ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Twin E-TEC's for an 18 Outrage
Author | Topic: Twin E-TEC's for an 18 Outrage |
Roarque |
posted 03-30-2005 08:27 PM ET (US)
With the 60 HP ETEC weighing in at 240 lbs, why not repower my 18 Outrage with two of these babies instead of the 115/140 Suzuki at 420 lbs PLUS a 100 lb kicker. Another advantage to Evinrude. Low weight/horsepower ratios eliminates the redundant kicker issue. At a price..... ;-) |
LHG |
posted 03-30-2005 08:50 PM ET (US)
The 4-stroke Mercury EFI weighs the same, at 248#, so that, and the Yamaha version of same engine, are also worthy of consideration. I have no idea how the various engines stack up performance wise, but either are minimum HP for an 18 Outrage in my estimation. You'll be cruising at an uneconomical high RPM most of the time. I'd go for the twin Evinrude 75's or 90's, which at 325# is pushing the transom loading, but it should handle it. Adequate twin, clean HP on an 18 Outrage is getting to be a challenge these days, unles you quickly buy some conventional 2-strokes like the Yamaha or Merc 75/90's. The old Johnson engines are fine too, but don't have the integral oil injection tanks, a real rigging disadvantage. Tohatsu DFI 90's are also out there, but that brand has a slim service network and the engines tend to be light on performance |
Roarque |
posted 03-30-2005 10:16 PM ET (US)
I was reading jimh's thing on the ETEC infomercial and presuming the technological advantage of the 2-stroke would exist at the 60-75 HP range. That is, better power for acceleration from standstill and better emissions than the 4-stroke. I'm fascinated by the concept of the ETEC design as is Mr Moderator, obviously. It makes the competition between vendors more interesting. The two North American vendors have re-established their competitive position with technology - even if the early technology came from Europe, we engineered it and brought it to market in "America". On the other matter, LHG, my experience with the 18 Outrage hull is minimal - are you saying that twin 60's would be a bad choice but twin 75's would be OK? |
Sheila |
posted 03-30-2005 10:53 PM ET (US)
Roarque, I know this point has been brought up before, but--If your twins are tied in to the same electrical and fuel system, you may not have a lot of "redundancy" there to depend upon in an emergency, as a "motor" failure is often an electrical or fuel problem. In my perfect world, my "come home" motor would be pull started and have a separate fuel tank. I'm halfway there.... |
Tom2697 |
posted 03-30-2005 11:19 PM ET (US)
If my memory is working, I believe 75 hp is the minimum hp required to plane this boat.... |
Peter |
posted 03-31-2005 07:37 AM ET (US)
Roarque, I tend to look at whether a given outboard motor is suitable, or a pair of outboard motors are suitable, by looking at two factors: total displacement and HP. In the case of the classic 18 Outrage, I think the minimum ideal displacement is 2 liters and minimum ideal HP is 120. While the pair of 60 HP E-TECs would meet the minimum HP threshold, they don't meet the minimum displacement threshold so I would not recommend that as a power choice. In my opinion, when considering twins, the displacment factor becomes even more important. If clean emissions and better fuel economy is not a requirement but twins are, I would consider slightly overpowering the 18 Outrage with a pair of light Yamaha 90 2-strokes (HP over 120, total displacement over 2 liters). While the Mercury 75 or 90 2-stroke is a possibility as they meet the thresholds, at 303 lbs each, I think they are borderline too heavy for the 18 Outrage. |
Bulldog |
posted 03-31-2005 08:51 AM ET (US)
My two cents. I have a 20' Revenge powered by two 1987 70 hp Yammies, I love it , we have pulled tubes and water skiers behind her with a bunch of people(7) in the cockpit, we got the water skiers up and got to where they were comfortable at about 30MPH with no real problem. She is not a fast boat hits about 36MPH and cruises at about a nice 24 MPH. Most twin engine boats have seperate electrical systems but not tanks, and I can pull start a 70 HP if I had two electrical systems fail at same time. I also am installing an emergency start relay to tie the two batteries together to start a motor with a dead battery from the helm. The fuel redundency issue is a little tough to get seperate tanks but I have seperate fuel systems with two sets of lines from tank through the two primer bulbs to the engines, so there is some redundency of all the fuel lines and connectors and primer bulbs. A kicker is only better if it has its own tank, and has enough fuel capacity to push that boat slowly home, I think in most cases people tie the kicker into their main tank, if any of us get a bad tank of gas, well then neither setup would work. If I were repowering today the 75 and 90 hp E-techs would be a consideration, with the 90 winning because it weighs the same and comes in the saltwater version, but all the new engines are getting heavy and the classics aren't rated for too much weight. I would add about 200 lbs. to the back of my boat , but I could relocate the batteries front which should help a bit. As for the HP I wouldn't hesitate to repower with twin 75hp engines, of some type of clean technology engine. I wish the E-tech 75HP was more in the 60HP weight range.....As you can tell, I'M A TWIN GUY, I have a better feeling running out the inlet with twins then with a single,I think the outrage would work fine, but it is not my money ,long 2 cents huh?.............Jack |
