ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Confusing Acronyms; Nautical Terms for Speed
Author | Topic: Confusing Acronyms; Nautical Terms for Speed |
siguy |
posted 11-04-2007 08:04 PM ET (US)
[This author has never returned to follow up on his inqury for advice in selecting a propeller, but his unfortunate use of an acronym started an interesting discussion on what unit of distance ought to be used to measure boat speed--jimh.] Was wondering what props you would recommend running on a 31 Jupiter Cuddy with 2 250 ETECHS. Using 14 3/4 21's only getting 35-38 KPH. Thanks, Sd |
posted 11-04-2007 09:25 PM ET (US)
If you are only getting 38-KPH, that is just 23.6-MPH. That is horrible performance. I cannot believe that with 500-HP you can't reach more speed. Give us more details about your engine speed readings in RPM so we can evaluate your propeller SLIP. |
Brian7son |
posted 11-06-2007 12:57 PM ET (US)
Jim, He's got to mean "knots per hour". He cant mean kilometers. Knots would put him at 40.25 mph, which I would imagine that boat could do all day long. That's a very nice boat with very nice motors. |
Brian7son |
posted 11-06-2007 01:05 PM ET (US)
Here's the same model boat that he's talking about: http://www.boattraderonline.com/addetail.html?79927391 this particular one has twim Yamaha 4 stroke 250's, it's cruises at 30-40mph and top end is 53mph. |
posted 11-06-2007 09:13 PM ET (US)
Boat speed is measured in miles per hour, unless you are engaged in a long ocean voyage. I will leave it to the original author to disambiguate his use of acronyms. |
Tom W Clark |
posted 11-06-2007 09:32 PM ET (US)
"Boat speed is measured in miles per hour, unless you are engaged in a long ocean voyage" A remarkably inaccurate statement from you, Jim! Where did you pull that from? Boat speed is measured however you like. Around here (the Pacific Northwest) there there seems to be about equal numbers of boaters who prefer MPH vs. knots. The never-ending debate about which unit of measurement is "correct" is a bore. Sd, I recommend you try a pair of Mercury Revolution 4 propellers. The recommended pitch will depend on what your WOT engine speed (RPM) is now. |
posted 11-06-2007 11:33 PM ET (US)
CONTINUOUSWAVE uses statute miles per hour, and that way we don't have to have a boring discussion when speeds are given in some other units. |
Rob Pirie |
posted 11-07-2007 12:34 AM ET (US)
Knots , nautical miles and fathoms is international and when you use these units of measure when on the radio no explanations or conversions are required. Any boatie worth his salt should know what they mean. Rob |
BarryGreen |
posted 11-07-2007 08:28 AM ET (US)
Agreed; all appropriate and correct units of measure for speed are acceptable, and here in the Northeast I find statute miles per hour (MPH) and knots (nautical miles per hour) both in common usage. Of course, Jim can set whatever convention he sees fit for his website. The problem siguy is having is that there is no such thing as "knots per hour". A knot means "nautical miles per hour", so speed should simply be stated in knots. Barry |
posted 11-08-2007 09:07 AM ET (US)
The original data given only specified the engines as being "250" power. I imagine this was a reference to their power in horsepower, and not in kilowatts. We generally speak of engine power in horsepower, not kilowatts, and as far as I am concerned, this is the same sort of convention as I insist on for the distance measurement. We use statute miles, and not nautical miles or kilometers. The propeller dimensions were only specified as 14-3/4 and 21. Again, I imagine this was intended to convey their size using inches. But this could also be centimeters. And again we use inches for this unit. If there is to be total freedom in expression of dimensions in any unit one chooses, as suggested for the speed being free to be expressed in either statute miles per hour or nautical miles per hour, I don't see why there ought not to be the same freedom for the horsepower and the propeller dimensions. Let's have those in kilowatts and centimenters, if you like. Personally, and as the moderator, I don't like that situation. It would just be confusing and make the units have little meaning for most readers. And this is the same basis why I made the statement I did regarding the speed. Tom asks: "Where did [I] pull that from?" I pulled it from my responsibility as the moderator to provide some uniformity to the discussions regarding which dimensions ought to be used. We use statute miles per hour for discussing our boat speeds, and it is done for the same reason that we use horsepower to measure the engine power, and inches to measure the propeller dimensions. There are very valid and reasonable alternative units for all of these measurements, but we don't use them because we don't want the discussion to turn into an unfamiliar soup of mixed dimensions and units. |
seahorse |
posted 11-08-2007 09:46 AM ET (US)
Do we measure the length of our Boston Whalers in feet or meters ? |
knothead |
posted 11-08-2007 11:11 AM ET (US)
Rods or furlongs or fractions there of. regards---knothead |
Brian7son |
posted 11-08-2007 03:44 PM ET (US)
Funny how this thread has developed. I was merely pointing out that based upon the model boat and engines involved that it was my impression that siguy was referring to 35-38 "knots". That still is my impression. I'm not saying it's proper nautical terminology. Lord knows, I am certainly no expert in that field (at all). However, I can tell you to get me a beer from the cooler whether it's on the port or the starboard side of the boat ;) |
posted 11-08-2007 09:14 PM ET (US)
This last point is well taken, and at the base of all the confusion was the use of an acronym which was not preceded by any explanation. Did the author intend that "KPH" mean knots-per-hour or kilometers-per-hour? How do we know? We cannot except by examining the data and seeing which makes more sense. The article seems to complain about poor performance, so perhaps it is a case of how poor we think the performance might be. Note that to really judge how poor it is, most people have to convert either knots-per-hour or kilometers-per-hour into miles-per-hour in order to have some point of reference. In the end, I don't think the fellow is still participating in this discussion. He is just a "drive-by" participant. If he shows up again, we can pick up where we left off, which is with asking for more information about the engine speeds being reached. |
