Sal DiMercurio
posted 04-24-2006 10:48 PM ET (US)
John, You will only get more speed if your engine can twist the prop with more pitch in it. More pitch means "LESS" rpms. For instance, if your running a 14.25 diameter x 17 pitch prop, & your engine "maximum rated" rpms is 5600 rpms & your getting 5600 rpms @ wot, you can't put a 14.25 x 19p prop on, because you will loose 400 more rpms because of the added 2" of pitch [ from a 17p to a 19p ]. 2" of pitch added means 200 rpms less for each inch of pitch, so that would make 400 rpms off your top end & drop your maximum rpms to only 5200 rpms. Now, if you go down in pitch from a 19p to a 17p, you will gain 400 rpms. It's 200 rpms per inch of pitch, more pitch means less rpms & less pitch means more rpms. Sal |
