ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance 150-HP Engine Comparisons
Author | Topic: 150-HP Engine Comparisons |
L H G |
posted 10-26-2007 10:36 PM ET (US)
Since 150's are so popular, Merc's tests here on the 150 Verado are of interest. Check this out: http://www.mercurymarine.com/look_deeper/head_to_head.php?ID=57& Filter=3,4 Let's forget the really excellent perfromance on the Verado (we know those numbers are rigged!), but what is of interest to me are Merc's test results on the Yamaha F150 vs the Etec 150, supposedly where they have no preference to push. After all, as a 4-stroke, Merc would consider the hugely popular Yamaha F-150 as Verado competition, not the Evinrude 2-stroke. If you remember, Evinrude did a video on the E-tecs pulling the Yamaha under water by the Evinrude, and also of the Yamaha 150 not being able to plane off the twin powered boat. Mercury's testing, at least, disproves all of that baloney. Honda and Suzuki owners may also be interested in the comparative results. "We report, you decide." |
posted 10-26-2007 11:12 PM ET (US)
Larry--I am glad you posted a pointer to those test results. At lunch today I was just saying, "We haven't had a good 'shoot-out' to debate around here in a while." |
L H G |
posted 10-26-2007 11:27 PM ET (US)
Thanks, Jim. Sometimes these controversial debates and data can make for great reading interest, just like Glen E has indicated. As I said, other than potential Whaler buyers who may be getting a I4 Verado powered boat, readers should ignore the Verado data, and consider the data on the other four engines as if done by an independent tester. Mercury could very well be better equipped to perform these tests, and with more professional, experienced engineering staff (like our contibutor XStech?), than some magazine writers. |
Binkie |
posted 10-26-2007 11:28 PM ET (US)
This was a smoke and mirror test. As we all know its all in the props that was used. Different props will give different results. If these tests were done by an independent source they might mean something, but run by Mercury R&D what would you expect. Mercury was only .3 of one mile per hour faster than E-Tecs. I wonder how many props they tried on the E-tec, before they found one that was slower than the Merc. rich |
L H G |
posted 10-26-2007 11:33 PM ET (US)
Binkie - I understand Mercury R&D only has two types of prop they stock. Comp-Props for the competition, and Enertia's for the Mercs. It's a lesson they learned from the Evinrude infomercials. |
posted 10-27-2007 12:19 AM ET (US)
Regarding the fuel consumption data, it is very interesting. These data for the Verado motors must be from the newest model, the Verado GEN2, which has improved the fuel efficiency of the supercharged motor significantly. I also think this report is the first one published by anyone that includes the Verado GEN2 in the mix. There is a natural suspicion about the validity of the data since it was gathered and reported by Mercury itself. And it is not surprising that the Verado does well in the tests, otherwise they would not have been published. With regard to the E-TEC fuel consumption, previous tests have shown that the E-TEC does tend to burn more fuel than the naturally aspirated four-strokes at mid-range and high-speed operation. However, the E-TEC has been extremely efficient at idle speeds, due to the use of a stratified charge combustion. The report from Mercury seems to omit this data point, and that is probably because it would have shown an advantage to the E-TEC. I wonder if any independent boating magazines will have the resources available in these times of boating recession to be able to conduct their own tests of these GEN2 Verado motors. Those results will be highly anticipated, to either confirm or contradict these Fond du Lac results. |
L H G |
posted 10-27-2007 01:47 AM ET (US)
Here is another interesting comparison, which, by easy interpolation, allows us to compare the 150 Optimax with the 150 Verado, using Mercury's own data. I am surprised at the results, and how good the Verado really is. http://www.mercurymarine.com/look_deeper/head_to_head.php?ID=56&Filter=6 By using the E-tec data from both tests as the common ground, the Optimax and Verado can be compared, something Mercury NEVER does. What is of interest, is that the Verado just slightly appears to OUT-PERFORM the Optimax in all categories, top end, acceleration(amazing - another myth busted) and fuel economy. No wonder Boston Whaler has gone all Verado. The I4 Verados appear to be quite the product, and a long term engine for the future of outboards. Boston Whaler buyers should be very happy to own one of these. And so far, the reports they have filed on CW indicate the same. The Verado carries it's weight quite well. |
highanddry |
posted 10-27-2007 02:19 AM ET (US)
Thanks for reposting the link I posted earlier in the other thread that [focused on financial results and the moderator moved to THE GAM]. I am sure some may find the results interesting. |
posted 10-27-2007 08:52 AM ET (US)
The reason that Boston Whaler dropped the OptiMax was not because of any comparative performance with the Verado. It was simply a case of customer demand. Boston Whaler new boat buyers showed literally no interest in the OptiMax when they could get a Verado. |
Peter |
posted 10-27-2007 10:02 AM ET (US)
It's interesting that the Mercury marketing department used the words "Look Deeper" for the link to these performance reports. I did look deeper and all I see is is very, very, very shallow, low budget comparative testing devoid of any details. They must be so proud of what they've done they apparently don't bother to proof read what they published. I do find amusing the handicap disclaimer in the Mercury home grown head-to-head twin 300 test: "* Suzuki engines were mounted lower to ensure they maintained water traction at higher speeds". I think they used the wrong word in the disclaimer. I think they meant "friction", not "traction". These latest low budget "look deeper" comparative tests bring back to mind that Mercury published a comparative test between the Verado 275 and the Yamaha 300 HPDI. In that test, Mercury handicapped the Yamaha 300 HPDI by overpropping it so that it would only turn 4500 RPM at WOT. In their eyes, that was OK because at WOT it was turning within the specified operating range of 4500 to 5500 RPM. Of course by doing that, the Verado would surely win the top speed and acceleration tests. It would also win a fuel consumption test if measured at 4500 RPM. But nobody would ever prop the Yamaha 300 HPDI that way in real usage. So Larry, since you are so delighted with the low budget "Look Deeper" performance comparison that has absolutely no backup data whatsoever (what propellers, what pitch, what WOT RPM was achieved, how much fuel in each boat, how many people in each boat, dry weight of each boat, etc....), please tell us how to understand the gallons per hour graphic in the 150 comparison. I am particularly interested in the segment where they have a legend that says "4501+ RPM WOT". What does that mean? Does this legend give Mercury even greater latitude to take liberties with the competition like they have done in the past such as by overpropping the E-TEC so it will only run at 4500 RPM at WOT and then measuring fuel flow of all motors at 4500 RPM? Of course, it really doesn't matter that much because comparing one motor's fuel consumption to another on an RPM to RPM basis is absolutely meaningless but I guess no one in the Mercury R&D department bothered to tell the Mercury marketing department. To illustrate using Mercury's own products, we can do an RPM to RPM comparison of the Optimax to the Verado and cast the Optimax in a negative light even though it is widely known that the Optimax is more fuel efficient than the Verado. For example, at 5000 RPM, the Optimax consumes 12.6 GPH but the Verado only 9.5 GPH. That comparison looks really great for the Verado, doesn't it, until you see that the Verado powered boat is running 8 MPH slower at 5000 RPM because it has a WOT max of 6400 (versus 5750 for the Optimax) and is propped and geared to reach that. With respect to the graphic regarding the statement that the 150 E-TEC can cost $2,500 more to operate over a 5 year period than Verado, if you do the math, the difference in the hourly fuel consumption is 1.57GPH (1.57 GPH x 500 hours x $3.18 gallon = $2500). Again meaningless without any backup data. Is the 1.57 GPH difference across the entire operating range for both motors running at the same average boat speed or is this another meaningless RPM to RPM comparison of one motor with an operating range maximum of 5800 RPM versus one that runs up to 6400 RPM and would be propped differently? What I do find interesting in all of this latest low budget comparative Mercury marketing material in a thematic way is how focused they are on bashing the E-TEC, just like Larry is. Contrary to what Larry wants everyone to believe, Evinrude must be doing something right for Mercury to devote so much of the comparative advertising's focus torward casting the E-TEC in a negative light on both the 4-stroke and 2-stroke fronts. It's impressive to me that a single product can apparently be taken as a serious challenge to both the 2 and 4-stroke formats. So Larry, if the E-TEC only has a very small dwindling marketshare and will never amount to much, as you say, why do they spend so much effort to bash it in the comparisons? Lastly, comparative advertisements are dangerous for the advertiser if they are done in a sloppy manner like these home grown "Look Deeper" tests are. The leave the comparison open to many, many questions about the testing which is not a good thing. Note to marketeers: If your product comparison requires handicapping the competition's product for your product to win, don't do a comparative advertisement like this one. All the handicapping or other misleading moves do is create doubts about the product that you want to paint as superior and creates doubts about the credibility of the folks behind the product. If you are going to do a comparative test, do it carefully. Get an independent tester to conduct the tests or evaluate the testing methods and results and don't handicap the competition, otherwise your published test results aren't worth the paper or pixels they are printed on in the consumers eyes. Consumers are far more sophisticated than these marketeers seem to understand. Note to Mercury: PROOF READ your marketing materials before you publish. You've got at least one spelling mistake and at least one incorrect legend in the comparative materials. |
posted 10-27-2007 10:38 AM ET (US)
I was also confused by the fuel money savings calculation. As Peter did, I deduced the gallons-per-hour differential. Then I noticed that all the data presented showed even higher differentials. This means only one thing: there must be other data not shown which have much lower differentials, perhaps even ones that favor E-TEC. You cannot average the three values shown and come up with a lower number than any of them unless there are other data not shown which are much more favorable to E-TEC. |
fourdfish |
posted 10-27-2007 11:21 AM ET (US)
All the outboard manufactures could make tests that would favor themselves. DOES ANYONE really believe that Mercury would make up tests that would favor anyone else and then publish them. Change any of the variables and you would get different results. These are NOT independent professional tests. I think these marketing tests show some real concern about the competition. At least the ETEC infomercials were entertaining and you could watch the videos. |
L H G |
posted 10-27-2007 03:40 PM ET (US)
My guess is that the reason Mercury makes reference to the lesser qualities of the Evinrude, is because Evinrude's advertizing REFUSES to deal with comparisons to Optimax and Verado, instead focusing on poor old Yamaha F-series, and the other non-supercharged 4-strokes. Mercury is showing us why, and exposing the flaws in their ad campaign. The non-supercharged 4-strokes are the only engines they can occasionally outperform (but not in fuel economy). Peter keeps telling us that Evinrude does not see Optimax as a competitor. So does Lambert with his +128# statement. That's a joke. If Evinrude fans think Merc is treating them unfairly, let's see some more infomercials with an E-tec pulling an Optimax or DTS Verado underwater, or a Merc not being able to plane off a twin engine boat. Why, the Evinrude is what would get pulled under, not the Mercs. Sad, but true. Mercury is bringing them back to reality, and forcing the comparisons. The fuel economy issue is a large one, incidentally. Evinrude is free to dispute Merc's tests. If they can even afford to do these "cheap" tests, they should expose this Merc "scam" on the public. I'm waiting. |
Perry |
posted 10-27-2007 06:04 PM ET (US)
You can always prop and rig one paricular boat to perform better than another. I would put more faith in an independant performance test if there is such a thing. I found it interesting that the Honda 150 was excluded from the fuel economy comparison. Why do you think that was? If they had a Honda powered boat for the exceleration and top speed, why not the fuel economy test. Also Mercury Marine included a noise test in the 90 and 300 HP comparisons. Why not the 150 HP comparison? |