Tom W Clark |
posted 11-08-2007 11:24 PM ET (US)
"Tom asks: "Where did [I] pull that from?" I pulled it from my responsibility as the moderator to provide some uniformity to the discussions regarding which dimensions ought to be used. We use statute miles per hour for discussing our boat speeds, and it is done for the same reason that we use horsepower to measure the engine power, and inches to measure the propeller dimensions. There are very valid and reasonable alternative units for all of these measurements, but we don't use them because we don't want the discussion to turn into an unfamiliar soup of mixed dimensions and units." Jim, That's fine. but that is not what you wrote. You stated that MPH are used (with one exception) as a matter of convention. This is simply not so. It is not true within recreation boating. It is not even true within the borders of the United States. As a matter of fact, units of speed are not uniformly used here on continuousWave if a review of the archives is any indication. I think what you were trying to express is that you would prefer that participants here used miles per hour (MPH) as the standard unit of speed measurement. I'm with you on using MPH in our discussions, that is my preference as well. I also agree with Brian that Sd probably was trying to say his boat travels 35-38 knots rather than kilometers per hour. It is not a great stretch to read between the lines there. Nor is it a great burden to convert knots to miles per hour or vise versa. Simply multiply or divide by 1.15 for a perfectly reasonable conversion. |
Kingsteven18 |
posted 11-09-2007 05:39 AM ET (US)
I think you're all knuts. |
posted 11-09-2007 08:52 AM ET (US)
The preference for a unit of measurement for distance may vary with the region in which one is boating, and it may be split along the lines of freshwater versus saltwater. To investigate this I consulted the publications of the United States, and in particular the fine series of COAST PILOT publications. In UNITED STATES COAST PILOT 6 which covers the Great Lakes, I found this declaration under the subheading "Distances" in Chapter 1--General Information. "Coast Pilot volume 6 is in statue [sic] miles unless otherwise stated. A statute mile is 5,280 yards [sic], or about 0.87 nautical mile." However, in UNITED STATES COAST PILOT 7 which covers the California coast, in the same section it states: "Distances "These are in nautical miles unless otherwise stated. A nautical mile is one minute of latitude, or approximately 2,000 yards, and is about 1.15 statute miles." In COAST PILOT 6 there are many references to limitations on vessel speed and they are all given in miles per hour, e.g.: "A speed limit of 4 mph is enforced in River Rouge and Short Cut Canal 21. (See 33 CFR 162.130 through 162.140, chapter 2, for navigation regulations.)" However, on the Canadian side of some waterways, the speed are given in knots: "Canadian regulations specify a speed limit of 8 knots for vessels of 15 gross tons and over in Amherstburg Channel." However, in my brief scan of these publications nowhere did I observe the use of the acronym "KPH", which seems to be mainly an invention of the original author in this discussion and as far as I can tell is not in general use by mariners as an abbreviation for "knots per hour." CONTINUOUSWAVE has a long standing policy of resisting the use of unknown or unclear acronyms, as we feel that they add no value to our discussions and serve mainly to detract from them and create confusion. I believe that use of KPH has only served to confuse this discussion and to result in almost complete abandonment of the original topic. |
posted 11-09-2007 09:13 AM ET (US)
The acronym KPH has only been used about 15 times prior in the hundreds of thousands of articles published here, and in all cases, as far as I can tell, it was used to mean kilometers-per-hour, for which I would readily agree it is a very common acronym and is in worldwide usage. CONTINUOUSWAVE does accept the use of many common acronyms, but it also accepts the common meaning of them as being understood. So when one writes about "MPH" we assume it means miles per hour and not "Master of Public Health" at least when talking about the speed of a vessel. In the case of KPH it is particularly strange that one would use it as an acronym for speed to mean knots-per-hour because there is of course the immediate confusion with kilometers-per-hour, also a speed measurement. Further, the word "knot" is commonly understood to mean "nautical miles per hour", so interpretation of KPH to mean "nautical miles per hour" requires that we abandon the most common meaning of "knot" and turn to some alternative meaning such as "nautical mile." If anyone can cite any example of where "knot" has been used in prior discussions here to mean "nautical mile" instead of "nautical mile per hour" I would be pleased to acknowledge them, but as far as I can tell, this was a first. As an example of how to cause confusion by use of acronyms, I cannot imagine a better example than demonstrated here by "KPH." It seems to be about the finest, most convoluted, confusing example of an acronym. The general reason for using an acronym is to save the effort of typing out the whole phrase, but in this case the savings are small. "KPH" is three capital letters, while "knot" is four lower case letters. Since one has to hold the shift key to type the upper case letters, it could easily be argued that typing "KPH" takes more effort that typing "knot" and thus wipes out any savings to be gained from use of an acronym. Thus not only is "KPH" harder to type, but, as we have seen, its use creates so much confusion that it cannot possibly be judged to have been worth the cost. |
Binkie |
posted 11-09-2007 03:40 PM ET (US)
