. Regards, RBruce |
| seahorse |
The E-TEC operating system has already been demonstrated on a single cylinder 3.3 hp outboard and on a chain saw. You will see more of these in the next 2 year years as Evinrude says it will be the first outboard company to have a complete 3-star Ultra-low emission product line. |
| Hoosier |
Since we're talking about other domains for the E-TEC engine, any rumors about an E-TEC powered Ski-Doo? In the UP we need a toy for the other half of the year....... |
| Joe Kriz |
I just got off the phone with my Evinrude dealer. He told me that the E-Tec smaller lineup will be avaialbe late 2005 or early 2006. At this time, the smallest one in the lineup is 9.9 HP.... |
| LHG |
With respect to Evinrude's claim that in 2 years it will have the first all 3-star line, I would say that RIGHT NOW, from 25 HP to 275HP, MERCURY already will be there when the new 150 and 175 Verados come out in Feb. And so will Yamaha up to 225HP, when they fill the 135 and 175 4-stroke gaps, which should be soon. Not as familiar with the Honda and Suzuki lines, but they must be close to this also. It actually appears that Evinrude will be the last to have all 3-star. Unless I'm missing something, Mercury has clearly won the race for 3-star, with by far the most offerings, if it means anything at all, and I'm not sure that it does |
| TexasWhaler |
True, Mercury is about to accomplished this through a combo two-stroke/four-stroke lineup. 3-star compliant, four-stroke engines 150 hp and above are everywhere being made by everyone. Nothing cutting edge about that. Let's see someone other than BRP make a full 3-star, two-stroke lineup. Ain't going to happen anytime soon. Reason is because to others don't have the technology. Even Merc, for some reason that's probably over my head, can't get any Optimax over the 135 hp to blow under the 3-star limit on the outboard breathalyzer. |
| LHG |
Texas - the others don't need to, as they are all putting their big money on 4-stroke EFI, such as Verado, etc. Mercury and Yamaha will be using the Optimax/HPDI as their "value" lines, and as "playing both ends against the middle". Unfortunately, BRP/Evinrude doesn't have this luxury right now, and E-Tec could also be forced to sell as a value line. For them, it's E-tec or bust. If Evinrude is right, and the DFI is perceived to still have a longer term future, I'm sure Mercury and Yamaha will put 3-star development funds into the 150 and up engines, particularly Yamaha, since right now they're tapped out at 225 4-stroke for 3-star. But I have heard that 3-star is IT for DFI, and tougher environmental regulations to come will make 4-stroke the only viable alternative. Are we in a situation where Mercury, Yamaha, Honda and Suzuki are all on the wrong track? To listen to Evinrude's advertizing, this is what they would have you believe. Even though right now I personally prefer 2-stroke DFI to 4-stroke, I'm not sure I'd want to be in Evinrude's position, lined up 4 to 1 against the big boys. Right now, however, I think the E-tecs are looking like quite attractive engines, regardless of all this "star" stuff. I guess we'll all just have to see what shakes out on the technology front |
| Peter |
Larry, I think Evinrude is in a great position because there is a certain segment of the outboard market that doesn't want a heavy slugish four stroke on the transom and they clearly have the best clean scalable 2-stroke technology going. According to Trailer Boat magazine article, the 90 E-TEC held its own against good 4-stroke competition. I think you might have it backwards regarding cleanliness. Without a catalytic converter or a direct injection technology, I believe that EFI 4-stroke might already be tapped out on CO and NOX emissions. If the noose gets tighter on these gasses, where are they going to put the catalytic converter on the Verado and how much is it going to weigh?
