  Two-stroke vs. Four-stroke
Author Topic:   Two-stroke vs. Four-stroke
pmberman posted 01-30-2005 09:12 AM ET (US)   Profile for pmberman   Send Email to pmberman
Since a lot of folks struggle with the two- vs. four-stroke decision, I thought I'd share pro's and con's of each:
There are just as many people out there who will tell you to get four-stroke as there are who will say two-stroke. The answer to "which is better?" is, "it depends." Best if I give you pros and cons to each.....
FOUR-STROKE PRO's
Clean burning
Quiet
Efficient (burns less fuel)
Don't need to worry about four cycle oil
FOUR-STROKE CON's
Heavier
Slower out of the hole (getting up on a plane)
Much more expensive
Need to change oil
More moving parts
TWO-STROKE PRO's
Lighter
Quicker out of the hole
Less expensive
Don't have to change oil
Fewer moving parts
TWO-STROKE CON's
Runs dirtier (more smoke and fuel in water)
Louder
Less efficient (burns more fuel)
Have to fill two cycle oil tank (this is easier than the old days of mixing with gas though - they are all oil injected now)
jimh posted 01-30-2005 10:31 AM ET (US)     Profile for jimh  Send Email to jimh
I disagree with several of your observations.
First, I think there are far more people today who will recommend a four-stroke than there are people who will recommend a two-stroke. This is reflected in the market share of new outboard sales, which is becoming overwhelmingly dominated by four-stroke engines.
Second, the four-stroke is not inherently "clean burning". Both engines ignite an air/gasoline mixture. The burn is not better or cleaner in a four-stroke than in a two-stroke. As Bombardier is showing with the E-TEC, the two-stroke engine can have very significantly lower emissions than a four-stroke.
The principal "dirty" component of two-stroke engines was the unburned fuel contained in the exhaust, and the burning of lubrication oil in older engines where the lubricating oil was mixed with the fuel.
Older two-stroke designs did have a smokey exhaust, but this is not due to their two-stroke nature, but because of the simple lubrication system they used.
Third, a four-stroke engine is not inherently more efficient. They burn the same fuel as a two stroke, and get the same energy from it. Again, older two-stroke engines wasted a lot of fuel by throwing it out in the exhaust without burning it. Modern two-stroke engines do not do this. If anything, a two-stroke engine should be more efficient because it wastes less energy moving its drive train components between power strokes
Four-stroke engines are not inherently quieter. Most four-stroke outboards do seem to be quieter, but I think this is due to better design of their exhaust system. Traditionally, very little design effort has gone into outboard motors for noise suppression, and you can hear it!
Many of the perceived advantages of the four-stroke engine over the classic 1950-style two-stroke are most prominent at low speeds. The two-stroke has several things working against it, particularly a difficulty in idling down to low speed running. Most two-stroke engines need the ignition timing to be severely retarded in order to slow the engine down to speeds appropriate for idle (600-800 RPM). At low speeds their fuel consumption was traditionally much worse due to the waste of unburned fuel. Also the exhaust smoke was most prominent at low speed.
Modern two-stroke engines have resolved all of these problems, so that a modern two-stroke engine using direct injection of the fuel into the combustion chamber and using direct oiling will now be:
--as clean or cleaner than a four-stroke
--as fuel-efficient as a four-stroke
--as quiet as a four-stroke
Looking over the remaining areas of you comparison, it then seems that the engines are on par except that:
--the four-stroke weighs more
--the four-stroke has more moving parts
--the four-stroke needs routine oil changes
In the area of cost, unfortunately the modern two-stroke is almost as expensive as the four-stroke. The older, classic two-stroke engines are less expensive, but then you give up all the modern improvements mentioned above.
As for the ability of the engine to produce torque at low RPM, this does still seem to be an advantage for the two-stroke outboard. However, the four-stroke outboard is evolving, and designers are finding ways to improve the torque output at low speeds. For example, almost all of the larger horsepower four-stroke engines on the market today include some technology designed to enhance low RPM torque. The most dramatic of these is the Mercury Verado, where a supercharger gives the engine superior low RPM torque.
John O posted 01-30-2005 10:57 AM ET (US)     Profile for John O
A lot of hours are needed to see any cost savings on fuel. The biggest advantage I see in four-stroke technology is the noise.
seasicknes posted 01-30-2005 11:38 AM ET (US)     Profile for seasicknes
I can go either way with either a new E-TEC or a four-stroke.
The negative thing about the four-stroke to me is the weight factor.
Peter posted 01-30-2005 12:51 PM ET (US)     Profile for Peter  Send Email to Peter
Just more examples of how boating is all about accepting a set of compromises that works for you.
pmberman posted 01-30-2005 06:42 PM ET (US)     Profile for pmberman  Send Email to pmberman
I agree. That's the great thing about Whalers and boating in general. You can customize the final product to meet your preference. And the great thing about a free country: we can all disagree.
I still prefer two-stroke for all the reasons I stated earlier (all facts). Four-strokes are heavier, more expensive and have too many moving parts. I believe the newer [direct-injection] two-strokes will eventually dominate the market. They have solved the polution problem and are 35% more efficient than conventional two-strokes.
Joe Kriz posted 01-30-2005 07:23 PM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
pmberman,
I second that.
I also would like to add the fact that you have to take a four-stroke in for the first service at 20 hours. For people like me that live in very rural areas, that means a 3 hour round trip drive, for me, just to take it in for the first service.
And, that's if I don't have to leave the boat overnight.
With the E-TEC, I believe you don't take it in until 300 hours...
The E-TEC I believe is going to be a big plus for me. Can't wait to check out the 150 HP when they become available.
ryanwhaler posted 01-30-2005 08:24 PM ET (US)     Profile for ryanwhaler  Send Email to ryanwhaler
One of my favorite things about the four-stroke is the smooth execration [!], all the two- stroke enigne I have made all kind of goofy noise while accelerating, and there are some speeds where they just run rough.
I was able to find one "con" with the DF70, in few times we used it.
