| Author | Topic: V-hull: Constant vs Variable Deadrise |
The classic Boston Whaler OUTRAGE hull as seen in the several implementations of it such as the 18-, 20-,22-, and 25-foot OUTRAGE and REVENGE models is a v-hull with constant deadrise. By this I mean the v-hull angle at the bow is the same as at the transom, and it is typically around 18° of deadrise. This hull form became popular in the 1960's after Ray Hunt designed the famous offshore racer MOPIE for Richard Bertram. The success of this hull in offshore power boat races spawned many imitators and launched the Bertram Yacht company into the business of building more of these hulls. One of the attributes of the constant-deadrise v-hull is very good tracking in a following sea, and very little tendency to bow steer. By bow steer I refer to the tendency of a boat to have its course influenced more by the bow than by the stern and the rudder (or engine). Boats with a constant-deadrise v-hull do not tend to go veering off course if the bow digs in when running down the face of a big wave in a following sea. The boat will run down large waves without wild changes in direction. The rise in popularity of v-hull boats lead to more experimentation, and soon there was the deep v-hull, where the deadrise angle was increased beyond 20°. As the v-hull deadrise was increased, the ability of the hull to slice into waves was improved. In situations where it is desired to run into large head seas, the deeper the v-hull the better. However, there was a price to pay for the deep-v: as the hull form became more acute, there was less lift available to get the hull onto plane, and more horsepower and speed was needed to achieve planing. The logical evolution continued and soon the variable-deadrise v-hull was invented. The bow was made sharp and deep to cut through head seas, and the stern was tapered into a flatter v-hull to give more stability at rest and more lift for planing. This design often has a tendency to bow steer, particularly at low speeds. Operating a boat which has a strong tendency to bow steer can be very tedious, as the boat will not hold a course line, and the helm must be constantly corrected to keep the boat on course. I now have almost ten seasons of experience with a classic Boston Whaler hull, and I have come to appreciate its characteristics. One of the most impressive is the hull's lateral stability at rest. When you board a classic Boston Whaler boat, the hull's lateral stability is evident the moment you put your weight on the gunwale: the boat hardly leans over in response. Running downwind in following seas or motoring at no-wake speeds, the hull tracks very well, and the boat does not veer off course. Constant attention to the helm is not required. Going into head seas is not the hull's finest hour, and, especially if the wave face is taken at about a 45° angle, there can be an awful hull slap. The Whaler hull really does not like a 45° approach. It is better to go head-on to a wave and let the bow try to slice it. But once you get into the longer hulls, the boat can usually float from wave crest to wave crest atop of the seas, and the ride is not bone-crushing. Just recently I spent a week cruising on the Ottawa River and began to reflect on my boat's hull form and how it was working in this sort of application. In riverine boating you generally do not have large wind-driven waves to contend with. Watching the fuel tank level gauge drop as we were running on plane at 27-MPH, I started thinking about how a hull form with a bit more planing surface aft might be more fuel efficient. But what will I have to give up if I change to a variable-deadrise hull? It seems that most boats built these days are using this form. It cannot be seriously flawed. Are our older, constant-deadrise classic Boston Whaler hulls an anachronism? |
| VI Jamie 22 |
I don't think the answer is constant deadrise or not constant deadrise. The variables are greater than that. Weight of the boat, Expected user speed range, Compromises that are important to the owner, Maximum length wanted by the owner, Sea conditions that the boat will be used, Number of people or weight to be carried. Fuel usage. Overall looks of the boat. And I am sure much more. For my area, I know that I did not buy the best rough sea boat, That would have been the locally made copy of the 22 foot Monza Hull. The Monza also has a constant deadrise. There is not a newer or variable deadrise boat in this area that is better. I just couldn't satisfy my Whaler Addiction with this boat. Does anyone know of a 18 to 22 foot variable deadrise boat that has a softer ride than a classic whaler in rough conditions that cruises about 25kts? |