fourdfish |
posted 10-28-2007 12:56 AM ET (US)
Why?? Because these are company AD campaign tests not real independent tests. Larry offers no independent proof for any of his opinions. Most here know that the company is just putting on a show and I for one don't really care what they do or for that matter what unsubstantiated opinions he posts! |
Perry |
posted 10-28-2007 01:27 AM ET (US)
I can't believe I spelled acceleration with an "ex" |
itl |
posted 10-28-2007 03:33 AM ET (US)
Honda 150 is known a very fuel efficient motor. It makes me wonder why Honda figures was not shown in fuel economy part of that comparison? |
TexasWhaler |
posted 10-28-2007 10:45 AM ET (US)
There are a couple of things I'd like to kindly remind LHG about. One, four-stroke outboards do not make near as much low-end torque as two-strokes. Low-end torque determines performance in such areas as "hole-shot", and time-to-plane numbers. I thought this was pretty much understood. However I've seen some recent posts that are acutally trying to say that some 4-strokes are as strong, or even stronger in this area. That is just simply not true. Two, even the mighty Verado, with it's screw-style supercharger, DOES NOT MAKE AS MUCH LOW-END TORQUE AS A TWO-STROKE OF THE SAME HORSEPOWER. This is even acknowledged by Mercury. Mercury touts the Verado as "the most powerful 4-stroke available". They do not say "the most powerful outboard, period", because even they know that even with a supercharger, DFI 2-strokes like their Optis, still make more low-end torque. That said, I really like the Verados. They are without a doubt, the most powerful, 4-stroke platforms available. |
sosmerc |
posted 10-28-2007 12:06 PM ET (US)
TexasWhaler...I too am a "2 stroke" guy when it comes to performance. However, the performance of the Verado does show what progress has been made with 4 strokes. I was just reviewing some of the performance specs on the new whalers and I see where the Verado often is QUICKER to plane than its comparable hp. Optimax model. Once on plane the Opti generally is faster to 30mph. Clearly the supercharger has created "parity" in the low end torque department. (see the Dauntlass 18 performance specs/engine comparison data) |
TexasWhaler |
posted 10-28-2007 02:08 PM ET (US)
Sosmerc, great points. I may not be giving the Verado the low-end, torque "credit" it deserves. |
djd35de |
posted 10-29-2007 11:38 PM ET (US)
If your talking torque, then Suzuki has got to be near the top. Most people know that good old cubic inches will give you the most low end torque. The engine that can swing a bigger prop must have that low end grunt. A DF 150 is almost 2.9L for a 4 cylinder. The verado gets its power form the the super charger but from a smaller displacement engine. When you stress a smaller block it probley won't last as long. I own a Honda BF150 but its 2.4L struggles to twist a 15.5" prop , and rattles like crazy with such. I can run a 14.5 " and it runs pretty smooth but thats about the most i can get away with. If i was a betting man , i'd bet the Suzuki DF150 has the most low end torque in its 4 stroke class. And a better match with a heavier loaded boat and lower planing speeds. |
L H G |
posted 10-30-2007 12:53 PM ET (US)
Forgetting the Verado, Mercury's tests show the Suzuki is not all that strong on low end torque (acceleration), but that it comes on strong with it's cubes at top end. The Yamaha F-150 is a lot quicker out of the hole, and runs with the 2-stroke E-tec. If you are getting prop rattle, you might see if your Honda can run a Merc prop with the Flo Torq IV hub, which was specifically designed for the 135-200 Verados. I think it can, since the earlier Hondas all used gearcases bought from Mercury anyway. |
L H G |
posted 10-30-2007 01:01 PM ET (US)
Also, by interpolation, since Mercury does not show fuel economy numbers for the Honda, but for the other 4 engines, it is reasonable to assume the Honda 150 gets the BEST fuel economy of them all, including the Verado. I guess that is the trade-off for the slowest performance across the board. Great fuel economy is clearly a strong selling point for Honda. |
fourdfish |
posted 10-30-2007 02:09 PM ET (US)
[Questioned the integrity of the data in the Mercury tests.] |
posted 10-30-2007 06:34 PM ET (US)
Re the imputed fuel economy of the naturally aspirated four-stroke Honda motor, I do note that Honda themselves describes their motors this way: "Honda engineers work to ensure that every Honda outboard model--ranging from 2 to 225 horsepower--sets the standard for fuel efficiency...." |
fourdfish |
posted 10-30-2007 06:48 PM ET (US)
And why can't someone question the integrity of the data? I have actually seen you do it several times. So you are saying this data is accurate? This was not a personnel post. |
djd35de |
posted 10-30-2007 08:49 PM ET (US)
I agree that the Honda BF150 gets great gas mileage. That is the main reason I re-powered. I went on a long trip past San Clemente Island, which is about 57 miles off shore from mission Bay here in San Diego. I had about 730 lbs in passenger weight with a full load of gear and extra cooler with ice and managed 4.6-MPG. The key is the lean burn system with an air-fuel ratio sensor . Under cruise conditions it pulls back the fuel up to 20%. It does work well. The main draw backs with my Honda is the weight, and maybe lacking a bit of low end. It runs strong at the top end with that VTEC system . But I do my best to stay under 4,200-RPM as it sucks the fuel down quickly. Kind of reminds me of the two-stroke motor I got rid of. David |
centerline |
posted 10-30-2007 11:14 PM ET (US)
I found this forum while searching for fuel consumption figures for the 225 Honda. After reading all of the posts here I am able to conclude that most data published and debated lacks any real meaning as it pertains to fuel consumption. I operate a 27-foot 9,200-lb laden aluminum water taxi powered by twin Honda 150 outboard motors. Operating speed is fixed at 21 knots @ 4250 RPM in calm salt water. Having logged between 1,200 and 2,000 hours per year on this power package for the last two years, I consider my data to be accurate . The props are 3 blade stainless 14-3/4 by 17 yeilding 35 knots @ 6000 RPM. Fuel consumption is an astounding 7.2 gals/hr at the operating speed of 21 knots laden. At 28 knots @ 5400 RPM , the fuel consumption jumps to a staggering 16 gallons per hour. A horrible price to pay for seven knots. Running in rough seas of 3 to 5 foot increases fuel consumption only slightly. These engines currently have 3440 hours and appear to be flawless . Maintenence has been meticulous with oil every 100 hours, valve adjustment every 200 hours and lower case oil every 200 hours. Having run Volvo diesel sterndrives for most of my 22 years on the water I can tell you that the Honda outboards are easily 20 percent cheaper to run all round. The original engines on this boat were Merc 150 EFI's that sucked an eye popping 22 gallons per hour @ 21 knots. If you see a used [Honda outboard motor] advertised--a very rare occurance--it will be gone before you can make the call. That says it all. As for Verado, pretty to look at and fraught with problems. |
