Topic: 13 FT -84 with a New 50 Yami
kdsundb |
posted 02-07-2005 06:23 PM ET (US)
Anybody set up a 13 sport with a newer 50HP Yami. Engine weighs in at 189. It may be a little more than I should - but I would like to get up on one ski behind the thing - and since I am not loosing any weight on my end - figure I would add some on the whalers.. Any horror stories before I commit. I am top bidder on Ebay for a NEW 2002 Yamaha 50 20 inch. PTT.
JBCornwell
posted 02-07-2005 08:37 PM ET (US)
The Classic 13 is a dangerous boat with more than 40hp.Been there. Scared hell out of me. Red sky at night. . . JB |
FISHNFF
posted 02-07-2005 09:37 PM ET (US)
I had a 1981 Sport 13 with a 1989 Yamaha 40. I later had it built up to a 50, with new carb jets, exhaust plate, and reed valves. Was it much faster? Maybe 2 or 3 MPH. Better under a load. I had it raised to the third hole (two showing) and ran a Yamaha 15" black SS prop. Just broke 40MPH (I think 41.7GPS). Maybe more, as it was slightly faster than a buddies Montauk w/90 Evinrude V-4 in flat water. Two persons with two batteries, livewell, and 6 gallons of fuel was fast. Too much trim and porpoised. Alone w/o livewell was scary. Trimmed way out and flew!FISHNFF |
kdsundb
posted 02-08-2005 08:58 AM ET (US)
Sounds like I should be focusing in on a newer 40 ... Can anyone compare a 25 4 stroke Honda to a older 35 Merc? Besides the obvious - cleaner, quiet ... what about performance?
JustinAndersen
posted 02-08-2005 02:27 PM ET (US)
Boy... 50 Yammie 2s to an older Merc 35 2s to a Honda 25 4s... I can tell you that unless you have the physique of a jockey you will NOT be able get up on one ski behind either the Merc or the Honda.In a nutshell, a 2S will provide more performance given a specific horsepower rating than a 4S, at the expense of fuel efficiency, quietness and cleanliness. I've never been impressed with the old Merc 35. Lots of maintenance, expensive repairs, plenty of vibration and excessive exhaust. The motor will, however, be more powerful than a 25 Honda obviously as it's a 2S and 35 vs. a 25. That said, a 40 Merc 2S will probably give you the most bang for your buck in terms of waterskiing performance. Whether you can get up on one ski will depend on your size and your prop. Go with a 40 4S if performance isn't the key issue. Speaking of the Yammie, someone posted some pictures of a beautifully restored 13 with a 50 Johnson on the back. The static trim looked a bit dodgy owing to the weight of the motor. Someone else referred to a 50hp powered 13 as "scary". Stay with the 40hp. I used to have a 13 with a 40 Merc 2S with T&T. Great boat. Lots of fun. Clocked out at 53MPH (measured on a Standard Horizon handheld GPS) on a calm day. |
macfam
posted 02-08-2005 05:19 PM ET (US)
JustinAnderson, C'mon....your're kidding. 53mph...with a 40 2-stroke on a 13'? I've got a 1987 13' Super Sport w/2000 40hp Johnson with T&T. 15" 3-blade aluminum (nuttin' special) Hasn't reached 40mph(GPS)ever! Havn't had the time to try my 17" SS yet...maybe 40mph then. How the heck can I get to 53mph? Share your secret(s). |
FloatingHobo
posted 02-08-2005 06:18 PM ET (US)
I have to agree with macfam. Fifty-tree seems extraordinary for a 13 with 40 horses. I have 77 13 sport with a 94 Evinrude 40 with T&T. Mine is pretty heavy aft with the battery and two 6 gallon tanks so I've only topped it out at 38 on a calm day. Had to trim way up to do that and she started the chine walk pretty bad at that point. Fifty-tree in a 13 sounds scary as all get out. |
Over the LINE
posted 02-09-2005 09:12 AM ET (US)
I have the set up you are looking at, down to almost exactly the same years on both motor and hull. I would not lend my rig to a child or the inexperienced (then again I don't lend it anyway). I, however am neither.For what I do the extra power comes in handy some times. I haul large amounts of junk to and from a duck / fishing camp in the marsh. I go hunting in really skinny water and need to get on an immediate plane with the prop in the mud. When not hauling junk or dragging the skeg through the mud, I run around 4200 RPM with the motor hardly working and fuel consumption down. I like the set up and don't think I would change. There have been many discussions about the insurance and other problems with overpowering. You can find them by searching previous posts. |
devildog
posted 02-09-2005 09:30 AM ET (US)
I did a lot of skiing behind a 13 with 40 hp Merc when I was a kid. I remember being able to tug the boat then. Now as an adult who also isn't losing any weight, I wouldn't even bother trying to ski from a 13. Just my 2 cents.Jeff |
kdsundb
posted 02-09-2005 08:15 PM ET (US)
You are right about pulling - but my fat butt is only behind it once in awhile. The hull is fine for the kids - expecially with the wake board ...you can't cut as hard as with a ski. I have my eye out for a 15 ...but I like to pull the 13 behind an older SeaRay Sedan Bridge. Why did I sell the Nauset! |
posted 02-09-2005 08:25 PM ET (US)
[Moved] |
2004_130_SPORT
posted 02-10-2005 01:56 PM ET (US)
Justin, You are full of crap on the 53mhp. That just doesn't happen i have a 130 sport with a brand new 40hp 2s merc and it tops out at 38 on a perfect day. |
The Judge
posted 02-10-2005 03:36 PM ET (US)
Nothing wrong with a 50 on a 13 but you are pretty much wasting money. That hull was designed to run a 25hp and do it at about 30mph. A 40 will give you 35+ and a 50 might fetch you 40+ if you set it up right. The main differences between all of them is handling loads. With 4 adults, you won't plane out with a 25 or just barely. Then again if you run with 4 adults in a 13, you need a bigger boat:).If you put a 70 on that boat I doubt it would not do 50, can't make a barge fly. |
de
posted 02-11-2005 09:02 PM ET (US)
I've got a '65 13ftr with a new F50 Johnson. To heavy, and kind of scary at WOT for me. .... she's smooth and quiet though. The main issue for me is the weight ... you can always pull back on the throttle. Maybe I'll take her out tomorrow and see what she'll top out at. It ain't 53 ... but it probably seems like it being that close to the water. I've been on bass boats running 75+ and feel safer than my little 13ftr running in the 30s.Some pics here .. http://boston.gotdns.com/whaler
mcollinstn
posted 02-15-2005 02:56 AM ET (US)
A 13' sport WILL run over 50. As any Whaler racer will tell you, though, you gotta knife edge the keel rudders or else they try to climb on top of the water in a scary manner... |
BQUICK
posted 02-16-2005 05:01 PM ET (US)
Tell me more about "knife edgeing the keel rudders".I've got a 71 Sourpuss with a 1970 50 Merc with power trim. I have to trim the motor WAY out to run 48 mph and it will chine walk. I was thinking of taking the "hook" out and the knife edging sounds interesting. What are the keel things for anyway? Turning is my guess...... Bruce |