| Lagniappe |
I own a 1996 [unrecognized acronym, possibly "OUTRAGE 17" intended] (hopefully close enough), with an Accutrak hull. I believe deadrise at stern is 17° and bow is 56°. It has been so long since being on an old style than I care to remember. I do really like the variable [deadrise v-hull] however. It is versatile. I initailly did not like it, but after four to five years I got the other variables you mentioned dialed-in. In my opinion, it was impossible to get true benefit from the bow when needed because of relative buoyancy, light weight of the boat, and high planning speed. My solutions: Strict weight distribution for my gear and passengers. I have found that if all tackle and food goes up front and two guys at the helm, I can keep the bow in the water much better. If three guys go, then one sits on the cooler forward, if four guys then three at the helm area, nothing in the stern. This improved things a lot. I felt that pounding four-foot waves at 18-MPH or better did not make for a comfortable ride even after managing weight. Airborne too often. I thought about trim tabs, but stern is not built for it, so for me the turbo lift and a painstaking evaluation of props solved my planning speed, plus other benefits. Can plane as slow as 12-MPH and have more control over bow than I ever imagined. So in four-foot waves I can maintain a speed below flight levels and really knife through wave with little stern movement. Benefits still present at higher speeds, too. Non-whaler friends who fish with me always remark how much better my [unrecognized acronym, possibly "OUTRAGE 17" intended] rides than their 22-foot something-or-other. I believe the variable deadrise makes this possible, but on smaller boats getting some weight forward and lower planning speed is important. john |
| Binkie |
Variable deadrise boats are nothing new, probably no one knows when they were first developed, the only older design was the true flatbottom, Like Lewis and Clarks river boat. All variable deadrise boats were at first displacement hulls, Sharp V at the bow and shallow V in the stern, with a rocker bottom towards the stern. This design was adapted from sailboats. and was used in the early powerboats (steam). As gasoline engines became lighter and more powerful, someone realized that if you took the rocker out of the bottom and straightened the bottom out the boat would rise out of the water and "plane". The only limit as to speed, was how much power could be applied..Remember the mahogany speedboats of the `20`s thru the `50`s. These boats were unbeatable but were hardriding and wet. Also during this timeframe raceboat builders experimented with other designs, such as stepped bottom runabouts, single step hydros, 3-point hydros, and tunnel hull boats. It is said that Ray Hunt invented the deep V hull, when in 1959, he entered his 30 foot wooden 24 degree deadrise hull with lifting strakes called Moppie (his wife`s nickname), in the Miami to Nassau and back race and cleaned house.This was the basic hull design that was used in 1961 for the 31 foot Bertrams, and later in the 25 and 20 footers, which were just scaled down versions. They are said to be constant deadrise hulls, but actually they have suttle changes in deadrise from bow to stern. It was the lifting strake that made them work, without that strake they wouldn`t ever get up on plane. The early Bertrams had a 22 degree deadrise, reduced from 24 degrees on the original wooden Moppie, as they thought it was to severe for a pleasureboat. I had a 25 foot Bertram, and it would blast through 5 ft.waves to get to the offshore grouper grounds, but I have a weak stomach, and tossed my cookies many times when on the drift, with the lateral instability of these boats. Deep V hulls have many limitations, and I think thats why you see so many different type hulls around now. If you`ve ever ridden on a modern catermaran, they don`t pound at all, but they lean to the outside like a car when turning at speed. Actually they are displacement hulls and ride in the water, not on it like the racing catermarans, which have a different design altogether. Then we get to the Whaler 13 footer, a strange hard riding little tri-hull boat with a hooked bottom....... Rich |
