Topic: Cable vs. Strap for Trailer Winch
justasmokin |
posted 04-11-2006 04:35 PM ET (US)
I have a 20-foot boat. Which is for my boat [trailer] winch, a 25-foot nylon strap 2-inches wide or a 7/32-inch galvanized steel aircraft cable 25-feet long? Thank you.
JBCornwell
posted 04-11-2006 06:54 PM ET (US)
Strap.No problems with cable digging in on the winch drum. No loose "threads" to cut and otherwise damage anything it touches. Red sky at night. . . JB |
posted 04-11-2006 08:18 PM ET (US)
On trailer winches, straps are more commonly used. |
JOHN W MAYO
posted 04-11-2006 11:32 PM ET (US)
I changed from cable to strap. This was a major improvement, much easier to operate and the no cable to dig in the drum. The strap comes off very easy, quite, and is strong. |
deepwater
posted 04-12-2006 06:28 PM ET (US)
Did you ever find a small steel splinter in your cable as you walked back along the cable ,sliding your hand slowly to keep your balance ^@^,I now use a strap. |
prj
posted 04-13-2006 09:35 AM ET (US)
Yep, go with the strap.I changed from cable to strap on both Whalers last year, with some difficulty as one winch drum was not "holed" to receive a shaft fixing the strap, in order to prevent those throbbing little punctures.
Outrage2795
posted 04-13-2006 12:54 PM ET (US)
Like everyone else said, go with a strap or good quality braided (not twisted)rope. The old shrimpers I grew up with call those steel splinters "meat hooks". Another good reason to avoid cables is if a cable parts it will snap back with tremendous force and injure you or your boat. |
high sierra
posted 04-13-2006 10:44 PM ET (US)
Go with a strap. I have a 3 inch scar on the back of my hand to show what a cable can do when it lashes back when it breaks. high sierra |
PeteB88
posted 04-16-2006 03:13 PM ET (US)
STRAP |
Chuck Tribolet
posted 04-16-2006 05:31 PM ET (US)
Strap and safety chain. Chuck
Teak Oil
posted 04-16-2006 06:33 PM ET (US)
Cables just plain suck |
eportfolio
posted 04-17-2006 01:21 PM ET (US)
I have an old '84 Cox trailer with a cable in my winch. Can you simply switch from cable to strap without buying a new winch? |
David Livingstone
posted 04-17-2006 03:53 PM ET (US)
Strap.eportfolio, you should be able to change over have a cable to strap with no problem. A strap also has an added safety feature in that it breaks by tearing and not snapping in two like a cable or rope. David |
