Topic: engine height
patf |
posted 01-14-2005 01:37 AM ET (US)
What happens if the motor is mounted too high? I have my 15 footer, 50 h.p. mounted all the way up for shallow water fishing, the only possible set back seems to be that it takes more speed/rpms to stay on plane. Does anyone have any experience with experimting with this
Binkie
posted 01-14-2005 06:23 AM ET (US)
You`ll need to use a prop with more pitch, how much more can only be determined through testing, and you`ll probably experience cavitation in rough water. Your load carrying ability will be less. Make sure you have enough pitch to keep your rpms within max range.Your top speed may be higher with a lite load. Hopefully your water pickup is still under the surface. |
posted 01-14-2005 09:15 AM ET (US)
[Moved from another forum.] |
