ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 170 Montauk 90-HP Veradito: 44-MPH
Author | Topic: 170 Montauk 90-HP Veradito: 44-MPH |
WT |
posted 03-13-2007 05:36 PM ET (US)
Best speed downstream 45.5-MPH, best time upstream 42.6-MPH. So I averaged 44.05-MPH. Data: 1. River current was approximately 1.8 mph. I had just bought a used Laser II 20-inch pitch prop which I took to a Prop Scan shop. True pitch is 19.5-inch and my three blades where not uniform in length. The Prop Scan tech said I was going to get some vibration with this prop and he was absolutely correct. He said the prop was off balance a bit but within tolerances. I felt vibration at 3,000-RPM. I also have large vents which are opened on the prop. My old Vengeance prop according to Prop Scan was a lot better proportioned and balanced prop. Its pitch was supposed to be 18-inch but was actually 17.5-inch. I'm going to have Prop Scan balance and "blueprint" my used Laser II tomorrow. Let's see if I can average 45 mph after the prop is dialed in!! Warren |
Perry |
posted 03-13-2007 10:45 PM ET (US)
That is good performance Warren. What was the top speed with your old 90 HP Mercury four-stroke and how does the hole shot compare? Boston Whaler's performance data says that the same motor and prop pushes the new 170 Montauk to 46.6-MPH. I thought that figure was a little high for a 90-HP motor. |
WT |
posted 03-13-2007 11:04 PM ET (US)
My old 2004 Mercury and Yamaha carburetor 90 got me to 39 to 40-MPH. This new Laser II 20-inch pitch prop shoots me onto plane pretty fast as compared to my old 18-inch Vengeance. Comparing getting on plane between both motors, the new Veradito is much faster. So far the new Veradito is faster, quicker and less thirsty. :- ) Warren |
Teak Oil |
posted 03-14-2007 06:23 PM ET (US)
Good info thanks. If the Laser II was put on the old 90 probably 42 would have been the max so it sounds like the new 90 definitely has more oomph than the Mercaha. 44 in a 170 is good performance with 90 horses. |
WT |
posted 03-14-2007 08:42 PM ET (US)
My old 90 Mercaha couldn't spin a Laser II 20 pitch prop at 6000 rpm. It could only spin my old 18 pitch Vengeance to 6000 rpm. I can't complain about doing 44 mph on my 170 Montauk. :- ) Warren |
contender |
posted 03-14-2007 08:51 PM ET (US)
Question, What are you guys using to measure your speed, GPS or a radar gun? thanks |
WT |
posted 03-14-2007 08:56 PM ET (US)
GPS. Warren |
WT |
posted 03-14-2007 09:01 PM ET (US)
Boston Whaler's website has performance figures for the 2007 170 Montauk. It states that top speed is 46.6 mph. My unscientific results may help to confirm Boston Whaler's results. Warren |
sosmerc |
posted 03-15-2007 10:27 AM ET (US)
WT...I'll bet Whaler didn't test with a Laser II :) The info you are providing is great! And I think it will be especially helpful if you give us some test results AFTER you have your prop repaired by these Propscan folks. |
WT |
posted 03-15-2007 10:51 AM ET (US)
sosmerc: Boston Whaler did indeed us a 20 pitch Laser II. I believe that all new 170 Montauks purchased with the 90 Veradito come with the 20 pitch Laser II. http://www.whaler.com/Rec/pdfs/170MontaukEng.pdf I bought my used prop on Ebay for $165 with a hub kit. A new prop was quoted at $300-450 without a hub kit. The seller said the prop had 5 hours on it. The reason for him selling the prop was because he wanted a stern lifter not a bow lifter. The real reason was probably because the prop is slightly out of balance. Here's some information about Prop Scan. They will check your prop for free. I figure that a prop is one of the most important pieces of equipment for boating performance, so I may as well make sure that it is tuned for my boat. Warren |
WT |
posted 03-15-2007 11:33 AM ET (US)
My outboard is mounted on the second hole meaning I could move it up 3 more holes. |
sosmerc |
posted 03-15-2007 06:15 PM ET (US)
I stand corrected...I see they did use a Laser II. That really surprises me, as many of the tests I've seen Whaler conduct they seem to prefer to use a less expensive prop such as the Vengeance....but never the less, I'm glad to see they used it. I wonder if they ever really played much with engine height. If the gearcase performs as well as the L4 2 stroke version I know for a fact that the prop will work with the engine all the way up. I once rigged a 17 Super Sport with a 1988 100hp L4 and we put the motor as high up as it would go and tried the Laser II. It worked very well, and the high engine height eliminated a spray issue with that gearcase. He pulled skiers no problem, and ran pretty fast at top end. We put dual cable steering on it to tighten things up to reduce chine walk. Merc makes a much less expensive version of the Laser II called the Lightspeed. It doesn't have as nice a finish and the last one I ran didn't have the PVS system, but it performed just like the Laser II. |
imko |
posted 03-16-2007 09:28 AM ET (US)
Warren, I have also a Montauk 170 with a 90 4-stroke (2003)
WT |
posted 03-16-2007 11:28 AM ET (US)
Imko: Wow! Did you notice a HUGE difference between the stock 18 pitch Vengeance and the 20 pitch Laser II? Did you raise you outboard 1 hole or did it come mounted in the middle hole? I think I'm going to have my motor raised to the middle hole the next time I bring my boat in for service. Are your vents opened on your Laser II? If they are opened perhaps you could use some medium plugs to gain 200 rpm at WOT. Are you sure your Laser II is 13.25 inches in diameter and not 13.5 inches? I just picked up my Prop Scanned Laser II. I may not get much improvement in speed at WOT. In order to match the size of all 3 blades on my prop, my overall pitch was reduced by .43 inches. My pitch is now 19.118, it was 19.548 inches. I suppose the smaller pitch was recommended because I sometimes carry 1 or 2 additional fishermen on board. I could also close my vents. Warren |
WT |
posted 03-16-2007 11:42 AM ET (US)
My old 2004 Mercaha 90 would hit 42 mph prior to me loading up the 170 Montauk with additional weight. After I added the kicker, Turbo Lift, additional batteries, etc., my WOT speed decreased to about 39 mph. Warren |
imko |
posted 03-16-2007 05:29 PM ET (US)
Warren, There is a big difference between this 2 props! I use the std. small vent plugs. Top speed is with 1 person on board, and 1 tank fuel. With the Vengeance 18"prop i hit the rev. limiter (6200-6300 rpm) Mid range is a lot better http://i75.photobucket.com/albums/i285/ihoekstra/DSCF0536.jpg Good look with youre new Veradito!! http://www.boatservicedannijs.nl/nieuw_motoren_specs.php?id=149 Regards, Imko |