kglinz |
posted 03-31-2005 10:24 AM ET (US)
I don't think you need to worry about "redundancy" on an E-tec. The most reliable motor ever made. Can't you cut the fuel line and keep going for hours after you pull start it. |
mfrymier |
posted 03-31-2005 10:30 AM ET (US)
I too am considering twin ETEC's on an OR18. I hadn't thought about going down to 60hp, which is a good idea from a weight standpoint. The 75 and the 90 weigh the same. A question: Are twin 60HP motors exactly the same as a single 120HP motor, assuming they both weigh the same? It seems to me that two propellers should give you more thrust, and more "hole shot", thus decreasing the actual amount of horsepower needed to plane, cruise, etc. Someone help me with that one... Sheila -- one cool thing about the ETEC's is that they can literally be pull started if your batteries die. If you are willing to bring along (or mount) a spare fuel tank (perfect under the RPS!), you could literally have a redundant fuel system as well. Maybe not for "far" offshore use, but enough to get you home in most situations. |
Roarque |
posted 03-31-2005 10:43 AM ET (US)
Peter, is there a difference between 2-stroke cc's and 4-stroke cc's? I've been told that 2 stroke engines have a better "hole shot" than the 4 stroke so I assume that means the 2 stroke engine has a different rpm versus engine torque curve shape than the 4 stroke. Does your criterion for cubes differentiate between the two engine design concepts? |
Buckda |
posted 03-31-2005 10:57 AM ET (US)
Well, I guess I'm in this boat too. I've been mulling a repower in the next couple years, and right now, my mind is on the twin-E-TEC 90 HP motors. Here's why: While 75 HP is the minimum recommended to operate the 18' Outrage, with the added weight of the second "dead" 75 E-TEC you could likely not achieve plane - since it's the minimum HP. I'm not 100 percent convinced yet that twin 90's would achieve plane on one motor, but believe that if propped right (for torque instead of speed) you may be able to do it. The other thought is the performance with both motors operating. While the twin 75 HP puts you at the recommended max HP of 150, you're fighting extra weight and extra drag of the second motor. "overpowering" slightly to 180 HP helps you overcome this and operate the motors at a lower RPM range, extending the life of the motors. LHG has twin 115 HP motors on the back of his 18 Outrage. They weigh about 305 pounds each. They're also set back about 8-10 inches, and he has batteries (say, 40 pounds each?) back there. Even if he only has one battery back there, the weight of twin 90 HP E-tecs (at 326 pounds each) with batteries in the console (as they are on mine) should be roughly equal. I know - this is heavy - lots of weight on the transom! I think that with proper trim techniques, you can overcome the apparent effects of the weight on the transom...however small trim tabs may be necessary to bring the bow down completely in some conditions. I believe it would be a good combination to have back there. I was hoping that the Verado came out lightweight and ready to fight, but for the classic 18 with twins, it looks like Optimax or E-TEC is the only way to go. |
Perry |
posted 03-31-2005 12:18 PM ET (US)
kglinx, when you say that the E-TEC is "The most reliable motor ever made", what do you base this on? The Evinrude infomercial? Doesn't reliability need to be determined after many years of trouble free operation? I am not bashing the E-TEC but wondering how a motor in its first years of production can be labled "The most reliable motor ever made" |
kglinz |
posted 03-31-2005 12:39 PM ET (US)
Perry I learned from the "infomercial". It's got to be true. Canadians never BS. Its just of those basic facts, like: "The Earth is flat", We never went to space, it was filmed in Hollywood, and 4 strokes have too many parts and will never last. |
hwnwhaler |
posted 03-31-2005 02:56 PM ET (US)
Perry, I was thinking the same as I read that. I guess his sarcism flew right over our Island and heads! LOL John |
Perry |
posted 03-31-2005 03:10 PM ET (US)
Yea John, I guess us island folks are a little slow in the morning :-) |
fourdfish |
posted 03-31-2005 03:25 PM ET (US)
Looks like both Perry and hwnwhaler both got hooked!! PERRY, I have to correct you on the E-TEC history. This is actually going into the 3rd year of production for the 40-90hp engines. Only 1 owner on this forum has had a major problem with the engine and BRP took care of it and he is still happy with the engine. Looks like you guys are not keeping up!!!! |
Joe Kriz |
posted 03-31-2005 03:57 PM ET (US)