posted 10-30-2007 11:39 PM ET (US)
Thanks for the data on the Honda fuel consumption. For boats that are operated in commercial service or recreational boats which are used for hundreds of hours a year, I agree that improving fuel economy is important to reduce operating costs. |
Tom W Clark |
posted 10-30-2007 11:51 PM ET (US)
centerline, About the Honda BF225 you write: Fuel consumption is an astounding 7.2 gals/hr at the operating speed of 21 knots laden. About the twin Mercury 150 EFIs on the same boat you write: ...Merc 150 EFI's that sucked an eye popping 22 gallons per hour @ 21 knots. Frankly, I find that very hard to believe. To propel a boat of a given weight at a given speed requires the exact same amount of power. I find it hard to believe the fuel consumption of of one power source could be three times as efficient as another. |
posted 10-31-2007 07:52 AM ET (US)
Tom--As I proposed in another article, the best way to resolve these claims of fuel economy which seem implausible is via a new method of testing. See: Claims of Fuel Economy: The Indian Chief Parable |
Tom W Clark |
posted 10-31-2007 09:25 AM ET (US)
Jim, We don't need an indian chief or his medicine man to do some simple math. I mistakenly attributed centerline's claim of good fuel economy to a Honda BF 225 when in fact he write that it is his twin Honda BF150s that get an astounding 7.2 gallons per hour at 21 knots. Astounding indeed. 7.2 gallons per hour at 21 knots equates to 3.35 statute miles per gallon. This on a 27 foot boat with a gross weight of 9200 pounds. Does this strike anybody else as absurd? That is about the size of a Whaler 27 Full Cabin Whaler Drive with twin V-6 four stokes, full fuel, gear and ten passengers on board. 3.35 MPG at 24 MPH? I don't think so. In contrast he reports the original power, twin Mercury 150 EFIs burned 22 gallons per hour at the same speed. That is about 1.1 MPG which is pretty close to what the lighter Whaler 27 will burn. That I believe. |
TexasWhaler |
posted 10-31-2007 01:10 PM ET (US)
Larry stated: "The Yamaha F-150 is a lot quicker out of the hole, and runs with the 2-stroke E-tec." There is no way that any, naturally aspirated, four-stroke, is going to run side-by-side to any DFI two-stroke, on hole shots. Any test that says otherwise, is seriously flawed. And another thing, the E-TEC 150, the Optimax 150, and the former HPDI 150, are all VERY CLOSE in performance. Not surprisingly, there all DFI 2-strokes! I had to add that, because once again, by stating that the Yamaha F-150 "runs with the 2-stroke E-TEC", and NOT saying "runs with the 2-stroke E-TEC, and Opitmax", he's implying that somehow the Optimax performs MUCH better than the E-TEC. I know this is a penetrating glimpse into the obvious, but that is just pro-Merc BS. |
Peter |
posted 10-31-2007 02:39 PM ET (US)
The lack of supporting facts for the 150 comparison brings to mind the 1980's Wendy's restaurant television commercial "Where's The Beef?" So what should we believe? An Evinrude infomercial that has the F150 and the E-TEC 150 side by side on the same boat running in the same environment on the same day of which the results, to date, remain unchallenged by Yamaha (the equivalen of a Wendy's triple) OR the air sandwich served up by Mercury? |
centerline |
posted 11-02-2007 07:16 PM ET (US)
Tom, Though I never expected my information on the honda fuel consumption to be ridiculed ,I understand your disbelief. I understand this site is for whaler enthusiasts, a number of which I have owned, with various power options.Indeed the whaler is a fine boat. But my intent was to report just the facts on the fuel consumption figures for a vessel I operate with twin 150 hondas, given that a debate appeared to be taking placeon the subject. A couple of points ! Anyone suggesting it takes x power to push x weight through the water knows absolutley nothing of hull dynamics , wetted surface, friction coefficients of various materials and many other factors that determine hull efficiency. To recap. The honda 150 engines burn 3.6 gallons ( imperial) per side @ 4200 RPM and produce a speed of 21 knots in calm water. They have been doing this since they were bolted on. I can add that when running @ 5600 RPM , the vessel is doing 30 knots and burning 17 gallons per hour ( 8.5 per side).I can say I logged only 50 or so hours on the merc EFIs so the consumption figures may be unreliable. I doubt they would be more than 20 percent off. I can tell you I do not sell honda outboards, nor do I work for them. I think the consensus out there is pretty clear. These engines are very very fuel efficient. The rest will catch up , no doubt. I have run alongside a 27 whaler cabin model with two persons aboard. The boat was sporting a pair of 250 yamahas and running at perhaps 25 knots (he went by me)Most of the hull was in the water.You are probably much more knowledgable than I and better at math. All I have is a drawer full of gas reciepts and 22 years of commercial experience on the Pacific west coast.In closing, I was in disbelief as well . For several fill-ups. Cost to fill is 490.00 . Price per imperial gallon up here is 5.90 today and rising. In any case , thanks for allowing me to join the debate and I will now leave the site, as I do not own or want another Whaler since I discovered Aluminum. Cheers |
fourdfish |
posted 11-02-2007 08:40 PM ET (US)
centerline-I find your post very convincing and think you are not here to deceive anyone. |
posted 11-02-2007 08:51 PM ET (US)
I believe that centerline had mistakenly interpreted skepticism for derision. Internal combustion engines are rated for fuel efficiency by their brake specific fuel consumption (BSFC). The range of values for gasoline internal combustion engines only varies from 0.4 to 0.6 lbs/HP/hour, or in a ratio of 1:1.5. This is considerably less than the reported ratio of 1:3 observed. If the reported data is accurate, there must be other factors besides the engine change which contributed to enhanced fuel efficiency. A change in propellers could affect the resullts.
