posted 10-18-2005 09:49 PM ET (US)
It occurs to me that marine engine manufacturers who work closely with particular boat builders have the opportunity to optimize the performance of their electronically controlled engines for specific applications. This is routinely done in automotive applications. For example, the 5.7-liter V8 engine in my GMC truck very likely has a different set-up in its electronic controller than the 5.7-liter V8 in a Cadillac sedan. Although they are the same basic engine, their performance has been optimized for a particular application or vehicle. It has been tuned for a particular transmission, axle ratio, and vehicle weight. Why not with boats?It seems reasonable that Mercury Marine could work with Boston Whaler, for example, and develop a specialized fuel map and control algorithm for a VERADO 250-HP engine when used on a CONQUEST 235 with a particular propeller. This might be different from the settings which would be optimum if you wanted to use that 250-HP engine on very fast bass boat.
One thing that might prevent this from happening is the cost of certifying many different engine versions with the EPA. Complex regulations about emission are already a hurdle to overcome for outboard engine makers; having to qualify several different models of the same basic engine could be expensive.
Historically, I did find some precedent for this with OMC and the Ficht engine. A dealer told me that there were plans for this sort of thing, but they never were implemented.
We have already seen how manufacturers use changes in the EMM programming to make one engine into two or three models of different horsepower. Honda (and others, no doubt) turn a 135-HP into a 150-HP just by changed some code stored in a controller. Why not add more refinement and tailor engines for particular applications.
And, for the suspicious among you, perhaps this sort of things is already being done. Who is to say that the engines that get tested at highly-publicized magazine "shoot-outs" are running on the stock fuel maps which were used for EPA certification? How would a magazine editor know?