In 20 years when the USA becomes a Spanish speaking country, speed will be measured in kilometers-per-hour. A typical thread on CW might read.-- I have a 6 meter Whaler, I would like to take my entire family (20 relatives) out on a Sunday, after a busy week of picking watermelons. The boat is powered by an old Johnson, that my uncle gave me. How many kilometers per hour will it go. How much gas do I need to get to Mexico, to pick up my 17 cousins. rich |
Mobjack |
posted 11-09-2007 04:20 PM ET (US)
I think Jimh has hit it on the head, this is a freshie vs saltie thing. As a coastal guy, I have no real reason to ever use statute MPH. In aviation, I always use knots, both in speed measurement and distance measurement, and the same goes for the time I spend on boats. MPH is a reliable way to measure speed over ground in a car, where complex navigation is not required. |
Brian7son |
posted 11-09-2007 04:32 PM ET (US)
Eureka: I have decoded the original post and determined the problem. He is "Using 14 3/4 21's". If you have fourteen, three quarter naked 21 year old ladies on your boat. 38 knots is all she'll do. But who's in a hurry with that crew. |
L H G |
[Introduced a new topic of discussion into this discussion--a discussion of the contents of the website. Please use the META-Discussion to discuss the discussions themselves or to make comments about the website--jimh.] I see we have yet another [E-TEC] owner disappointed in top speed. No change there, either. |
knothead |
posted 11-09-2007 04:41 PM ET (US)
I also believe it's a salt water vs. a fresh water thing. Funny thing, even though the Intercoastal Waterway is salty, it has Statute Mile markers. It seems to me that sailboats and big ships use knots and motorboats use MPH. No pun intended in the first part of that phrase. As for you Binkie, you must immediately report to Duke University to undergo an intensive course of political correctness indoctranation. Until you comply, I won't read any more of your posts. regards---knothead |
fourdfish |
posted 11-09-2007 05:55 PM ET (US)
I agree with you Larry (LHG) Your were NOT missed! However, It would seem that you always ignore the same threads which have Mercury and other manufacture outboard owners with the same grip!. I believe your post belongs in the meta section along with mine! |
posted 11-09-2007 08:48 PM ET (US)
Welcome back, Larry--What I see in this, and I think you have overlooked, is that among Jupiter 31 Cuddy owners it is clear that E-TEC has dominant market share. No reports of Verado powered Jupiter 31 Cuddy boats--ZERO. The only solution is for Brunswick to acquire the brand. |
Rob Pirie |
posted 11-10-2007 10:22 PM ET (US)
(In 20 years when the USA becomes a Spanish speaking country, speed will be measured in kilometers-per-hour).... That won't happen. I live in Australia and we switched to the METRIC system over 35 year ago and we still use MPH for speed , cubic inches & horse power for capacity in the marine industry because all our engines come from the good ole USA plus when we talk part sizes and clearances we still use thousands of an inch because the metric conversion converts to ridiculously long decimal point number that we don't even understand.Kilowats & Kilometres per hour are only widely used in our car industry as these come in from all over the world but the die hard mopar style enthusiast still quote the old system. (I think Jimh has hit it on the head, this is a freshie vs saltie thing)..... I agree and my comments are based as from coastal perspective. Rob |
John W |
posted 11-11-2007 02:05 PM ET (US)
Knots, or nautical miles per hour, has been the standard measure for speed over the water for recreational and commercial boat traffic in the USA and internationally for a very long time. Using statute miles per hour as a nautical measure is a fairly new development, and I believe it probably resulted from novice boaters with trailer boats using a term they were familiar with from their cars. But nautical miles per hour is the correct nautical measure, and knots is the correct nautical term...just as yo can refer to the "back" and "front" of the boat if you want, but "stern" and "bow" are the correct nautical terms. Many would consider "Piloting, Seamanship and Small Boat Handling", by Charles F Chapman, to be something of a bible on most aspects of recreational boating...it has been in print for decades and is updated frequently, and is used by the United States Power Squadrons as well as various branches of the U.s. Navy and Coast Guard. "Chapman Piloting", at least in an older edition I have in front of me, specifically points to the use of MPH instead of "knots" as an example of a novice mistake in terminoligy...along with other examples such as calling the galley a "kitchen" or referring to a chart as a "map". Clearly, the KPH term used by the original poster is incorrect. It is also clear that jimh can make MPH the standard for use on this site if he chooses to, and there may be good reasons to do so. MPH is certainly a measure that we all are familiar with from land travel in the USA, and I have used MPH in discussions here frequently. But the statement "Boat speed is measured in miles per hour, unless you are engaged in a long ocean voyage" is not at all correct. Given that jimh generally like this site to be proper and accurate, down to correct punctuation and grammar, I am surprised that he wants us to avoid the use of the correct nautical measure on this site. John |
posted 11-11-2007 03:34 PM ET (US)
What does Chapman have to say about soundings? Measure them in fathoms? In the Great Lakes and in most inland waters soundings are in feet. You saltwater mariners are welcome to fathoms. Do you keep time onboard in "bells"? Stop at local noon to take the altitude of the sun as it passes your meridian? Perhaps you measure your engine speed in propeller shaft RPM? Should wide-open-throttle become "all-ahead-full"? I am all for some traditions. Give me a nice straw boater (hat) and a Martini with London Dry gin, but I am afraid I will forego measuring my trip up an inland river in terms of minutes of latitude. Its miles under the keel and miles-per-hour for me and for most recreational boaters who operate off a trailer and on inland waters. And that is probably the majority of Boston Whaler owners. |