The ramp we use to launch our Montauk is on the shallow side. I like to just get the lower unit in the water and back off, it takes a considerable amount of throttle to get our Montauk off the trailer in reverse, and the four-stroke will stall when you give it the gas before it is warm, I never saw this happen to a two-stroke, they are kind of like chain saws, start them and punch it. We have to keep the trailer lights and hubs under water for a few minutes while the engine warms up, not to wild about that.
fourdfish posted 01-30-2005 08:27 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
pmberman--I third that! Mercury has passed off the new Verado as a big step forward. I see it as huge vertical automobile engine. It was written in the magazine as weighing 715-lbs without the hydraulic pump.I didn't want all that weight on my transom. Any extra power coming from that engine is offset by its weight. It is almost 200-lbs more than a comparable E-TEC and much more than the older model two-strokes which I have had great success with in the past. I'm a fisherman not a racer but it doesn't take a rocket scientist to know that all other things being equal the heavy four-stroke cannot beat the significantly lighter model engines. By the way the E-TEC has shown to be a very quiet engine. From personnel experience the sound is quieter and more pleasing than the four-stroke Honda. My two cents
Buckda posted 01-30-2005 08:41 PM ET (US)     Profile for Buckda  Send Email to Buckda
I'm quietly rooting for E-TEC to be successful in a big way. I can see this as the most favored re-power option for my classic Outrage (even though I don't want to leave a Mercury power platform...).
The 90 HP E-TEC weighs just 15 pounds more than the carbureted 115-HP in-line 6-cylinder Mercury's of the mid-1980's. I'm hoping that the 150 HP E-TEC is similar to the mid-1980's Mercury 150 Black Max (375 lbs or so...) If they fly in at under 400 pounds, I'm sold.
gss036 posted 01-30-2005 09:14 PM ET (US)     Profile for gss036  Send Email to gss036
I think the real JURY is still out on the four-stroke technology. I think that several years down the road when it come to minor reparis and people are faced with HUGE repair bills on their four-stroke engines, there will be many second thoughts about why did I go this route. I think in the long run, repair costs will kill the four-stroke business. The retired people like me, just flat out cannot afford it. My wife is already bugging me wanting me the sell my boat and find something else to occupy myself with. Maybe walking the river bank fishing? :-) My two cents.
Brooke posted 01-31-2005 10:54 AM ET (US)     Profile for Brooke  Send Email to Brooke
I just bought a "leftover" 2004 Yamaha 40-HP four-stroke but it's carbed liked the two-strokes. I'm not sure how she's going to run since it's the dead of winter here and I haven't had her out yet. The motor is only 192 lbs. so I'm hoping I have the best of both worlds with this motor.
Moe posted 01-31-2005 11:07 AM ET (US)     Profile for Moe  Send Email to Moe
I suspect when automobiles came about, steam engine proponents said the similar things about gas engines. And when four-strokes became popular in the early automotive days, I'm sure that there were those who said, "You just wait... those four-stroke buyers will be sorry when they have to have a valve job in addition to piston ring replacement." I'll bet they even exaggerated that valve jobs would cause "HUGE repair bills" back then, too.
In the overall scheme of things, only a probably tiny percentage of all the outboards ever sold are rebuilt. Even with two strokes, by the time they're 10 years old, people have less confidence in them, and at 20 years old, owners and buyers are talking about or actually repowering. And that's simply because of age, because few have any idea how many hours of operation is on the average outboard. Again, in the overall scheme of things, when you consider how little MOST outboards are used after the first year of ownership, using a figure of 100-200 hours of operation per year as an average is probably WAY high for the set of all outboards sold. But even at that, we're talking 1,000 to 4,000 hours in a 10-20 year period. The probability of any engine, two or four-stroke that's not totally neglected, needing MAJOR repair within this hour range is WAY less than 50%. And by that time, the repair often costs more than the motor's worth, even with carbed two-strokes.
You may wish they'll be sorry, but the odds are also high that most buying four-strokes today won't even own them by the time MAJOR repair is required. The ones paying for the valve job, if there ever needs to be one, will be those who can't afford a newer motor. Perhaps that will relegate them to fishing off the banks.
If you think the jury's still out, consider that Honda has been shipping four-stroke outboards to this country for over 30 years, and they still have a reputation, if not the best reputation in the industry, for durability. OTOH, it appears BRP is spending most of their marketing money fighting a strong public perception that four-strokes are better than two-strokes, yet they have the haunting stories of their own FICHT problems, Mercury's OptiMax problems, and now darling Yamaha's HPDI problems, scaring buyers away from high-tech two-strokes. These are buyers, who as a population, have never had to rebuild a four-stroke automotive engine, so they know what has worked for them.
I think two stroke outboards are now in the position of vinyl records when CDs were first introduced, interestingly at more than double the price of vinyl. I too would like to see BRP succeed, but I think they have a LONG, TALL mountain to climb, not just from public perception, but from the exclusive powering agreements sewn up by Brunswick and Yamaha.
Moe
Buckda posted 01-31-2005 11:16 AM ET (US)     Profile for Buckda  Send Email to Buckda
Moe -
I totally agree. I'm rooting for E-TEC for my own selfish reasons (I want the lightweight motor for the back of my classic Boston Whaler).
If the rest of the pack can figure out how to put their four-strokes on a diet, I'd be back in the fold.
Moe posted 01-31-2005 11:53 AM ET (US)     Profile for Moe  Send Email to Moe
Dave,
I'm doing my part by strongly recommending the E-TEC for repowering older boats, specifically because of the weight issue. I think it's a mistake to put heavy four-strokes of the boat's max power rating on their transoms. For those who are more concerned with fishing and less with speed, using a smaller horsepower four-stroke nearer the weight of the max HP carbed two-stroke, like Tony did, is also a good alternative.
Moe
Brooke posted 01-31-2005 11:53 AM ET (US)     Profile for Brooke  Send Email to Brooke
I must be in some kind of weird weight zone for my motor. My four stroke is lighter than the two-stroke equal. I guess this is an exception and not the rule.
Moe posted 01-31-2005 12:22 PM ET (US)     Profile for Moe  Send Email to Moe
Brooke, it's hard to compare apples to apples in the lower, clean horsepower range. The comparble 40HP E-TEC is a much larger motor, used for up to 60HP, and it has a big gearcase with lower ratio, so you have to compare it to the heavier Mercury BigFoot motors, where the same is true (Yamaha doesn't make a 40HP High Thrust). That's why Whaler, who uses BigFoots where possible, can't offer them on the 130 Sport. Instead of the heavier and larger 4-cylinder 40HP BigFoot, they offer a smaller 747cc 3-cylinder 40HP Mercury small foot, with apparently the same powerhead as the 40HP small foot Yamaha.
While 40HP is 40HP, I don't think either of these small discplacement four-stroke 40s would push as much of a load in the mid range rpms, as the 33% larger displacement E-TEC or BigFoot 40s.