A flatter deadrise in the stern will help get the boat on plane at lower speed. However, the boat you are describing has about the same deadrise at the stern (17°) as my classic hull (18°), so I cannot see how it contributes to any better low-speed planing performance. If anything, I would expect that a constant deadrise v-hull with 18° of v-hull would exhibit better low-speed planing characteristics than a variable deadrise v-hull of the same general size which had a finer entry forward and tapered to about 18° at the stern. It is hard to make a direct comparison between our boats as my hull is longer, and generally longer boats can stay on plane at lower speeds. In my case I can be on plane at about 12-MPH, although that mode is not very efficient as the stern is digging a big hole in the water and wave-making in the wake is quite large. Proper weight distribution is necessary in any small boat, as the addition of crew and gear adds a significant percentage of the boat's weight. My hull only weights about 2,500-lbs, and if three big 250-lbs guys come aboard, they represent 30-percent of the hull weight. Such a large increase in the load has to be carefully positioned, no matter what the hull form, or the boat's performance will suffer. Therefore I have to reject the notion that there is something about a variable-deadrise v-hull which requires special attention to weight distribution. It is a concern in all small-boats. In the case of your boat (which I assume is an OUTRAGE 17), three big guys will have even more impact on the boat trim. So, yes, you have to position them properly. |
| Peter |
My recollection on the 22 foot classic hull in the form of a 22 Revenge that I once owned is that the angle of the bow entry is sharper than the deadrise angle at the stern. It's bow entry angle is certainly sharper than the bow entry angle on my 27 Whaler. I think the 15, 22 and/or the 25 have the sharpest bow entry angles of the classics. There is clearly a trade off between deadrise, bow entry angle and overall handling. The classic Whaler hull design has made a trade off between head sea and following sea handling.
quote:-- JimH What you are describing with respect to the hull slap at the 45 degree angle is what I call "chine slap" caused by the fact that the boat is riding on the chine as it leans into the wind due to the steering corrections needed to maintain course. Chine slap can be significantly reduced with the proper use of trim tabs adjusting the boat's Port/Starboard trim to lift the windward chine such that its not constantly riding on the windward chine that causes the slap. The trim tabs act somewhat like a shock absorber. If you don't have trim tabs, you can't adjust the ride except by shifting weight which is difficult to do while underway. |
| Mobjack |
A couple corrections first off: JIMH: Moppie was a 24 degree deadrise bow to stern. variable deadrise hulls are not anything new, that is true, and they are perhaps nowhere more prolific than here on the Chesapeake Bay. In fact, for those of you who have never spent much time in MD or Va, the nickname for the big traditional wooden workboats of the Chesapeake is "deadrise". This phrase/nickname is derived from the extremely variable deadrise common in these hulls, which can range from upwards of sixty degrees in the bow to as little as 0 (flat) in the stern. The hull when viewed from below is a constantly changing curve as it sweeps aft. A constant deadrise hull can slice the waves better than your average carolina skiff, but one drawback that is not noted here so far is that a hull like Moppie, while great at speed, will roll much more substantially at rest in heavy seas than perhaps my Montauk for example. Variable deadrise hulls in the modern definition seem to be an attempt at a magic bullet, in effect an answer to the boater who wants wave cutting ability to soften the ride, combined with the ability to have extremely shallow draft and more stability. There was a design which was started by a fellow named Tom Simmons in Myrtle Grove, North Carolina in the early sixties called a Simmons Sea Skiff. These vessels had extremely steep bow entries, I wont quote the deadrise angle because I cannot remember it accurately, but it is extremely steep- But they have about fifteen degrees at the transom. Among other things, Simmons mounted the outboard inside the transom in a well, and then raked the transom aft approximately 35 degrees so that a following sea would lift the stern and not swamp it. These boats were built in 18, 20, and 22 foot lengths, and about three thousand were made. Their reputation was always that they would "Bring you back a long time after you wished you weren't out there." For an 18' lapstrake skiff that was regularly used offshore in the carolinas for twenty years or so that is an impressive resume. |
