  Twin 90-HP E-TEC on OUTRAGE 18
Author Topic:   Twin 90-HP E-TEC on OUTRAGE 18
jimh posted 04-08-2006 07:35 PM ET (US)   Profile for jimh   Send Email to jimh
Some preliminary results--from memory, so rough numbers. (And should add, this is for an OUTRAGE 18 with a standard notched transom, with twin 90-HP two-stroke E-TEC motors, mounted on 12-inch setback brackets with jack plates):
TEST CONDITIONS:
Air temperature = 45-degress
Water temperature = (about the same)
Canvas = Foward Shelter, Windshield, Flying Top
Fuel = 1/4-full tank
With Bombardier three-blade aluminum, 17-inch pitch:
RPM vs Boat Speed
5,500 = 46 MPH (engine speed may have been higher, more like 5,800--jimh.)
3,000 = 26 MPH (engine speed may have been higher, more like 3,200--jimh.)
With Bombardier three-blade aluminum 19-inch pitch:
RPM vs Boat Speed
5,400 = 51 MPH
3,100 = 31 MPH
(Gear ratio is 2:1 on this motor.)
Teak Oil posted 04-08-2006 08:16 PM ET (US)     Profile for Teak Oil  Send Email to Teak Oil
Thats pretty good with the shelter up. Add a couple more mph when it is down. I would just keep a 17" aluminum in case he needs to run on one engine for some reason
fourdfish posted 04-08-2006 08:20 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Impressive! I guess this is for Daves new babys?? The 19" is obviously the prop but what is top RPMs for these engines?
Perry posted 04-08-2006 09:30 PM ET (US)     Profile for Perry  Send Email to Perry
Impressive numbers. How many people aboard for the test? I bet a couple more mph could be gained with stainless props.
jechura posted 04-08-2006 09:41 PM ET (US)     Profile for jechura  Send Email to jechura
I'll have to say that Gambler is a hot one and David is another satisfied E-Tec owner.
Jerry
http://s5.photobucket.com/albums/y173/jerrym4/?action=view& current=DSC01244.jpg
jimh posted 04-09-2006 12:05 AM ET (US)     Profile for jimh  Send Email to jimh
Two nice short videos (recorded by Jeff) show the new twin 90-HP E-TEC motors in action:
At idle speeds
http://smg.photobucket.com/albums/v427/jeff_rohlfing/?action=view& current=FirstSteps009.flv
Accelerating to plane from idle in about 2-seconds
http://smg.photobucket.com/albums/v427/jeff_rohlfing/?action=view& current=FirstSteps010.flv
(Requires Flash Player)
jimh posted 04-09-2006 12:15 AM ET (US)     Profile for jimh  Send Email to jimh
Some images:
Wake at speed--notice small wake and slight toe-in on engines
http://continuouswave.com/whaler/images/castorPollux/wake.jpg
Grainy blow up showing hull lift at speed--only a couple of feet of the hull in the water.
http://continuouswave.com/whaler/images/castorPollux/onPlane.jpg
LuckyLady posted 04-09-2006 12:20 AM ET (US)     Profile for LuckyLady  Send Email to LuckyLady
Can't tell you how excited I was watching the video when Dave hit the throttles on those babies! Most exciting thing that happen to me all week!
Oh boy!
Power to spare!
Rene'
Peter posted 04-09-2006 09:40 AM ET (US)     Profile for Peter  Send Email to Peter
Dave must be one proud Papa! The video from the boat is great inspiration to start getting my rig ready for the season. The alignment of Castor and Pollux looks pretty good judging by the wake and they sound like they are singing the same tune in harmony.
The 17 inch props clearly do not have enough pitch. Assuming a WOT report for the 19s, I'd be inclined to try a pair of 21 inch pitch propellers (using the old OMC/BRP pitch designation methods) just to see what happens. My thinking is that if the typical pitch used with a 150 (1.86:1 gear ratio) was/is 19 inches, then 180 HP applied by a pair of propellers through 2:1 gear ratios and elevated just might be able to turn 21 inches within the upper part of the WOT range.