| LHG |
Fair enough, Peter, but the supercharged Verado (alone) is not a "sluggish" 4-stroke. It will accelerate with the fastest of the 2 strokes. |
| Peter |
As far as 4-strokes go it might not be sluggish as some of the others but I'm not convinced its as fast as a 2-stroke out of the hole. If it was, I think they'd be using the 1.75:1 gears instead of the 1.86:1 gears in the gearcase. |
| LHG |
Generally all 4-strokes have lower gears, since they rev higher. This avoids the need for more lower pitch propeller options, and keeps normal pitch ranges current. If a 250 EFI, with a 1.76 gear ratio, can turn a 21" pitch prop up to 5800, and 62 mph, on a 250 Verado, which would turn the same top end, but at 6400rpm, the same 21" prop would be used, or maybe a 19". Yamaha goes even lower with their 4-stroke, using a 2.0 gear ratio. Whaler published testing shows the Verados out-accelerating the Optimax's. Don't lower gears enhance acceleration |
| Peter |
No, generally lower gear ratios hinder acceleration, everything else being equal. The lower gear ratio on the Optimax would be analogous to starting your car in second gear rather than first from a standing stop. Does your car accelerate faster from a standing stop in first or second gear? I don't put too much faith in Whaler performance tests because I think they've biased them in favor of the Verado. Next time you're over there take a close look at all of the statistics in the reports rather than taking the data on blind faith. In almost all cases I think you'll see that the Verado equipped boat is lighter. Also, I think they have propped it advantageously. All part of the continued hype plan. Brings a whole new meaning to truth-in-advertising in my opinion. One example of this can be seen in the performance reports for the 270 Outrage. The twin 225 Optimaxes are turning 21P Rev 4s through the 1.75:1 gearcase (total boat weight of 8027 lbs) to 5500 RPM (redline is 5800) while the Verado 225s are turning 19P Rev 4s through a 1.85:1 gearcase (total boat weight of 7328 lbs) to 6200 RPM. Interestingly, Whaler doesn't publish a time to plane or time to 30 MPH for the 225 Optimaxes. I wonder why. Must have been a simple oversight by the Brunswick marketing department, right? Whaler does publish time to plane and time to 30 for the pair of 200 Optimaxes also turning 21P Rev 4s (total boat weight of 8007 lbs) to 5420 RPM and the 200s aren't far behind the Verados in terms of hole shot with a steeper gear ratio and a higher pitch propeller despite more than 600 lbs of additional weight to push. Put a pair of 19P Rev 4s on the 200s and let them rev up to 5800 like the 200 is made to do and I wouldn't be surprised to see the 200 Optimaxes have a better hole shot and time to 30 MPH than the 225 Verados even while pushing the extra 600 lbs. I'd love to see them do an everything equal test between the Optimax and the Verado. I'd be willing to bet the Optimax would come out ahead each and every time. However, I don't think you will see that from Brunswick because they have too much invested in the Verado. One last thing that convinces me that the Verado isn't that fast out of the hole compared to the 2-strokes. If the Verado was so quick out of the hole, you'd see the bass boat guys raving about the Verado. Such does not appear to be the case from what I've read so far. I don't believe a 250 Verado can keep up with the E-TEC 225 HO made for the bass boat market and most definitely it cannot keep up in the first 10 hours. ;) |
| LHG |
Do we have a semantics problem on "lower" gear ratios? The numerically higher gear ratio number on the Verado and Merc 2.5 liter engines is a "lower" gear ratio. The larger the number, the lower the gear ratio. So, using the same convention as an automobile transmission, the Verado has a lower gear ratio than an Optimax 3.0 liter. On an outomatic transmission, LOW is 1st gear. |
Added several photographs of a 225-HP Evinrude FICHT engine for comparison. Thanks to Peter for sending them. |
Added several additional hyperlinks to various patents related to the E-TEC engine. Thanks to Peter. These patents contain some quite interesting information. I am just in the process of reading them more carefully. One thing that comes immediately to mind: Does the E-TEC production engine have any sensors in the cylinders or exhaust ports? |
| Peter |
Judging by the hose going into the EMM that says "EXHAUST" I am guessing that the E-TEC 225 monitors exhaust pressure or something relating to the exhaust, could be an O2 sensor I suppose since I don't see an exhaust pressure diaphragm connected to that hose as is the case for the Ficht 225. BRP has finally updated its Evinrude website. It has quite a bit of interesting information about the E-TEC and how it works. |
Added link to patent information on the E-TEC injector. Compare the waveform shown in Figure 6 of U.S. Patent 6,398,511 with the waveform shown in the website animation. Patent Animation |
| seahorse |
Peter, The V6 E-TECs use an exhaust pressure sensor similar to the earlier FICHTS. They do not need the large plastic diaphragm because the barometric pressure sensor is a separate item and there is no start delay relay that the FICHTs needed. |
| fourdfish |
After doing all my research and keeping up with the posts I bought the new 200hp E-TEC and had it installed on my 24ft boat. I can say without any reservation that It was the right choice. All of the claims made by Evinrude are true. Today was my 2nd big run on the water and it was just great. The motor starts on one revolution and runs very quiet and smooth.At idle you can barely hear it run. My dealer is also a Honda dealer and he says it is significantly quieter than the Honda 200hp. I also have friends that have Yamahas and it is quieter and smoother than the Yamahas. The pickup is just fantastic. Absolutly no smoke or fumes at all.It does not burn oil as some have said in the other E-TEC topic.I did not notice any weight difference. I know it is 80-100 lbs lighter than the other 200hp 4 strokes. We hooked up the computer in the shop and the software is easy to use. I am getting the cord and program as I move around a lot. The oil tank is not large and is not a problem. I am glad it is not under the engine cowl. We put a line on the tank and so far almost no oil has been used. I have not been able to check how gas has been used but the gauge has not moved much.Like Peter I also have an extra spin on fuel filter before the engine.The nylon mesh covering all the lines going into the engine is a real nice touch. My only minor gripe is that the winterizing button and process is not the same on all boats and is not real clear. I think they should have put that under the engine cowl. I guess I sound like a E-TEC commercial but I think this engine will sell itself. Thanks to JIMH, Peter and Seahorse for the real useful info.I think LHG should get out and test one of these. I have not found out why the wave pattern is different in the Patent. If anyone has questions ask away and I'll do my best to answer them. |
