Topic: DAUNTLESS 16, 115-HP Ficht: Stiletto 15-inch
Jefecinco |
posted 03-30-2007 09:01 AM ET (US)
Finally got the 1999 Dauntless 16 with 115-HP Evinrude Ficht motor on the water two days ago, and I was able to check the performance with the new Stiletto four-blade 13.25 X 15-inch pitch propeller. The performance was just about perfect with my normal fishing load in the boat. Hole shot and acceleration were vastly improved and WOT was 5,500-RPM which is on the low side of the maximum recommended 5,500 to 6,000-RPM. I'll provide more detailed information including speed numbers when I get the opportunity for a little more testing. The former, now spare, propeller is a Stiletto 13 1/4 X 19 three blade. Many thanks to Tom Clark, Sal, and others who gave of their time and expertise to help me. Sal, I have to tell you, four blades are sometimes better than three. When time permits I'll provide a more detailed report to include speed data. My engine uses so little fuel that it's a complete non-issue and I won't be calculating fuel usage. Butch
posted 03-30-2007 06:32 PM ET (US)
We look forward to seeing some data on the new propeller. It sounds like decreasing the pitch by four inches, a somewhat drastic change, has been beneficial, along with the change to four blades from three. |
posted 03-31-2007 07:51 AM ET (US)
Jim,Thank you. I was concerned that a four inch drop may have been too drastic but it is just about dead on. Tom Clark and other participants have an amazing appreciation for just what propeller adjustments can improve the performance of Boston Whaler boats. Butch |
Sal DiMercurio
posted 03-31-2007 08:30 AM ET (US)
Why do you feel it's perfect when it's at the lowest end of the rpm scale for that engine? The rpms have no place to go except lower, with just slightly more load. What advantage is the 4 blade other than getting on plane faster & staying on plane at a lower speed? Did you try a 3 blade 15p? I think you would be very surprised & very happy with a 3 blade 15p Stiletto. Your rpms would be up where they belong,....... your now 500 rpms shy of where they need to be, which means your over propped. I see no benifit at all with a 4 blade prop on a 16 ft boston whaler, other than the above mentioned, plus it looks nice when on the trailer. But if your happy with it, who am I to tell you your not? Sal
posted 03-31-2007 08:52 AM ET (US)
Golly, Sal, you're a hard sell.Although 6000 RPM is the absolute maximum recommended WOT RPM on the 115 FICHT on my boat I would never run at that speed for more than a few minutes. I've owned the boat and engine for eight years. During this first outing with the new propeller the boat was loaded at the highest weight it has ever seen or is likely to see. It remains to be seen how the engine will perform with the four blade propeller at a light or moderate load. I suspect it will come much closer to the 6000 RPM redline lightly loaded and perhaps around 5700 to 5800 RPM with a moderate load. Time will tell. Would you agree that in order to make 6000 WOT RPM with a light, moderate, and heavy load a variable pitch propeller would be required, or alternatively three different propellers? Eight years ago the three blade 19 inch pitch propeller seemed to work well except for hole shot which has always been disappointing before changing to the four blade propeller. Adding a hydrofoil improved hole shot but very little compared to the new propeller. The hydrofoil remains on the engine. I'm considering removing it before further testing as it may now be a liability. I certainly wont know until I try it. Butch |
Sal DiMercurio
posted 03-31-2007 09:49 AM ET (US)
Butch, in your first post, you said with a normal load, now it's a light load ????? If I remmeber correctly, you were only getting like 4800 or 5100 rpms with the 19p,...[ think it was you ]. If so, you were way over propped. You make the comment that you would rarely run your engine at WOT. When your over propped, the engine is over propped from the very second you put it in gear, not just at WOT. It's like putting semi truck tires on your pickup or car. Your first gear becomes 3rd gear instantly & there is no more 1st gear. Another explanation is, your going up a steep hill in your truck or car & towing your boat, your rpms are now down to 2500 & still droping, your foot is all the way to the floor board, & you still haven't down shifted or dropped your automatic tranny into a lower range & your only going 35 mph. How long do you think that engione can operate like that before telling you, "LATER PAL", I'm outta here. Thats the very same thing that happens to an outboard when it's over propped. It isn't only over propped at the top end, it's also over propped at 1,000 rpms, because the throttle is not