If the opportunity presented itself, other propellers I would try are:
18P Raker
20P Laser II
17P Stiletto
19P Stiletto
19P Viper or SST (swept back blade design)
19P SST II (old OMC design)
Tom W Clark posted 04-09-2006 02:27 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Very nice! 50+ MPH with the canvas up and stock aluminum props. There's more to be had there.
I agree with Peter's recommendations. The 20" Laser IIs would be the first I would want to try and then the 19" Stiletto Advantage Is.
If a 19" pitch set of props is what ends up being optimal, and *IF* Dave were to carry a spare for single engine operation, he would want to have a 15" pitch prop. You will generally go down 4 inches of pitch when going from two engines to just one.
So in reality, if Dave were to be serious about having full redundancy for safety, he needs to carry two spare propellers on board. A 19" aluminum for replacing a damaged prop on a motor that still runs, and a 15" for use on a single engine if the other is disabled for some reason.
LHG posted 04-09-2006 08:43 PM ET (US)     Profile for LHG
I'm very impressed with those Evinrude aluminum props. I have two jackplated rigs with the same 2.0 gearing, and I've never been able to get a Merc 19" pitch aluminum to run more than 44-46 MPH at 5500. With hot props like that, who needs Stilettos. I'd stay with them.
jechura posted 04-09-2006 10:04 PM ET (US)     Profile for jechura  Send Email to jechura
MORE SOUNDS
You see Gambler coming, but you don't here it until it's on-top of you and then it sounds like a twin engine low flying aircraft. Come on and take another ride, but hold on.
Jerry
http://s5.photobucket.com/albums/y173/jerrym4/?action=view& current=sound.flv
fourdfish posted 04-09-2006 10:36 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Really Great! What can you say!
WellFairFisherman posted 04-09-2006 11:21 PM ET (US)     Profile for WellFairFisherman  Send Email to WellFairFisherman
Very "Cool".....What kind of range do you get with that setup???
Buckda posted 04-10-2006 10:16 AM ET (US)     Profile for Buckda  Send Email to Buckda
WellFairFisherman-
I won't know about range until I get a few hours on the engines. You're looking at the very first run of the boat (the beauty of no break-in with the E-TECs). Jeff's video literally shows the very first run from inside the boat to WOT with 14X19 props.
I settled on the 13.2 X 19 BRP props to take home with me. Apparently this is a new prop from BRP and it has a little more aggressive cupping on the blades.
Tom is right. I'm going to end up with a 17 or 15 inch prop as a spare, which I'll order in a few weeks when Uncle Sam gives me some of my money back.
The test with one engine was on the 13.2 X 19 prop, so I know that I can get on plane with the current props, however, you saw how difficult it was...I had to wobble the hull to break it out of the hole.
Once on-plane though, it ran fine, and I was suprised to see the high 30's in the MPH range with a single.
Also - one of the things that needs to be pointed out is that the river has a strong current. I'm still going to be interested in top speed in "still water" settings and after I monkey around a bit with the jackplates. Right now, the engines are jacked quite high.
Overall, I'm very pleased with the rig.
Thanks for the great comments and suggestions. I'm going to have fun this summer dialing her in and getting comfortable with operating a twin-engine boat.
Dave
Buckda posted 04-10-2006 12:03 PM ET (US)     Profile for Buckda  Send Email to Buckda
More general info about the test that might be interesting/useful for others.
The boat was loaded with 1/4 tank of fuel (about 15 gallons) and 3 adult men as passengers for each test.
Douglas Zammit and I were the only "constant" passengers.
I'd guess Douglas weighs around 160, and I'm at around 180.
Other passengers included 200 - 225 pounders...so fairly big guys.
Tom W Clark posted 04-10-2006 12:06 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Dave,
Is the 51 MPH top speed at 5400 RPM cited above by Jim an average of upstream and downstream speed runs?