Mobjack--thanks for the information. I did not mean to imply that the deadrise of MOPPIE was 18°, but just that it was a constant deadrise v-hull. The 18° deadrise was associated only with the Whaler hulls, not the Bertram hulls. |
| BlackMax |
Boston Whaler Outrage/Revenge hulls, 18-25', are variable deadrise, stern to bow. |
BlackMax--You only have to look at one of these hulls to know that is wrong. |
| BWLucky13 |
Power boat hulls have evolved based on high power engines that use as much cheap fuel as possible. If anything about that equation changes, then so will the hull shape. Time is money. Most small boaters have more of the latter. So, the ability to maintain more speed in a chop is given priority over other attributes. So, if you want a low powered boat that is miserly with fuel, planes at low speeds, is sea worthy under a variety of conditions, and is easy to handle, then you simply look for an old design. Older designs tend to be longer, narrower, soft chined, sharp bowed, and flat aft. Modern designs are exactly the opposite. The performance difference between these two extremes can be shocking--for better and for worse. If you want to examine some older designs, the downeast lobster hulls are classics. Check out the Eastern 18 and the Seaway 18. |
| Binkie |
You can go to huntdesigns.com and read all about Ray Hunt`s deep V- hulls, and nowhere will you see the term "Constant deadrise" hull used. The article mentioned the terms "deep-V"or "high deadrise. hulls. I think the term constant deadrise is a misnomer, as no hull would be designed with the same deadrise at the bow as in the stern. Maybe offshore race boats like the cigarette type hull would be the closest to a constant deadrise hull. Actually the twin hulls of semidisplacement cataramans like the World Cat may be close to constant deadrise. Can anyone think of a brand of boat that has the same deadrise at the entry as at the stern? Rich |
| macfam |
Yup! Carolina Skiff |
I don't understand the inference I am supposed to draw from the statement in reference to the current contents of the Hunt Design website. The fact that they don't mention a particular hull form in their current website does not revoke or refute anything that happened 40 years ago in the past. It is not necessary to be a naval architect to recognize a hull that has a constant-deadrise v-hull form. |
| macfam |
Seriously: jimh is right. Take a look at this article from Boston Whaler. The part about "constant deadrise" is about three-fourths thru the article. http://www.whaler.com/Rec/default.asp?content=customersatisfaction All in all, my 25 Revenge WT, standard transom, does so many things well. They were ahead of their time in many ways. It works out much better for fuel economy than a variable deadrise. |
| Binkie |
Actually the term constant deadrise really means that the stations on the forward part of the bottom are of a convex design and beginning at a point aft the deadrise angle remains the same, Where that point aft is, can be different on different hulls. Variable deadrise means that the deadrise is always flattening out towards the stern, but to different degrees in different boats Its as simple as that. the early Bertram's never were constant deadrise, the difference in deadrise angle were very subtle. Thats where the magic was. |
Actually, the Hunt Design website does mention the term "constant-deadrise", and they also agree with Binkie about their hulls. For Hunt's own opinion on "constant-deadrise" see: http://www.huntdesigns.com/about_deepv_qa.htm I do have to observe that if the Hunt hulls are not literally constant deadrise, those subtle changes they mention must be awfully minor to fool all of the learned boating writers who looked at them and pronounced them "constant-deadrise" v-hulls. :-) |
To clarify what seems to be a world of woe for some folks, the notion of deadrise applies to the bottom of the boat, not to the bow of the boat. The bottom--the lowest portion, or that which is seen from below or by the fish or other creatures swimming below the boat when they look up. Just want to be clear on that in case someone starts measuring an angle up around the bow towing eye and gets excited if it is not 18° precisely. |
| Perry |
jimh, you seem to contradict youself. You say in your last post that "the notion of deadrise applies to the bottom of the boat, not to the bow of the boat". But in your first post you say that a constant deadrise is when "the v-hull angle at the bow is the same as at the transom". Which is it? Does the deadrise begin at the bow or not? Maybe at the water line (entry)? |
