Topic: Hydrofoil on 13ft Sport
RICHNLE |
posted 08-17-2007 08:50 AM ET (US)
RICHNLE posted 08-16-2007 04:40 PM ET (US) I have a 2004 13ft Sport with a 40hp Merc 4 stroke. The boat tends to porpoise badly unless I have the trim all the way down and add weight to the front of the boat. I would like to add Doelfins or Stingrays to help. Can anyone comment on how either of these products reduce porpoising on the 13ft sport? I know that both products reduce minimum planing speed and bow rise, but my main objective is eliminating the porpoisiong. The Stingray Jrs (1.5 - 40HP) and Seniors (25 - 365HP)both fit this engine, so please indicate which model you have. Thanks for the help!Rich Plotman posted 08-16-2007 05:13 PM ET (US) Raise the engine first. HuronBob posted 08-16-2007 07:47 PM ET (US) my 130 sport (also a 2004) doesn't porpoise at all, it never has, but I've always run my engine trimmed almost (just a bit up to reduce the vibration that happens when the engine is tight against the transom). I've never had to add weight to the front of the boat. I guess I'm wondering why you wouldn't want it trimmed all the way down? As for the Doelfin...it was a great addition to the boat, I would recommend it in a minute to anyone with the same configuration. jimh posted 08-16-2007 09:24 PM ET (US) Good topic for PERFORMANCE. Please move there.
Tadpole
posted 08-17-2007 09:16 AM ET (US)
Had a stringray years ago; didn’t like the sharp downward pointing leading edge – imagine the side view of airplane wing, but with sharp leading edge. It was hard to dial in engine height so that the leading didn’t bite and cause excessive drag.I used a dolphin for a while and liked it – with engine height such that it skimmed the surface at planning speed. But, “I” wanted the slowest planning speed possible, so I used the dolphin as a template, made new ones that extend 3” further to the back - out of 3/16” aluminum, and 100% pleased.
skred
posted 08-17-2007 10:18 AM ET (US)
I have a 2002 130 with the 40 Merc EFI. I installed the Tiger Shark VG on mine. Porpoising is gone. Pops on plane much faster, and planes at as little as 13 mph. I did notice, however, that when running, the hydrofoil on mine is not out of the water completely. I plan to move the motor up one hole to alleviate that. I'll report on any changes in performance. I also used the Tiger Shark on my former Dauntless 16 with significant improvement in performance.
CaMoFroG
posted 08-17-2007 12:45 PM ET (US)
Hi i have a 2006 130 Sport with the 40 hp EFI Mercury, i put a SE Sport 300 Hydrofoil .. big difference i love it. if i trim it up to much i can still get it to porpoise ...just a little... but can easily trim it down a touch and it goes away. I do not have to have the motor all the way down either.the other thing i would recommend is get a stainless 4 blade trophy sport mercury prop i use the 12 pitch its cupped and i hit max wot rpm 5700 ... i dont have a speedometer but it doesn't "feel" any slower. 30 to 35+ mph I can pull a 200lb adult skier no problem, with three people in the boat. I can still plane off and hit about 4500 rpm with 900+ lbs in the boat |