Brake Specific Fuel Consumption |
towboater |
posted 11-05-2007 07:30 PM ET (US)
Was centerline's info a round-about way to plug Aluminum hulls? LOL. |
JMARTIN |
posted 11-05-2007 07:44 PM ET (US)
Imperial gallon, man I have not heard that one for awhile. An imperial gallon is about 1.2 US gallons. John |
Jordi |
posted 11-05-2007 08:45 PM ET (US)
centerline, "As for Verado, pretty to look at and fraught with problems". Sounds more like a description of an old girlfriend. I am giving you credit that indeed you have good taste in women. "I do not own or want another Whaler since I discovered Aluminum." Beer cans and girlfriends...you got to love this site. Let us know when you get some real "advice" on Verados. Cheers, Jordi |
andygere |
posted 11-05-2007 11:28 PM ET (US)
Note that Mercury 'tested' the outboards on a fairly light(1500 lb.), flat bottomed boat. This will tend to mask the lack of low end torque on the naturally aspirated 4-strokes. I gotta admit though, that 0.3 mph advantage in the top speed coupled with that blistering 0.2 seconds faster 0 to 30 mph time makes me want to junk my E-TEC and go right out and by a Verado. Them's braggin' numbers down at the dock. And I read it on the internet, so it must be true... |
Rob Pirie |
posted 11-06-2007 05:24 PM ET (US)
Well that's the best read I have had in ages. It looks like you should get together with your own boats and do your own test. My first boat 31ft has twin 200 Optimax and weighs 10,000lbs I'm a Merc man but the ETEC is starting to impress me , you can't compare my fuel figures as the boats are too different but the one thing that no-one has mentioned is "oil consumption" and if you use your boats allot like I do you need to add this to your fuel consumption figures. The ETEC hardly uses oil compared to the Optimax it absolutely leaves them for dead in this department. I still wear a black cap as there are days when I want to burn my ETEC but I'll leave that to another thread but overall the Etec performs well against the Opitimax with miserly oil consumption being its stand out feature. Rob |
cooper1958nc |
posted 11-07-2007 02:53 AM ET (US)
A few realities to ponder: 1. Equal horsepower engines will propel the same boat at equal top speed if propped correctly, assuming only the weight, air resistance (negligible probably) and hydrodynamic lower unit drag are comparable. Power is power is power. Equal horsepower engines will consume close to the same amount of fuel per unit time if putting out equal horsepower; any differences are due to varying internal friction and parasitic losses, plus possibly differences in fuel mixture. 2. Equal horsepower engines may have very different curves of (full throttle) torque vs RPM. This affects acceleration but has little affect on steady state performance. Stated another way, an engine that can produce greater midrange torque than another, does not "produce" that torque unless the boat is accelerating. A boat requires a certain amount of torque, converted to thrust by the prop, to go a certain speed. If more torque is applied, the boat accelerates. If not, nobody knows you have the "extra" torque available. 3. The RPM at which max power occurs is meaningless because lower unit gearing can trade RPM for torque or vice versa. 4. The idea that 2 stroke engines produce "more torque" because of twice the power strokes is unscientific. Full throttle torque at any RPM is largely a function of how much fuel/air can be pumped, which is equal to the displacement times the volumetric efficiency. (Peak torque usually occurs at max volumetric efficienty by the way). For four strokes you multiply the displacement by .5, for two strokes by 1. But two strokes usually have pretty terrible volumetric efficienty. So you have to consider displacement, volumetric efficiency, and intake strokes per revolution all at the same time. |
blkmtrfan |
posted 11-07-2007 11:32 AM ET (US)
quote: Do you have any scientific data to support this? |
cooper1958nc |
posted 11-07-2007 12:46 PM ET (US)
It is basic engine theory. On what specific point would you like to see a reference? Explaning VE: http://www.epi-eng.com/ET-VolEff.htm: "In a four-stroke naturally aspirated engine, the theoretical maximum amount of air that each cylinder can ingest during the intake cycle is equal to the swept volume of that cylinder (0.7854 x bore x bore x stroke). "Since each cylinder has one intake stroke every two revolutions of the crankshaft, then the theoretical maximum volume of air it can ingest during each rotation of the crankshaft is equal to one-half its displacement. The actual amount of air the engine ingests compared to the theoretical maximum is called volumetric efficiency (VE). An engine operating at 100% VE is ingesting its' total displacement every two crankshaft revolutions. There are many factors which determine the torque an engine can produce and the RPM at which the maximum torque occurs, but the fundamental determinant is the mass of air the engine can ingest into the cylinders, and there is a nearly-linear relationship between VE and maximum torque." For two strokes, of course, there is an intake stroke ever revolution. However VE is significantly less. See, e.g. A Textbook of Power Plant Engineering By R.K. Rajput I did not mention supercharging or turbocharging which can increase VE a lot for either 2 or 4 stroke engines. |
JayR |
posted 11-07-2007 03:35 PM ET (US)
Nice responses guys! So cordial and polite.... Is it me or have all those nasty responses taken a vacation? How long can this continue??? |
fourdfish |
posted 11-07-2007 04:09 PM ET (US)
Until he gets back to the computer. I think he is in Fl now and is busy! Thank God! |
cooper1958nc |
posted 11-07-2007 04:39 PM ET (US)
While I am on the topic, a theory I often hear is that higher "torque" can reduce minimum planing speed, or can keep a boat planing when it might not otherwise. Higher full throttle torque can certainly accelerate a boat through a high drag region and allow it to plane. But planing speed is a function of the hull (meaning the hull design, the weight and weight distribution, the angle of thrust being applied, and maybe other things). The hull does not know how much additonal thrust might be applied if the throttle were opened more. For unaccelerated motion, thrust equals drag. Excess thrust (torque) accelerates. If the drag exceeds the thrust available at that throttle setting and RPM, the boat goes no faster. If the throttle is open, and the thrust equals the drag, that is called top speed. If the boat is heavily loaded, that top speed might be 12 mph. An engine able to produce more thrust at low RPM might allow the boat to accelerate and reduce displacement and wetted surface through hydrodynamic lift, which we call planing. All that assumes the factors of propeller design, trim, thrust angle, and the like are unchanged. Why could one engine produce more torque than another at the same boatspeed? If all gearing issues are equivalent, better VE. If they are not, more gear reduction. Note that gear reduction (by gear or prop) is no free lunch because a large reduction gear means the engine might reach redline RPM while the boat is still able to accelerate. |
