posted 02-12-2007 01:35 PM ET (US)
I don't think it is practical. With a 12-inch jackplate, water will rise approximately 1-inch behind the transom while on a plane. If you have a high quality, high performance propeller with exceptional cupping, you can run the engine perhaps 2.5-inches higher than the lowest keel point. Theoretically, you would have to adjust the 12-inch jackplate down 1.5 inches from base.Note however that the powerhead would be closer to the water because (1) the increased transom weight distribution (increased aft displacement) caused by the weight of the engine extended 12-inches from the transon (via the jackplate), and (2) the additional 1.5-inch downward adjustment on the jackplate itself.
In practice, I mounted the same motor (c.1991) with a 25-inch shaft, on an Outrage-18 with a full transom, using a Slidemaster 12-inch jackplate. With a four blade Turbo Propeller (a high quality, high performance propeller with exceptional cupping) we were only able to raise the Jackplate +/- 1.5 inches. You would have to lower it 3.5-inches to achieve the same performance with a 20-inch shaft engine. That's pretty close to the water.