| sjohnson |
After learning more about the etec than I've ever cared to know about any other outboard, including the Evinrude v-4 I own . . . I'd like to hear what that signature sound sounds like. Anyone out there have any way of recording the sound? Just curious . . . Great engine, forcing myself to wait though . . . fourdfish: If you have pictures, we always like seeing those things mounted, so post 'em if you got 'em. -SJohnson |
| Mike Brantley |
fourdfish, I want one of those for our "new" Revenge! Alas, we have to get some hours of use out of the '98 Evinrude that's on it before we can repower. (We have an E-Tec 50 on our 15 Sport, however). Thanks for the report about your experiences with the big E-Tec. There may be one in our future, down the road a ways. |
| rehenderson |
Apologies in advance if someone has already posted this, but I thought the following article provided some good E-TEC insight: http://www.bassandwalleyeboats.com/site_page_899/article_page_309.cfm |
| TexasWhaler |
[fixed link] http://www.bassandwalleyeboats.com/site_page_899/article_page_309.cfm |
Thanks for the pointer to the Jim Baron article. He is a respected technical writer in the boating field, and his opinion carries some weight. Also, I just learned another very interesting thing about the E-TEC fuel injector: they are all serialized and given individual identifiers. When an injector is replaced on an E-TEC engine, the serial number of the injector is entered into the firmware of the Engine Management Module (EMM). Apparently the serial number pattern contains some information about the injector's individual characteristics, and the computer makes adjustments for this. Or at least that is what I infer from the need to inform the EMM about the new injector's specific serial number. If this is the case, this represents a very sophisticated level of control. I have never heard of anything like this before, at least in an outboard motor. The individual testing and characterization of the E-TEC injectors and the provision for the EMM to adapt to these characteristics is another example of the advanced engineering that has gone into these engines. I also believe the Bombardier manufactures the E-TEC injectors themselves, which is appropriate inasmuch as they hold the patent on them. |
| seahorse |
That is how the first FICHT injectors worked since 1999. Prior to then, the injector tolerances were very tight and expensive to produce. Then they came out with the serial numbered versions, that they called "compensated" The ECU or EMM retains the injector number until re-programed with a disk included with a new or rebuilt injector. The serial numbers are also printed out in any service history reports "pulled" by a tech using a laptop or PDA. That is why you cannot replace the ECU or an injector from one from another engine. |
Thanks for the information on the Evinrude injector manufacturing. It had occurred to me that having extra intelligence in the engine controller would allow for some savings in manufacturing. The output of any manufacturing process contains some variation in product. This is like the microprocessor chip business. They make the chips in the same process, and some come out of it able to run at higher speeds than the others. Some chips get marked 1.0-GHz speed, and some get marked 1.5-GHz speed. They were made the same, but variations among them as a result of the process created the variability. (It may also be that higher graded chips are subjected to more testing, too, so this may not be the perfect analogy.) It is another good example of how having "more transistors" in the product can make it better. Well, in this case better for the manufacturer by allowing use of a wider tolerance in the injector. But also better for the consumer because the product works better when it can more accurately meter the fuel into the engine, as it can when it knows about the precise characteristics of the individual injectors. In general I am quite amazed at all of the technical information which has been released on the E-TEC. The source of most all of this goes back to Bombardier. Perhaps it is part of their corporate culture to be proud of the technology in their products. I've never seen any technical literature about the Optimax from Mercury (or the Ficht from the OMC days) that goes into the detail that Bombardier has supplied about the E-TEC engine. -- |
| seahorse |
OMC did pretty good giving out its tech info on the FICHT system. Was there anything in particular that you wanted to find out? |
| dannymac |
Gentlemen - I have a 225 e-tec on my 23 mako... I had a yahmaha 225 4 stroke on it... hated it and took it back and went e tec... lighter, just as quiet, much mroe responsive... the external fuel tank to me is nicer (i personally woul never want to have to always get under the cowling)... computer interface is great... I can do any diagnosics on my motor from priming the poil with a click of my laptop or palm to checking error codes and adjusting fuel management. After looking into this for quite some time... four strokes dont compare... the emissions are extrememely lower than verados or yahmahas... plus they weigh more... and we all kow two strokes perform much mroe efficiently than fours...(assuming everoyne knows how the two stroke vs. four stroke vaires in cylinder movement)... not hatin on yahmaha or merc... but they got beat.... |
| Perry |
Welcome to the forum. I'm glad you like your E-TEC. Even though 4 strokes dominate the outboard market, I guess they are not for everyone. Ejoy your boat and new motor. |
