Topic: YAMAHA 90-HP: Installation Advice on MONTAUK
capedave |
posted 10-23-2005 06:24 PM ET (US)
[What length engine control cables are recommended for a MONTAUK?][Are MORSE brand cables better than YAMAHA brand cables?] Picking up the new [90-HP YAMAHA] engine from the shipper tomorrow. Ordered 90 OB. tac kit, switch kit, wire kit, single console mount control, and a 17 pich prop. This is going to be instaled on a 1982 [BOSTON WHALER MONTAUK 17], will rewire and straighten out a few things, new switches for lights etc. I know and have read on mounting heights. Any other pitfalls or pointers to give if you have done the intall???? Thanks all Dave
Teak Oil
posted 10-23-2005 09:13 PM ET (US)
Get some 5200 to seal the bolts in the transomI dont know if Yammies have an "eye" avail for hanging the engine, but getting one and using an engine hoist is the way to go. |
David Livingstone
posted 10-23-2005 09:36 PM ET (US)
Capedave, you might want to use 3M 4200 and not the 5200. If you use the 5200, you might have a though time taking off the bolts in the future. Your washers will be glued to the transom.All the best with the install, David |
posted 10-23-2005 10:57 PM ET (US)
I don't know about YAMAHA outboards, but Mercury and Bombardier publish extensive installation guides for their outboards. Be sure that your dealer delivers your new engine with all the literature that is supposed to come with it.You should receive a detailed instruction manual which will provide you with all the information you need. If you do not, make inquiry with your dealer. BOMBARDIER, for example, publishes a very detailed and thorough guide to installation of their engines. This publication has dozens of illustrations and runs on for 50 pages or more. It answers all your questions. Again, I don't know if Yamaha has this available. Historically it has been very difficult to pry information from them. A few years ago they refused to sell their customers the Yamaha service manuals. I guess they figured they were helping their service providers by keeping this from the customer. |
SIM
posted 10-24-2005 08:57 AM ET (US)
Yamaha does publish there own "Outboard Rigging Guides". They have every year since I have been a dealer...1999. The literature that comes with all of those rigging components is kind of vague. As far as the engine main wiring its all kind of plug and play. The harness's only fit one way. Most of the time the engine control cables end up being the same length as the boat. Yours will be in the 16-18ft range. Yamaha and Morse cables are the same. Either will work and I don't see any significant cost difference between them. Morse are red jacketed and Yamaha's are blue. They match the engine color if that matters to you..... Whoever sold you the engine should be able to provide you with any additional rigging info that you need. If you run into a snag, please feel free to email me at andyjr@shipyardisland.com and I will be happy to answer any questions that you have. One pointer....I have re-powered several Montauks and as a pre-cautionary measure we will fabricate larger backing washers for the insides of the engine mounting bolts. The washers provided with the engines I think are to small of a OD and when the bolts are tightened, they tend to suck in the supplied flat washers into the transom a bit. A larger OD washer will help spread this load out more. I have gone as large as 4" round. 5\16" alunminum works well for freshwater applications. We will cut the backing washers out of plate with a 4-1\2" hole saw, use the plug as the washer and then finish the edges off with sanders down to a 400 grit finish. As far as Yamaha service manuals are concerned.....been selling those since I have been a dealer. There are also no rules on not selling them to owners. Who ever told you that was mis-informed. Andy |
Clark Roberts
posted 10-24-2005 09:39 AM ET (US)
Dave, I agree with above post to NOT use any 5200 and will add that I would not use any 4200 either! Suggest you use a good amount of silicon and certainly nothing any more tenaceous. Suggest you never use 4200/5200 on anything that you may possibly ever need to remove! I have mounted several 90 Yamahas and all have had a lifting "eye" bolted to engine at proper balance point but don't know about current models. Happy Whalin',... Clark.. Spruce Creek Navy |
posted 10-24-2005 10:54 AM ET (US)