where it should be at 1,000 rpms now, it's where it should be at 1500 or 2000 rpms, yet your only getting 1000 rpms. I got an e-mail from someone on another site, that the guy told me he propped his engine so it would only turn 4500 rpms, compared to the 6000 rpms recommended maximum, because he thought it would use less fuel........WHEW!!! Wrong big time. If he could only turn 4500 rpms yet his throttle was a wide open, he's using the absolute maximum fuel the engine can pull, yet he's going slower than the boat is capeable of. I'm not trying to put you down at all, just keep in mind, 4 blade & 5 blade props are for bass boats & boats much bigger than your 26 ft. Bass boats fish in very, very shallow water, & the reason they run 4 & 5 blade props is, they must get on plane as quick as possible so they don't hit rocks or logs under water. The bigger boats [ over 24 ft ] use 4 & 5 blade props for more power to hold them on plane at lower rpms, or get them on plane faster & in some cases, less vibration. I just don't see putting a 4 blade on a 16 ft boat unless your going to be pulling water skiers from deep water starts. More blades equal less top end speed & more low end grunt. Let us know if you can get a 15p 3 blade stiletto to compare. I don't think you will notice much difference between the 3 & 4 blade except for the cost of the 4 blade being higher. Sal Sal
posted 03-31-2007 06:18 PM ET (US)
Sal,Thanks again for the perspective. I'm not sure I completely understand everything you've said but I certainly believe you are correct. As earlier stated, the engine manufacturer recommends WOT RPM of 5500 to 6000. As the engine is now making 5500 RPM is it really lugging, or were you refering to the situation with the 19 inch propeller? I'll try to clarify a little bit then I'll reserve comment until I can report minimum RPM and speed to maintain plane, speed at WOT RPM, and, if I can time it, how many seconds it takes to get on plane. I'll try to have the data under three loading conditions light, moderate, and heavy. This may take some time but I'm determined to obtain the data. Finally, as you have correctly recalled I was unable to get over approximately 5000 RPM with the 19 inch three blade Stiletto with a heavy load. A heavy load for the boat is 25 gallons of fuel, three adult male fishermen with a lot of tackle, food and beverages, half full ice chest, a full five gallon live well, and all the electronics and safety equipment a prudent boater would carry. Moderate load would be two fishermen with a little less bait and ice. Light load would be just me running around without bait, tackle, food, etc. Unfortunately I'm unable to borrow a 15 inch three blade Stiletto propeller for testing or I would have done so before buying the four blade. Butch |
Sal DiMercurio
posted 03-31-2007 08:46 PM ET (US)
If you would have gone from that 19p 3 blade to a 15p 3 blade, you would have gained 800 rpms right now. The difference between your get on plane time now & with a 3 blade 15p will be about 1 second. Whats the advantage of getting on plane 1 second faster in a boston whaler? The difference in the price of the 4 blade prop vs the 3 blade sure dosen't justify 1 second faster out of the hole. Sal
tmann45
posted 04-01-2007 08:16 AM ET (US)
Sal, although you give lots of great advice, I can not agree with everything in your last post since jimh is such a stickler for facts. ________________________________________________________ When your over propped, the engine is over propped from the very second you put it in gear, not just at WOT. It isn't only over propped at the top end, it's also over propped at 1,000 rpms, because the throttle is not where it should be at 1,000 rpms now, it's where it should be at 1500 or 2000 rpms, yet your only getting 1000 rpms. ________________________________________________________If you look at a propeller curve, you will see that HP required by the prop at any given rpm is less that the engine is capable of producing until you get to the point where the prop HP and the engine HP curves cross. So, if you only idle around the harbor and never try to get up on plane, I would not consider that over propped for that use, even if you can’t get on plane because you might only be using 5 HP when the engine can produce 20 hp at that idling rpm. Just an example, not a realistic situation. If you want to use all of the HP that the engine is capable of producing, yes, you have to prop it so that the prop HP and the engine HP curves cross at the maximum engine rated rpm. __________________________________________________________ If he could only turn 4500 rpms yet his throttle was a wide open, he's using the absolute maximum fuel the engine can pull, yet he's going slower than the boat