John W |
posted 11-11-2007 09:24 PM ET (US)
touche, Jim! Quite funny. If someone's at the con o' me Boston Whaler scow, it's all-ahead-full unless they want to walk the plank. And no martini's on board, please...on a proper vessel it is strictly "grog" at happy hour. As others have pointed out, using MPH versus knots may vary on fresh versus salt water, as well as with the size of the boat...I've never heard anyone quote the cruising speed of a yacht in any measure other than knots, but trailer boaters frequently use statute MPH. Seperate from the knots versus MPH discussion, I do think using proper nautical terminology, within reason, is fun and quite practical. I was taught early in life that on board a boat, there are dock lines and anchor rode, but the only "rope" on a boat is used to ring the ship's bell. |
Plotman |
posted 11-11-2007 10:51 PM ET (US)
My understanding is that the US government uses nautical miles for all "ocean" publications, but statute miles for all inland publications, which includes the great lakes and major river systems (Mississippi, Missouri, etc.) Jim's comment on the different conventions in the various volumes of the coast pilot bear this out. It is logical that boaters will then measure speed using the distance scales that are printed on their charts. Jim, being a great-lakes sailor, is used to using statue miles for both distance and speed. Those on the right and left coasts are much more likely to use nautical miles and knots. I believe that this odd situation came about because historically, the rivers - and by extension, the great lakes - were considered the domain of the Army Corps of Engineers, which, for obvious reasons, used the "land mile". The waters of the Atlantic and Pacific Oceans, being the domain of the US Navy, used the "sea mile". David |
posted 11-12-2007 01:28 AM ET (US)
By the way, this is an exact quote from COAST PILOT 6" "Coast Pilot volume 6 is in statue [sic] miles unless otherwise stated. A statute mile is 5,280 yards [sic], or about 0.87 nautical mile." I am sure they meant a statute mile is 5,280 feet. Heck, even the government can make a mistake now and then. |
itl |
posted 11-12-2007 05:03 AM ET (US)
Well, I think that knots or nautical miles per hour are only correct units at marine environment when measuring speed, but it is ok for me, if someone uses different units like miles or kilometers per hour. Important thing is that everybody knows what unit we are talking about. Personally I prefer knots, because when we are talking speed measured by knots, for example 20knots, I immediately understand how fast/slow that is. If we are talking about miles or kilometers per hour, I always have to convert that reading in my mind as knots before I really understand how fast/slow the velocity of the boat is. However, I think it is a bit weird that MPH is preferred speed unit in this forum, because I see knots as the only correct unit when talking a speed of a boat, but it is ok for me if someone else like to use for example mph. Anyway, we are guests here and we need to play by forum rules. I can use the speed of light as a velocity unit if forum rules requires that. |
hauptjm |
posted 11-12-2007 08:55 AM ET (US)
I have NEVER heard the term knots per hour. I'm familiar with miles per hour (MPH), kilometers per hour (KPH) and knots (KTS), but never have I heard of the phrase knots per hour. I think this entire thread was based on a futile expression that doesn't even exist. I went to every manufacturer of marine equipment that produces speed measuring devices and not one of them has a gauge, display or device that shows a knots per hour measurement. You can buy any number of them that will provide the requested speed information in MPH, KPH or KTS. Whew! An example: http://www.raymarine.com/SubmittedFiles/FileManager/349.tn.sm.jpg |
posted 11-12-2007 09:22 AM ET (US)
When operating on the ocean, and particularly in international waters, I am certain that the preferred unit of distance and thus speed measurement is the nautical mile. This makes complete sense because when a vessel is at sea it is not really bound by the preferences of distance and speed measurements used by a particular country for its land and waters. A vessel at sea is independent of the land, and it may adopt its own preferences for many conventions, thus not only are speed or distance measurements at variance with the land but the time of day aboard ship might be different, as well as many other customs, such as the serving of alcohol on a particular day of the week or whether the crew is permitted to smoke tobacco in certain circumstances. But when operating in waters that are inside a particular country, it is not unusual for speed and distance measurements to conform to the preferred unit of that country. For example, when we navigated the historic Rideau Canal in Ontario, Canada, this summer, we found that speed limits were posted in kilometers per hour. Cf.: http://www.tc.gc.ca/acts-regulations/GENERAL/c/csa/regulations/001/ csa005/csa5-c.html When we saw posted speed limits of 8-kilometers-per-hour, we did not get offended and wonder why these poor misguided people weren't using nautical miles per hour, we just slowed down to 5-MPH and continued our pleasant trip. The length of a nautical mile comes from a minute of latitude, and you might say it is a natural length. A statute mile of 5,280-feet is not quite as natural a dimension. There is a good discussion in Wikipedia http://en.wikipedia.org/wiki/Mile which notes, "The statute mile is the distance typically meant when the word mile is used without other qualifying words..." That interpretation is used here. If someone says their boat goes 33-MPH, that is taken to mean 33 statute miles, never nautical miles. If someone gives their vessel speed in nautical miles per hour, I usually convert it to statute miles per hour so that there is some consistency to our discussions and to avoid confusion. When someone gives their boat speed in knots, I hope they are using the term correctly to mean nautical miles per hour, and proceed on that basis. If someone gives their boat speed in "KPH" I assume they mean kilometers per hour. Wikipedia agrees; see: http://en.wikipedia.org/wiki/KPH It is quite common in my experience to see speeds for boats given in kilometers-per-hour, as much of my actual boating is done on inland waters of Ontario, where kilometers-per-hour are the official unit of boat speed. I do not really think there is anyone who can make a serious argument that one ought to interpret KPH as knots-per-hour where knot no longer has its standard meaning but becomes "nautical mile." Is my preference for boat speed in miles-per-hour something I dreamed up? No, it is the unit generally used in inland waters and on the Great Lakes. It might not be as yachty as knots, but I think it is more familiar to most boaters. |