Buckda posted 04-10-2006 12:22 PM ET (US)     Profile for Buckda  Send Email to Buckda
I think the excitement of the day got to us a little.
I'm going to be a bit more conservative and say that the boat is running in the 49-50 MPH range. The top speed held by the GPS was 51.9 MPH, however we "saw" 52.7 on the readout for a flash.
I may have my directions mixed up (I'd never been boating on this specific stretch of water), but I believe we were going downstream towards lake Erie when I saw those GPS numbers on the 13.2 X 19 prop.
On the upstream side with those props, I was in the back checking the anti-vent plate levels and then just hanging on and marvelling at the sound of the motors. (Doug Zammit was piloting).
As I said before, I'm anxious to do some tests in a "stillwater" setting.
...but with an arch and full canvas up and three guys aboard..I was still impressed, and I think that with tuning the jackplate settings, I can get another few MPH out of the current prop setup.
My regret on the day is that I did not choose to fill the tank before arrival in Detroit. It would have been nice to have picked the props that worked best and then spent the rest of the afternoon "tuning" the boat.
With a nice weather forecast for this Saturday, I may take the boat to an inland lake with a quiet ramp and do just that.
Dave
Tom W Clark posted 04-10-2006 12:30 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Dave,
That makes sense. You've got all summer to play around with this. Enjoy it.
I suspect your top speed this weekend was more like 46-48 MPH. At 51 MPH thee props would be running with a -5 percent slip factor! Even with a slip factor of ZERO, the predicted speed would be 48.6 MPH.
I agree, with full canvas and RADAR arch, it is still extremely fast for that boat. I have no doubt you will break 50 MPH once you get it dialed in.
whalersailer posted 04-10-2006 01:18 PM ET (US)     Profile for whalersailer  Send Email to whalersailer
Dave,
That's one sweet ride!
After you get the first 10 hours on those babies, you will notice an increase in the power. When my 90 was new (in the 1st 10 hours), I could only pull about 5,300 rpms, but once she got past 10 hours, 5,500 (with the same load) was easilly achieved. The power for acceleration was also noticably increased.
Considering that you are doubling what I have (twins vs. single), you might want to consider holding off on final prop selection until they are broken in - just a thought.
-WS
Slippery Eel posted 04-10-2006 02:50 PM ET (US)     Profile for Slippery Eel  Send Email to Slippery Eel
This whole thread is awesome! I watched all of the clips about 10 times so far. I am picking up my boat this week with my 2006 E-TEC 90 and I am pumped. Can't wait to hear the sound of the motor and have similar giddy experiences.
Great job documenting your whole process. Kept me entertained all winter.
Hutch
Eagleman posted 04-10-2006 04:25 PM ET (US)     Profile for Eagleman  Send Email to Eagleman
Dave,
Thanks for the visual ride on your new set up, it rocks! Anxious to see the boat sometime this summer. I'm looking for additional pictures of your complete teak deck, I saw a couple in the process of layout any of the floor completed?
Take care
Tom W Clark posted 04-10-2006 04:33 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I have a feeling Dave has just "sold" a few more E-Tecs.
Buckda posted 04-10-2006 05:23 PM ET (US)     Profile for Buckda  Send Email to Buckda
LOL Tom.
I just answered an e-mail on that very same topic: How can I contact Lockeman's for a quote, and do I think the twin 75's would be adequate.
The answer is yes, I think twin 75's would be adequate, however you would definitely need a 17 inch prop for single-engine running, probably a 15 inch.
You can contact Lockeman's Hardware and Boats, on Jefferson Avenue in Detroit, Michigan if you are within a few hundred miles. They're on the web. Ask for Dave or Doug Zammit, and be sure to tell them to give me a bird-dogging fee!!!
Dave
Buckda posted 04-10-2006 07:13 PM ET (US)     Profile for Buckda  Send Email to Buckda
Russ -
Thanks.