Moe
Brooke posted 01-31-2005 12:41 PM ET (US)     Profile for Brooke  Send Email to Brooke
Moe, I agree. I think displacement is just as important an issue when buying a motor. My boat is about 1000 lbs. minus the 192lb. motor loaded, so I'm hoping the 40HP will have enough kick to it. I don't push heavy loads but if I did I would have spent the extra $500 on the Etec. I won't know if I made the right choice until I splash the boat in the Spring.
luife posted 01-31-2005 12:47 PM ET (US)     Profile for luife  Send Email to luife
I don't know enough history, but I was wondering if somebody knows why they four-stroke did not survive against the two-stroke 40 years ago? Actually, I know that Bearcats outboards were originally installed in Boston Whalers back in the 60s and early 70s. Thus, why the two-stroke won that battle back then? Does somebody knows? I think the answer tho these questions are important to analyze this issue about four-stroke vs. two-stroke. I know that back then the environmental matters were not an issue, but as we know, with clean two-stroke of today, it should not be an issue now either.
jimh posted 01-31-2005 01:23 PM ET (US)     Profile for jimh  Send Email to jimh
This history of the Bearcat outboard is presented in:
Fisher Pierce Bearcat Outboard
http://continuouswave.com/whaler/reference/history/bearcat.html
One problem those engines had was corrosion of the water cooling system.
Moe posted 01-31-2005 01:42 PM ET (US)     Profile for Moe  Send Email to Moe
Great article, Jim! I don't know how I missed that before.
Moe
Ketch posted 02-02-2005 10:14 AM ET (US)     Profile for Ketch  Send Email to Ketch
There is a good article in February's issue of Boating which sets forth a thorough comparison of the Yamaha F150 and HPDI 150. The crux of the article is that the two engines are surprisingly similar (in fact almost identical) in almost all respects (top speed, fuel efficiency, initial cost, maintenance costs, etc.). The only differences were that the F150 is quieter at trolling and idle speeds and the HPDI has better aceleration. When all is said and done, the article concludes that those who value acceleration and a quick holeshot should opt for the HPDI and those who enjoy the silence of a four-stroke while at idle should opt for the F150.
fourdfish posted 02-02-2005 10:36 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
Or, You can get both with the E-TEC!!
TexasWhaler posted 02-02-2005 03:06 PM ET (US)     Profile for TexasWhaler  Send Email to TexasWhaler
Right you are, fourd !!!!
mccomas posted 02-04-2005 01:08 AM ET (US)     Profile for mccomas  Send Email to mccomas
Hello all!
There is a lot of conflicting information on the internet about the advantages and disadvantages of two- and four-stroke engines. The discussions are divided right down party lines. I just purchased an 2005 Sport 130 with the 40-HP Mercury four-stroke EFI. I upgraded the engine for about $1,200 and am trying to convince myself that I made the right decision :)
Multiple sources, including this forum, claim that four-stroke engines require additional displacement than a two-stroke equivalent to produce the same power. This is a logical argument since the two stroke cycle has twice as many power strokes per revolution than the four-stroke cycle. However, Mercury claims that their new four-stroke EFI has less displacement than the 40-classic. They also claim that their four-stroke only weighs a few pounds more than the two-stroke (not the 100 lbs that I hear people saying). I could use some help sifting through the conflicting information.
http://www.mercurymarine.com/mercury_40_classic
http://www.mercurymarine.com/mercury_40_fourstroke
I find it hard to believe that modern two-stroke engines can have emissions and fuel economy on par with comparable four-strokes. In order for the exhaust gas to leave the cylinder at the same time the air-fuel mixture enters, mixing must occur. I am a fluid dynamicist and I guarantee that mixing is inevitable; especially in the turbulent combustion chamber. This means that some un-burnt fuel will leave through the exhaust. I don't see how a modern two-stroke engine could get around this?
I'm not an environmentalist, but the idea of dumping a quarter of my fuel in the lake bothers me.
It also makes sense that two-stroke engines would have higher torque at low RPM than four-strokes; however, the top-end speed between the two engines should be identical. Power is simply torque times RPM and peak power is the power at WOT and max RPM. Torque at low RPM could vary widely between engine types rated at the same HP. Thoughts?
Oh, I just picked up my 130 sport yesterday. I don't get to take her out for a spin until this weekend... I can't wait!!
Peter posted 02-04-2005 08:21 AM ET (US)     Profile for Peter  Send Email to Peter
Mccomas, congratulations. Given the way the general outboard motor preferences are going these days, I think you made the right choice given the very, very limited choices you had.
Modern two-strokes, that is direct injected two-strokes, can have emissions that are equal to or exceed four-stroke emissions. This is because the fuel is not introduced into the cylinder until after the exhaust port is closed. Unfortunately for you, Mercury has no modern, environmentally friendly direct injected two-stroke 40 product offering. If they had, you might have been able to get the best of both worlds, two-stroke low end torque with four-stroke fuel efficiency.
FYI, the 3 cylinder Mercury Classic 40 is really a detuned 60 HP motor. It displaces 59 cubic inches which is really overkill for a 40 HP two-stroke. While some will advocate for the advantages of this generous displacement, the problem is that the advantage is offset by a weight penalty as it is easily the heaviest 40 HP two-stroke on the market. The Mercury Classic 40 with power trim and tilt probably weighs a good 30 lbs more than a 42 cubic inch two-stroke Yamaha 40.
TexasWhaler posted 02-04-2005 09:43 AM ET (US)     Profile for TexasWhaler  Send Email to TexasWhaler
mccomas and Peter,
It should be noted that the E-TEC two-strokes are not in the same arena as conventional, modern DFI two-strokes.
With that in mind, it should also be noted that the E-TEC outboards are as clean as some four-strokes on emissions, and CLEANER than many four-strokes.
I understand that this, in theory, should not be possible. That is why what Bombardier has done is so revolutionary. They have actually made a two-stroke outboard that is as clean and cleaner than ALL current four-strokes. All of that AND the legendary, unmatched performance and light weight of two-stroke engines.
It is a hard thing for many to believe, but I believe 2005 is going to be they year that many are going to realize just how amazing and cutting edge the E-TEC line is.
fourdfish posted 02-04-2005 10:37 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
mccomas, I'd bet that your dealer did not mention nor offer your boat with an E-TEC as Whalers come pre rigged with Mercury engines so I think you did the right thing to upgrade.
However, many misconceptions about the two-stroke E-TEC abound and Peter and Texaswhaler are some of the few who are on top of this technology. Bombardier does not own all the boat companys that Mercury does, so most of thier market is in repower and boats which do not come prerigged. The company also has done poorly in it's marketing. With that being said I think the E-TEC sales will unfold slowly as people find out that the E-TEC is not your ordinary two-stroke.