posted 11-12-2007 09:44 AM ET (US)
One more point: Most ocean-going vessels--the ones that use knots for speed measurement--travel at quite moderate speeds, typically less than 10-nautical-per-hour, and the difference between 10-nautical miles and 10-statute miles is not huge, being only about a mile and a half. One can shift units of measurement at these speeds and not be off by much. Many Boston Whaler boats attain speeds of over 40-MPH, and at this speed the difference between expression in statute miles and nautical miles begins to become more significant. A speed of 40-knots is 46-MPH. At these speeds a change in boat performance on the order of 6-MPH is very significant and often crucial to the discussion of whether or not the boat is performing up to its expectations. Therefore, as the speed being discussed increases, I find it becomes more important to clearly distinguish which unit of measurement is being used. And similarly, it become more important that a common unit be used in such discussions, otherwise the reader is going to be presented with data that varies considerably depending on the unit. I would also judge that the nautical tradition or preference to use knots tends to diminish as speed increases. In terms of record high speed runs, my recall is that these are always given in terms of statute miles per hour, not nautical miles. |
Tollyfamily |
posted 11-12-2007 11:14 AM ET (US)
Everyone (100%) of the people we cruise with up here in the NW have always used knots. I do see some people talking MPH when talking about speed boats or dingys. Dan |
Perry |
posted 11-12-2007 02:35 PM ET (US)
I hear the term "nautical miles per hour" quite often. Maybe he should have abbreiviated it "NMH" instead. In Wikipedia, it says that one knot is equal to one nautical mile per hour. |
itl |
posted 11-12-2007 04:28 PM ET (US)
There is a good reason why nautical terms are used. As you know, nautical distance unit is nautical mile which is same as one minute of latitude and that makes it as a natural unit: earth is divided to 4 x 90 = 360 degrees and one degree is divided 60 minutes, so circle of earth is 60 x 360 = 21600 minutes and that is the same thing as 21600 nautical miles. So what knots has to do with this. As we know speed is distance divided by time. Time is measured with hours and distance is nautical mile. Those factors makes speed as a knot which is nautical mile/hour. So knot is based on natural units. That makes sense, right? The most important question is, what we benefit of this? Nautical charts contains latitudes and longitudes. You can see latitude scale (degrees and minutes) in a side of chart. So based on that, you can "pick" one minute there and easily use it as a distance unit when measuring distances from chart. When you are navigating at sea, you need to know at least three things; distance, speed and bearing. You measure the distance and bearing from chart and take a look of your speed meter to figure out your speed. Then you put distance and speed to formula: distance/speed=time and as a result you can estimate your travel time. With this information and by using chart, compass and speed meter, you can navigate where ever you want to go. Without electronic divices. But if you dont use correct units when calculating these things you get wrong results and most likely you are lost very soon. Abviously you can calculate these things by using statute miles and mph, but then you first must get distance from the chart as nautical miles and convert it as statute mile if you like to use mph as a speed unit. That is totally unnecessary conversion and when ever you convert something, errors can happen and then you distance, time and speed calculations give wrong result and soon you dont know where you are at the sea. Ok, that is all about traditional navigation by using chart, protractor and compass. Nowdays allmost all boats are equipped with electronic navigation devices (mostly GPSs). Because of that it is not really necessary to do traditional navigation and you can use what ever unit you want. Chartplotter shows how to go the place where you are going and the same device show your speed in what ever unit you want. The only problem is what to do when electronic gizmo breaks and you have to figure out how to go back home from the sea. Then it is really good thing if you can navigate traditional way. Sorry for so long posting, but maybe now you understand why I prefer knots instead of mph. However, I try to use mph units here, because it is preferred speed unit in the forum. |
Tollyfamily |
posted 11-12-2007 05:16 PM ET (US)
I guess thats why we always use knots, the paddle wheel speed, GPS speed and plotter speed are all set to knots because we have plotted our routes on a paper chart and measured the distance per leg and it all has to be the same. I laugh when reading some of the boat test articles that use MPH while talking about large boats. Dan |
WT |
posted 11-12-2007 06:19 PM ET (US)
The original poster is located in Kingston, Jamaica which uses the metric system. Since he was complaining of ONLY getting 35-38 KPH (22-24 MPH) it makes sense that he meant kilometers per hour. I would not think he would complain of 35-38 knots (40-44 mph). My 2 cents. Warren |
posted 11-12-2007 09:40 PM ET (US)
