posted 03-06-2006 08:45 AM ET (US)
1982 22 Outrage notched transom. The prior setup was with 250 OX66. I didn't have it very long and someone stole the engine. After much consideration, I finally decided to take a chance on a 2005 250 HPDI. The prior setup generally ran about 10 difference between rpms and mph, i.e. 3500=25, 4000=30, 4500=35, etc.I am really impressed with the performance of the 250 hpdi on this hull. The numbers are much closer. 3800 rpms cruises at 36mph. I haven't found any place on the powerband above planing speed where the difference is more than 5. Without trying to trim and tweak, I got 47 mph with two people, 46 mph with five (two were kids. WOT is 5200. On the way to pull out yesterday, with just me and 2/3 fuel, it hit 49. That's with a t-top. Hole shot is really quick. Everybody needs to be holding on to something, if you goose it out of the hole.
I generally cruise about 3800 rpms. I just gained 8mph at the same rpm level at cruise. That's almost 30% increase in efficiency, not including the "less fuel usage" factor.
Mounted high. Turning a 21 pitch stainless. I'm impressed.