Re the Yamaha service manuals. I bought a 1987 Yamaha engine in the year 2000. I looked up the nearest dealer and called him to buy a service manual. This authorized Yamaha dealer told me that the policy of the Yamaha outboard motor company prohibited him from selling me a service manual. I see that there could be several possible interpretations of this:--the dealer was lying. In this case Yamaha ought to screen their dealers and choose more reputable people. --the dealer was misinformed. In this case Yamaha ought to train their dealers and better inform them. --the dealer was correct. The policy at that time was as the dealer stated. It apparently has since been changed. I solved the problem by buying an aftermarket service manual. I found a decent Yamaha dealer several hundred miles away who would sell me the parts I needed. I then took the motor to my local Mercury dealer for service on the gear case. He was very familiar with it because the gear case was an exact duplicate of the Mercury gear case. In fact, he used a Mercury part to fix it because it was half the price of the Yamaha part, which was identical. The power head needed service, but he was familiar with it, too, because it was extraordinarily similar to the OMC three-cylinder engine of that era. In fact, I believe that it was so similar that Yamaha was sued by OMC and had to make a substantial financial settlement with them to continue production of the motor. Just to clarify, do I understand correctly that when you purchase a new Yamaha outboard motor you should receive a detailed manual with an installation procedure? I mean somthing more than the usual owner's manual. |
David Livingstone
posted 10-24-2005 12:37 PM ET (US)
Clark, thanks for the correction not to use either 5200 or 4200. Come to think of it, I only use the tube of silicon that I keep on the boat.David |
NedsPoint
posted 10-24-2005 12:38 PM ET (US)
Ibought a 03 Yamaha 300 HPDI and part of the sale agreement was that I get the full service manual and parts catalog.I got it no problem |
SIM
posted 10-24-2005 12:52 PM ET (US)
Jim,I can't vouch for what your Yamaha dealer told you 5 years ago. Currently you can purchase Yamaha OEM manuals right on the Yamaha retail website. Been that way for a year or so. First I have heard of any OMC\Yamaha lawsuit. I am not saying it did not happen but can you point to any factual info besides "thats what I heard" ? We are dealers for Mercury and Yamaha. I have never tried to subsitute parts from one manuafctuer to another. Mercury parts are not any cheaper then Yamaha parts that I know of (similar part to similar part) and certainly not for me enough cost difference to justify using a Merc part in a Yamaha or vice versa. When you purchase an engine from a Yamaha dealer the engine comes with no rigging instructions. Just the owners manual. No significant rigging info in this owners manual either. What I posted was a suggestion for the owner to contact his selling dealer for his specific rigging questions. A suggestion......5200, 4200 or 101 3M sealant is without a doubt the preferred choice for outboard engine bolts sealing. Don't worry about not ever getting them off if needed.....they are bolts...........a turn or two with a rachet\socket and they are broken free and will spin out. Silicone sealant is not reccomended for under water use. IE.....lower engine bolts. Andy
bw12
posted 10-24-2005 01:18 PM ET (US)
Dave,I can't speak for the 90 HP, but I installed a 1999 Yamaha 50 HP 4-stroke on a 1983 Montauk, and the engine’s lower mounting holes were too low to clear the hull inner splash well. I didn’t want to use blind holes and lag bolts, so I drilled another set of holes into the engine mounting brackets. I disassembled the engine brackets and drilled them carefully with a drill press, but my motor was used. I wouldn’t go that route with a new engine, and would instead use a set of aftermarket adjustable setback brackets, available from companies that make jack plates. The only downside to the setback brackets is moving the engine weight further aft. If you have a 2-stroke, then it’s lighter weight means the setback effect is less significant. The 2-stroke 90 and 4-stroke 50 are with 10 pounds of each other, and the static trim of my boat is excellent. I read several posts here about what length throttle/shift cables to use and went with 18 ft. ones, which I’m not real happy with. I would go longer (or shorter, depending upon how the cables are routed) if I had to do it again. Remember that if you use a setback bracket, all connections to the engine will be further back. The standard length 16 ft. main (10 pin) electrical cable was barely long enough. I believe you can buy a 6.6 foot extension. The standard tachometer and power trim cables are 22 to 23 feet long and work fine. Finally, for what its worth, adding a Stingray hydrofoil to the engine made a dramatic difference in lowering the planing speed from around 17 mph to 11 mph. This makes my boat more comfortable to operate in rougher conditions. I can understand the hesitancy to drill into a pristine cavitation plate, but I would do in again in a heartbeat.