cooper1958nc |
posted 11-07-2007 04:41 PM ET (US)
Correction. Better VE if displacement is equal. If not, the metric to compare is the displacement times the VE. |
posted 11-07-2007 05:12 PM ET (US)
Fixed long pasted URL which was destroying the line wrap on a lot of browsers. If you paste them as LINKS, the are automatically corrected and wrapped. |
blkmtrfan |
posted 11-07-2007 05:34 PM ET (US)
I guess I am from the camp that believes that the 2-stoke will give a better holeshot in that more energy can be produced at the lower RPM because there is not the wasteful extra 2-strokes. I do understand what you are stating about VE being easier to optimise with the valvetrain of a 4-stroke especially if variable valve timing is being used. However, it has to be considerable more efficient to provide more power at low RPM when compared to a 2-stroke. Overall 2-stokes are more efficent per volume of displacement. Typically all the normially asperated 4-stokes are of larger displacement than the equilvant HP 2-stroke. Another factor to consider is that with a DI 2-stroke the VE is greater than with conventional 2-stroke. Consider that the fuel charge no longer has to pass through the intake port, the port can now be sized and tuned for just the combustion air as the fuel charge (and all of its mass) enters after the port is closed by the piston. |
fourdfish |
posted 11-07-2007 06:50 PM ET (US)
Although I am not interested in addressing Coopers1958nc theory of "torque" diff between 2 stroke and 4 stroke engines, I will say that the weight difference between the 2 engines will make a difference in acceleration if all other factors are equal! |
Rob Pirie |
posted 11-07-2007 08:02 PM ET (US)
"I will say that the weight difference between the 2 engines will make a difference in acceleration if all other factors are equal!" Not anymore the new 4 cylinder 200hp Verado is only 510 pounds and that makes the ETEC 200HP only 1 pound lighter at 509 pounds. |
JayR |
posted 11-07-2007 08:16 PM ET (US)
Rob, where did you get that E-TEC 200 weight figure? You are wrong, the 200 HP E-TEC weighs 427 pounds (25" shaft) and the 20" is 419 pounds. Please see the link... That's 83 pounds difference (if you were comparing the Verado 200 HP 25" shaft) and the E-TEC is a V6 not a V4 like the Verado. |
fourdfish |
posted 11-07-2007 08:25 PM ET (US)
Jay-You beat me to it! Rob, You are following in the footsteps of others here in that you don't check your facts before posting! So Rob what do you say about the differences in weight and 2 less cylinders to BOOT!!!! BTW, I did not say anything about the Verado as we were talking about all 4 stroke engines and you will not see me bash those engines. (Only point out facts) BTW, The larger block(3.3L V6 ETEC engines) weigh about the same as the 4 cyl Verado! |
Rob Pirie |
posted 11-07-2007 08:49 PM ET (US)
http://www.akmining.com/boat/evinrude_outboard_08.htm This where I got from plus I also own a 200HO hp ETEC and in the broucher I originally got it has the engine as weighing 516 pounds? It is sitting in front of me as I type this??????? The only thing I can think of is we are getting old stock here in Australia. I'm not a plugging the ETEC and flogging the Verado infact it's the reverse I am about to replace my 15 month old Etec with the Verado. Rob |
fourdfish |
posted 11-07-2007 09:01 PM ET (US)
Rob--I'm am sure that you have the 3.3L big block V6 engine! That HO, meaning High output gives you more than 200 horses. The small block V6(2.4L I think!) weighs in at 419lbs. If you purchase the hydralic steering system with the Verado then add about 75lbs more to that weight. BTW- If you don't mind! What kind of problems are you having with that ETEC? |
Rob Pirie |
posted 11-07-2007 09:27 PM ET (US)
It all here http://continuouswave.com/ubb/Forum4/HTML/005738.html It's dragged on too long I over it. Rob |
JayR |
posted 11-07-2007 09:43 PM ET (US)
The 200 HO is a different animal. It does in fact weigh more than the 200 HP E-TEC. After all, it is more than 200 HP... |
JayR |
posted 11-07-2007 09:45 PM ET (US)
BTW.... sorry to hear of your troubles. I hope you have success with the Verado. |
fourdfish |
posted 11-07-2007 11:28 PM ET (US)
Rob- I guess I missed that thread! Sorry to hear about your engine and you have a right to be Pi--- off! They say that a product is only as good as the support you get for it! I have to say that products made here in the States have better support here! I know your not going to like to hear this but this can and does happen to any of the different manufactures engines. It would seem that your mechanic does not really know what is going on and may in fact not be prepared to work on that engine. I would want my money back from BRP! The engine is under warranty and they need to step up! |
cooper1958nc |
posted 11-08-2007 12:52 AM ET (US)
"I guess I am from the camp that believes that the 2-stoke will give a better holeshot in that more energy can be produced at the lower RPM because there is not the wasteful extra 2-strokes." Well, not exactly. There is some energy loss to bearing and ring friction, of course, so the fact you have to run a 4 stroke twice as fast (equal displacement and VE) to pump the same air means more frictional loss, but the main losses inherent in the piston engines are "pumping" losses, heating and air friction incidental to pumping air. (Eliminating pumping losses is the theory behind the "variable cylinder" engines now being produced for automobiles). Two strokes have about the same pumping losses as 4 strokes if they are pumping the same amount of air. And any friction difference would be greater at high speed, not low speed. "However, it has to be considerable more efficient to provide more power at low RPM when compared to a 2-stroke. Overall 2-stokes are more efficent per volume of displacement. Typically all the normially asperated 4-stokes are of larger displacement than the equilvant HP 2-stroke." It is not more "efficient" per unit volume of displacement, but 2 strokes have an advantage per unit volume per revolution because they pump twice as fast. However, low RPM torque for 2 strokes is terrible, reflecting the inherently poor VE due to the problems of getting mixing intake and exhaust, scavanging exhaust, exhausting intake charge, etc. The value of 2 strokes was that historically they could run sustained at higher RPM because they had no valve train to worry about and because they had needle bearings (poor for low RPM high load, good for high RPM low load).