If my sentence confuses, you the change "bow" to "forward end of vessel." How much does the angle have to change before it is no longer constant? How subtle is a subtle change? When I sight along the hull of my classic Boston Whaler it appears to have a constant angle. Perhaps there is a slight variation of a some minor amount, too small to be seen by eye. Shall we bore deeper into the minute of this discussion? Or would someone like to return to the original question I posed: [W]hat will I have to give up if I change to a variable-deadrise hull [from a classic Boston Whaler hull)? |
| bsmotril |
What you might give up is a bit of fuel economy and some bouyancy up front. What you gain is less pounding as the finer bow cuts through the waves easier versus riding over them. Downside might be an occasional greenie over the bow. Grady White has been doing alright selling variable deadrise hulls for quite a while now. BillS |
Bill--You've given me a good idea--I need to go for a long ride in a Grady-White hull and see what it is like. Too much of my boating has been limited to Boston Whaler classic hulls and nothing else. I need to try some other styles to see what the difference might be. |
| Binkie |
jimh, that might not be such a good idea. You might get attached to some other brand of boat.What Will happen to your Whaler forum. Boats are like women, they can lure you in. Well, I guess you would always have room for a 13 foot Whaler. Rich |
| macfam |
I have ridden in many Grady White SeeV2 hulls. There is a distinct difference in the "Tournament" models that have the two seats and a walk-thru windshield, and a bow-riding area, vs the “Center-consoles”, vs a “Walk-around” model. The “Tournament” bow rider, and “Center console” models have significantly less weight in the bow area. They have far less tendency to “bow steer”. I find the Walk-around has substantial, perhaps too much, weight up front. The hulls are superior in head seas. They are very smooth over very steep chop. Yet, I have seen and felt a very pronounced “bow-steer” in following seas. Also in taking the waves and/or wakes broadside. A friend had a 1997 24’ Grady White Walk around with a 260hp Merc I/O. He has since moved to a 2450 Walk-around Pursuit with twin 115 Yamaha 4-strokes. There is no “perfect” hull for all conditions. All are “trade-offs” in one respect or another. |
| bsmotril |
Riding in different boats is good. Nine times out of ten, it makes me really appreciate my Whaler. The exception was the triple 250 hp Fountain 38 center console which had an amazing ride in 3-5s at 45 mph. Then I looked at the fuel burn and appreciated my Whaler even more. It never ceases to amaze me how two different maker's hulls which appear similar at first glance can ride totally different once you get them into some chop and wind. Where I fish, some of the local brands have taken on "slang" names to match their ride: |
| Lagniappe |
Jimh, Just wanted to get back to you, maybe clarify some of my points that I did not make clear :), much earlier in the thread. With regard to planning in my Outrage 17 with a variable vs. your 18 constant - in my opinion too the constant plans much better. I noted this becasue I felt sometimes planning speed was too much for conditions and countered the apparaent benefits of sharp entry, and I felt my 17 delivered a similar beating going into the waves as you described yours. With regard to weight distribution, did not mean to state the obvious. What I have learned about my variable and light (2052 lbs boat/motor) in rough water running, is that I needed to really weight the bow (100+ lbs on the casting deck, plus any people positioning). This reduces the bow poping up with each wave to my liking and comfort at speed. The other step I described was the turbo lift (Chuck Bennett from Whaler turned me on to this). The control this device has on trim is remarkable. Some squatting at 12mph, no appreciable at 13mph or better. Stability of bow at speed in the rough is equally impressive. My tinkering has made this boat much much better in the rough, by getting the bow down and keeping it there - thus actually benefiting from the sharp entry. These efforts allow me to run nearly level (no idea what percent that is) into reasonably rough waves at good speed. I have never stuffed it, although I will back speed down and trim down if better than 5's or some 4's. I was able to completely change the handling attributes with this variable hull, and tried to propose that degree of flexiblity may not be as feasible with a "constant" hull. Thanks for the great discussion topic ! john |