The basics of navigation are beyond the scope of this discussion, and it is presumed that everyone is competent in the art. There is nothing about navigation which inherently favors any particular unit of distance. It is all a matter of preference. Here is a press release from Mercury Marine which mentions boat speed records: "Mercury Marine established five new world kilo bass boat speed records Monday, November 4, 2002, on the Tennessee River in Clifton, Tennessee....McClain flew through the traps at an average speed of 102.099 mph to set a new 1500 lb. Pro Stock Bass 200 world kilo speed record on his first attempt! ....Nichols made four runs in a Mercury Racing OptiMax 250XS Bullet 20CC bass boat to set a 104.483 mph world kilo bass boat speed record in the newly established 1800 lb. Pro Stock Bass 250 outboardclass.... McClain quickly hammered out a new 1400 lb. Pro Stock Bass150 class record with an average speed of 92.103 mph....Nichols made four passes to achieve a best of two-pass average speed of 105.020 mph....[another boat] blistered through the traps averaging 99.191 mph...to set a new 1400lb. Pro Stock Bass 175 class record." Why are all of these speeds given in statute miles per hour when nautical miles per hour is supposed to be the standard for boating? Are Mercury Marine just another laughable example of naive and inexperienced boaters who don't know the proper units for boat speed? |
posted 11-12-2007 09:48 PM ET (US)
The notion that the earth consists of 360-degrees of arc, and each degree consists of 60-minutes is not entirely "natural." It is just a conceit of man imposed on the earth and measurement of angular distance. There is nothing "natural" about 360 X 60 = 21,600. It could be better argued that distance measurements around a sphere ought to be measured in units of radians. See: http://en.wikipedia.org/wiki/Radian "History--The concept of radian measure, as opposed to the degree of an angle, should probably be credited to Roger Cotes in 1714.[1] He had the radian in everything but name, and he recognized its naturalness as a unit of angular measure." |
posted 11-12-2007 10:01 PM ET (US)
Proponents of "natural" units of speed are really arguing for expressions in radians-per-second. [My original math was a bit off, so I have corrected it--jimh.] 21,600-nautical miles / 2*pi radians= 3,437 nautical miles/radian So a boat speed of 1-Kn would be 1-nautical-mile/1-hour X 1-radian/3,437-nautical-miles = 0.00029-radians-per-hour. Now there is a natural dimension if I ever saw one. Should we adopt it for boat speed? |
WT |
posted 11-12-2007 10:44 PM ET (US)
I may have had too much to drink at dinner but... My perception of boaters in the United States that pilot little (under 30 feet) Boston Whalers and use knots as a measurement of speed is that they are trying to impress someone. Kind of like a college professor trying to wow the coeds. This is especially true if they pilot boats in FRESH water. Warren |
jgkmmoore |
posted 11-19-2007 06:25 PM ET (US)
WOW! |
jgkmmoore |
WOW! |
Mobjack |
posted 11-20-2007 11:33 AM ET (US)
WT, not really trying to impress anyone, really could care less how anyone else drives their boat. I don't care if I am paddling a friggin kayak around in the ICW, I still measure my speed in knots, because that is the correct unit of measurement to use when travelling in a boat or an airplane. You are quite welcome to start measuring the fuel consumption of your car in miles per quart. It will be really creative, no one else will be doing it, and then you can come back here and ask why everyone is looking at you funny when you mention it. After all, who says you have to measure it in gallons? Those rules of convention are stupid anyway... |
2manyboats |
posted 11-20-2007 04:18 PM ET (US)
Before finding this site I have never used mph on the water. Marine weather forecasts use knots for the wind speed,in all our sailboat racing both the speed of the boat and the length of the course, knots and nautical miles were used. So whether offshore, coastal, or inland we use knots, always have always will. For what ever reason mph seems the preference here , so when in Rome. I don't see it as a big deal. |
posted 11-20-2007 09:21 PM ET (US)
When we use "gallons" we mean the U.S. gallon (four-quarts), and not the Imperial gallon ("five" quarts). I am afraid that gallon is another term like mile; they both need clarification when used. See http://en.wikipedia.org/wiki/Gallon Because aircraft move through air, they often measure their air speed as opposed to their ground speed. It seems incongruous that an aircraft would measure its ground speed in a nautical unit. If they do, perhaps they ought to call it their "ocean speed" instead. How aircraft measure speed is probably an interesting discussion, but I do not see the applicability here. Wind velocity is often given in knots, however meteorologists in Canada use kilometers per hour. So I question the notion that knots are universal. Clearly knots are not. |
blackdog54 |
posted 11-21-2007 06:38 PM ET (US)
My Garmin 498 came with the factory presets to measure in "KNOTS" not MPH. This Garmin also came with coastal, but not inland, waterways maps. You can override the factory setting and change it it MPH. I did NOT get the paddle wheel transducer as I am using it on a motorboat, not a sailboat (and it was larger and more expensive than the already-larger transducer I did buy). I am with JohnW, I think MPH has evolved for novice boater's (but I do like WT's "impress the co-eds" point as well). I like KNOTS, it distinguishes the activity being measured from NASCAR or Jonathan Papelbon's fastball. |
2manyboats |
posted 11-22-2007 09:18 AM ET (US)
As gas prices go up maybe we should measure speed and distance in dollars. I don't think my Garmin has that setting so I guess you just have to figure it in your head. |
jimp |
posted 11-22-2007 11:49 AM ET (US)
