Topic: Re-power: Propeller, Jack Plate
ChiTown Cetacean |
posted 08-09-2007 06:12 PM ET (US)
I am repowering my 1973 Outrage 19 (Whaler 19) with a 1998 Johnson Oceanpro 150. This has a 25 inch shaft, and my Outrage has a 20 inch transom, so a jack plate will be needed.I would very much appreciate some suggestions as to what jack plate and prop would be best. Thanks in advance.
Tom W Clark
posted 08-10-2007 11:12 AM ET (US)
The CMC jack plate would be a good choice.An OMC/BRP 14-1/2" x 19" pitch SST or Viper would be a good propeller choice as would a 14-1/4" x 17" Stiletto Advantage II. |
Tohsgib
posted 08-10-2007 12:19 PM ET (US)
Had a 175 ocean runner 25" on my 19 Revenge and she ran a 19" SST so your 150 on a lighter outrage should do about the same (50+mph). |
towboater
posted 08-11-2007 01:47 PM ET (US)
I have a CMC 4" offset manual adj prepared to install on the back of my 18 and carry a 150 Merc 2 stroke. No lag bolts. I plated both sides of the transom with 1/4 alum. (Work boat). Check Cabellas pricing for CMC jackplates. I have a boom truck (removing outboards is a snap). Just for grins I am plan to do a before and after 4" offset performace comparison. mk |
Sal DiMercurio
posted 08-11-2007 07:18 PM ET (US)
Go top ,...."Bob's Machine Shop.com" & select the manual 5" setback, 5" lift plate. You can turn it around so it is only 2.5" setback, instead of 5" setback. I have that jackplate on both of my whalers [ 15' & 20' ]. Call them at their 800 number & tell them what you have & what do they suggest. They will tell you exactly what you need. You might also order their transom back plates with their name on it. It is a 3/8" thick backing plate you put on the inside of the transom & the bolts go over them,...also looks very very nice besides beefing up your transom. They also sell the kit with all the s/s nylon locking nuts, bolts & washers that your going to need. Cheaper than the hardware store. I think $25.00 The plate is very, very, very easy to install, & you just bolt the engine to it. Sal |
ChiTown Cetacean
posted 08-11-2007 11:12 PM ET (US)
Thank you to all of you for your great advice. It is much appreciated because this is my first boat, and of course, my choice was to go Classic Whaler... |
Rob Schmidt
posted 08-13-2007 11:46 AM ET (US)
I have a 14.25 x 17 Stiletto Advantage II, three blade, polished stainless steel propeller (the same that Tom mentioned) for sale for $215.00 (includes shipping.) Used three times, perfect condition. Let me know if you are interested. robertschmidt@allstate.com |