15ftlover posted 02-04-2005 11:30 AM ET (US)     Profile for 15ftlover  Send Email to 15ftlover
I am not sure I am buying the reliability of a two-stroke ETEC just yet. I plan on keeping my engines for at least 12 years. Four-stroke technology has been around for a very long time (cars, planes, boats). I have had cars go over 300,000 miles without any major component failures. "With all the extra moving parts" it has still been a reliable technology-that alone makes a strong argument. The E-TEC is indeed new technology, and "Oh!" how great all new technologies must be. But the idea that this motor has not been out very long requires some scepticsm. The tolerances seem to be alot less forgiving for an E-TEC. If anything were to go wrong with that microlubrication system (clogged line, viscosity changes, leak, brief interuption) it seems that this engine would self destruct pretty quickly. I know four-strokes. I've worked on them, owned them, repaired them. The fact that all newer engines now have electrical components including microprocessors does not translate into reliabilty. The marine environment is tough. Computers crash, hardware failes. I hope ETEC is all the things it claims to be. If they have an excellent reputation 12 years from now I'll be first in line to buy.
HL
seahorse posted 02-04-2005 11:59 AM ET (US)     Profile for seahorse  Send Email to seahorse
We did not have large fuel injected four-strokes 12 years ago, but we had decades of large two-strokes. Using your logic, you should be buying an E-TEC two-stroke instead of those newfangled electronically controlled four-strokes.
15ftlover posted 02-04-2005 01:07 PM ET (US)     Profile for 15ftlover  Send Email to 15ftlover
Decades of large two strokes yes, but none using the E-TEC technology. The E-TEC is in fact a new breed--not to be confused with the older two-strokes of years ago. Time will tell
HL
seahorse posted 02-04-2005 01:14 PM ET (US)     Profile for seahorse  Send Email to seahorse
Less than 12 years of computer controlled EFI four-strokes. It was only 3 years ago that the Yamaha F200-225 four-stroke came on the scene. According to your logic, they are still new and unproven.
Just funnin' with ya.
15ftlover posted 02-04-2005 01:16 PM ET (US)     Profile for 15ftlover  Send Email to 15ftlover
Seahorse,
True, true you got me there ;) I'm hoping the midrange EFI motor I just purchased lasts me 12 years!
HL
jimh posted 02-04-2005 02:02 PM ET (US)     Profile for jimh  Send Email to jimh
The concept of the high-horsepower four-stroke outboard is really quite new. It was just a few years ago that a 135-HP HONDA four-stroke was the horsepower champ. And that was one very large, very heavy, very expensive motor.
The concept of multiple valves, multiple overhead cam shafts, and multiple cam lobes with variable valve timing is about a year old in outboard motor technology.
Direct-injection technology (such as used by E-TEC) is very well developed. It has ben used in diesel engines for years.
Peter posted 02-04-2005 02:51 PM ET (US)     Profile for Peter  Send Email to Peter
Direct injection is now starting to show up in gasoline powered automobiles. Audi's newly introduced A6 has a direct injected multi-valve four-stroke V6 engine. Direct injection, whether in the two-stroke or four-stroke format, is the future.
LHG posted 02-04-2005 02:59 PM ET (US)     Profile for LHG
The comment about "mccomas" having to put up with a Mercury four-stroke 40HP EFI on his new Whaler is ridiculous. That should even offend the Yamaha people here, as theirs is the same engine, only without EFI. Combined, these are probably the best little 40's on the market today.
Most of the readers here seem to prefer EFI four-strokes over DFI's, any brand you want to choose, especially in the 115HP and below categories. Mercury has a long track record of excellence in outboard EFI, beginning in the mid 80's I think. It's unbelievably reliable and efficient when compared to the carbureted offerings in either two or four-stroke. Mine have been superior.
New 2005 Montauk buyers will soon be telling us which technology THEY prefer, as now the 90 OptiMax is being added to the choice. Will the OptiMax outsell the 90 four-stroke? Highly unlikely, and it is reasonable to assume the 90 E-TEC performs about the same as the OptiMax. According to Whaler's data, the OptiMax 90 is no stronger than the four-stroke 90. And then, there is Mercury's own 90 four-stroke on the horizon for 2007? Since Mercury is playing both ends against the middle, it will be interesting to see which way the consumer goes. Is the 45# difference in weight between the 90 E-TEC and 90 Yamaha EFI four-stroke enough to sell it in large numbers, and compete with Yamaha's transom tie-ins? Who knows
seahorse posted 02-04-2005 04:42 PM ET (US)     Profile for seahorse  Send Email to seahorse
JIMH and 15ftlover,
"Direct-injection technology (such as used by E-TEC) is very well developed."
The Evinrude direct injection is in its 9th year of production. It was introduced in June of 1996 as a '97 model. There have been several re-designs and improvements made to the injectors over the years.
fourdfish posted 02-04-2005 04:59 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
LHG--- I went back and read the posts and find no place where it was commented to MCCOMAS "having to put up with a Mercury four-stroke, 40hp EFI". I myself said that he made the right choice given his options. It would seem that you have written off the E-TEC at all costs. I also disagree that most of the participants of this forum like the EFI over DFI and Mercury the best.
LHG posted 02-04-2005 05:35 PM ET (US)     Profile for LHG
As an owner of 5 conventional two-strokes, Mercurys no less, I admit that I should probably not be participating in a discussion of clean technology with all you whiz kids and assorted factory/dealership engine reps.
But I have noticed over the years that the overwhelming interest and preference of the Classic (not the Post-Classic) boat owners on this website is Japanese branded four-strokes. It's just that simple. I don't like it, but that's the way it is.
fno posted 02-04-2005 11:23 PM ET (US)     Profile for fno  Send Email to fno
Clarify this for me... E-TEC means direct injection (a good thing), and electronic controls (jury out). So your E-TEC is not your average carbed two-stroke. Call a spade a spade. Not that far removed from an OptiMax if you ask me. Taking the parallel of automobile four-strokes, if an average engine is good for 200,000 miles at 65 MPH, that's about 184,000 hours before [vulgar figure of speech meaning "failure"]. [This math is way off. It only takes 3,077 hours at 65-MPH to go 200,000 miles--jimh.]. I and most of you, if we take care of our motors will be long since dead before they quit. [It only take 128 days to run for 3,077 hours.--jimh] Take into account the RPM differences between the two and most of us will still be taking a dirt nap before our four-strokes quit. Look at your transoms and put the right motor on it, two-stroke, carbed, EFI, direct, four-stroke all have their place on Whalers. I'm still looking for a coal fired (shovel in hand) outboard for my next Nauset.... Oh!!! and no noxious emissions either....
