ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance E-TEC Fuel Injector
Author | Topic: E-TEC Fuel Injector |
posted 12-02-2007 09:37 AM ET (US)
In looking through my photo-archive, I noticed a few details of the Evinrude E-TEC fuel injector which I thought were interesting. The design of the injector has changed slightly. The original E-TEC injector looked like this, as seen on an early production model of the E-TEC 225-HP motor: http://continuouswave.com/whaler/reference/images/ETEC/ 4fuelRails480x640.jpg The new style injector, seen here on a just-built E-TEC 250 H.O. motor, is slightly changed: http://continuouswave.com/whaler/images/ETEC300/ETEC300injectors457x480. jpg The most obvious difference is that the word "E-TEC" is now embossed onto the top of the injector. I have heard--unofficially--that the injector is going to be used on some other Bombardier products, and those divisions wanted some visual identification on the device to distinguish it as an E-TEC feature. They wanted the E-TEC name embossed on the injector cover. Another change that can be seen is the deletion of the two cast towers on one side of the injector housing. These were threaded and held machine screws which retained an ignition coil on some models. The injector has four cast inlets or outlets for fuel connectors, but only two are used. It appears that after casting the cover is machined in left-hand and right-hand versions, and two of the four connectors are machined to become the fuel line connectors, and the other two left unfinished. |
Tom W Clark |
posted 12-03-2007 11:23 AM ET (US)
Is it just my aging eyes, or does the upper of the two injectors pictured in the second photograph appear to be grossly blemished? It looks like the casting melted or came out malformed. |
L H G |
posted 12-03-2007 02:46 PM ET (US)
It looks like someone was beating on it with a hammer trying to get it to work properly! |
posted 12-03-2007 03:28 PM ET (US)
I think what is being seen are JPEG artifacts. We have seen before how low resolution digital photographs have led some observers to be completely mislead about the actual object being photographed. I am afraid my own digital camera has gone on the fritz, or I'd just take a new picture. |
fourdfish |
posted 12-03-2007 06:07 PM ET (US)
Larry-I think you have it backwards, it is you own eyes that are in need of attention so you can focus correctly. |
posted 12-03-2007 08:03 PM ET (US)
Not to distract from this excellent discussion about the fidelity of digital images which have been compressed according to certain algorithms developed by the joint photographic experts group (JPEG) but let me repeat a portion of my original article, but this time I will add a bit of emphasis on what I think is the most important point: "The most obvious difference is that the word "E-TEC" is now embossed onto the top of the injector. I have heard--unofficially--that the injector is going to be used on some other Bombardier products, and those divisions wanted some visual identification on the device to distinguish it as an E-TEC feature." This may help focus follow up comments on the portion of the original article which I think is the most important. |
onlyawhaler |
posted 12-05-2007 04:12 AM ET (US)
I hae enjoyed following the news on the E-tec since it began and I think it is unique in the outboard world. It is surving and doing well in a 4 stroke world and seems to have real advantages to the few remaining DFI motors with regards to being simplier, cleaner and quieter. I have gone back and looked at the Evinrude site and it appears that the most important aspect of this technology is the injectors. Rather than the more complicated HPDI or high pressure Optimax, it's injectors are markedly different and simplier in how they adomize the fuel/oil mixture and the swirl pattern which result in a cleaner burn. It is most interesting to me that this technology can inject and burn a gasoline/oil mixture and do it cleaner than a 4 stroke which injects gasoline alone. It is pretty astounding and I wonder if this BRP technology can be directly applied to 4 stroke/cycle motors everywhere. That would be a huge impact in the marketplace and it seems to be only injector related to get that postive effect. It would seem to eliminate the emmissions threat that may require additional meansures to stern drives like cathletic converter and everything else. Any thoughts? Sterling |
fourdfish |
posted 12-05-2007 09:20 AM ET (US)
onlyawhaler--I think you have misunderstood the ETEC injector! It only injects straight gasoline NOT oil! The oil is injected into the engine by separate oil injectors and does not get injected into the cylinders. The only oil that is burned is that which makes it's way up from below the piston on the walls of the cylinders( just like a 4 stroke). This is one of the reasons the engine burns so clean. Another reason for clean burning is the duel spark in the cylinder when engine is running below 2000rpms. |
fourdfish |
posted 12-05-2007 09:45 AM ET (US)
I'm sorry a tiny amount of oil is brought into the cylinder along with the air during the intake phase. The ETEC injector is also capable of injecting diesel fuel, kerosene and other hydrocarbon fuels so the engine will run on these fuels with changes in the computer software map. Although this ETEC injector is a great advance in technology, I think most do not realize that without the advanced engine computer today none of this would work. |
Peter |
posted 12-05-2007 11:23 AM ET (US)
I'm not 100 percent sure about this but I think a little fraction of oil may also be introduced into the fuel system to keep the injector components lubricated. |
fourdfish |
