Topic: E-TEC 200 H.O. Sensor Problem
Rob Pirie |
posted 10-03-2007 08:58 PM ET (US)
My new boat has a 2006 Evinrude E-TEC 200 H.O. I have a problem that no one seems to be able to solve especially my mechanic. When I am idling out of the marina and when I hit the open water and push the throttle down immediately the over heat sensor comes on , I then put it in neutral turn off then turn on and the engine fires straight back up and I'm away with no heating problems.This happens about 50% of the time not every time and only the instant you push the throttle down. Other than that I never have a heating problem. My mechanic swore it was water pressure problem. I told him it can't be it's too quick and if it was hot why is the engine still not over heated on the immediate restart. It has to be a computer or sensor error. He got his way and ran a water pressure test. Guess what--100% OK. He then hooked up the computer with me on board and it showed the engine over heating to 130-degree-C, but I said to him, "what is the temp after the immediate restart?" 73-degree-C. I told him an engine can't cool down almost 60-degree-C in one second; it has to be a fault in the sensors or the computer. Finally he is on my side of the fence now, but he doesn't know what to do . It has the latest mapping program and both sensors on the port and starboard side are randomly sending hot temperatures. If you ease the throttle forward slowly everything is fine. The engine also changes speed at low speed approximately 200-RPM on its own, if that has any relevance. Any advice will be greatly appreciated. Thanks--Rob
djd35de
posted 10-03-2007 10:03 PM ET (US)
If he can scan it and see live data. Pull the connector off a sensor and note the reading. Should read very hot max degrees. Next cross the connector with a wire or paper clip and should read max cold reading. Do this on both sensor circuits. This checks the wiring circuit back to the computer. If they read the same , say 250 degrees F and say - 40 degrees F. Then the wiring is ok, If not you could have a bad ground. Maybe both sensors share the same ground. Check all connections in both circuits. Another good test is the wiggle test. While watching the live data on the scanner, wiggle each temp sensor connector. If it glitches you have a loose connection. Its also possible that a pin at the computer is not making a good contact. Remove the connection at the PCM and look at all the pins. Sometimes a dab of grease will help make a good contact. When you do this the key must be on. Good luck David
Rob Pirie
posted 10-03-2007 10:31 PM ET (US)
Thanks David I have forwarded your response to my mechanic , I think you are on the money as he has looked the plug connectors prior to this and he did say there was some paint on them , they have been cleaned but maybe another look is required.Thanks Rob |
djd35de
posted 10-04-2007 12:51 AM ET (US)
Your welcome Rob. Tell him to clean off the paint for sure as that will only insulate from having a good connection. I have a feeling it'll be something simple.
Good luck David |
Rob Pirie
posted 10-04-2007 01:30 AM ET (US)
David how is this for frustrating.I rang BRP Bombardier headquaters here in Australia and explained in detail to their top man my problem including the data from today's computer read out.Even though the engine isn't physically over heating he still got my mechanic to check the water tube lengths inside the engine thinking this would solve the problem thinking that the engine wasn't getting the water..... My mechanic tried it (which I can't believe he did) and guess what all is fine. I told my mechanic to check his email and try what you suggested , why he bothered with the water tube is beyond me. BRP Bombardier Australia has now gone to BRP Bombardier USA for some advice , I thought my Optimax's were a pain in the ass because of the lack of expertise here In Australia looks like the ETEC'S will take top billing for that. I'll keep you posted. Rob |
seahorse
posted 10-04-2007 02:01 AM ET (US)
Rob,Some of the earlier E-TEC V-6 engines had a software glitch that would give intermittent false overheat warnings. Having the dealer install the latest revision takes care of the problem. It's a quick, easy, and free fix. It sounds like your dealer tech is not "up to speed" or trained in these motors. |
seahorse
posted 10-04-2007 02:05 AM ET (US)
I forgot to add that some of the first E-TEC V-6's had a mis-machined hole in the thermostat cavity. There was a service bulletin published about it and it only affected a small number of motors determined by serial numbers. The hole is easily drilled out by a tech. |
Rob Pirie
posted 10-04-2007 07:31 PM ET (US)
The engine has all latest updates I actually checked this with him online . I didn't see any date regarding temp sensors though ? They may not be availble Down Under ? I let him know about this plus the thermosats.Thanks Seahorse. Rob |
djd35de
posted 10-04-2007 09:10 PM ET (US)
Rob I really believe its just a bad connection. The reason is you said as soon as you give it gas you get the over heat warning. Something must be loose.