I just happened to talk to my Evinrude dealer this morning asking him when the E-TEC 150 was going to come out. I also talked to him about the E-TEC 90 and if he had any problems with any of the engines he has sold. He said NONE... No returns, no problems. I mentioned the problem that one of the forum members here had and he said that is the first one he had heard of. For What It's Worth. |
prj |
posted 03-31-2005 04:18 PM ET (US)
No horse in this race, but I'm guessing that within this forum, fewer than 10 E-TECs total are owned. Let's say 8 units, with 1 failure. That amounts to a 12.5% failure rate. |
mfrymier |
posted 03-31-2005 06:06 PM ET (US)
Anyone else notice that Kriz didn't tell us his dealer's answer on the 150HP availability date? C'mon Kriz, give us the goods! Are you going to horde these E-TEC 150's like your swivel seat collection???? Matt from Semi-Northern, Sort of Central California. ; ) |
Joe Kriz |
posted 03-31-2005 06:23 PM ET (US)
Matt, I am a Pack Rat... But no, I won't be hording those E-TEC 150's. I might let you buy one from me... :-) The dealer told me there is still no date set for delivery on the 150's or even on the 115's. What did one buzzard say to the other buzzard? Later, Joe |
LHG |
posted 03-31-2005 07:17 PM ET (US)
The 150 has got to be be behind the 115, which at least had a prototype at the Miami show. With not even a prototype, the 150 (and 135 & 175?) must be well over a year away from the consumer. Maybe they saw what an incredible dual overhead cam 4-stroke machine the 135, 150 and 175 Verados are, and just decided to hang it up! There are tons of great 150's on the market today, 2 stroke carb (Johnson, Merc, Yamaha), EFI, OX66, Optimax, HPDI, conventional 4-stroke and supercharged 4-stroke. It's unlikely that, even once introduced, the E-TEC would be be rated HIGHER than all of these. They are a little late to dance, it seems. So why wait at all, except for good ol' OMC brand loyalty, and for that, why not a Ficht Ram 150? |
Peter |
posted 03-31-2005 08:09 PM ET (US)
Rourque - Criterion applies to 2 or 4 stroke. Best results are with at least 2 liters of displacement. Larry - The rumor I heard as to why the E-TEC 150 is delayed is that the Evinrude team is still recovering from rib injuries sustained in Miami that were caused by laughing too hard when the weight of the Mercury 4 cylinder Verado was revealed to the public. ;) Seriously, I wonder whether the delays have something to do with military purchases of the MFE capable variety. I just happened to look at their government products website and note that the product line includes the 115 and 150. As an aside, what is quite interesting to see in that government products bulletin is that Evinrude offers a direct injection version of their bullet proof 2 cylinder cross flow 30 HP motor. The basic design of that motor has been on the market since 1976. Assuming the 122 lbs specification is accurate, it weighs the same as the carbureted Johnson version. Twin 30 HP E-TECs for a 17 Montauk anyone? |
posted 03-31-2005 08:19 PM ET (US)
What is hard to understand is how all of a sudden there is a total flip-flop in the marketplace from two-stroke to four-stroke. Imagine for a minute if the E-TEC were a four-stroke. Let it have all the same specifications, the same weight, the same emission, the same fuel economy, the same size, the same noise, just pretend for a minute it was a four-stroke. Oh my heavens! The praise would never stop. People would be agog. They'd be amazed. Here's this engine that weighs less, that is smaller, that is just a quiet, just as fuel efficient, and actually runs faster with more low-end torque. And it does not need any maintenance for THREE YEARS. And it has a SEVEN YEAR WARRANTY. You'd never hear the end of the praise for it. All of the rest of the four-stroke guys would be headed back to the drawing board to try to catch up. But, for some odd reason, because the darn thing is a two-stroke engine--just like all the two-stroke engines that have run for years and years in recreational outboard use, just like the 13-year-old engine on my boat or the 14-year-old engines on LHG's boat--because this thing is a two-stroke engine somehow all of these advantages get looked over like they didn't mean a thing. All of a sudden if you're a four-stroke engine it is OK to be really huge, it's OK to be very heavy, it's OK to need regular oil changes and adjustments, it's OK to add 200 parts to the cylinder heads, it's OK to have exotic variable valve timing, it's OK to have 24 valves, etc. And how come the 225-HP four-stroke engines, which have only been in service for a year or two, are suddenly looked upon as being capable of twenty year life spans? Where did that notion come from? From experience with a 8-HP four-stroke? |
Roarque |
posted 03-31-2005 08:44 PM ET (US)