Thats an interesting idea, one I have never heard before. The mass of the fuel is small in relation to that of the air (about 1/14th), but it does take up 1/14 of the volume, so I guess you are right in a way. You get a free 1/14 of extra air I guess, all other things being equal. However, the energy required to do the direct injection has to come from somewhere, and it comes from running the high pressure pumps off the engine. But on the subject of VE, yes, maybe DI gives you 1/14 extra displacement. Never thought of it. |
Peter |
posted 11-08-2007 08:31 AM ET (US)
"However, low RPM torque for 2 strokes is terrible, reflecting the inherently poor VE due to the problems of getting mixing intake and exhaust, scavanging exhaust, exhausting intake charge, etc." -- Cooper Your statement might be true if 2-strokes didn't used tuned exhaust systems. I suggest you take a look at the powercurves for 4-cylinder, similar displacement 90 HP motors in this document members.iinet.net.au/~pauldawson/gen/Iame24-4strokes.pdf . The torque is higher for the 2-stroke throughout the meaningful 2000 to 6000 RPM power band. |
blkmtrfan |
posted 11-08-2007 12:00 PM ET (US)
cooper1958nc, with the DI 2-stroke you also don't get:
quote: And as far as the hole shot, it isn't just the extra frictional losses of the 4-stroke, but, like you said yourself: quote: If 4-stroke doesn't spin up twice as fast as the 2-stroke it won't put the power out to get things moving as fast. Having double the power strokes at low RPM is a huge advantage when you are trying to move a stationary object. Now I do agree in practical applications the form 0 rpm, 2-strokes need a little help which is why most well built outboard props have tunable ports in them (Merc calls theird PVS) to allow some slipage until you get in to the meat of the torque curve, but once you are there which doesn't take long, watch out. Have you ever seen a 4-stroke in outboard drag racing |
Peter |
posted 11-08-2007 12:44 PM ET (US)
"Having double the power strokes at low RPM is a huge advantage when you are trying to move a stationary object." It's not really "double the power strokes" because the power strokes are not the same. While it is true that for 2 and 4 stroke motors of the same number of cylinders the 2-stroke will have twice the frequency of power strokes, but each 2-stroke power stroke will have a lower "amplitude" (force) than each 4-stroke power stroke. In a 6 cylinder 250 HP outboard, for example, the 2-stroke will have 6 smaller bangs versus 3 larger bangs for the 4-stroke for each crankshaft turn. In essence the power deliver of the 2-stroke is smoother because there is less of a gap between power pulses driving the crankshaft. |
blkmtrfan |
posted 11-08-2007 01:03 PM ET (US)
Are you trying to say it is double? I understand that the 4-stroke may be more efficent per power stroke (plus as stated above most 4-strokes of similar HP have greater displacement) but for this theory to work out each your 3 big bangs would have to produce greater power (force, work, or however you want to chose to calcualte it for this argument) than 2 of the smaller 6 bangs, and then still make up for the losses of the dead stroke and make up for the extra weight of the motor. Like I said above, you don't see to may (if any) 4-strokes in outboard drag racing. Heck, lets take this to a smaller scale. I will bet anyone that I can beat you in a dingy dragrace. Two identical dingys, I will put on my 15hp merc 2-stroke on one, you put on any 15hp 4-stoke of your liking on the other one and drag for pinks, LOL |
fourdfish |
posted 11-08-2007 01:16 PM ET (US)
I think you 2 are saying the same thing! |
Peter |
posted 11-08-2007 01:21 PM ET (US)
I am in agreement with you, the evidence is overwhelmingly contrary to the notion that 4-strokes make more low end torque. What I was trying to convey in a simplistic sense is that the 3 big bangs of the 4-stroke are the rough equivalent of the 6 small bangs of the 2-stroke. For example, if a 250 HP 4-stroke and a 250 2-stroke require 25 GPH to make 250 HP, then the fuel converted into useful work is spread out over 6 pulses per crankshaft revolution verus 3 pulses. The combustion product in each of the 6 pulses of the 2-stroke must be approximately 1/2 as forceful as the product of the 3 pulses in the 4-stroke. The above assumes all pumping, frictional and other parasitic losses are the same, which they are not. We know this because the 4-strokes need more displacement to match the power curve of a 2-stroke. |
imko |
posted 11-08-2007 01:31 PM ET (US)
What about this engine http://www.megoutboard.com/ Regards, Imko |
blkmtrfan |
posted 11-08-2007 02:26 PM ET (US)
Perhaps we are talking about the same thing if we look at the point where they both make the same HP. What I am trying to say is the 2-stroke will build power faster in the RPM band, in other words greater acceleration. I agree top speed with be the same if you make adjustemts in weight to equalize them on the same hull. Back to my dingy example, the top speed will be the same if they both put out 15hp (and you handicap my dingy with the extra weight), but I will get there first :) |
cooper1958nc |
posted 11-08-2007 05:50 PM ET (US)
I believe it is not possible to generalize about whether 2 or 4 stroke engines have "more torque" at any given RPM. It really depends on how the engine is designed. Remember, also, that it is thrust that is important, which is converted by the propeller from torque input. So it is not engine torque but propeller torque (allowing for the reduction gearing) and secondly propeller pitch, which must be considered in the equation. A high revving engine can be geared lower, and thus produce more propeller torque, possibly, than a low revving engine. If all other things are equal. What I said earlier was the design of the 2 stroke makes it problematic to achieve high VE at very low engine speeds. This is because the exhaust is not entirely removed, and the intake air is partially removed, unless there is a good powerful flow,i.e. higher mass velocities. This is true whether the engine is a carb or DI design. Extremely effective design (akin to variable valve timing in 4 strokes) may alleviate this to some degree. As to whether 2 or 4 stroke engines are presently used for drag racing, I cannot comment directly, except to say there are numerous factors involved. Weight may be an important factor, and 2 strokes are lighter, all other factors equal. Two strokes, we have seen, use their displacement twice as "much" at a given RPM, having twice the intake strokes. However, due to gas mixing and incomplete exhausting, the VE is much lower so the advantage is mitigated somewhat. Four stroke engines can supercharge the intake stroke to make up the difference as well. (I am not aware of commercially successful supercharged 2 strokes. Are they made?) |
highanddry |
posted 11-08-2007 11:37 PM ET (US)
The combustion process of a modern DFI is very efficient which is how they get two and three star ratings and very low fuel consumption--lower than many four strokes. |
cooper1958nc |
posted 11-09-2007 02:14 AM ET (US)
DI 2 strokes inject fuel after the exhaust port has closed, avoiding one of the serious 2 stroke problems -- exhausting fuel air. They also use computer algorithms to calculate the proper amount of fuel for conditions. They still suffer from mixing the intake air (without fuel) and exhaust, which means some exhaust is retained, and some air exhausted. Both decrease VE. A decrease in VE does not however have anything to do with fuel economy. Less VE just means less air is pumped. If you meter the fuel accordingly, fuel mixture is unaffected. Superior fuel economy in DI 2 strokes, over some 4 strokes, is due to: 1. less internal friction (needle bearings, more pumping per RPM); 2. possibly the ability to handle leaner fuel mixtures due to having no exhaust valve to burn; 3. lighter weight. I can't prove #2 though. Maybe someone has measured this. |
highanddry |
posted 11-09-2007 09:13 PM ET (US)
Generally two stroke engines I have worked with have lower EGT than a four stroke comparable engine (about 1200 degrees being critical)--outboards I imagine would be similar. I am not sure I follow your VE reasoning, two stroke engines are crankase supercharged, the downward movement of the piston rams the air into the cylinder. Of course ambient pressure replenishes the crankcase. Four stroke engines that are normally aspirated would not pump more air than a two stroke engine crank revolution for crank revolution. The exhaust stroke is not pumping air so a four stroke loses there. The higher VE of a two stroke is the reason they make more horsepower and torque for a given displacement. |
cooper1958nc |
posted 11-09-2007 11:12 PM ET (US)
Yes the crankcase pressurizes the intake, but there is no way to get the exhaust out and the air in at the same time, without some mixing. Two strokes pump more per revolution, having twice the intake strokes, but not per intake stroke, so it depends on how you define VE. The way it is usually defined, a 2 stroke would pump twice the air as a 4 stroke, assuming equal displacement and VE and RPM. As it is, at equal RPM and equal displacement, the 2 stroke pumps something like 1.5 times the air. The difference is due to lower VE, due primarily to intake/exhaust mixing. Here's a quote from a patent claim: I agree the small two strokes have EGT's around 1200, which is much less than equivalent 4 strokes and indicates they are running substantially richer than peak. I just have never seen anyone measure a big outboard or DI outboard's EGT. |
seahorse |
posted 11-10-2007 01:46 AM ET (US)
cooper1958nc wrote: .... I just have never seen anyone measure a big outboard or DI outboard's EGT.