If you have the wiring diagram or can get it. Follow the ground circiut for the coolant temp sensors. If they both share the same ground there's a good chance thats the problem. Remove it and clean it make sure there's no paint where it connects. Next just check the connector at the sensors. You said there was paint at the sensor, clean it off and make sure it a good tight fit. And if this solves your problem . Tell the factory you want a job being a consultant and demand big $$$$ LOL good luck David
Rob Pirie
posted 10-04-2007 09:16 PM ET (US)
David I going with you , I'm picking the boat up from the mechanic this arvo I've had a gut full of this crap.I can pull my Optimax's apart blind folded I'll back myself on this and try what you said. You might get a thread on Monday:- 2006 200hp ETEC won't start PLEASE HELP... LOL... THANKS FOR ALL YOUR ADVICE Rob |
seahorse
posted 10-05-2007 12:55 AM ET (US)
Rob Pirie posted 10-04-2007 07:31 PM ET (US) ----------------------------------------------------------- The engine has all latest updates I actually checked this with him online... Rob,
Ask the mechanic what is the revision number for the latest software in your motor? If you were given a printout of the computer report, it would be on there. I can then check if it is up to date. Post your serial number and I'll check if your motor was included in the undrilled hole service campaign. |
Rob Pirie
posted 10-08-2007 05:13 PM ET (US)
Sorry for the late reply. I have been away from the computer. Serial number = 05136096 |
djd35de
posted 10-12-2007 01:12 AM ET (US)
Hey RobDid you get it figured out? David |
Rob Pirie
posted 10-14-2007 05:05 PM ET (US)
No luck , but the BRP guys are actually here having a conference right in my backyard hopefully one of the cheifs will come this week.Rob |
an86carrera
posted 10-14-2007 09:23 PM ET (US)
Rob.Buy the software yourself on Ebay check it out realtime with your laptop or PDA. Len |
Rob Pirie
posted 11-07-2007 08:36 PM ET (US)
Update:BRP Australia are now dealing direct to try and fix this engine , I am still currently waiting for parts to be delivered to so "THEY CAN TRY" changing the exhaust pressure valve ? This problem is now 6 months old on a 15 month old engine (150 hours).I cannot believe the absolute lack of technical knowledge of the ETEC here in Australia , what makes it even more frustrating is that I live right in the middle of all the major boat manufacturers in Australia and I have some fantastic contacts in this industry.Everybody is shaking their heads. I've had Mercs all my life and never experienced anything like this.On my other boat I have twin 200hp Opti's with over 1200 hours each and they just keep going strong. This is BRP's last chance to fix this engine otherwise it's gone.It will be replaced with one of the new 4 cylinder 200hp Verado's. Rob |
JayR
posted 11-07-2007 09:46 PM ET (US)
Truly a sad story and experience. I would be PO'ed!
Rob Pirie
posted 11-14-2007 12:45 AM ET (US)
Sage Update:- Parts finally arrive "Exhaust port sensor" it was fitted and water tested still doing the same thing............... BRP Australia are now programming a new EMM and sending it with 2 new temp sensors. I am so confident they will fix it especially after they made this comment "We have no idea what’s causing it, hopefully this will fix it"......unbelievable. 2 days to the deadline before this engine comes off and a Black one goes on. |
djd35de
posted 11-14-2007 01:52 AM ET (US)
Rob, Are they going to offer you a refund? That would be a good thing. Its sad that they seem to not even know their own product. Maybe if they did more testing and training of techs you would'nt be going through this. I feel bad for you. What a major pain. I still hope for the best for you. David |
Rob Pirie
posted 11-14-2007 04:50 AM ET (US)
Thanks David to say I'm over it is an understatement. I've been a Merc man my whole life and I have had such a great association with Mercury through out my racing career as well and what pains me so much is that this would never have got to this stage if it was a Merc.How could any major manufacturer let this happen is beyond me. I'm not about to go out and publicly trash the ETEC I'll just let facts state my claim. When it's running the ETEC is a great engine but what's the point in owning one if NO-ONE can fix it. I am so disappointed. Rob |
seahorse
posted 11-14-2007 06:31 AM ET (US)
Did you ever find out what the software revision number is that is presently installed in your motor?Just to confirm, it is the HOT light coming on, not the CHECK ENGINE light, correct? |
Rob Pirie
posted 11-14-2007 07:35 AM ET (US)
We did check again and it was the latest version on the upgrades I can't recall the number.The overheat alarm comes on and engine goes into limp mode.. Overheat shows on the guage. |
seahorse
posted 11-14-2007 07:52 AM ET (US)
See if your software revision number (PCN) is 94040-HO. If it is not, well........ |
L H G
posted 11-14-2007 12:58 PM ET (US)
Since I am considering the new 200 HP I-4 Verado also, I'll be anxious to hear how you like it, and how it compares to the E-tec in running quality, overall performance, etc. I would expect that the large 3.3 liter E-tec would be more powerful top end than the 1.7 liter Verado. |
djd35de
posted 11-14-2007 01:34 PM ET (US)
Wow I still think its a simple fix as in a wiring circuit problem. Or its a bad connection inside the PCM. Or defective coolant switch. But the wiring and connections are the weakest link and more times then not the cause. Any decent tech should be able to test that circuit all the way back to the PCM. And determine the cause. Maybe a electrical shop could help More then likely all you'll need to provide is a wiring diagram and thats it. Lots of times these outboard techs are more mechanical then electrical. And you know its a electrical fault here. No program or update will fix a poor connection.
