ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Propeller for Revenge 22 WD
Author | Topic: Propeller for Revenge 22 WD |
maupilota |
posted 01-09-2007 11:52 AM ET (US)
I have bought from one boat little used Boston Whaler Revenge 22 Whaler Drive ,with motor Mercury Optimax 220 but without propeller. According to you which propeller would be adapted? From 17 o from 15. The propellers quicksilver 15 or 17 are goods? Thank's Maurizio Maschio Venezia Italia |
Tom W Clark |
posted 01-09-2007 12:10 PM ET (US)
Maurizio, Congratulations on your new boat and welcome to ContinuousWave.com. You should read this article: http://continuouswave.com/whaler/reference/propellerWDSingle.html Understand that your OptiMax may not have the same gear ratio as Jim's Evinrude. Look in your owner's manual for this information. It will may change the pitch you need. |
maupilota |
posted 01-09-2007 02:17 PM ET (US)
Tank's for the informations. I dont'have the manual of the my Optimax, but i will look for a copy. Regards, Maurizio |
Tom W Clark |
posted 01-09-2007 03:16 PM ET (US)
What year is your OptiMax 220? You can probably look that information up online. |
maupilota |
posted 01-09-2007 04:41 PM ET (US)
Optimax june 2006 |
Tom W Clark |
posted 01-09-2007 04:52 PM ET (US)
I *think* the gear ratio of your motor is 1.75:1 which is different than Jim's Evinrude with a 1.86:1 ratio. If this is true, then your propeller spins faster for any given engine spped (RPM) and thus you would necessarily choose a propeller with a lower pitch than Jim's boat uses, all other things be the same. |
maupilota |
posted 01-09-2007 06:04 PM ET (US)
I think so. Thank's for the information and for the time that you have dedicated to me. |
posted 01-10-2007 12:06 AM ET (US)
Try a Mercury MIRAGEplus three-blade with 15-inch pitch. |
maupilota |
posted 01-10-2007 12:11 PM ET (US)
Well , i'll try a Mirageplus 3-blade wit 15 inch pitch.It Will not easy to find it, because here they use a lot the solas and quicksilver. |
Tom W Clark |
posted 01-10-2007 12:29 PM ET (US)
A Quicksilver Thunderbolt propeller is exactly the same propeller as a Mercury Mirage, just a different name. |
maupilota |
posted 01-10-2007 12:43 PM ET (US)
Thanks, i did'n know it |