is capeable of. __________________________________________________________ Fuel consumption is not dependent on throttle position, but HP output. HP at 4500 rpm is usually less than at 5500-6000 rpm, therefore fuel usage is less. Look at it this way, with the throttle wide open, at 4500 rpm the engine is sucking less air that at 6000 rpm. An engine needs the correct air fuel ratio to run, does not matter what rpm or loading, the mixture ratio stays the same. So, at 4500 rpm, less air is being used therefore less fuel than at 6000 rpm. Thus, you are not using the maximum fuel the engine can pull, but you are using the maximum HP the engine can produce at that 4500 rpm, and you are using the maximum fuel the engine can use at that 4500 rpm, which is less that it can use at 6000 rpm. Just some finer points to consider. Tom |
Tom W Clark
posted 04-01-2007 10:48 AM ET (US)
Actually Sal and Tom, both of you are somewhat correct and somewhat wrong, but good points have been made. At any rate, nobody wants to be over propped but I am not sure Butch is.Butch, The recommended WOT range for your motor is 5500-6000 RPM. You have reached 5500 RPM with your new propeller. Strictly speaking, you are fine. If you were egregiously over propped, the manufacturer would NOT say it is OK to have a WOT engine speed of 5500 RPM. However, I have found that most outboards will simply perform better if they are propped to reach the upper end of the RPM range. In your case, the range is small. If indeed you were more heavily loaded than ever before, then by all means go back out and test again under more normal conditions. The other thing we have not talked about is motor mounting height. You will find that the Stiletto props will tolerate much higher engine mounting heights. Depending on where your motor is now, you might consider raising one set of holes and re-testing. |
Sal DiMercurio
posted 04-01-2007 10:50 AM ET (US)
Tom, if rpms is what uses more fuel instead of less rpms pushing or pulling a bigger load, why does your pickup get better fuel economy when driving on a flat freeway at 55 mph, comparded to climbing through the mountains with your foot much farther into the throttle & only getting 35 - 40 mph at the same rpm. When driving up a hill your engine is working much harder to maintain the same rpm & your foot is much farther down on the throttle & using way more fuel, yet your rpms are near the same as the freeway? I have a 5 speed 4x4 stick shift & if I don't down shift to turn more rpms while going up a steep hill, my fuel economy goes out the window. When I down shift & only use 1/2 of the throttle travel, my rpms go up & so does my fuel economy. On a carbed engine, 1/2 of the fuel is going out the exhaust un-burned, because the engine isn't turning enough rpms to burn it, but back off on the throttle & the prop catches up to the engine at less throttle advance, yet the same rpm & it burns less fuel. Also, which engine is going to last much longer, the one that can only reach 4600 or 4800 rpms at wot, or the one that can reach it's recommended maximum rpm of 5800 or 6000? Please don't give people the idea that propping their engines to turn less rpms is the way to get better fuel economy, because thats a crock. Sal
posted 04-01-2007 11:25 AM ET (US)
Thanks to Tom (tmann45) for joining the discussion.If I may, let me restate what he said about horsepower and boat speed. We have seen (from Crouch's forumula) that as boat speed is increased, the amount of horsepower needed to produce this increase goes up exponentially by the power of 2 (or "squared"). We have also seen from manufacturer's charts of horsepower as a function of engine speed that the engine power output tends to increase as a linear function (i.e., not an exponential rate of increase). As engine speed increases, horsepower increases in a linear fashion. (Note that in some engines horsepower will actually decrease above a certain engine speed.) From these two observations we can see that as the boat speed decreases from the maximum, the rate at which the actual engine horsepower output decreases will be less than the rate at which the propeller shaft horsepower needed decreases. In other words, the two curves meet at maximum boat speed, but below that the engine should always be able to produce more horsepower than is needed by the propeller shaft for a given engine and propeller shaft speed. This situation is the definition of being properly "prop-ed". (I am going away to see if I can generate a graph that shows this relationship.) |
tmann45
posted 04-01-2007 12:58 PM ET (US)