If that sensor is a 2 wire sensor, Try crossing it with a paper clip and go for a test run. That will trick the Pcm into thinking its running cold, so it may run a tad rich. If the lite does'nt come back you may have a bad sensor. Good Luck Rob Sorry to be so long winded. |
seahorse
posted 11-14-2007 02:29 PM ET (US)
Pirie, Ask your tech, or if you are talking to an official BRP factory tech, to install a #348820 pressure relief spring inside the blow-off valve assembly located on the top aft of the block. This is assuming that the software is the latest version as mentioned in a previous post, and that the engine sensors have been checked for being in spec and accurate on temp readings. On a similar note, several years ago an engine had all kinds of weird sensor warnings, and after a lot of troubleshooting, we found the 5 volt reference signal voltage would vary quite a bit after the motor ran for a while. That knocked everything out of calibration and set off erroneous alarms. The EMM had to be replaced in that situation. Good luck and let us know what they find out. |
Rob Pirie
posted 11-14-2007 04:19 PM ET (US)
Thanks for all the imput I have'nt seen my boat for almost 2 weeks so I'll be paying her a visit today with a print out of this thread.If it comes down to the engine swap (hopefully not) I do have concerns whether the 200HP I-4 Verado will match the punch of the ETEC HO ? We might all find out next week. Rob |
djd35de
posted 11-14-2007 05:16 PM ET (US)
A blown zener diode would cause a varying 5 volt reference signal. Thats inside the pcm and can be checked real easy. Just check any 5 volt ref signal to a engine sensor. Coolant temp, air temp, mass airflow sensor etc... if it varies its defective and the Pcm will need to be replaced. Most common problems are poor grounds, even the main computer ground can cause all sorts of false codes. But we're talking about one circuit here. And it sounds like just a poor connection thats heating up and causing intermitten or false signals. And setting a over heating code and limp home mode. That makes it run like a real dog and limits Rpm .Or a defective coolant temp sensor. They do go bad also. If they're throwing parts at it, have them replace the collant temp sensor. Can't be that tough. Try an electrical Shop. It would be worth the effort. They don't know what there're doing.Sorry to say. If they fix it Charge Evinrude and make them extend your Warranty the time you were unable to use your boat. They should jump on that if it works out. They owe you at least that much!!! David |
Rob Pirie
posted 11-22-2007 08:06 PM ET (US)
Well I'm back in the water and I still have a white engine (Evinrude E-TEC) on my boat. The dealer never actually isolated the problem but just changed the following:-- Fitted high-performance water pick-upl no difference --Exhaust pressure sensor; no difference --Temp sensors; these were tested with a heat sensor gun and ohmmeter and found to be different than specified, so they were changed. --Fitted new Engine Management Module (EMM) and reset the engine timing. It's fixed Six months ago I told them it was the computer. I'm just glad it's fixed. Fingers crossed all will stay OK. Rob |
djd35de
posted 11-22-2007 10:03 PM ET (US)
Great Rob, I'am glad your back on the water, but what a long wait and hassle. They should at least extend your warranty for the HOOPLA David |
JayR
posted 11-22-2007 10:16 PM ET (US)
Wonderful! So glad they fixed it for you. I hope for your sake it is easy sailing from this point forward. |
fourdfish
posted 11-23-2007 11:22 AM ET (US)
Funny Rob- When you first posted about your engine, I was thinking the problem was in the computer. Computers in our new technology have problems all the time. |
Rob Pirie
posted 11-24-2007 01:40 AM ET (US)
Took the boat out yesterday arvo for a blast offshore perfect conditions ran out 10nm at 30 knots it ran like clock , trolled for an hour and ran back in with engine running like a well oiled sewing machine right back to my dock.It now starts better with touch key starting the revs also don't change at slow idle plus I have picked up a couple of extra knots. Obviously the computer was faulting on more than just the heat sensors. I have given my mechanic a real hard time over the past few months but to his credit he was never going to give up until this engine was running perfect , so Stu if you are reading this "Thanks mate for top job". BRP Australia I know you will read this and maybe now you won't treat your engine owners as your average mug punter. I said from day one it was the computer. Your support to my mechanic was to say the least lazy but now it's fixed I'm a happy man again and I'll soon forget the pain of the past few months. Rob |