Perhaps I'll cross on over to see you guys sometime this summer.
I'll post more re: the teak deck once I'm truly finished.
There was some Hydraulic fluid spilled on the deck when purging the helm, and some other spots that I need to clean up, then I'm going to caulk the deck down and take the final photos and host them on Photobucket. I'll be able to share all the photos with JimH for an addendum I'd like to write to Jeffs22Outrage's article on his project...since I had the same problem but just went in a different direction for a solution.
Dave
erik selis posted 04-11-2006 11:46 AM ET (US)     Profile for erik selis  Send Email to erik selis
I am also very impressed with watching the video's. The sound these engines make is amazing. The harmonics are very pleasant to listen to. Like a perfectly tuned guitar with new strings. Everyone I have shown the video's to are impressed. Great stuff!!!
Erik
Plotman posted 04-11-2006 12:49 PM ET (US)     Profile for Plotman  Send Email to Plotman
You never really know what the true effective prop pitch is compared to what is stamped on the prop, so slip calculations are obviously an estimate.
However, for point of comparison, with standard Yamaha black stainless semi-cleavers, I get ~5% slip at WOT on my 22 with 130 twins.
Awesome set up Dave. Now I'm going to have to work pretty hard not to come up with a reason to replace my perfectly good engines with a pair of E-TECs.
David
The Judge posted 04-11-2006 02:36 PM ET (US)     Profile for The Judge  Send Email to The Judge
With all that WOT running, how long did the 1/4 tank last? They sound noisy in the videos but then again it is a video and running WOT. How loud are they WOT and at cruise compared to a conventional 2 stroke?
Tom W Clark posted 04-11-2006 02:40 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I have some experience running an E-Tec 90 on a Montauk. They are quiet. Almost as quiet as a four stroke at idle and as quiet as a four stroke while cruising. WAY more quiet than a conventional two stroke.
At WOT nobody is doing any talking...they're just trying to hang on!
Buckda posted 04-11-2006 02:55 PM ET (US)     Profile for Buckda  Send Email to Buckda
We started with slightly more than 1/4 tank, and finished with slightly less than 1/4 tank. I'd say we burned 1/8 tank (full tank is 63 gallons) in the testing...or around 8 gallons. I'll check the GPS trip log to figure out the distance traveled and the running time.
Any way you cut it, at WOT, 180 HP is burning 18 GPH approximately...two stroke or 4 stroke. I expect the economy to come at no-wake and at cruise...not at WOT.
At idle the motors are very quiet and even when cruising they have a quiet rumble...but when you hit WOT, you've effectively lifted the hull to the point where you're hearing the motors noise and the props that are cleaving the water on the keel side of the motor..so you can hear that prop slap, which I think is why some of the guys in Jerry's video commented that it sounded like an airplane. Effectively, you were hearing the full exhaust and the props beating the water.
Even at WOT with the canvas up (reflects noise), you could carry on a conversation with passengers in the boat at a much lower volume than my old Merc 150.
Also - no smoke...and just a hint of 2-stroke smell when the wind caught it just right at idle.
Plotman posted 04-11-2006 03:07 PM ET (US)     Profile for Plotman  Send Email to Plotman
Dave, did you have your fuel flow instruments hooked up? did you get any mpg readings?
Buckda posted 04-11-2006 03:28 PM ET (US)     Profile for Buckda  Send Email to Buckda
David -
The fuel plumbing got a little more tight than I expected, and the fuel flow meter's transducer was cut out of the line at the last minute when getting the rig ready. I'm going to re-install it further down (closer to the bilge sump) so that it can still be "vertical" as indicated.
That is one of the first changes I'm making on Saturday morning, after I visit Sears for a racheting boxed end wrench with 1 1/16" grip for jackplate adjustment while on-the-water.
So, to answer your question, no, I don't yet have accurate fuel consumption data at this time, and given that I know I have to calibrate that transducer - based on it's erronious readings last summer - it may take a few weekends to sort that out entirely.
