posted 11-03-2007 08:45 AM ET (US)
No matter how many hours of use in the season, when preparing any four-stroke engine for a long period of storage the lubricating oil ought to be changed, and especially so on an outboard motor. Four-stroke outboard motors have been reported as being particularly prone to contamination of their lubricating oil with water and gasoline. These are in addition to the normal combustion products which contaminate the lubricating oil. The oil sump should be drained and all of the lubricating oil removed and replaced with fresh oil.Can you tell us more about the procedure you used to remove the lubricating oil from your Mercury 115 EFI motor. I am assuming you are talking about the newer style of motor using the engine block from the Verado. This is called the "FourStroke EFI" or the "L4NA" or the "Veradito" or "Le Verado Petit".
Can the oil be removed from the oil sump by gravity flow? Or do you need to use a suction pump to withdraw it? Does the engine need to be positioned in a special orientation to promote proper flow of oil to the sump for removal?
When the oil filter is removed, how is the filter oriented? Does the residual oil in the filter spill out as you unthread it? Do you have to puncture a hole in the filter before removing it to drain the residual oil inside the filter? Does the engine have to tilted or rotated in a special way to position the oil filter for removal?
Was the procedure particularly messy? You mentioned the inadvertent spilling of oil into the boat. How about spilling of oil on the motor itself. Did the oil change require a lot of rags or towels to clean up the motor and yourself after finishing?
Also, how did you dispose of the used motor oil? This is not a question specific to your particular motor, but to all four-stroke engines in general. I have changed the oil in my vehicles and take the used oil to an oil recycling collection center, however they do not accept the containers, just the oil. I asked the operator of the center and he explained it this way: plastic containers with residues of used motor oil cannot be discarded in his usual trash pick-up. Their trash is often inspected for containers of used motor oil and if any are found they are liable for a $5,000 fine. So after he pours my used motor oil into his collection tank, my plastic container is returned to me for disposal.
I suppose that technically I am subject to the same regulations as the recycling center, so I should not just throw out my contaminated oil container in my trash. On the other hand, I assume I am permitted to throw out the oil container if it only had a residue of new, unused oil in it.
Please let us know how you handle disposal of the used motor oil and the container it was in.