Sal, nowhere in my post did I mean to say that higher rpm used more fuel than less rpm at the same hp being used.Nowhere in my post did I say that over propping would give you better fuel economy. I apologize if my post was not clear. What I said is that fuel usage is related to hp produced and usually an engine can produce more hp at higher rpm, therefore it can use more fuel at higher rpm, but that is only because it can produce more hp at the higher rpm. But, the amount of hp an engine CAN produce at any rpm is not necessarily the hp being used, this is two different things. Jim discussed this above. Fuel usage is directly related to power produced to move the desired load at a certain rate. If your WOT is 4500 rpm at 30 mph you will be using less fuel per mile than WOT at 6000 rpm and 45 mph, does that make sense? Theoretically, ignoring prop and engine efficiency at different rpms, moving your boat at 30 mph uses the same amount of fuel, whether it is at 3000 or 6000 rpm, 100 or 200 hp engine. This has gotten off topic, but to continue the thought train, I posted here. Tom
posted 04-29-2007 07:59 PM ET (US)
Today I finally raised the engine on my Dauntless one hole. It is now in the third hole so only one is left.The work was both more difficult than I imagined and easier. The reasons the job was difficult were: 1. I had never done this job. 2. I had no help. 3. My drive is not level so the boat was not level. The reason the job was easier was that I had good advice from forum members. One issue that could have been a problem was that the engine was low on one side while attempting to line up the holes. This was solved by using a piece of wood and a mallet to move the wood under the skeg to the side resulting in perfect hole alignment. I've applied liberal amounts of Boat Life Caulk as recommended. Now, I'm looking forward to trying the boat once more. Is this fun, or what? Butch |
posted 04-30-2007 09:31 AM ET (US)
An unforeseen consequence was that the boat cover no longer fits as well. If I raise the engine to the final hole another cover will be required.Butch |
lordswork2007
posted 04-30-2007 01:26 PM ET (US)
Confusion abounds in this area.Jimh, your observation that hp increases "linearly" with engine speed (RPM) is half right. It is true only under full throttle. In actuality when RPM is decreased it is usually by the throttle. Fuel consumption varies more or less linearly with RPM and also linearly with manifold pressure (throttle). Sal is wrong I believe in stating categorically that there can be no improvement in fuel economy with overpropping. The automotive analogy supports this, where very tall final gears ("overdrive") are most economical, yet they do not yield highest top speed (and nowhere near maximum RPM at highest speed). My BMW 540 6sp is actually fastest in 4th gear, but quieter and more economical in 6th. Why more economical? Less engine friction is the main reason. Plus there may be slight improvements in combustion efficiency in running at slightly higher manifold pressure and slightly lower RPM. Throttle timed carburated outboards may be mistimed when overpropped. Modern computer outboards, and inboards, should be perfectly happy running at full throttle a thousand RPM less than max. For middle speeds, this arrangement may in fact yield improvements in noise and fuel economy.
lordswork2007
posted 04-30-2007 02:56 PM ET (US)
ContinuationThis is not to say that manifold pressure varies linearly with RPM. MP (throttle setting) varies with RPM in a complex relationship that depends on the boat. For a static propeller that is not cavitating, MP varies as the square of RPM, and power (and fuel) thus vary as the square times the linear, or the cube. For planing boats at middle speeds, MP varies more linearly with RPM (giving a square relationship between power and speed, as cited in this thread). At high speeds (and static props as noted above) MP is more nearly a square function of RPM, resulting in the power varying as the cube. The reason for this is essentially that there are two major drag functions at work in a planing vessel, frictional drag and wave-making drag. Frictional drag is proportional to the wetted area times the square of the speed. Wave making drag is complex and generally decreases with speed. Wetted area often decreases with speed, at the slight expense of an increase in wave making drag, though. Aerodynamic resistance increases as the square of the speed, but under about 50 mph it is a minor term. Manifold pressure for any given setup is proportional to total drag. RPM is related linearly to speed and secondarily to drag, the latter by slip. |
posted 05-29-2007 07:25 PM ET (US)