LHG posted 04-11-2006 03:32 PM ET (US)     Profile for LHG
When a magazine tested the 90's, they said the E-TEC and Optimax were the loudest at WOT, and the Honda and Suzuki were the quiet champions.
Bulldog posted 04-11-2006 04:14 PM ET (US)     Profile for Bulldog  Send Email to Bulldog
Dave, looks great, nice to see all that work paying off huh? That wrench is going to be expensive, tie a line to it!.........Jack
Buckda posted 04-11-2006 04:22 PM ET (US)     Profile for Buckda  Send Email to Buckda
Since I haven't heard a Yamaha 4-stroke or a Suzuki 4-stroke, or even a Mercury OptiMax on an 18' Outrage with full canvas up, I'll refrain from making direct comparisons about something I personally don't have any experience with.
The engines are very quiet at idle. One of Jeff's videos shows the boat at idle and you can very clearly hear the water swishing louder than the engines.
When the boat is cruising at around 3,000 rpms, it is still quiet enough to talk normally and be heard.
At WOT, you can hear the engines, but you can also hear the wind on the canvas, and can hear the guy next to you talking in a normal voice. You generally don't feel the need to shout, though it is natural to talk in a slightly louder voice than when idling along. Df course, You can hear the devil-pixies that live under the cowlings of those motors shouting at each other to hurry it up...but that's part of the cool sound of the engines.
Buckda posted 04-11-2006 05:52 PM ET (US)     Profile for Buckda  Send Email to Buckda
The E-TEC 90 HP motor, in twin configuration appears to be an excellent match for the 18' Outrage hull. Although it is entirely too early in the process to make any predictions on engine reliability and longevity (which at least for the next three years are covered under warranty), I can say unequivocally that the performance (with very little fine-tuning, by the way) has been as expected.
The platform delivers solid throttle response, full-force hole-shot and a pleasing sound.
There is no smoke (I noticed a small puff of smoke when pounding the throttle from idle...but we're in a "double oiling" regimen for the next few hours on the motors).
There is very little sound at idle.
The shift cables are smooth and the BRP dual binnacle control offers a nice feel and "weight" when shifting from neutral into gear. My one complaint on this particular instrument is that I'd like to have the option, as Mercury offers, to sync the trim/tilt for general purposes, with the normal independent operation as a continuing option.
The SystemCheck Tachometers are easy to read and have a very clear display and the warning LEDs are easy to read and understand.
Overall, I think it will prove to be a great combination for my uses.
Dave
prj posted 04-12-2006 09:39 AM ET (US)     Profile for prj  Send Email to prj
Congratulations Dave, it looks great.
Do you have a photograph that shows the new static trim?
What is the approx. total weight on the transom,
including jack plates?
Thanks.
Buckda posted 04-12-2006 10:38 AM ET (US)     Profile for Buckda  Send Email to Buckda
PRJ -
Static trim is not too bad - about the same as LHG's. I'll have to dig up a photo showing that..I think you'll see one soon here on CW.
Total weight on the transom, (assuming the plates weigh 30 lbs each)...would be approximately 700 lbs.
(320 lbs for each motor and 30 lbs for each jackplate).
I guess with oil and props, we're looking at more like 720 lbs.
The batteries are in the console, and the new teak floor weighs less than the old fiberglass molded floor, but I can't remember by how much (it's pretty significant).
Plotman posted 04-12-2006 12:26 PM ET (US)     Profile for Plotman  Send Email to Plotman
Dave-
Something to think about with regards to which props you select: The comparatively dense air of the cold temps you tested the boat in will give better performance than the typical summer weather you are more apt to boat in.
I can see an extra 200-300 rpm and a couple mph at WOT in April or October above what I can wind up to in mid summer. Whether this is what caused Pat to see an increase the in RPMs he got out of his engine or whether there really is some kind of unadvertised break in period on the E-TECs after all is hard to call. I suspect more of the former.