Dealer I visited today had the infomercial. They were sitting around watching it when I walked in. There were no line-ups at the cash register but hope in their eyes as I told them I wanted to learn more about their new baby. They didn't have a 60 HP in stock, only 75s and 90s which I checked out flipping off the cool new lids. Nice looking engine layout. I can actually see the spark plugs! I could probably change them all by myself! Gee, I love 2 strokes! They phoned the factory and found out the promise for delivery of the 60 HP ETEC is end of June because "they're having problems with the cylinder liners" on the larger engines and the engineers have stopped production of the 60s until the problem is resolved. They suggested I use two 75s for the Outrage 18 until I asked them to check the weight of the 75. Then they told me there was going to be a 2 cylinder 70 HP ETEC. By the way, wouldn't a 70 HP engine that measures its HP at the prop be equivalent to an older 75 HP that measured its HP at the flywheel? |
Roarque |
posted 03-31-2005 08:49 PM ET (US)
Oh, another thing, the 75HP ETEC was $6125. in US dollars in this shop.... |
Peter |
Since weight is now completely unimportant as evidenced by the new recent highs achieved by Mercury, I think I just solved Evinrude's E-TEC 150 problem. All they need to do is to put a governor on the throttle of the 524 lbs 250 E-TEC so it can't be opened up to more than 60 percent and change the "2" to a "1" and --Voila-- instant E-TEC 150. Just add water and your ready for brutal head to head competition with the still not available for purchase but absolutely "incredible dual overhead cam" supercharged 527 lbs 4 cylinder Verados. |
kglinz |
posted 03-31-2005 10:12 PM ET (US)
Jimh I think a lot of people feel they can get good service from their V-6 4 stroke by looking at their Honda sitting in the driveway, with 150K miles, and no maintance ever done except oil changes. I know outboards are run harder than cars, but modern a 4 stroke engine with electronic control and EFI is about as reliable as any equipment around. Sometimes a car, run hard on the hiway, outlasts a city driven car. |
macfam |
posted 03-31-2005 11:27 PM ET (US)
jimh, That was about as well spoken (written) as any opinion I've heard in a long time. Why in heavens name would anyone overlook an E-TEC vs 4-strokes. All I can think is that when the major brands came out with the quiet, smokeless, smoother operating 4-strokes it gave the 2-strokes, not only a bad name, but the status of the red-headed stepchild. Two-stokes became a "step-down", the "second choice". It was revolutionary. |
Joe Kriz |
posted 03-31-2005 11:47 PM ET (US)
That was excellent jimh. Many people in the business that I talk to still maintain that the 4 Strokes are eventually going to need to install a Catalytic Converter to meet future EPA standards. (especially CA) Just look at the infomercial. 58,000 parts per million of CO at idle for the Verado and 600 parts per million for the E-TEC. That's a huge difference. Question: Peter, Macfam, |
Chick da Barba |
posted 04-01-2005 08:38 AM ET (US)
You nailed it Jim! My sentiments exactly. Chick |
Peter |
posted 04-01-2005 08:54 AM ET (US)
Joe - That really would be one heck of a 150. It would have the hole shot capability of a 250 (no other 150 would come anywhere close) and would theoretically far outlast the supercharged 4-stroke competition since it won't have to spin in the 6400 RPM range to produce 150 HP. I estimate that WOT RPM for the 150 E-TEC HD (HEAVY DUTY) to be 4000 RPM and cruise will be around 2500 RPM. I'm willing to go out on a limb here too and suggest that it might be more fuel efficient at WOT than the supercharged 4 cylinder 4-stroke. With respect to emissions, I suppose the the 4-strokes could use direct injection to avoid the catalytic converter. Either way they go, that means the 4-strokes will get even heavier and even more complicated than they are now. |
LHG |
posted 04-01-2005 02:34 PM ET (US)
Jim's hypothetical 2-stroke vs 4-stroke situation is actually now fact, in several HP ranges, and the 4-strokes are winning the war. The Yamaha 4-stroke 150 weighs 2# LESS than the Yamaha 150 DFI. And it costs about $600 LESS, and performs as well (according to Yamaha). It's obviously selling like hot cakes, and probably selling better than the 2-stroke HPDI model. It is about a "battery weight" heavier than Merc's 150 Optimax, and Merc's 150 Verado is about a "battery weight" more than the Yamaha 150 4-stroke. So Mercury has both a 431# 150 and a 505# Verado 150, nicely covering the weight spectrum, with Yamaha in the middle, which in reality doesn't matter that much anyway in single engine applications, to most buyers, where the majority of 150's are used. I would guess the Verado 150's will soon be outselling the lightweight 150 Optimax (what will the 150 E-Tec weigh?), which is currently the fastest clean 150 on the market (don't know how it compares to the Verado yet). Note: all weight figures are from current catalogs, on 20" engines. As for Peter's idea, since the Mercury 250 Optimax is 30# lighter than the 250 E-Tec, Mercury could also bring out a nice 3.0 liter 150 HP version of this engine, and still be lighter than the Verado 150-175. Generally, "cheater" drop-down versions of large cube engines are fuel pigs. This has often been done in the 20" bass boat market. Currently, Mercury just offered a new 3.0 liter "cheater" 200 EFI for that market, on a block that can easily produce up to a true 277 HP, but don't expect it to be economical to run when compared to the 2.5 liter 200 EFI. But I'll bet it really moves out on a boat rated for 200HP. Bottom line is that the marketplace is consistently proving that weight DOESN'T matter, and most buyers now want 4-stroke outboards. |
