ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Recommended Engine Shaft Length For Boston Whaler Boats
Author | Topic: Recommended Engine Shaft Length For Boston Whaler Boats |
kenny2831 |
posted 07-01-2007 08:35 PM ET (US)
I'm looking to purchase a early 1990's 25 outrage with twin 150's that needs repowering. I heard that this boat needs 20 inch shafts for twins. Can anyone verify that info is accurate? What would happen if repowered with 25 inch shafts? |
Tom W Clark |
posted 07-01-2007 08:42 PM ET (US)
That is correct, the classic 25s use 20" shaft length twins or a single 25" shaft length motor. You can use twin 25" shaft length motors but you will need to use jack plates with each of them to raise the motors that extra 5". This would not be a big deal and would result in a pretty nice set up of counter rotating motors, something you don't get with 20" motor (unless you modify one of them.) |
kenny2831 |
posted 07-01-2007 09:11 PM ET (US)
Ok thanks for the help. I'm looking at a pair of used 150 4 strokes with one counter rotating. |
Tom W Clark |
posted 07-01-2007 09:24 PM ET (US)
Yes, that would be very nice power for an Outrage 25. |
posted 07-02-2007 08:01 PM ET (US)
Information about recommended shaft length is provided in the REFERENCE section. See http://continuouswave.com/whaler/reference/specifications.html |