In any event, at a minimum, I would look for props that get you right to or even a little past the upper end of the reccomended RPM band in cool temperatures. You will likely see the max RPM fall comfortably into the range in summer temps, and you will be better able to plane on a single engine if necessary as you will be running a lower pitch prop.
David
whalersailer posted 04-12-2006 01:49 PM ET (US)     Profile for whalersailer  Send Email to whalersailer
David (Plotman),
The initial running of the engine was done in late May last summer (temp in the mid 50's to low 60's). It was in these conditions that the engine had less than 10 hours on it and was only able to pull 5,300. The engine was pulling 5,500 in early-mid August (temp in the upper 70's to mid 80's), so from my perspective, the engine was definitely stronger after this 10 hour break-in period.
Also, I had the boat out on Lake Superior last Sunday, and she was pulling 5,600 and 1.3 knots faster with a good load and a kicker on the back. That would make sense as the temperature and humidity were relatively low compared to August of last summer.
-Pat
fourdfish posted 04-12-2006 01:53 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
As I have been corrected on this twice by 2 different certified mechs, I might pass it on again for everyone.
E-TEC eccess oil breakin is 2 hours over 2000rpms not 10hrs as everyone seems to be saying! I guess the Ficht engine was a 10 hr breakin!
seahorse posted 04-12-2006 07:22 PM ET (US)     Profile for seahorse  Send Email to seahorse
The earlier production E-TECs had a 10-hour computer controlled oil MAP for new motor break in. Later production models were changed to a 2 hour breakin and that only starts the timer when the engine is over 2000 rpm. This break in info is in the factory service manual which is available to everyone.
jimh posted 04-13-2006 08:12 PM ET (US)     Profile for jimh  Send Email to jimh
[A number of comments which were off-topic and did not contribute to the discussion of the engine performance have been removed.--jimh.]
Buckda posted 04-17-2006 11:37 AM ET (US)     Profile for Buckda  Send Email to Buckda
A note on performance:
When coming to a fast stop off plane the splashwell takes some spillover. The 1,000 GPH Rule that I installed last night should keep the area mostly dry (usually it’s enough to fill the small splashwell sump, but no more (about 1 liter of water).
Drifting in 1-3 foot Lake Michigan chop on a stiff North wind on Saturday resulted in no splashover when drifting stern-into the wind, however you can hear the exhaust burble under the waterline as the boat bobs around. In a big sea, I’d definitely want to set a drift-anchor to keep the bow into the wind, or at least take it on beam-to.
I installed the Navman Fuel 2100 Fuel Flow sensor on Saturday morning.
At idle with both engines, the fuel usage is not measured (0.0 GPH returned). Idling both at about 1,000 RPM results in a fuel burn of between 0.2 and 0.4 GPH. With one motor, it hovers around 0.1-0.2 GPH. At both motors at 1,000 RPM, I’m making about 5 to 6 MPH on GPS.
This fuel flow meter has not yet been calibrated, and it read quite high readings (inaccurate) for the Merc 150 (it was off by about 10 gallons at Isle Royale (readings were high, which is the more comfortable side of accurate!)). For the Merc, I was getting 2 GPH at idle (6 mph) and averaged about 2.7 to 3.1 MPG for the many trips I took with that rig (both idle and at speed).
Assuming the inaccuracy has remained the same (for comparison purposes), I think I’m in a good place for this rig. It appears to be exceptional at idle.
As I said before, I’m still learning to be comfortable with adjusting the speed, synchronizing the engine tachs and piloting the boat (all at once, that is), so it was difficult to get figures on the meter for consumption at speed because it took so long to try to dial in the right speed and course for the conditions. …I think the translations were looking like 2.5 to 2.7 GPH for a given speed…it stayed the same for nearly all settings except for around 3,200 RPM, which returned 32 MPH (GPS) and about 12.8 GPH on the meter.
Also note - the economy should improve slightly after break in.
Dave