fourdfish
posted 11-24-2007 11:15 AM ET (US)
It sounds great Rob! Hope it gives you continued good service. Remember, It is just a man made engine and any brand of engine can and does have problems once in awhile! |
Rob Pirie
posted 12-01-2007 10:06 PM ET (US)
You are not gonig to believe this but I went out today trolling and it is doing exactly the same thing AGAIN.Over heat alarm comes on, switch OFF, switch ON, it resets itself and I'm away ? HELP ME--what's left to change? Maybe the wiring loom or harness? Rob |
JayR
posted 12-01-2007 10:24 PM ET (US)
Ugh! Good luck! |
fourdfish
posted 12-02-2007 10:20 AM ET (US)
OMG- Rob, I hope you have been in contact with BRP on this! They have a responsibility to fix this! I would be livid! |
djd35de
posted 12-02-2007 11:52 AM ET (US)
I'd say a new harness would be a good place to start. And have them re-check all the grounds one by one!!! Good Luck Rob. David |
JayR
posted 12-02-2007 02:41 PM ET (US)
Any Lemon Laws there? I would want the motor replaced. Let them deal with the problem and let you go on your way with a motor that works. |
seahorse
posted 12-02-2007 08:30 PM ET (US)
Rob,Is there a chance that the powerhead was replaced at one time with an earlier model that needs the air bleed passageway drilled out larger, as was in an early E-TEC V8 service bulletin? Your original serial number is above the bulletin's serial number range. The symptoms are the same as you describe and are very intermittent. |
Rob Pirie
posted 12-02-2007 09:06 PM ET (US)
I've put 11 hours on the engine since my last post and all was fine until Saturday Morning. Brp are sending their man down tomorrow, they really have no idea.The engine is also changing revs at low speed on it's own. I'll check out re the earlier powerhead. ???????ROB!!!!!! |
Chuck Tribolet
posted 12-02-2007 11:56 PM ET (US)
Rob, you get big points for looking for a solution rather than just ranting on and on. Chuck
seahorse
posted 12-03-2007 12:21 AM ET (US)
Rob,I asked earlier if they installed a new spring in your pressure relief valve (blow off valve) but they should just get the new updated valve on your motor, if that hasn't been done. |
Rob Pirie
posted 12-07-2007 06:36 AM ET (US)
They have had the boat for another week and can't fault it ? I asked about the the pressure relief value and it was replaced also .I've put 2 more hours on the engine and it's fine we are at the start of our marlin season here so tomorrow the engine will get another 10 to 15 hours put on it this weekend , the only comment they made was I picked up a bag....I sharply informed them the first thing I checked before I shut the engine down was to feel the tell tail and was only luke warm plus I put the engine in reverse just in case i did pick something up , when it happened for the 3rd time in 15 mins it wouldn't reset so I killed the power to the engine through the battery isolator , it then reset the computer and all was fine and it hasn't faulted since. If it faults while I'm fighting a marlin I'll put a chainsaw through the transom and solve my problems once and for all. Rob |
posted 12-07-2007 08:33 AM ET (US)
Rob,I hope your engine problem is now taken care of. You are an understanding man. Intermitent electrical faults are, IMO, absolutely the worst kind as they are so very difficult to find as they are not repeatable in the shop if they don't store in the computer. In my limited experience they are often caused by temporary high resistance connections in harnesses. Those, in turn are often caused by a slightly loose or corroded connector. I'm sure your dealer's shop people have inspected and lubricated all the harness connections from the key switch to the end. To finally find the problem it may be necessary to hook up the dealers laptop computer to the engine for a day of fishing. With today's EMMs that may no longer be useful but it's worth a mention. Perhaps the technician who is working on your engine would enjoy a day of fishing on your boat? Butch |
Rob Pirie
posted 12-11-2007 07:52 AM ET (US)
Well I've put another 15 hours on the engine and all is still fine , hopefully it was just a glitch.The only difference I can notice is it now using a bit more fuel but as I mentioned earlier I have picked up an extra 2 knots so I'm just wondering if a bit more horse power was dialled in with the new Management Module (EMM) ? The engine hours have also been reset so I've lost 120 hours off the clock. Time will tell,thanks for all the support. Rob |
fourdfish
posted 12-11-2007 03:16 PM ET (US)
Rob, Keep us up to date. Those types of problems can be a PITA! |