Seems as though the propeller is now dialed in just about perfectly.Finally got on the water today to test the result of raising the engine one hole. WOT was about 5950 and speed was about 42 MPH GPS. I believe I can get to 6000 RPM WOT with a little bit more work on engine trim adjustment. Conditions today were not great. A lot of wind and 1 to 3 footers of chop. The readings were into the wind, BTW. Not sure of wind speed but estimate about 10 - 20 MPH. The propeller wants to ventilate in sharpish turns with the trim at or near maximum. My idea of maximum trim is the point just before porposing begins. I believe a better result aill be observed in better conditions. I would have chosen a better day for testing but this was the day the planets permitted a fishing trip for me and one of my regular partners. I have to admit my spouse does not allow me to be on the water by myself and she prefers not to be on the boat. I will try to get out on a good testing day and record some numbers while taking the time to get the best result possible by adjusting trim. One very beneficial result of the propeller change and engine height adjustment is that I'm now able to remain on plane at 3000 RPM. Previously, 3500 RPM was about the minimum. Time to get on plane is about three seconds and I have to start trimming the engine out about the time I give it full throttle to get on plane. Performance is now so good that I often leave the engine trimmed when it's time to move and the hole shot is quite good with the engine fully trimmed. I'm very happy with the preliminary results. A big thank you to all who helped with special thanks to Tom W Clark. Butch |
andygere
posted 05-31-2007 02:29 PM ET (US)
Having spent a fair amount of time operating my dad's Dauntless 16, I am not at all surprised that this boat is able to benefit from a 4 blade prop. The Dauntless is a fine boat, but it is notoriously slow to get on plane, and tends to have a bow-up attitude while it's climbing the bow wave as it comes on plane. Any prop that provides a better holeshot, and gets a better "bite" as the boat comes on plane will improve the performance of this hull. I am a big fan of multi blade props because all else being equal they:1) Get you on plane faster 2) Allow you to stay on plane at a lower speed. These are significant advantages for many boaters, and are probably not limited to ski boat and bass boat owners. It sounds like Butch has found an ideal prop for his setup, and 42 mph on that boat in a chop is pretty impressive, as is 3 seconds to plane. I have been trying to convince my dad to get rid of his aluminum 3-blade prop and replace it with a better performing stainless prop to solve some of the problems noted above, and this is encouraging information. |
Tom W Clark
posted 06-01-2007 09:48 AM ET (US)
Butch,I am glad we were able to get you dialed in so well. It is interesting to note that engine height, in addition to the propeller selection can make a significant difference in the performance of one's boat. The Stiletto's are known to tolerate higher mounting heights and in this case it seems to have been of some benefit. |
posted 06-01-2007 09:51 AM ET (US)
Andy,I just plugged in the numbers from the latest WOT result on my engine. The resulting slip calculation was 0.6 which seems much too good to be true. Do you think it's possible the HP rating on my engine is slightly understated at 115? I've heard that many FICHT engines produce slightly more HP than indicated on the data plate. Butch |
Tom W Clark
posted 06-01-2007 09:54 AM ET (US)
Butch,Regarding your slip numbers, what you report is typical of the Stiletto propellers. They seem to perform like a propeller with two more inches of pitch than indicated. This is why I usually recommend folks drop to the next lower pitch model when switching to a Stiletto from some other brand of propeller. I generally add two inches of pitch when doing theoretical propeller calculations of a Stiletto with normal slip figures. |
posted 06-02-2007 10:16 AM ET (US)
Tom,Thank you. I recalculated the slip based on a 17 inch pitch. The result was 13 percent. Is slip influenced by conditions such as load, sea state, and wind speed and direction? I assume it is but admit to being a complete ignoramus on boat performance issues. I'm guessing that if speed is higher than the 42 MPH used in the calculation that slip would be lower and that therefore conditions have everything to do with slip. But, if more favorable conditions simply allow the RPM to increase along with speed then slip will be more constant. Does this make sense and is 13 percent slip reasonable? I'd guess less slip equals more efficiency and therfore one would seek to minimize slip. True? Butch |
Tom W Clark
posted 06-02-2007 10:31 AM ET (US)