Gentlemen, thanks for the additional comments. They were very interesting reading. Perhaps we ought to organize a sort of ecumenical council or gathering. We could get some Pursuit and Grady-White boats to join us with our Whalers, and we could all go out boating for the day and swap boats and rides. |
| Binkie |
We would probably get more Whaler fans. |
| zotcha |
Jimh, are you coming to Beaufort, SC this fall. I'd like you to experience a "Potter hull" SeaCraft. And if you like that we can compare the flat bottom bath tub JS-04. Not sure which you'll appreciate more, but I'm sure you will be happy to get home to your Whaler. Oh yeah, please try riding in the Grady first. zot. Very interesting read, BTW. |
| gss036 |
Zotcha, I was wondering when someone would put something on this discussion about the SeaCraft hull. I sure love the ride of my Seacraft 23WA. I fish with a couple of guys, one has a Whaler, good ride but really bounces around on the short chop here in the Puget Sound/Gulf Islands. The other 2 are Bayliners, it is even hard to steer them out of the harbor and they just beat you to death with all the slamming. I wonder how they stay together. My buddy busted the engine mounts in his 24 Sierra (Bayliner)about 3-4 weeks ago. His wife says he is too proud to slow down in the chop. |
| zotcha |
gss036, do you belong to www.classicseacraft.com? Or do you just have a different user name? I hear there are quite a few in you neck of the woods. I'm not sure when Bayliner evolved but I know they were around in the late 70's and early 80's. I was well warned to stay clear of all of them. Especially the ones with the white (Force) engines with the cowlings removed. Guaranteed to lose a few hours towing it somewhere. The young dad with the giant red question mark STAMPED on his forehead, and the rest of the family curled up under the dash. Oh and never take your eyes off of them while in tow. Amazing how they will suddenly start, then try closing in on you to retrieve their tow line. Inexpensively priced, with first time buyer incentives, and very poor product quality. This is just my experience, and personal opinion, but I believe that line was one of the most popular brands ever sold from new car dealers. Maybe that was just a Jersey thing. I don't know, but I don't think I would go out in any ocean in a Bayliner. Unless of course I was being rescued from my sinking SeaCraft. That has been known to happen!?! zot. |
| Mobjack |
I have to preface this by saying I have never owned a Gay..oopps Bayliner, but what I do know to be fact is that here in the southern Ches Bay area they have a very poor reputation. Amazingly you still see a lot of them plowing around. There is no substitute for personal experience, but in my book when everyone I know who knows diddly squat about the water, from working on it to playing on it regards a certain product as garbage, its enough for me to take it as gospel. They make a damn fine artificial reef though... |
Here is a new term to add to the discussion: continuously-variable v-hulls. (These ought to be an adjunct discussion on continuousWave, eh?) This term comes from C. Raymond Hunt Associates. They use it to describe the hull they just designed for Southport Boat Works. Their hull is claimed to be designed specifically for the weight of twin V6 four-stroke motors, or more than 1,100-lbs of motor on the transom, not the puny 900-lbs of twin V6 two-strokes. The boats look like darn nice boats, and I imagine the price is right up there in the same strata as Grady-White and Whaler. Now one very interesting comment from that article is a reference to the better fuel economy provided by this hull, and in particular its ability to maintain plane at lower speeds (low 20-MPH region) but still get good fuel mileage. They say: "Most hulls have a narrow band of maximum economy, usually over 30 miles per hour." This is somewhat true for my own boat. The fuel economy peaks at 27 to 30 MPH. If I am not running in that band, the mileage falls off noticeably. Vector off to this article for more background: |
| macfam |