fourdfish |
posted 04-01-2005 03:40 PM ET (US)
LHG wrote "weight DOESN'T matter" This is one of the most ridiculous things I have ever read. Most of the people on this forum have a boat and know that weight is a huge factor in a boat. All of his argument has only to do with selling Mercury 4 stroke engines. An article in the new April 2005 issue of Trailer Boats Mag Page 42-48 which shows different engines on the same new boat illustrates performance differences with different weight engines. This company will not even offer thier boat with a 4 stroke engine. These are not even Verados which weigh much more than LHG would have you believe. I'm sorry but after reading most of his posts I think LHG only cares about Mercury.(You have to wonder why?) The E-TEC is sour grapes to him and many times he is not at all objective in his posts. He does not offer real life experiences with a Verado on his boat so we have to assume he does NOT have one. Many boat owners on this forum are fisherman like myself and are not interested in supercharged engines. They will help determine the market for outboards not LHG. I don't pretend to know the future but I know that a free market place will determine the future of outboards. |
Peter |
Larry, I don't think you can necessarily say that what applies for EFI in terms of fuel pigishness necessarily applies to DFI. I've run both types of 225 HP engines and fuel consumption is a whole different ball game when it comes to DFI because the exhaust port is closed when fuel is introduced. The point of the exercise was to show the vulnerability that excessive weight has in an outboard design. The new 4 cylinder 4-stroke Mercury's excessive weight has made Mercury's new products quite vulnerable to easy competitive attack from a variety of directions. To just pick a nit here -- last time I checked the weight spread between a 2-star Optimax 250 XS and a 3-star 250 E-TEC was 11 lbs not 30. For that extra 11 lbs you get an extra 0.3 liters of displacement in the E-TEC. |
mfrymier |
posted 04-01-2005 03:51 PM ET (US)
My wife likes steak, I like chicken.... I like sailing, my sister likes motoring... LHG likes 4 strokes, JimH likes E-TEC's.... [hum your favorite patriotic anthem now] Don't you just love America? The best thing about capitalism is that if there is demand for your product, you can sell it. I GUARANTEE that good, clean versions of 4-strokes and 2-strokes will continue to exist, side by side, for years to come. It's why they make cars in different models and colors! One observation: I don't think it is fair to compare an Optimax to an E-TEC as "apples to apples clean 2 strokes". I like the optimax line, and think they will continue to sell. However, the E-TEC's are quieter, smoke free, more fuel efficient, and hypothetically require less maintence (but with a nod to LHG, we don't really know yet do we?). I agree with LHG that "most buyers want 4 strokes", but I also agree that is generally because "old style" 2 strokes were loud, noisy, polluting, etc. "new style" 2 strokes such as the first generation DFI motors addressed some of these issues, and the E-TEC addresses all of them, including the DFI elecrical load issues. The big question will be if Bombardier's "infomercials" etc. can get people to buy 'em. Witness LHG's opinion -- he is far from alone. As for me, I will buy an E-TEC 150 for my OR18 when they become available, unless Kriz and JimH buy them all and put them on ebay for a premium ; ) I will have a 1990 150hp black max for sale that day -- great, bombproof two stroke that someone else will love for another 5-10 years. Capitalism at it's finest. p.s. this forum makes me laugh at least twice a day, and that is a very good thing p.p.s. I say we start a new thread "guess the weight of the E-TEC 150, win a pile of jellybeans" |
LHG |
posted 04-01-2005 06:41 PM ET (US)
Fourdfish, I have always spoken highly of you. |
Perry |
posted 04-01-2005 07:40 PM ET (US)
"The lightweight 150 Optimax is currently the fastest clean 150 on the market" Is LHG's statement true? According to Boston Whaler's performance data, the Nantucket 190 equipped with a 150 Optimax will top out at 44.5 mph. According to a thread I read not too long ago, Sal A's Nantucket 190 with a Yamaha F150 tops 50 mph on gps. If this info is true, and I have no reason to believe that it is not, the 150 Optimax is not the fastest clean 150 on the market. It may not even be the second fastest because I have heard from another forum member that his Nantucket 190 with a Honda BF150 can reach 49 mph per gps. |
LHG |
posted 04-01-2005 08:29 PM ET (US)
Well, then, not being aware of those Forum reports, I guess it does mean that 4-strokes are taking over the performance sector of the market, too, and these 2-stroke DFI's just aren't cutting it. No wonder Mercury developed the supercharged Verado. I think a Boston Whaler person might have told me that a 150HP Optimax pushes the Nantucket to 50 MPH, but I'm not sure my memory is holding up there, since it was two years ago. Their published figures as given by Perry have to be taken as fact. |
