posted 11-19-2005 09:37 AM ET (US)
If you purchase the factory service manual for your particular brand, model, year, and horsepower, it will have information on how to service the water pump impeller as well as information about the proper torque and sequence for the cylinder head bolts.To torque the cylinder head bolts you will need:
--torque wrench
--torque specifications
--bolt sequence specifications
To replace the water pump impeller you will need:
--water pump repair kit (recommend OEM parts)
The water pump on outboard motors is almost universally located in the gear case. Here are brief instructions:
--remove propeller
--disconnect any shift linkages
--remove all fasteners holding gear case to mid-section
--remove gear case
--disassemble water pump
--install replacement impeller, seals, housing, gaskets, o-rings, etc.
--reassemble water pump
--re-install gear case onto mid-section, being sure to align various cooling water passages and hoses, exhaust gas passages, shift shaft, drive shaft, etc.
--re-install fasteners
--reconnect shift linkages
--test motor for proper operation
I recommend you take the engine to a good mechanic for this work. On a 90-HP engine it will probably cost about $150 or less for this procedure. Considering the cost of a new engine, this is a good investment.
Replacement of the water pump impeller is routinely done periodically, so this expense is not unusual in the general cost of maintaining an engine. The cost to check the cylinder head bolts will be minimum; it just takes a few minutes.