Would it be that professionals use knots and novices use miles per hour? I've used knots on my Dad's boats since the mid-60s. Everybody was using knots, nobody used mph (that I knew, but I only boated saltwater). MPH became popular when boat manufacturers started putting speedometers in boats that said mph, suddenly that's the only reference boaters had regardless if they were old timers, novices, saltwater or freshwater. Nautical charts are printed using minutes of latititude - the nautical mile. Does it make sense to use a nautical chart and then convert to miles per hour? Then again, few use charts and most/many rely on their electronics that can give them knots or mph. 2manyboats has the best unit of measure in dollars per mile. Regardless of nautical mile or statute mile, $ per mile will continue to grow. The Great Lakes have historically used miles per hour. What units are the charts printed in? JimP |
posted 11-23-2007 10:29 AM ET (US)
If you are the master of a vessel navigating the Great Lakes in U.S. waters you will find the speed limits are posted in nautical miles per hour, as I mentioned above in Coast Pilot 6. When I go to my local lake there is a sign informing me there is a speed limit of 40-MPH on the lake, which I think you will find is in reference to statute miles. Jim's point about the dial calibration of the pitot-tube speedometer in use for the past 50 years is an excellent observation. They are all calibrated in miles per hour. I do not think I have ever seen one calibrated in knots. Small boats, and particularly small outboard boats which travel at relatively high speeds, used that instrument and its unit of measurement for decades prior to the widespread adoption of GPS speed measurement in the last few years. If you bought a taft rail log to tow behind your vessel to deduce your speed it probably did not read directly in a unit of speed and needed to be converted. The conversion table probably offered a choice of units. Most all speed measurement devices which are electronically based have a calibration setting to select the unit from several choices. I do not find it particularly authoritative that the newest manufacturer to enter this market, Garmin, choses a particular unit as the default setting in their software setting. As far as I am concerned, Garmin, as a manufacturer of marine electronics, is the new kid on the block. Navigation charts for inland waters, and particularly for rivers, are often not presented with a north-up orientation. On such charts there is not a scale of latitude printed on the left-hand and right-hand borders of the chart. As a result, there is no convenient way to use the markings of latitude as a distance chart. It is also quite common that details of harbors are presented in very large scale drawings often called "plans" (to distinguish them from charts) and these usually lack any scale of latitude on the borders. Such charts will include a distance scale, and generally it is calibrated in statute miles. Everyone is perfectly free to choose a unit of speed measurement for their boat that pleases them, but, as the moderator of this discussion I find statute miles per hour to be the most appropriate unit, and in the interest of keeping the discussion consistent, I convert all other data offered to statute miles per hour. As far as I am concerned, it offers the least confusion. There are too many folks who are actually measuring in MPH but go around spouting "knots" because they think it is more proper or more nautical. Proponents of knots as a standard measurement of the speed of all boats, of all shapes, of all sizes, on all waters, based solely on the notion that the nautical mile is somehow especially blessed with universal applicability should simply undertake their own conversion of MPH to knots where presented in these discussions. |
blackdog54 |
posted 11-23-2007 11:41 PM ET (US)
JimH states: "Everyone is perfectly free to choose a unit of speed measurement for their boat that pleases them, but, as the moderator of this discussion I find statute miles per hour to be the most appropriate unit, and in the interest of keeping the discussion consistent, I convert all other data offered to statute miles per hour. As far as I am concerned, it offers the least confusion. There are too many folks who are actually measuring in MPH but go around spouting "knots" because they think it is more proper or more nautical." Hmmm, just so I understand the rules, does that mean that the forum moderator prefers "front and back" over "bow and stern" or "fore and aft"? Should we refer to the boat as "left and right" vs "port and starboard" because our only reason for using them is "more proper or nautical"? While the MODERATOR finds Garmin to be the "new kid on the block", I would venture to say that Garmin holds a comparable percent of the market, with regard to Raymarine, Lowrance or other major GPS manufacturers, in the sizes of boats we all are referring to. Moreover, most "paddle wheel" transducer manufacturers products are referred to in "KNOTS" and that is not limited to the newcomer, Garmin. (Perhaps it is more orchestrated than that and Garmin is just sending these out in KNOTS to sabotage the moderator's preference to using MPH.....) Maybe, to keep it really simple and consistent, I should refer to the helm as the steering wheel, keeping Dale Earnhart, Jr and I on the same page. |
posted 11-23-2007 11:52 PM ET (US)
Who is Dale Earnhart Jr.? And why would I care what he thinks about MPH versus knots? |
blackdog54 |
posted 11-24-2007 08:59 PM ET (US)
Jim- you can actually be pretty funny once in a while. |
Plotman |
posted 11-25-2007 11:35 PM ET (US)
Jim P- Charts & Coast Pilots for the inland river systems and the great lakes are printed giving distances in STATUTE MILES, as was indicated earlier in this thread. This is because historically, the inland waters were the domain of the US Army Corps of Engineers, which used the statute mile as their institutional standard (you dont think the army is going to use a Navy mile, now do you?). |
Mobjack |
posted 11-26-2007 09:54 AM ET (US)
I can't believe you guys even have speed limits on the water up there...that is depressing. |
Plotman |
posted 11-27-2007 03:47 PM ET (US)
Not on open water, Mobjack, but in Harbors, Marinas, conjested areas, etc. |
posted 11-27-2007 08:56 PM ET (US)