Joe Kriz |
posted 04-01-2005 08:41 PM ET (US)
Perry, The 150 Optimax is NOT Carb 3 rated. Not clean enough for California. Last month I made this Quick Reference Guide up for the Outrage 18's. http://users.sisqtel.net/jkriz/drawings/Outrage18-QRG.html Here in California, we could not purchase the 150 Optimax. The only 2 Strokes we can buy are the E-TEC's and a few of the smaller Optimax's like the 115 and the 135... |
Perry |
posted 04-01-2005 09:31 PM ET (US)
LHG, take them for whatever you want. Their published figures are on their website, check them out for yourself. Like fourfish, I too am amazed at the lack of objectivity in your posts. There are many fine outboard motors out there, including Mercury. Why don't you acknowledge that fact. Here is a clip from the thread I was referring to: I test drove Sal's boat today after installing the new motor. I started off with a 13 3/4 x 17 ss yamaha prop. Top speed was 46 mph with the engine bouncing off the rev limiter. Next up was a 14 x 19 Merc vengance ss prop. Top speed increased to 50.5 mph at 5800 rpm's. All speed readings came directly from Sal's fixed mount gps reading miles per hour" http://continuouswave.com/ubb/Forum8/HTML/001837.html
fourdfish |
LHG-- Contradicting yourself again!! You have been a member since the year 2000 and post regularly. Still, you say "and not being aware of those Forum reports". Then you say " I think!! "a Boston Whaler person might have told me". Confronted with this you accept Perrys post which quotes Boston Whalers own data. Then you give your own sweeping opinion again that 4 strokes out perform all the DFI 2 strokes when in fact the few tests done with the E-TEC do not show that. Then back with the heavy Verado!! It really sounds like a Mercury infomercial to me!! |
posted 04-01-2005 10:10 PM ET (US)
Two important additions to my comments about: After I wrote this about the E-TEC, I thought the same attributes apply to the OptiMax, too. These fine engines deserve to be considered in light of their weight and performance. (The only areas where they are lacking is in noise and smoothness.) Where this fascination with the four-stroke comes from, I don't understand. Trolling at idle for ten years with an 8-HP four-stroke is not quite the same as running at 80-percent throttle with a 250-HP four-stroke, with 24-valves, with four camshafts, with variable valve timing, with superchargers, etc., for ten years. These comparisons to automotive engines are not particularly applicable. Most people do not drive up hill at 80-percent throttle while towing a trailer for hours and hours on end with their four-stroke automotive engines. The V-6 3.1-liter four-stroke automotive engine in my passenger car runs about 2000-RPM and is loafing along in overdrive on level ground most of its life. It goes 55-MPH and gets about 30-MPG. That is a fuel consumption of about 55 Miles/Hour / 30 Miles/Gallon = 1.8 gallons/hour By the typical fuel consumption rate for all internal combustion engines of 0.5 pounds of gasoline/hour/HP, that implies that I am using about 1.8 gallons/hour / 0.5 pounds/hour/HP * 6 pounds/gallon = 21.6 HP to drive my car at 55-MPH on level ground. I can assure you that if I operated a 225-HP outboard at a throttle setting where it was only producing 21.6-HP, I could expect it to last the equivalent of 100,000 miles or 100,000 miles / 55-MPH = 1,818 hours However, I don't think that in typical boating I am going to be using my four-stroke 225-HP engine at a throttle setting that produces about 21.6-HP. I am going to be cruising at 25-30-MPH or faster and running it closer to 60-80 percent of throttle most of the time, and I will be producing about 100-150-HP to do this. Thus I reject the notion that a car which runs for 100,000 miles with its four-stroke engine is an applicable comparison for a boat cruising along at 25-30 MPH. You are really kidding yourself to think that comparison to an automotive engine is applicable to your outboard motor, unless you putt-putt around at 7-MPH all the time. |
posted 04-01-2005 10:16 PM ET (US)
[Opps--had to fix my math!] |
kglinz |
posted 04-01-2005 10:57 PM ET (US)
Jim So how much more wear, on the valve train, do you get using 80% throttle when compared to 10% throttle at the same RPM. |
Bulldog |
posted 04-02-2005 09:02 AM ET (US)
Roarque, there is a lot of info and also some bashing on this thread, good thread though. The thing you stated about possible 2 cylinder 70Hp E-techs sounds like if they come out, they might be the way to go. Weight might be down at the 60Hp level, but I assume they might run rougher. I think the best thing if possible is wait a little bit, the technology is all changing so fast. It just seems like we should be able to build a 70HP motor today that would weight less, use less,smoke less, cost less, and even play DVDs then my 18 year old Yamahas!..........Jack |
Roarque |
posted 04-02-2005 01:18 PM ET (US)