Butch,13 percent slip is perfectly reasonable. Understand that you reached that conclusion simply be inputting an artificially raised pitch, but yes, 13 percent is fine under most circumstances. Conditions will affect the propeller slip to some small degree but certainly does not "have everything to do with slip." No, lower propeller slip is *not* necessarily better. I think there is a bit too much attention paid to propeller slip. Ultimately you need to look at the performance of the boat, speed, fuel economy and handling. Hey, if a boat is simply faster with a propeller that yields a high slip factor (as is often the case), then so be it. |
posted 11-17-2007 10:13 AM ET (US)
Went fishing yesterday and the bite was terrific.But, the reason for this post is to report on WOT performance. It was a cool morning with air temp of about 50F degrees at 0730. Chop was light at about 8 inches. Wind was around 7 MPH. The tide was falling. Two aboard with the usual live bait, ice, lunch, and gear. Running upstream with the wind on the forward quarter WOT was 6000 RPM, trim was at maximum tilt and GPS ground speed was 44 - 45 MPH. This was in salt water at 60F degrees. I found that to be quite surprising but welcome news. Due to the current and head wind I was very surprised at speed over the ground. In the afternoon the air temp was 72F degrees and the tide was slack with virtually no current. The water was mirror flat aith a temp of 69F degrees. Wind was from behing at about 6 MPH. Weight had increaed by about 25 pounds. At this time I was able to make only about 5900 - 5950 RPM WOT with speed over the ground of 42 - 43 MPH. The only thing I can attribute to the difference in speed over the ground and WOT RPM is the chop earlier in the AM. I believe my boat, engine, propeller combination is about as well tuned in for optimum performance as possible without custom propeller tuning or professional adjustments in which I have no interest. I hope this thread will be of some use to other Dauntless 16 owners. Tom, thanks for the perfect propeller for my needs. Butch |
Skipjack 17
posted 11-17-2007 11:02 AM ET (US)
My hats off to Tom,Tom He recommended a Stiletto three-blade 19-inch pitch propeller and the numbers were excellent for our 115-ETEC. This prop actually holds the boat in the water better at faster speed and produces a safer ride. After a small modification of the intake manifold by the dealer this pro hits close to 48 MPH at 5700 RPM. BRP is actually recommending to the dealers a to shoot for a range of 5600-5800 RPM for the 115-ETEC motors. Thanks Tom
Tom W Clark
posted 11-17-2007 07:50 PM ET (US)
Butch, Bob,I'm glad I was able to help you guys out. You have learned that the correct prop *can* make a big difference in a boat's performance. |
cooper1958nc
posted 11-17-2007 11:47 PM ET (US)
The difference in speed is probably at least partly attributed to the difference in air temperature. Power is increased percentagewise inversely proportional to the change in absolute temperature. The reason is that air density is inversely proportional to absolute temperature.A 20 degree F rise in temperature is reduces power to 95% (convert both temps to absolute by adding 459, then divide). If boat speed varies as the square root of the power (a fair assumption) you get 97% of your former speed, which is about what you got.
posted 11-18-2007 10:06 AM ET (US)
The air temperature is a factor I had not considered. What about the different sea conditions? How much, if any, share of the speed difference can be attributed to a slight chop vs flat calm conditions?As this is a year round boating area perhaps we should have a seasonal selection of three peopellers; a Spring/Fall, Winter, and Summer propeller. Butch |
Tom W Clark
posted 11-18-2007 11:14 AM ET (US)
Butch,While the air temperature (and hence air density) certainly does affect the power output of an outboard, the speed difference you experienced was mostly attributable to the short steep chop you were running in that morning. Anytime you introduce more air under a hull, the friction will be greatly reduced and your speed will go up. |
Sal DiMercurio
posted 11-18-2007 11:19 AM ET (US)
Tom is dead right. Many people think that glasssy water is optimum for prop testing & top end speed, but that couldn't be farther from the truth, because 1' very close chop, is optimum water for top end performance. Air under the boat, is where it's at. Couldn't have said it better Tom. Sal |
cooper1958nc
posted 11-19-2007 06:53 PM ET (US)
I would like to see some substantiation for the proposition that running in a 1' chop increases speed. I agree it *feels* faster, but where is the proof of increased speed? |
Tom W Clark
posted 11-20-2007 10:14 AM ET (US)
Proof is as near as your GPS. It is very obvious that light chop increases speed if you observe your GPS. Try it.One foot chop for a 16 foot dauntless is not going to work unless the chop is extremely steep as when a wind opposes a strong current. |