cooper1958nc |
posted 11-10-2007 10:26 AM ET (US)
(From the website cited above:) "Usually, more than 1300 degrees at full bore is too lean (not enough fuel), and the engine may preignite or detonate" OK that is interesting. Peak EGT for 4 stroke engines at high power is typically upwards of 1700 degrees; metallurgical limits are imposed around 1650. Lean-misfire/detonation limits may be imposed before that. In a multicylinder engine, the EGT and mixture are a separate ballgame for each cylinder, although few have the intelligience to adjust fuel flow for independent cylinders. Usually the leanest cyl controls. Without seeing a fuel mixture vs EGT plot for a 2 stroke outboard, I can't say what the resultant mixture is at 1300 degrees. Is that peak or far richer? I am inclined to think it is substantially richer, but can't say for sure. The instruments sold in the website are interesting, but you have no control (other than throttle) of EGT in your outboard, unless you rejet (carbs) or reprogram (DI). The art and science of leaning airplane piston engines fills volumes, and there is substantial disagreement among practitioners. It is a big deal, though, because running full rich doubles the fuel consumption and running too lean destroys the engine. Maybe someone here fiddles with the chips in Etecs and has played with varying the mixture and watching the resultant power, fuel economy, and EGT change. Maybe racers or such. Would be interesting to hear about. |
posted 11-10-2007 11:25 AM ET (US)
In a recent Bass & Walleye Magazine series of articles, an older two-stroke motor was enhanced with the addition of new electronically controlled fuel injectors. As part of the process of installing the system, an exhaust gas temperature gauge was installed and the fuel-air mixture adjusted. I believe this was done on a cylinder-by-cylinder basis, and the control system provided for different mixtures are different throttle settings. "A remote control unit ...allows for leaning or enriching the fuel mixture on the fly.... We used the Digatron exhaust temperature gauge to help us zero in on the right fuel-air mixture at each rpm level." The retro-fit of this electronic system was quite expensive, about $3,700 for kit and quite a bit of work to install it, and it is probably targeted only at high-performance enthusiasts who have a particular love of older motors. See: Project Budget Basser, Part V: We're Really Cookin' Now |
XStech |
posted 11-10-2007 12:25 PM ET (US)
Man I love the internet. Discussions like this always bring a smile to my face. |
highanddry |
posted 11-10-2007 12:33 PM ET (US)
One of the problems with the EGT beyond 1200 on a two stroke of any kind is holing the piston. The four stroke engine piston has a cooling opportunity as it fies only every other revolution. The two stroke piston is cooled by the incoming charge in the crankcase and this is limited due t o the small amount of time available. The 1200 degrees give or take if exceeded often results in melting the piston or seizing it (differential expansion). Four stroke high performance engines also may have oil directed to the bottom of the piston to help with cooling. Obvioulsy directing oil to the underside of a two stroke piston or raw fuel is problematic since the underside of the piston is open to the crankcase which contains the incoming air (and fuel charge with non DFI units). The four stroke engine limiting factor as has been surmised is the exhaust valve. There is very little opportunity for this critical part to transfer heat away and thus it is a limiting factor in much the same way the piston dome on a two stroke is a limiting factor. Four strokes at least can run stainless and other high temperature materials for that valve, the two stroke engine is pretty much stuck with aluminum (high silicone alloy) as a piston material at least until hybrid metal/ceramics etc come along. |
cooper1958nc |
posted 11-10-2007 03:50 PM ET (US)
Thats right! Didn't think of that. Half the time to cool. Exactly. The ultralight crowd flying two strokes is always complaining of burned pistons. True 4 strokes can direct oil right on the underside of the piston. Hard to do with 2S. My earlier question was, is peak EGT in a 2S near stoichiometric, and is it over 1600? If so, 1200 is pretty overrich. I would say 2 gph richer than peak for a 150 hp engine. A lot of gas to waste. But for that matter how does the supercharged Verado survive sustained high power operation without frying its exhaust valves? Does it run rich too? |
Rob Pirie |
posted 11-10-2007 10:40 PM ET (US)
(and it is probably targeted only at high-performance enthusiasts who have a particular love of older motors.) Back in my boat racing days a local mechanic developed an adaptor plate that bolted to the face of an Merc Mod VP race engine which enabeled you bolt 2 carbies per cylinder it was called a 12 pack and it worked achieving the world speed record for a mono hull (Bullet One) the only problem with was keeping the engine together , quite often boats running this system were towed to shore with a hole through the side of the cowling were the engined had lunched itself and sent a piston out through the side of the engine. Rob |
Binkie |
posted 11-11-2007 09:21 AM ET (US)
jimh, I remember that article "Budget Basser" in Bass & Walleye magazine. The whole article was irrelevant to anything someone would do to put together a Budget Bassboat. That article was in my last issue before my subscription expired and I never bothered to renew. The magazine was so thin and devoid of any actual info., pertaining to bass boats that you could read it in 15 minutes, and I think John Tiger is overrated anyway. Last year I put together a budget bass boat and trailer for under $5 grand with an Awlgrip paint job and a good running `87 Suzuki DT Super Six, that will run in the high sixties, stock, and will run that way all day if you want to feed it. Everything is brand new in the boat, with the exception of the motor which I got from E-Bay and the actual hull which I stripped of everything including fuel tanks , and it even has mahogany trim. I don`t use this boat much as I live an hour away from any suitable lakes, and I don`t use it in salt water. http://i27.photobucket.com/albums/c191/floridaboy2053/boats2/100_0003. jpg Rich |
fourdfish |
posted 11-11-2007 11:16 AM ET (US)
Binkie- That is a great little ride!! I finally deep sixed all the boat Mags. They are becoming mostly advertising with a few repeating articles for the newbees! It would seem that those that spend the most on advertiseing, get the best reviews. Of course that makes sense for thier pocketbooks! |