Everyone, Thanks for your input. It doesn't solve my problem but does provide food for thought. Revs on twin 60s/70s would be an issue. Cubes on the E-TEC engines would be an issue. Both issues work to shorten the life of the engines and increase fuel costs. Come to think of it, I don't REALLY have a problem since the Outrage arrived with a 1986 vintage 140 HP Evinrude that the former said has been bullet proof and the VRO has been zero maintenance. However, it does smoke and it does drink and it is noisy - kind of like a teenager. Strong like a teenager too! Think I'll run the 'Rude for this summer and if I like the size of the Outrage then repower over the winter. I can always opt for a nice light Suzuki 140 and Sheila's kicker. Meanwhile the 15 Sport sulks in the garage having done nothing to deserve it's fate except be the sweetest little boat in my world for 20 years. Oh, and one last thing.....why are you guys so rude to each other? What's up with that? Pretend you're at a pub with friends and shooting the breeze. Smile when you write. |
LHG |
posted 04-02-2005 03:35 PM ET (US)
So, in conclusion, we have learned: 1. Twin 60's may be a little light for an 18 Outrage, although pefectly reasonable, and Roarque has decided to stay with what he has. 2. E-TEC 60's are still held up in production due to "cylinder liner problems on the larger engines" (which LARGER engines?), but the same weight 3-star EFI 60 HP 4-strokes, Smartcraft enabled, as designed and produced by Mercury, and also sold by Yamaha, have been around for 3 years now, and seem to be trouble free, with no cylinder liner problems. But we are still wondering why 4-strokes are selling so well and think the buyers of same are basically stupid. And, unrelated to his original question, we have learned: 2. Mercury's 2.5 liter 150 Optimax, based on Whaler's own testing, is shown to be a real poor performer when compared to several Japanese same HP and same displacement 4-strokes, which are also 3-star rated. Are we still wondering why 4-strokes are capturing the marketplace? 3. The yet non-existant Etec 150 performs just as well as the Yamaha and Honda 150's., even though the same cube Optimax won't. We don't know where the Yamaha 150 HPDI fits in. 3. A 3.3 liter, 2-stroke 150HP engine is a ridiculuous proposal. 4. The Evinrude affiliated people here continue to trash the Mercury Verado's, and most other 4-strokes as well, or anybody defending them, a lesson well learned from observing the now infamous infomercial commercial. 5. It's impossible to have a little fun on this website any longer. As indicated, personal rudeness and insults still prevail. |
DaveH |
posted 04-02-2005 05:51 PM ET (US)
Larry: I'm all for a successful technology advancement, but the Verado appears to hit the wallet in the performance tests for 225Hp engines on the Ventura 21. Where's the efficient technology? See below: Note the Verado plotted numbers do not equal the chart that Boston Whaler supplies. By the chart, it appears that the Verado gets 1.7 MPG and the Optimax 225 get 3.2 MPG at 4000 RPM. Me thinks something is rotten in Denmark. ;-0 |
Peter |
posted 04-02-2005 10:45 PM ET (US)
Sorry Larry, I don't think that we learned that the 3.3L E-TEC is a ridiculous proposal. If what you said before is true -- that the marketplace doesn't care about weight anymore -- then thanks to Mercury, this hypothetical 150 is quite a viable possibility and one that would be capable of producing a hole shot unmatched by the 150 HP competition. Isn't getting a better hole shot out of a 4-stroke really the primary reason Mercury went the small displacement, supercharged route? Or was it marketing? In any case, the hypothetical low reving 150 E-TEC HD would appear to have numerous advantages. Because it need not rev as high to make 150 HP, it probably wouldn't need to use as much oil for lubrication as say a higher reving, smaller displacement 2-stroke motor. Ridiculous? Due to its low reving nature, the hypothetical 150 E-TEC HD might be much quieter than the Verado and other 4-strokes at all operational speeds except for idle. As indicated by PowerBoat Reports, the E-TEC produces a sound pressure level of 85 dB at 4000 RPM (WOT for the hypothetical 150 E-TEC HD). The Verado 6 cylinder (no data on the 4 cylinder yet) produces a sound pressure level of 92 dB at 6250. It would be a reasonable assumption that the 4 cylinder running at 6250 RPM would produce the same sound level as the 6 cylinder or about 92 dB. Last time I checked 85 dB was quieter than 92 dB. Ridiculous? Because it need not rev as high to produce the same boat speed at all throttle settings, it would probably last far longer. Lasting longer is better than lasting shorter last time I checked. Ridiculous? The only disadvantage to the consumer that it seems to have is that it would be quite heavy by conventional 150 HP standards. Ridiculous? Perhaps. The disadvantage to the manufacturers is that it would probably never wear out in normal use and so it would not need replacing. Instead of thinking in terms of repowering a boat at some point in its life, you might need to start thinking in terms of reboating the E-TEC 150 HD sometime in its life (except for the case of long life Whalers where the life expectancy of the E-TEC 150 HD would be a very good match for the life