ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Prop recommendations for 1986 Evinrude 90HP on Montauk
Author | Topic: Prop recommendations for 1986 Evinrude 90HP on Montauk |
wjriling |
posted 06-07-2005 08:53 AM ET (US)
Hello all, Any recommendations for aluminum propeller for 1986 Evinrude 90HP on my Montauk? Size, brand, etc. Thanks for all your help! Regards, |
Teak Oil |
posted 06-07-2005 09:58 AM ET (US)
Please use the search function, this has been talked about many many times. I like OMC aluminum props and use a 13x19 for light loads |
Tollyfamily |
posted 06-07-2005 12:59 PM ET (US)
Same setup with 13X17 gives me 5500 rpm. Dan |
WHALETEX |
posted 06-07-2005 01:21 PM ET (US)
The stock OMC 3 blade aluminum in 17 pitch for Montauks with moderate loads and skiing. Same prop in 19 pitch for light loads. For very heavy loads (maybe overloads) I have used the same prop in a 15 pitch to pop the boat up, but you must watch the rpm to keep from overreving once on plane. These props are readily availble used and rebuilt at most prop shops, boat dealers, and on the net and they represent a good value. A good setup is both a 19 and 17. Put the one on the motor that best fits the need of the day and keep the other aboard for a spare. Also keep several spare cotter pins (don't reuse), a spare nut, spare washer that goes under the nut, a spare thrust washer that goes behind the the prop, and a wrench to fit the nut. |
posted 06-07-2005 01:38 PM ET (US)
There are more articles and threads about the propellers and performance for MONTAUK 17 than any other boat model, and most of those are for a 90-HP situation. My advice would be to read some of those previous articles. Or just get a three-blade 17-inch pitch and start from there. |
LHG |
posted 06-07-2005 08:04 PM ET (US)
With a Merc 2-stroke 90 on a Montauk, the aluminum prop of choice is a 21" pitch, 2.33 gear ratio. But it is a poor performer compared to an SS model. |
The Chesapeake Explorer |
posted 06-07-2005 09:31 PM ET (US)
13 1/4 X 17 ! |
posted 06-07-2005 10:27 PM ET (US)
Here are 90 other discussions on propellers, Montauks, and 90-HP: http://continuouswave.com/cgi-bin/sw.pl?Search=propeller+montauk+90-HP |
posted 06-07-2005 10:30 PM ET (US)
If those articles aren't enough, try this one, with leads to many more: http://continuouswave.com/whaler/reference/16-17/repower.html |
rumrunner |
posted 06-14-2005 04:50 PM ET (US)
Interesting. 1986 90hp Evinrude on Montauk, 13x19 prop, WOT 4200 rpm 32 s.o.g according to GPS Seems like you guys do quite a bit better. Thinking of switching to a 13x17 to go skiing and tubing. |
Teak Oil |
posted 06-17-2005 09:19 PM ET (US)
rumrunner your engine is performing very poorly and certainly needs to see a mechanic. Only getting 4200rpm I bet you are not even running on all cylinders |
Joe Kriz |
posted 06-17-2005 09:40 PM ET (US)
We haven't seen wjriling here in 10 days so I don't know if he is still interested.
The only thing that matters is the pitch... Let the engineers keep track of the rest. Example, cupped, double cupped, etc... Just think about pitch in the beginning. I agree with Chesapeake Explorer and jimh, try a 17 pitch OMC aluminum prop. rumrunner, I had the same problem on my Montauk as many others have had by the dealer installing the engine using the blind holes and the engine was mounted all the way down. I never did raise my engine because I did not want to fill the holes. Many times though, I wished I had. Two factors on getting your engine up to the recommended WOT RPM's is the prop and the mounted engine height. For the engine height... First rule of thumb is make sure you are not throwing a large rooster tail from the cavatation plate.. This will tell you immediately your engine is too low. Let us know what you come up with and make sure your tach is working properly when you run the tests. |
rumrunner |
posted 06-18-2005 08:51 AM ET (US)
Joe, Good suggestions here. I'm going to go through each of your points. I noticed on a couple of occasions late last summer the tach (which is a 6000 rpm tach) fluctuated a little, so I had the OMC shop check it out this winter. Naturally, when they did there was no problem. Teak oil, the reason I don't think it is a powerhead issue is that it is about 5 hrs. out of a tune-up, carb rebuilding, thermostat change and everything was fine. It runs absolutely flawless in terms of starting, acceleration. Has 300 hrs on it, and compression on all cylinders is excellent. Did have some water issues in the fuel this spring, but the Racor filter seemed to straighten that out. It is definitely running on all cylinders, and gives absolutely no indications of having any powerhead issues. That's what has lead me to suspect prop/trim/mounting combo is to blame. I'm curious to see the difference the 13x17 will make. Bottom line, I'm more curious than concerned. A top end of 4200 rpm doesn't cramp my style for what I do, and the waters I'm in usually prohibit running anything close to that anyway. |
Joe Kriz |
posted 06-18-2005 04:34 PM ET (US)
rumrunner, Here is the answer to your curious question that way I see it. You can run almost any prop on your boat at 3,000 RPM. Is it the right prop? Look at it like this. How much work is your engine doing to keep the rpm's at 3,000? The engine may be working too hard even though it is running at 3,000 rpm. In this case, even though the motor is running 3,000 rpm's, it is working too hard. Maybe not getting the optimum fuel mileage, etc... The engine manufactures list the WOT rpm's in their manual for a reason. You want the right prop to achieve the correct rpm's for your particular engine. What tach are you using? Even though many brands are being sold and used for, let's say OMC, I would suggest and OMC tachometer. That's just my opinion. OMC designed the tach for their engines and that is what I stay with. You can buy them brand new on eBay fairly cheap if you don't have an OMC. Second, get the right prop. I would start trying the 17 pitch OMC. Try borrowing one from someone first. When you get the right prop, you should be between 4500 and 5500 (read your manual to make sure about this) rpms at Wide Open Throttle with a light load and between 1/2 to full fuel tank(s). |
rumrunner |
posted 06-18-2005 06:34 PM ET (US)
Joe, All good points, and well taken. Re the tach, it is o.e.m., so I "assume" it is OMC (or endorsed by them), however, in absence of a logo on the face of it, can't be sure. I'm going to try a 17 prop out of curiosity (need a spare anyway), and see how that works. Like I have said, don't feel as if there is a problem with the engine, just a matter of optimal prop/trim I believe. Thanks for all the input! |