This entire discussion about choosing a unit of measurement for boat speed has been focused on the distance dimension, and so far has ignored the time dimension. The concept that time is to be measured in units of hours seems entirely arbitrary and totally unnatural. I think time ought to be measured in sidereal units. This is much more natural than the notion of an "universal hour" which is just some arbitrary concept imposed on the rotational period of the earth by man, and codified in some standards, as opposed to Greenwich Sidereal Time. Greenwich sidereal time is related to Universal Time by Greenwich Sidereal Time = 1.00273790935 × Universal Time So in making a case for the most natural expression of boat speed, I think it is clear that one must use angular velocity (radians) for the distance measurement and Greenwich sidereal time for the time measurement. |
2manyboats |
posted 11-27-2007 10:21 PM ET (US)
Thanks Jim ,finally someone brings some sense to this discussion. The time part I think I can do with my Casio , but is there an aftermarket adapter that will make my dash mounted speedometer read radians . |
Rob Pirie |
posted 11-28-2007 04:06 PM ET (US)
Good point Jim but you have over looked SOLAR TIME. Until relatively recently in its history, humankind measured time by the rotation of the earth, using the visual positions of the sun, moon, and other celestial bodies as they traveled across the sky. Two kinds of such astronomical timekeeping are sidereal time and solar time. Sidereal time is measured with respect to the distant stars, while solar time is measured with respect to the sun. A solar day lasts from the time at which the sun is directly over a given point (for example, the Prime Meridian at Greenwich, England), until it is next over that same point. A sidereal day lasts from the time at which a distant star is over a given point until it is next over that point. Because the motion of the earth in its orbit around the sun is negligible with respect to a distant star, but not with respect to the sun, a sidereal day is about four minutes shorter than a solar day. Rob |
daveweight |
posted 11-30-2007 07:49 AM ET (US)
I think that if you are going to use navigational charts for moving around on the water instead of road maps from Walmart then the only real answer is knots or nautical miles per hour. Anything else is tomfoolery. Dave Weight from Greenwich England |
posted 11-30-2007 09:13 AM ET (US)
One problem with using nautical miles is that no one seems to be able to agree on how long they are. I find it hard to accept that the recommended unit of measurement does not have a fixed length. |
swist |
posted 11-30-2007 09:18 AM ET (US)
Once I saw a small overloaded boat pull up to a restaurant dock near here. Just watching their docking antics and conversation made it obvious they had no idea what they were doing. This was confirmed when I saw the afore-mentioned Walmart road map lying open in the boat, clearly having been the navigational chart of choice. I can imagine these boaters were completely lost when they could not find big green overhead signs on the water like "Joe's Marina 3/4 miles, right lane". |
Richard Quinlivan |
posted 11-30-2007 10:27 AM ET (US)
For the record the nautical mile is defined as 1852 meters exactly. Convert that to feet and you get 6076.103333333.. or in statute miles 1.150777146.. Therefore 1 knot is approximately 1.151 or 1.1508 or .. or .. depending how particular you are. The navigation convention of one nautical mile equal to one minute of latitude dates back to a time when navigation was less precise and a spherical earth model was in vogue. The shape of the earth is approximately an ellipsoid which means that the length of a minute of latatude varies from the equator to the pole. Dick |
Richard Quinlivan |
posted 11-30-2007 11:05 AM ET (US)
For the record again be careful of approximations. The nautical mile is defined as 1852 meters exactly and the inch is defined as .0254 meter exactly. Do the math and you get the nautical mile at 6076.115485564300 and the statute mile at 1.15077944802354 which should be close enough for Boston Whaler purposes. Dick |
westcoastwhaler |
posted 11-30-2007 02:43 PM ET (US)
It is confusing as most bays and lakes use MPH and do not use knots. According to Chapman's Piloting, Seamanship and Small Boat Handling: 1 Knot = 1.15 MPH. The terms comes from an old technique they used to use to calculate speed. They would throw a log chip attached to a line off the stern and count the knots in the line for a predetermined amount of time. Little tid bits of information that I picked up getting my CG Master's License. Most of it is not relevent today as modern electronics has taken all of the guess work out of navigation. But, it is good to know when the batteries die and you have to pull out the charts an dividers. |
posted 12-01-2007 11:59 AM ET (US)
I am a strong proponent of carrying on certain nautical customs. For example, I do enjoy a mildly alcoholic beverage in the late afternoon while aboard. I think the historical precedents of this involve the yard arm, the sun, and watered rum. Historically, however, I think the nautical mile comes after the league. I believe that this is apparent in many references: "20,000-Leagues Under the Seas" wrote Jules Verne, not 20,000 nautical miles. Emily Dickinson wrote: Exultation is the going Bred as we, among the mountains, And, ahem, I believe the league is based on the statute mile. So, if historical use is to be the determining factor, it looks like naught for knot. |
cooper1958nc |
posted 12-03-2007 09:48 PM ET (US)
As Jimh reflected upon aircraft practice, aircraft today use knots for both groundspeed and airspeed. Current indicators are considered to show KIAS (Knots indicated air speed) or KCAS (Knots calibrated air speed). Applying transformations for air density, one obtains KTAS, knots true air speed. Older aircraft airspeed indicators (pre 70's) were marked in mph. Distances between waypoints are always nautical miles. Older aircraft had no direct ground speed indicators; ground speed was computed from time and distance and the result was in knots. Modern airplanes read ground speed directly from GPS, always in knots. |