goinboatn
posted 10-25-2005 12:57 PM ET (US)
I have a 82 montauk rigged with a 83 rude 90 v-4. You NEED to call bob's machine shop and not look back! the flats jack weighs 29 pounds and does not effect my boat at all. Your motor is alot lighter then mine and a jackplate would solve any mounting problems you might encounter. Plus the ability to run with less draft in a major plus! I also run the hydrofoil - keeps more water to the prop. I have a water pressure guage and can get up plane and run with the motor six inches up. |
posted 10-25-2005 04:36 PM ET (US)
Andy--I bet you don't get the Bombardier manual with an engine either. You probably could order it. It is quite a document, however. What is part number for the Yamaha equivalent?Yes, five years ago Yamaha might have been operating under a different set of principles. That you can now get their service manuals is a good move for them. |
SIM
posted 10-25-2005 06:39 PM ET (US)
Jim, The 2005 version Yamaha rigging guide is part number LIT-18865-00-06 . Its thicker this year because of the new Yamaha Command link info that is included. I gotta take it home for some on the "pot" reading :^) If they through in the service manuals with new engines...what would I be able to sell them then? jk Andy |
capedave
posted 10-25-2005 10:16 PM ET (US)
Hello all and thanks for the replies. As far as manuals go I purchaced one for a 9.9 4stoke years a go no problem. Never did use it but it was great reading.I picked up the motor and boy that puppy looks huge laying in that foam box. Absolutly nothing on mounting or installing motor in the owners manual that comes with motor. SIM thanks for the part #, what is retail for that if the dealers are the ones suposed to be doing the instals??? Picked up a lift ring to remove the old mec and a standard drill plate for the instal after I repair the old holes. I was going to mount the yamaha at the same hight as the merc but it is a lighter engine???? Hmmm what height now more research is needed.Thanks all for the info provided. Dave |
capedave
posted 10-27-2005 07:30 AM ET (US)
Removed the old mecury found the lower holes drilled up 3/4 inch on the mounting bracket. I drilled and extended the lower mounting slots on the new Yamaha so I have compleat hight adjustabilty, I mounted it one hole up witch puts the motors cavitation plate 3/4" above bottom of boat. At the same time I have removed everything from the console, its empty. I have been taking photos and will do a new toppic with materials used for this repower, rehab. At the moment I am going to recover the face of the console with black formica after I repair the old cutouts. The top of the console now has a wood top covering the multitude of mounting holes, I am going to make up a corian top. Then fill it back with all new stuff, stearing system,wirring etc......Thanks all again Dave |
NedsPoint
posted 10-28-2005 09:17 PM ET (US)
ps - I bought a 04 300 hpdi, not an 03 as stated above....old age approaches |
capedave
posted 10-30-2005 08:08 PM ET (US)
Finished the instal and rewire and rework consol on the boat tonite. Will take it to be checked for corect instal and adjustments tomorow and hopefully get it out on the water. Will work on getting the photos up.Thanks Dave |
Capt Black
posted 04-13-2008 03:06 PM ET (US)
I am about to do the same thing -- I have a 1976 17' Montauk. I plan on bolting on a 2008 90hp 2 stroke Yamaha. The 2 stroke is over 100 lbs. lighter than the 4 stroke, this should give me better mpg & mph. Any thoughts? |
Tohsgib
posted 04-14-2008 12:20 PM ET (US)
Nope. Youw ill get worse MPG and worse top speed over the 4s. The 90 Yamaha 2s is more like 80hp but still burns about 4.5gph at cruise. The 90 4s is 90hp and will burn about 3.5gph at cruise. |
davidmassi
posted 04-14-2008 06:08 PM ET (US)
I just installed a 2001 100HP carbed Yamaha on my 1963 Nauset.It runs 46 MPH on GPS WOT It cruises in between 26-28 MPH In 4 hours of use (much of that was WOT as I was doing some prop testing) I burned 6 gallons of gas. That equates to 1.5 GPH....if my math is right. |
davidmassi
posted 04-14-2008 07:24 PM ET (US)
...and I should have said that its a 4 stroke. |
Tohsgib
posted 04-15-2008 11:46 AM ET (US)
Can't really go by that David. You need to hook up a 3gal tank. Set it at your cruise and see how long it takes to run it dry at speed. If you can't cruise for an hour straight(I can) then do it with 1 gal and see how long it lasts at cruise. My average per tank is always about half of what I burn at cruise. |
davidmassi
posted 04-15-2008 05:44 PM ET (US)
Thank you. I do understand that my GPH number is an avaerage that takes into account any no wake time. I offer it for comparison only. Without a fuel burn guage, one of the easiest ways to check GPH at cruise is measure gas levels for exactly an hour while running at cruise only. |
