posted 01-04-2006 10:30 PM ET (US)
I also have a Whaler Drive (on a 22-foot hull). I have a single engine. I infer you have twin engines. My SONAR performance was unsatisfactory, but I recently moved the transducer to a new location which improved it quite a bit. The transducer is now about 13-inches to starboard of the centerline of the Whaler Drive. (This may not be possible on your boat if you have twin engines.) Previously it was farther outboard, and in that location SONAR performance was poor. The bottom echo was lost at speed and was very sensitive to boat trim. (Sorry--I do not have a picture to show this location.)I would have thought the flat center portion of the drive would have been a good location. Apparently it has not worked well for you. There does seem to be quite a bit of turbulent water coming off the hull center line in that area. It also makes the propeller run in quite airy water, too, but that is another story. Before giving up on the current location, be certain you have the transducer immersed into the water far enough. I have found that in some cases a change of vertical position of as little as 1/4-inch will make all the difference.
Before I moved the transducer to its current location, I was giving some thought to mounting my sonar transducer on the actual transom of the boat instead of on the Whaler Drive. It looks to me like you would have to mount it inboard of the sponson, which would put it more or less under the Whaler Drive (WD) . Because of the way the WD meets the hull, it looked to me like the best approach for mounting in that area would be to make a small fairing block (perhaps from wood to start and later maybe changing to King StarBoard if it worked out well). I would try mounting the fairing block so it extended the line of the hull bottom a few inches. The block would be in an L-shape so that it fit around the flange of the WD. In this way you could attach the fairing block using one of the existing larger screws--I think they are self tapping screws--that hold the WD to the transom. Or you could work around those screws--maybe a better idea to preserve their strength--and fasten the fairing block to the hull with some long screws through the lowest part of the block.
The idea of the fairing block would be to simplify the mounting of any SONAR transducer by making a nice flat surface a few inches behind the transom and carrying the line of the bottom of the hull. You could easily attach a transducer there using the stock bracket.
Running the cable from the transducer would required it to travel outward on the underside of the WD to the point where it could snake upward in the gap between the hull and the WD, and thence into the boat. If the connector is not too big, you could try to route it in via the scuppers.
I was going to try this approach, but after moving the transducer to its current location, the bottom sounding improved drastically, and I can [now] hold the bottom while on plane up to speeds of 35-MPH or so.
Another concern with twin engines: you do not want to mount the transducer directly upstream of either engine. The transducer may disrupt the flow of water into the engines. If you have twins, probably the best place is to mount it just off the keel centerline. Clamp the cable securing along the hull and bring it around the WD and into the boat.