fourdfish posted 02-05-2005 10:26 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
The E-TEC and the OptiMax are not even similar. They are miles apart). E-TEC does not have carbs and does not mix fuel and air before it goes into the cylinder. The fuel is injected only after the ports are closed and then mixed with the air and burned. None is lost. No oil is in the fuel! As Peter said the only auto with this technology is the new Audi. The last I heard the factory has been running E-TEC for over 40,000 hrs. Technology drives our lives,the computer your using, DVD,new TV screens, new cars, appliances etc. Things change!
fairdeal2u posted 02-05-2005 11:53 AM ET (US)     Profile for fairdeal2u  Send Email to fairdeal2u
fno
200,000 miles at 65 miles per hour
200,000 miles x hour/65 miles =
comes out to around 3,000 hours.
If you look at the discussion on how long two-strokes have lasted people on this forum. It comes out to just about that amount of time. 3-4000 hours on a regularly maintained and used two-stroke. Look at the postings from Sal.
Vic Holmstrom posted 02-05-2005 01:31 PM ET (US)     Profile for Vic Holmstrom  Send Email to Vic Holmstrom
According to the Whaler website, the 90 OptiMax is no longer offered on the Montauk. Remaining choices include the 90 Classic, 60 four-stroke EFI, and 90 four-stroke (not sure if it is EFI or carburated).
I saw an add in the February issue of Boating World magazine with a picture of a Mercury 90 four-stroke with EFI decals. They may be in the process of changing over.
Peter posted 02-05-2005 03:41 PM ET (US)     Profile for Peter  Send Email to Peter
Those 3000 hours of frequent use on the road as an automobile engine laying horizontally in the engine compartment are very different from 3000 hours of sporadic use spent vertically on the transom of a boat in a corrosive environment. Unlike in the case of an outboard motor on the transom of a boat, it's quite possible that half of those 3000 hours are served going down hill with little or no loading.
So I'm not so sure I'm ready to conclude that the life of a vertically arranged four-stroke engine that serves as an outboard motor pushing a boat should be the same as the life of a horizontally arranged four-stroke engine serving some part of its operating time pushing or pulling an automobile. Large two strokes serving as an outboard motor have a very long and wide history of service. Large four-stroke do not yet have that.
Moe posted 02-05-2005 05:09 PM ET (US)     Profile for Moe  Send Email to Moe
I'm curious what the orientation of the engine has to do with its life.
Moe
Peter posted 02-05-2005 05:27 PM ET (US)     Profile for Peter  Send Email to Peter
Not all pistons are similarly situated, unlike in an automobile.
linust posted 02-05-2005 06:08 PM ET (US)     Profile for linust  Send Email to linust
quote:
The E-TEC and the OptiMax are not even similar.(miles apart) E-TEC does not have carbs and does not mix fuel and air before it goes into the cylinder. the fuel is injected only after the ports are closed and then mixed with the air and burned.(none is lost) No oil is in the fuel! As Peter said the only auto with this technology is the new Audi. The last I heard the factory has been running E-TEC for over 40,000hrs. Technology drives our lives,the computer your using, DVD,new TV screens, new cars, appliances etc. Things change!
fourdfish--are you implying the OptiMax has a carb? Perhaps I better go back to my dealer and ask if they forgot to install the carbs are on my Opti 225 ;)
The E-TEC and the Opti do have quite a few similarities...both are two-stroke, direct fuel injection. Where the E-tec has it over the Opti is in the programmable oil-injection system and fast computer/electronics--the poor Opti has to crank through 3 revolutions before the computer knows where everything is and can fire it up :( Then there's the air compressor assist to the fuel injection.
As for Audi using this technology, at this time, only in Europe, unfortunately. Even though they're marketing the new engine with the same FSI acronym in the US, it doesn't include the same technology--yet :(
On the topic of four-stroke technology and complexity...Trailerboats magazine's February 05 issue detailed the Yammy F250 with VVT. This is a DOHC 4valve/cylinder engine with a flexible drive timing belt. Any of you who've ever broken a timing belt on a car know what happens...you stop. right now. And if this is an interference engine, you bend valves. I hate to ask what this repair might cost.
mccomas posted 02-05-2005 08:10 PM ET (US)     Profile for mccomas  Send Email to mccomas
Thanks for the good comments! I now know I made the right decision. I took the new Whaler out for the first time this morning (130 Sport). Not only could I hold a conversation at WOT, but the 6-gallon gas tank is stil half full after 4+ hours of playing on Lake Wahington (Dont worry, I followed the engine break-in procedure).
I now see how direct-injection two-stroke would fix the fuel economy problem; however, the 2-stroke will still suffer from lower compression on the powerstroke than the four-stroke. Some of the travel of the piston is being used to expel exhaust, rather than compress the air-fuel mixture. However, since the two-stroke has twice as many power strokes per revolution than the four-stroke, I suspect their performance is on par with each other.
Anyway, since I bought my whaler new, I only had two engine choices: Mercury four-stroke EFI or Mercury two-stroke. I'm now convinced I made the right decision!
Andrew
P.S. I got about 5 "nice boat" comments today! Once at the gas station and twice when launching and retreiving the boat. The Whaler reputation is bigger than I thought!
fourdfish posted 02-06-2005 07:24 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
linust-- I didn't mean to imply that the OptiMax had carbs but was responding to the post on two-stroke carbs and mixed it in with the OptiMax. With regard to the OptiMax I think the things they have in comman are that they are two-strokes and direct injected. The similarities end there! The OptiMax has a two stage injection system while the E-TEC does not! The OptiMax needs an air compressor which the E-TEC dosen't. The E-TEC has far better fuel injectors. Speaking of belts doesn't the OptiMax have them!! The E-TEC doesn't need them. Side by side they are very different engines. I think the new Audi will be here soon. I see that Whaler is no longer offering the 90HP OptiMax on the Montauk and from conversations I had at the Boat Show, you have to wonder what Mercury is going to do with the OptiMax in the future.
Peter posted 02-06-2005 08:25 PM ET (US)     Profile for Peter  Send Email to Peter
The new Audi A6 3.2 FSI with direct injection is here. I've already seen several on the road.
linust posted 02-07-2005 04:20 AM ET (US)     Profile for linust  Send Email to linust
fourdfish--yes, the Opti relies on a belt...its breakage won't risk a catastrophic mechanical failure like a busted timing belt on a four-stroke w/ DOHCs. I don't know (or want to find out) if a busted compressor belt leaves the Opti dead in the water, though. As I noted, the E-TEC has some definite advantages over the Opti.