expectancy of a Whaler). That is certainly ridiculous from the OB manufacturer's perspective. With a simple governing modification probably not costing more than a few dollars (as compared to millions of dollars invested by Mercury), Evinrude could have a 150 2-stroke with 4-stroke qualities that would be much more than a headache for the very heavy 4-stroke 4-cylinder Verado. When you think about it, using a 3.3L 2-stroke as the foundation for a 150 is really no different than the approach American car manufacturers took for decades with their use of large displacement, low HP, low stress V8s producing less than 1/2 HP per cubic inch of displacement. Would you say those designs were ridiculous? To point out the excessive weight of the 4 cylinder or 6 cylinder Verado in an objective fashion is not trashing the Verado, it is merely calling attention to what appears to be a huge weakness in the design. One way or another, weight still matters. If the effect of it doesn't matter on the static trim or boat balance or fuel economy, then, as I've said before, the excessive weight matters in that it leaves the competition door wide open to all kinds of less expensive and quite possibly better alternatives, including one you alone seem to suggest is ridiculous. The so called ridiculous hypothetical 3.3L 150 E-TEC is really no different in concept than the the practice of overpowering a classic 18 Outrage with a pair of 6 cylinder 115s (combination weighs 200 lbs more than a single 150 or 100 lbs more than a pair of 75s) except that in following the hypothetical, the 115s are governed so as not to produce more than 75 HP each by limiting the throttle opening and revs. Still think its ridiculous? |
fourdfish |
posted 04-02-2005 11:41 PM ET (US)
Right On Peter! It appears though that your points are lost on LHG. If you disagree with his statements and he is unable to back them up, he says it is rude and insulting. His unobjective opinion has been easy to recognize lately. From what I understand BRP has had problems produceing quality cylinder liners for the 60hp E-TEC(not larger HP engines as was earlier stated) which is why they are not being offered. As you can see, LHG used this to try to spread another rumor about the E-TEC. Read his earlier statement on another thread about the props used in the test as another example. I am not selling E-TECs nor do I care if anyone buys them, but LHG is obviously trying to sell the Verado. The last statistics I saw had sales of 2 strokes vs 4 strokes at about 50-50. Small boat owners prefer less weight and that won't change. When I see something I disagree with I will say so!! |
posted 04-03-2005 12:34 AM ET (US)
Fellas! Best to keep the focus on the boats and motors, please. That Ventura performance chart (see link above) is definitely off kilter from the tabular data in the Verado section. The Verado fuel economy seems to hold up very well at mid-throttle, but it drops significantly at WOT. The E-TEC seems to be just the opposite, getting its best fuel economy at WOT or at idle speeds, and falling off the mark in the mid-range. The four-strokes seem to have very good fuel economy across their RPM range. The Verado engine is not so much an engine choice as a whole new "power system" choice, because you also get the fly-by-wire controls, the power steering, and the all-digital instrumentation. It moves the outboard powered boat to a new level of performance, which, of course, comes at a price. To make the discussion even more roiled, what about the new Suzuki 150-HP engine? It should be available in late summer, will be an in-line four cylinder, and have a displacement of 2.867 liters. |
Perry |
posted 04-03-2005 03:04 AM ET (US)
Interesting point about the new Suzuki 150 4 stroke. Was it only 2 years ago that there were no 4 stroke outboards in the 150 HP range? With the introduction of the Suzuki and Verado 150 4 strokes, it will mean that there will be no less than 4 different brands of 150 HP 4 strokes on the market. What will this do to the 4 stroke / 2 stroke market? If it was 50/50 last year, what will it be in 2005? |
fourdfish |
posted 04-03-2005 10:53 AM ET (US)
Perry- Thanks for bringing up that fact. We all know that the production of 4 stroke outboards is a direct result of the US emmision regulations. Why would any of the outboard manufactures change over from 2 stroke to 4 stroke unless they had to? The end of this year will probably see the last of traditional 2 stroke engine sales in the US. In a way it is sad! However, good for the enviroment! So! that being said, it is obvious that 4 stroke sales has been increasing and will soon far outstrip the 2 strokes. That leaves only a couple of options left. Most think Mercury plans to leave the Optimax line and switch over completely to the 4 strokes. That leaves the E-TEC. Several fisherman friends of mine are planning to buy new traditional 2 strokes while they can still get them.I have 3 traditional 2 strokes left which run well and I'm not getting rid of them. Baring unforseen problems, the E-TEC will be an alternative to the heavier 4 strokes in the future. Does that mean we have to love the 4 strokes??? |