posted 12-05-2007 11:40 AM ET (US)
Peter- You might be correct on that however, I have never read that on any ETEC references. I also have not seen a spot which would allow that to happen. Perhaps a more knowledgeable person may come on here and enlighten us on that. |
onlyawhaler |
posted 12-05-2007 09:28 PM ET (US)
I thought there was some oil mixed in with the gasoline ahead of the injectors. I am not sure now. Regardless of that, some, alittle or none, isn't it interesting that the E-tec injectors can inject the gasoline and burn it so cleanly without the high pressures needed by other DFIs? That, I think is the critical point. Three Star rated from the beginning on all models at a time when other DFIs are doing it in a more complex way or dropping models. Three Star rated from the beginning of this technology and doing it cleaner than 4 stroke which have no issue of any oil in the gasoline. I wonder if this less complicated injector technology could be licensed to work on 4 strokes anywhere, including conventional stern drive engines (GM engines) and have them burn clean enough to avoid the complication of cathletic converters which are on the horizon. Onlyawhaler |
posted 12-05-2007 09:46 PM ET (US)
On E-TEC motors some of the lubricating oil is pre-mixed with the gasoline in the fuel lines upstream of the injector. The percentage is rather low. Most of the lubricating oil is directed into the engine crankcase area where is lubricates the various components. Ultimately, the lubricating oil does eventually get carried into the combustion chamber, and it is burned off. |
fourdfish |
posted 12-05-2007 10:19 PM ET (US)
Actually, I think the sky is the limit on these injectors. They are based on simple technology and they work well. I think that some day BRP will license the technology to others. Only time will tell. |
L H G |
posted 12-05-2007 10:31 PM ET (US)
It is widely known from various testing that the E-tec system gets lower fuel economy than either the 3-star Yamaha High Pressure DI system, or the 3-star Optimax LOW pressure system. Does anyone know why this is so, other than XSTECH, who I assume would tell us that the secret of the Optimax economy is the additional air injection? If the fuel only E-tec injector is so clean, it sould seem logical that it would get the best fuel economy, but instead it gets the worst. Better fuel economy means even cleaner, since less gasoline is burned to emit pollutants. Or, is the problem not in the injector system but in the engine block designs. I.E., would a 3.0 liter 60 degree Merc get better fuel economy with an E-tec system installed |
fourdfish |
posted 12-05-2007 11:49 PM ET (US)
Mr Larry--"WIDELY KNOWN" These terms you use are only your opinions!!! NOT FACTS!! Please site the research and testing done by reputable nonbiased institutions to back up your statement. BTW the flawed tests done by B&B magazines would not be accepted by a majority of enginners, scientists or even the general public. Your statement that the ETEC gets the worst fuel economy is not supported by real FACTS! You should use the terms in "YOUR OPINION" in future posts unless you can quote research done and accepted by everyone. (These are called FACTS) |
Peter |
posted 12-06-2007 09:02 AM ET (US)
Apparently everybody but the resident Mercury salesman knows that Yamaha HPDI system is NOT 3-Star compliant. In order to sell product, it seems that a salesman would want to be perceived as having unimpeachable credibility and unimpeachable credibility comes, in part, from getting the facts in the sales pitch right. |
JayR |
posted 12-06-2007 09:16 AM ET (US)
fourdfish, Lies, Hearsay and Guise could not possibly use the term "in my opinion" as it is not part of his modus operandi. I just wouldn't fit his agenda..... |
If readers would like to discuss the comparative fuel economy of all outboard motors, please begin a separate discussion on that topic. |
XStech |
posted 12-06-2007 09:18 AM ET (US)
LHG The amount of fuel burned has nothing to do with the measured emissions output. Emissions is measured at five mode points. Idle to WOT. They measure HC and NOx in grams per kilowhatt/ hour. In general, the leaner a motor runs, the lower the HC output is, but the higher the NOx output is. And the NOx goes up much quicker than the HC goes down. Thus, a higher GPH motor with tend to measure lower in emissions output,(3 Star) where a low GPH motor will then to have a higher measured emissions (2 Star) However (and here comes the Merc plug) it really comes down to how well (complete/clean) you burn the fuel that you use. This can be affected by porting, head chamber shape, etc,etc. But there are two very important factors in a DI engine that have a great effect on emissions. These are droplet size of the fuel, and control of the fuel plume in stratified and homogenious mode. This is where the air assist Orbital system has the advantage. The droplet size is generaly half the size of other injection systems. This makes the plume easier to light in ultra lean conditions (less lean missfire) and you get a more complete burn. The computer used by Merc is very powerfull. And when coupled with the two stage injector system give very fine control of the fuel plume, both at idle and at high RPM. Hope this helps. |
Peter |
posted 12-06-2007 09:30 AM ET (US)
The only commercial problem that I think the Orbital system has, and this relates directly to the fuel injection system, is scalability. The Optimax system doesn't seem like it would scale downward very well. The air compressor driven system seemingly becomes too complex for low HP applications. |
posted 12-06-2007 09:36 AM ET (US)