Peter--my prior post on the Audi technology was a bit off...
The new Audi FSI engine IS in the US and is direct injection, but it is also kinda crippled...nutshell: our relatively dirty fuel prevents the use of super lean fuel-air mixtures. So where FSI means Fuel Stratified Injection, it really isn't a stratified charge in the US. bummer.
see these two articles for more details:
http://www.roadandtrack.com/article.asp?section_id=6&article_id=1367&page_number=1
http://www.caranddriver.com/article.asp?section_id=19&article_id=8781
Thread relevance? Audi developed this technology years ago for competition use in their 24 hr. LeMans winning R8. So if you think DI technology is "new" or potentially unreliable, I'd beg to differ.
Peter posted 02-07-2005 08:04 AM ET (US)     Profile for Peter  Send Email to Peter
Thanks Linus -- that explains why they talk of the stratified and homogeneous charging on the AUDI UK website but not on their U.S. website. Nonetheless, the benefits of direct injection are finding their way into passenger cars. I believe its only a matter of time before this becomes the standard induction method for automobiles.
Sal DiMercurio posted 02-07-2005 10:12 AM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
A few weeks ago I got a distress call from a good buddy of mine with a 2004 ....115 opti with less than 40 hours on it.
His belt broke & he was 14 miles from the harbor.
Guess who had to tow him back with the supposedly no good FICHT engine ?
If an engine is useless because it broke a belt (on the water), it's time to re-think its design because it could be a life threatning situation in rough seas.
I'm not a Merc basher but this isn't the best advertizement for them.
Sal
linust posted 02-07-2005 12:50 PM ET (US)     Profile for linust  Send Email to linust
Sal, ummm, thanks, I think :( Not what I wanted to hear.
Just checked the owner's manual again. Nothing in there about belt maintenance. Is this a field maintainable item? Or was this a fluke occurrence with this particular motor?
sinjun posted 02-08-2005 12:06 PM ET (US)     Profile for sinjun  Send Email to sinjun
The [wide open trottle] for the 13 SPORT two-stroke and four-stroke are not the same if you go to Boston Whaler's web site they have the performance numbers on both the two-stroke is 1.5- to 2-MPH faster. I know that doesn't sound like much but speed is expensive on the water, and you paid $1,200 for less speed.
LHG posted 02-08-2005 03:37 PM ET (US)     Profile for LHG
Based on Sal's remark, we should have a discussion of which outboard engines, made today, have belts. We now know that the OptiMax engines do, and that HPDI engines do, and so do the Merc two-stroke EFI's with 60 amp charging. How about four-strokes? Do they use any belts at all, or are the overhead cams turned by gears? And how reliable are belts in general, or are they to be avoided at all costs in outboard motors?
I know my car has belts and seems to do quite fine! They do need occasional replacement, however
sinjun posted 02-08-2005 05:34 PM ET (US)     Profile for sinjun  Send Email to sinjun
All the [four-stroke engines] I have looked at have belts in them.
seahorse posted 02-08-2005 06:45 PM ET (US)     Profile for seahorse  Send Email to seahorse
Yamaha's larger four-strokes all use belts. Only the F200-F225 will not have the pistons hit the valves should a rubber timing belt break. The new F250 will damage valves, as will the 115 and smaller four cylinder motors.
Suzuki uses timing chains on many of their four-strokes.
Evinrude FICHT and the new E-TEC do NOT have any belts or chains. The other DFI motors do.
fairdeal2u posted 02-11-2005 01:13 AM ET (US)     Profile for fairdeal2u  Send Email to fairdeal2u
My friend's Honda 90 manual recommends belt change at 300 hours. My Yamaha 115 four-stroke manual recommends belt checked at 1000 hours and changed if needed. Belt is very easy to see and to check.
RocketMan posted 02-12-2005 09:04 AM ET (US)     Profile for RocketMan  Send Email to RocketMan
I'm listenin' to ya'all as I head down to the Miami Boat Show next week to look things over. Right now sounds to me like the E-TEC will be the prefered way to repower my classic 16. I've had great service for the past 20 years from a Yamaha 90 but its ready for inshore duty. The boat show usually has nice cut-aways, brochures, and an occasionnal engineer who can discuss the details (you don't do that with sales people) as well as all the manufacturers. All that and merchandise at a show price. I'll report back with a summary after the show.
johnr posted 02-13-2005 09:50 AM ET (US)     Profile for johnr  Send Email to johnr
If I were you on your classic 16 I would definately put a two-stroke, because at the time the boat was made it was made to take a certain amount of weight and of course the two-stroke is lighter. You could go down on the horsepower if speed does matter.
jimh posted 02-13-2005 10:47 AM ET (US)     Profile for jimh  Send Email to jimh
[Administrative post]
RocketMan posted 02-20-2005 08:55 AM ET (US)     Profile for RocketMan  Send Email to RocketMan
Great topic for repowering a classic 16 ft hull.
At the Miami Boat Show yesterday:
Looked under the cowls of all the 90's there and have the brochures if there are questions. My gut is all of the engines are very good or even excellent and buyers will end up deciding based primarily on demonstrated dependability, their own experience, features that match their requirements, and finally on technology. We really have some great choices and there's a lot of competition to keep the cost down.
The main engine replacement factors to me, not in order of importance, are HP, cost, weight, maintenance, and dependability. About all you can check out with much reliability at a boat show are the first 3, something about the 4th, and a "trust me" on the fifth and most important.
Conclusions: New engines vs. the venerable 2-strokes
The new engines perform better and are more efficient
The new engines cost more
The new engines weigh more
The new engines were designed to minimize maintenance
The new engines should be more dependable, we'll see...
Review:
The E-TEC 90 seemed to be the belle of the dance. The 2 stroke I-3 1295 cc E-TEC injected engine was the most slender and petite at 320 lbs. Got one show price of $6795 from a local dealer for just the engine. Easy to fall in love with, the only thing missing with this engine is a demonstrated track record even though it comes from a great family. But is the salt water version really only available in 25 inch ?
Yamaha F90EFI was probably Miss runner-up weighing in at 369 lbs but looking slightly pregnant. A 1596 cc I-4 4 stroke DOHC and looking pretty clean under the cowl. A local dealer would remove my old 90 Yamaha 2-stroke and install this one new including controls and gauges for $8500.
