ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Outrage 22 with 30-Inch Set Back Bracket
Author | Topic: Outrage 22 with 30-Inch Set Back Bracket |
mikejana |
posted 04-11-2007 11:50 PM ET (US)
I just puchased one of the Yamaha OX66 250s from crbenny. I am placing the motor on the back of a 22 Outrage with a 30 inch aluminum setback bracket. While this may seem like a rehash of this discussion: http://continuouswave.com/ubb/Forum4/HTML/005238.html , my interest is more than academic. The bracket is expected to arrive no later than May 1 and I hope to splash that month. My outrage has neither the cuddy cap nor the large tank of crbenny. (also no bottom paint and no t-top) PROPer suggestions are appreciated. Thanks, Mike |
John from Madison CT |
posted 04-12-2007 07:19 AM ET (US)
I'd go with the Yamaha Saltwater Series in 15.25" x 19". |
posted 04-12-2007 07:33 AM ET (US)
I am looking forward to seeing some pictures of the bracket installation and seeing some performance numbers for this boat. |
Tom W Clark |
posted 04-12-2007 10:11 AM ET (US)
I recommend a 15-1/4" x 19" Mercury Mirage Plus three blade, 14-5/8" x 19" Mecury Revolution 4 or a 14" x 21" Mercury Offshore/Vensura four blade prop. |
mikejana |
posted 04-12-2007 10:57 AM ET (US)
Jimh- I am trying to document my project and will submit what i can, thanks Tom, Mike |
Tom W Clark |
posted 04-12-2007 11:03 AM ET (US)
Mike, I do have a few used props laying around... |
mikejana |
posted 06-24-2007 12:18 PM ET (US)
Follow up advice now that it floats..... I have not yet added electronics or finished the details, but We have had it in the water 4 times to work out the kinks. It seems that the 15-1/4" x 19" Mercury Mirage Plus three blade prop may be a little too much. With less than 400 pounds aboard plus 20ish gallons of gas; 31 mph at 3300 rpm; 51 mph at 5300 rpm (max). The motor is mounted with the cavitation plate 3 1/2 inches above extended keel line. Seems to be correct from my observations while running. I get extreme porpoising before I can trim out to higher RPMs. Thanks, Mike |
Tom W Clark |
posted 06-24-2007 12:24 PM ET (US)
I don't know Mike, sounds pretty darn good to me. Full fuel, big passengers and still 49 MPH at 5200 RPM on a motor with a 4500-5500 WOT RPM range? If the boat is propoisng, try raising the motor another set of bolt holes. |
mikejana |
posted 06-24-2007 06:05 PM ET (US)
Thanks Tom, I was under the impression I should be looking for 5800-6000 rpm. Mike |
Tom W Clark |
posted 06-24-2007 06:56 PM ET (US)
Mike, Well, I could be wrong. Check your owner's manual. I was operating a fiend's Yamaha 250 OX66 last weekend and I believe John said 4500-5500. His was performing very well at 5100 RPM at WOT. |
Tom W Clark |
posted 06-24-2007 06:58 PM ET (US)
Oh, one other thing. I'm serious about you raising your motor more. 3-1/2" is not much when set back 30 inches. I've seen motors perform optimally at 2-7/8" above the keel when only set back 10 inches! |
mikejana |
posted 06-25-2007 07:52 AM ET (US)
Only one more hole up avilable, I'll try it. Thanks again. Mike |
Peter |
posted 06-25-2007 08:01 AM ET (US)
5500 RPM is redline on that motor. |
mikejana |
posted 06-27-2007 05:34 AM ET (US)
Thanks- mike |