Cataumet Boats on Cape Cod, the exclusie Grady White dealer, dropped the Parker Boat line, and took on Southport. They must have made the right decision, because I've been seeing lots of them around Falmouth, Buzzards Bay and Martha's Vineyard. BTW, Edward's Boat Yard took on the Parker line and they are selling great. I have never seen so many Parker's, particularly the 23' with a cabin powered by single 225 or 250 Yamahas. I assume Boston Whalers #1 dealer Nauset Marine is still doing very well. With todays fuel prices, I'm continually amazed at the number of new premium boats I'm seeing. Jimh, you're right. These Southports are a premium boat with a premium price. Like you said, they are built for big time 4-stroke power, and it shows when you see them running. Got to get me a ride in one soon! |
| Sal A |
I have a 2005 Parker 2520SL with a Yamaha F250. It has a steep angled bow for cutting through chop, and a 16 degree deadrise at the transom. This 16 degree deadrise compares to the 14 degree deadrise on older Parker 2520 Sport Cabin MV models (modified V), and is designed to be a compromise for those who dont want the DV (deep v) 21 degree 2520's, and the added power those models take (typically at least twin F150's, or preferably twin F200's), as well as their propensity to rock more. I have ridden on the 21 degree Deep V's, and yes, they ride in rougher water more smoothly than the 14 degree or 16 degree deadrise models. This comes with a trade-off, as you might expect, which is that the 21 degree deadrise models use more fuel to push them, as well as noticeably more rocking on the drift. I can't imagine what the 24 degree deadrise Regulators or Contenders are like at drift in this regard, but given my propensity to not enjoy such heavy sea-motion, I would imagine those models are not for me. A more stable and probably fuel-efficient ride makes my 16 degree, nine foor beam, hull a nice compromise. For those that don't like pounding in chop, slowing down and generous trim tab use makes for a great ride, and a stable platform. I think this applies not only to Parker 2520 models. |
| Sal A |
http://www.thehulltruth.com/photos/photo-thumbnails.asp?albumid=1678 |
| Sal A |
I'm sorry; I hit submit too quick. In the above collection of pictures, one of them kind of displays the flattening out of the hull towards the transom as you look at its profile on blocks. Another stern view on blocks shows the 16 degree deadrise. |
| zotcha |
How funny. Had no idea Parker Sal was Sal A, from the Jersey Shoo-Wa. Small world. Vezo, Part II. This internet stuff never ceases to surprise me. Have a great day. Hope the Barnegat is nice today. I'm locked up at the firehouse. Oh well, only every third Sunday. |
| Rickie |
Interesting reading, but why all the discussion? We can only buy what is available on the market (new/old). Having actively boated for over 40 years, here is what I can share with you..... Bigger is BETTER!!! No joke intended:):) My 1982 20' Revenge was awesome in comparison to the 13' Classic Sport. My 27 Walkaround made the 20' seem like a pond boat. And, my 350 Defiance, well most people think it handles like a 42-43 footer. 5-7 Lake Erie footers at 29.2 mph sitting down on autopilot for 8.5 hours. I just wish BW was still making the Defiance and gearing up for a bigger one as I once again have no boat to dream about moving up too. |
| Mobjack |
Rickie, I am not sure how to respond to your post, as I tend to have mixed feelings about it. Bigger is always more comfortable when we're talking about travelling in heavy weather or big seas, I guess.... It depends on your hull type. But theres' a lot of baggage that comes along with a bigger boat.(more fuel, more engine, more worries, though you might not be worrying as much about getting capsized or something like that) I spent five years fishing the Alaskan coast near Kodiak Island for halibut and salmon in a 16 foot aluminum Lund skiff, and I now own a montauk which I take offshore a little bit, but mostly fish in the Ches Bay. I think "Bigger is always better" is a trap that a lot of boaters fall into. If you know how to handle a boat you can do twice as much with a smaller boat as a novice can do with his big boat. If I could swing a bigger boat I would probably go a little bigger, but I dont think size is the cure for everything, especially considering the maintenance and cost often associated with the upgrade. |
| Rickie |
Certainly going up a small river requires a low draft boat. My point was that being out in big water is a whole lot nicer in a bigger boat. Of course trailering a 35 with tower is not possible. The 27 has a 10' beam which makes a huge stability difference over an 8-6, but oversize for trailering. Revenge or Outrage 22 is about the most versatile compromise one can get. Can go big water, can trailer, easy to handle, and relatively low maintanance. |
| kingfish |
Second everything you said about a 22- John |