Mercury was the girl next door and displayed a 4 stroke I-4 DOHC carb engine and the layout was straight forward and clean. A little heavy at 386 lbs. the Mercury folks told me that the 90 EFI would be available around May and the MSRP is $8400. No Verado 90 discussed but had nice cutaway of one in other power range. The cutaway of the heatexchanger looked a little scary.
Honda BF90, was valedictorian and from a nice Asian family was next. Their 4 stroke I-4 1590 cc SOHC V-TEC three-valve weighs in at 370 lb. but looks bigger. The only price given was $7100 and think that was a show price, not MSRP. Funny, one of the reps gave a caveat about the weight because they knew someone who put one on a classic 16 ft hull and it was probably too heavy.
Suzuki 90T was Miss Congeniality for weight reasons (416 lbs) and demeanor. Last on the list but still an attractive contender, depending. The 4-stroke I-4 1950 cc FI DOHC engine had an offset powerhead to move the powerhead forward and reduce the cantilever influence of the weight. It can take a one inch bigger prop and has a 40 amp alternator, so with the displacement is built more like a workhorse (Clydesdale?) engine. Local dealer said $8000 installed vs. MSRP of $9648
I'm replacing a 1985 90 ETN Yamaha that cost $4300 installed back then, weighs 270 lb, went 20 years before breaking anything (a magneto link plastic rod end split after a bad-gas-chugging-in-flight-shutdown), required only water pump maintenance every few years. This past year removed and replaced the cylinder head to clean out some salt and replace a thinwall casting at the thermostat. Still runs perfectly, all I can say is what an engine it has been but the ride may be over. Local dealer still has them, said he'd do a total swapout for $7400. This baby still has my heart but it might be time to move on.
fourdfish posted 02-20-2005 10:04 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
Rocketman, Thanks for the Boat Show Report! After reading it I was surprised that the E-TEC price you got was the best of the engines you listed. That engine comes with a 7yr warrenty if purchased before April. I see that the E-TEC was the lightest of that group you listed. Evinrude had virtually no presence at the Chicago Boat Show so I was unable to compare prices. Thanks again!
Joe Kriz posted 02-20-2005 11:24 AM ET (US)     Profile for Joe Kriz  Send Email to Joe Kriz
Rocketman,
The E-Tec 90, Saltwater series is available in both the 20" and 25" shafts.
Model E90DSL = 20" shaft, 320 lbs.
Model E90DPX = 25" shaft, 326 lbs.
Both the above Saltwater versions are White in color.
The Non-Saltwater model is E90DPL, 320 lbs., and comes in Blue.
This model appears to be available only in the 20" shaft length.
RocketMan posted 02-20-2005 11:30 AM ET (US)     Profile for RocketMan  Send Email to RocketMan
fourd - That's right! ... thanks for bringing that up about extended warranty. Right now EVERY OEM is adding 2-3 yrs extended warranty free for select models of new product purchased before the end of March or middle to end of April.
Peter James Morgan posted 06-17-2005 03:53 AM ET (US)     Profile for Peter James Morgan  Send Email to Peter James Morgan
Audi was not the first to have DFI. Mitsubishi took out patents on its GDI (gasoline direct injection) technology back in 1996 and maybe earlier. The first GDI Mitsubishis were on the road here in New Zealand in 1998 or thereabouts. Coming next to automobiles and trucks, are camless 4-stroke engines, both petrol and diesel. Outboards will surely follow – it’s a sure way to lower the weight. Check out www.mrtruck.net/camlesslaneesc.htm and www.sturmanindustries.com
Peter J. Morgan
Technical Editor
New Zealand Propeller magazine
LHG posted 06-17-2005 11:22 PM ET (US)     Profile for LHG
Direct injection may now be moving over to 4-stroke automotive engines, maybe even to outboard 4-stroke engines, but I think it's days with 2-stroke outboards are definitely limited, except perhaps for BRP, who, as Yamaha's Dyskow has said, is "betting the farm" on it.
It keeps looking like Yamaha HPDI and Mercury Optimax, the largest sellers in 2-stroke DFI, may have a limited future, no matter how good they are, at least in terms of volume percentages, that is, unless the NMMA is getting a lot of bad information. How long they will continue to be produced probably is determined by how long it takes the others to develop 4-strokes that will totally outperform them in the performance segments of the market. Verado is already is pushing this threshold. It appears that the only place 2-stroke DFI is holding it's own is in the bass boat market. Whether the Verado will impact that segment has yet to be determined, but the design intention is definitely there.
tgrobson posted 06-22-2005 05:25 PM ET (US)     Profile for tgrobson  Send Email to tgrobson
I really appreciate this discussion. As the owner of a classic 22 outrage with 1989 "Old Smokies" yamaha 130's on a whaler drive, I know I am facing an expensive repowering decision. Being that most of my time is spent inshore, and near inshore, I am leaning on going to a single 250 E Tec.
Factors are, weight, fuel efficeincy ( a big plus as my yami's get about 1.3 mpg), and reliability. I'd be interested in hearing from anyone who has recently made a simlar change. In the meantime, I can't seem to kill the old yamahas. Hope that continues through the summer!
17 bodega posted 06-22-2005 05:51 PM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
I love reading these threads. They are the best of what we have here. There is a great deal of insight and knowledge here. I learn something every time I read an outboard motor thread.
Thanks and keep it coming.
I see a theme here and I heard it said before. We all have different perceptions of reliability and highest and best use. I am always grappling with the most efficient way to rig a boat. Does a boat reach maximum efficiency when you have the lightest, most powerful motor with the ideal weight and horsepower to move the boat with minimum drag and fuel usage? To me this means using the leastpowerful engine to get the boat to your desired cruising speed. Overpowering seems to be an issue on this website... always having to use the maximum rated horsepower. You get very little extra speed, and you add lots of weight not to mention you need more fuel to complete a fishing trip. I always liked my underpowered setup because the weight is under the maximum, and I can store extra fuel for longer fishing/ cruising trips.
One complaint I've always had about two strokes is the smell, and the fluttery-chokey spot at about 1500-3000 rpms that seems to always run rough. I don't know about the new technologies, but the oldies (motorcycles included) always had that powerband issue.
Steve
Peter James Morgan posted 06-22-2005 08:27 PM ET (US)     Profile for Peter James Morgan  Send Email to Peter James Morgan
My experience is that for any given outboard-powered planing boat, maximum fuel efficiency, i.e. maximum miles per gallon, occurs at around 3500-4000rpm (maybe for some of the new higher-revving 4-strokes such as the Verados it's more like 4000-4500rpm). Logic says that a bigger motor is going to have a higher speed at which its fuel economy is maximized. It follows that at a higher speed the fuel economy suffers, and the converse is true for smaller motors. Therefore, provided a smaller motor is powerful enough to have its best fuel economy revs at a point where the boat is properly on plane and not wallowing near its "hump" speed, even when carrying its maximum load of people and fish, a smaller motor would give the best fuel economy. Human nature being what it is, however, most boaters opt for more power. Fuel economy is not their top priority. Realistic analyses show that fuel cost is only 10%-20% of the total cost of owning a powerboat, but because for most people it's an up-front out-of-pocket expense, it's regarded as being very important. Back in the mid 1960s there was a 20ft Bertram deep V that had as its standard powerplant a 150hp (at the crankshaft) MerCruiser. The identical hull, under a different brand name, (yes, it was 'flopped' around 1972) is still in production in both Australia and New Zealand, and nobody, but nobody, would dream of having only 145 propshaft horsepower to push it -- most have big single V6 outboards (static stability is achieved by having a built-in flooding chamber). Before the advent of the big V6 outboards most of the boats had V8 sterndrives, even though they squatted something terrible as they came up on plane and again when they came down off the plane.
Also in the 1960s, another 20ft deep V produced in Florida was the Vega, and the first of them had 80hp Volvo Penta sterndrives, with a top speed of 30 mph. I can't imagine any boater being satisfied with a deep V 20 footer with a top speed of only 30 mph these days, but maybe the current high fuel prices will have people slowing down a bit!
I can't recall seeing any boat test where different horsepower motors were compared for top speed and fuel economy, to prove that what I said above is true -- I've seen only shoot-outs between competing brands and technologies, all of the same horsepower.
It would help boaters' general understanding of how to get their best fuel economy if all US boating magazines published graphs in their boat tests, of mpg versus boat speed. Such graphs clearly show how fuel economy at planing speeds rises and peaks, then falls off drastically as speed is further increased.
One magazine that shall be nameless, publishes graphs of gal/hour versus engine rpm, and others have gal/hour versus boat speed, neither of which shows at a glance the most economical boat speed and at what rpm to which that corresponds. When I suggested to the Technical Editor that he publish graphs of mpg versus boat speed, he agreed he should, but said that when he tried to do it that way, he was over-ruled by the Art Director, who had more editorial power than he did.
It's my observation that favouring style over substance in the past is now coming back to haunt the Detroit auto industry, as Toyota marches inexorably towards becoming the world's number one auto manufacturer, with an annual profit already easily exceeding that of all three US auto manufacturers combined. There's a lesson here for the US outboard motor manufacturers -- let's hope it's taken to heart!
Peter J. Morgan
Technical Editor
New Zealand Propeller and Australian Propeller magazines
LHG posted 06-23-2005 02:03 PM ET (US)     Profile for LHG
I think under-powering is made even worse with with the new higher revving 4-strokes. To me extended cruising at 25-30 MPH with engine(s) turning a high pitched 4500 RPM is no fun at all for the ears. Not what I would call enjoying a day on the water. I prefer the tune of much lower RPM.
royaloakwhaler posted 06-23-2005 04:31 PM ET (US)     Profile for royaloakwhaler  Send Email to royaloakwhaler
BostonWhaler.com has performance data for each of its boats. The data shows multiple different engine setups. Its interesting to see the difference in noise and speed for the different engine setups. The gph vs speed and rpm are also graphed.
Peter James Morgan posted 06-23-2005 05:57 PM ET (US)     Profile for Peter James Morgan  Send Email to Peter James Morgan
Thanks for that, Royaloakwhaler.
I just checked out the test on the 220 Dauntless/Verado 225hp, and was pleasantly surprised to learn that I guessed wrongly about the Verado 225's most economical cruise speed -- it's at 3000rpm, 26.2mph, 5.0 gallons/hour, 5.2 statute miles per gallon. The boat had a top speed of 48.8mph, burning 21.2 gallons/hour, at 5500rpm. On the pdf document, I couldn't read the prop diam, but could read that it was a 17 inch pitch 4-blade ss. The test was conducted with three people abord and three-quarters of its full fuel load. Incidentally, sound level measured at the helm was 80dBA at 3000rpm and only 90dBA at WOT. Quiet indeed. On the outing I had recently in our editor's own boat recently fitted with a Verado 225, I was amazed at how quiet it was, even at WOT, and the prop we had on allowed it to peak at 6400rpm!
Now, what I'd really like to know -- could somebody please give me a link to a test of the 225hp E-TEC, preferably on the 220 Dauntless.
I'm also keen to find out if BRP's claim in one of its brochures that "the new E-TEC 250HP is 36% more fuel efficient than the Mercury Verado 250HP at Wide Open Throttle" is just marketing hype or is, as we say Down Under, 'fair dinkum'. I should say that the Verado's WOT in BRP's test was probably at or near 6400rpm, and you don't have to be very clever to figure out that at another 900rpm it will burn a lot more fuel. The only fair way to compare them is on identical hulls on the same day in the same conditions, and compare fuel consumption at equal boat speeds, not engine speeds. Anyone having a link to the published results of such a test of any 4-stroke against a like hp E-TEC is asked to please post it here, so we can all see it and learn from it.
Peter James Morgan
rbruce posted 06-23-2005 07:18 PM ET (US)     Profile for rbruce  Send Email to rbruce
Jimh:
Two strokes are inherently by design noisier than four strokes as the spent gas is expelled in the same stroke as the admission/compression stroke, whereas in a four stroke the crankshaft has to rotate a full revolution to exhaust the spent gas this is indeed an expansion chamber and this helps with the noise.
In an aquatic environment, I rather have a two stroke motor. The maintenance is less (no valves to calibrate) and the risk of an oil spill from the crankcase and oil filter seems to be less.
Perhaps the techology in HPDI two stroke is here to stay and this will prove more cost efficient and energy efficient than a four stroke. I also wish this technology could spill into automotive applications also. Good by oil changes!
fourdfish posted 06-23-2005 09:17 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
I know you have not heard a 200hp E-TEC, as mine is as quiet as the Honda 4 stroke 225hp side by side. My dealer sells both and was as impressed as I was when I first got it. It is not your typical 2 stroke. If you get a chance check it out. Test results are available on the BRP E-TEC site. The gas data is also very impressive. It is also about 200lbs lighter than a Verado which has hydralic steering.