The new E-TEC injection has just begin to appear on motors, so I doubt that any previously published test data would include results obtained with the new injector. However, I don't see any claim by Bombardier that the change in the injector has caused any change in performance. Data on fuel economy when derived from boat tests includes the influence of the hull and propeller. To compare only the engines would require some sort of dynamometer testing. Perhaps that data is available in the EPA laboratory test information. Fuel economy comparisons also have shown an advantage for the E-TEC engine at certain speed ranges, notably at idle or slow speed operation. In the overall cost of boating, a variation in fuel economy of a few percent at selected engine operating speeds may not be a factor whose weight is sufficient to over ride all others. Again, the unofficial information I have indicates that the E-TEC injector is headed for wider application to motors other than those designed for use in marine applications as outboards. |
Peter |
posted 12-06-2007 10:01 AM ET (US)
As I've said before, I would not find it surprising to find an adaptation of the E-TEC injection system on 50 cc 2-stroke scooter motors in emerging market countries. I would find it surprising to find an Orbital system with its belt driven air compressor on a 2-stroke scooter motor. |
XStech |
posted 12-06-2007 10:52 AM ET (US)
Even BRP is using Orbital tech. Makes you think. http://www.orbeng.com.au/orbital/directinjection/csbpr.htm Bombardier, the world's leading personal watercraft (PWC) manufacturer, launched its Sea-Doo™ GTX™ DI and Sea-Doo™ RX DI models in 2000. These were the first personal watercrafts to employ Orbital OCP™ technology, leading the way to cleaner waterways and better fuel efficiency. This was followed by further Orbital DI models including a range of sports boats some of which employed OptiMax™ engines from Mercury Marine. Sea-Doo™ engines, when equipped with OCP technology, operate up to 70% cleaner and provide at least 30% improvement in fuel efficiency over traditional carburetted 2-strokes. Sea-Doo™ watercrafts include a number of value-added features made possible by Orbital's smart usage of electronics and software. One example is the exclusive "Learning Key", a specially encoded lanyard key which restricts vehicle speed for beginners and other less experienced riders. Another innovation on the Sea-Doo™ is the detonation sensor, where Orbital software protects the engine from damage if, for example, incorrect fuel is used. The Sea-Doo™ DI range has won several industry awards including Watercraft World's "Watercraft of the Year" for 2000.
XStech |
posted 12-06-2007 10:56 AM ET (US)
OMG Its even on a 2 stroke scooter. http://www.orbeng.com.au/orbital/directinjection/motorcycle2s.htm
Further product is scheduled for release in India on 3 wheeler autorickshaws. Direct injection on the 2 stroke scooter offers the following benefits to the end user:
In the European market, the Orbital systems enable the manufacturers to maintain the performance level of the traditional 2 stroke engine whilst meeting the ever increasing emission control requirements. In India and other key Asian countries, the key requirement is improved fuel economy. The Orbital systems achieve between 30 to 40% fuel economy improvement on the autorickshaw, and localisation of supply has been implemented to achieve the cost targets required in this region. More recent developments have been to address the requirements of the niche very high performance market such as Enduro and Trail motorcycles. The Orbital systems have achieved emission control with performance levels up to 140 kW/litre and 160 nm/litre. In addition, the system can enable 'multi-fuel' capability for spark ignition of diesel, kerosene and/or gasoline for motorcycle applications. |
fourdfish |
posted 12-06-2007 11:04 AM ET (US)
XStech--What does that have to do with the ETEC fuel injectors! Are you aware that you and LHG completely derailed this thread! |
XStech |
posted 12-06-2007 11:12 AM ET (US)
Sorry, your right. Shame on me. |
Peter |
posted 12-06-2007 11:20 AM ET (US)
The article says: "The technology developed and introduced for the marine market has been simplified for 2 stroke scooter and motorcycle application". So after having been simplified, is it still the same technology that you see on an Optimax? In other words, does it have the noisy belt driven air compressor injection system? |
fourdfish |
posted 12-06-2007 11:35 AM ET (US)
Peter--He is just advertising for his company again on an ETEC thread. He is trying to goat you and it looks like he has hyjacked a thread again. But that is what he gets paid to do! |
sosmerc |
posted 12-06-2007 11:42 AM ET (US)
Perhaps one of these days we will see an Orbital design that uses a crank driven piston in the block to serve as the air compressor. (a small 4 cylinder motor...3 cylinders for power and one to produce the required air pressure) This would "clean" things up as far as the air compressor goes. You could go back to an under-flywheel stator to completely eliminate the need for a belt. By the way, compared to all other DFI systems out there, Orbital is a very LOW pressure system. My guess is that we are going to see DFI of all stripes and colors on a great variety of products in the future...both 2 stroke and 4 stroke. DFI can easily be used with a great variety of fuels and that is why this technology is finally starting to take hold. |
L H G |
posted 12-06-2007 06:27 PM ET (US)
I am shocked to learn that Bombardier/Sea Doo is using Orbital technology on it's OWN engines, rather than E-tec. Does this mean that when Mercury's Optimax patents expire, |
fourdfish |
posted 12-06-2007 06:31 PM ET (US)
The troll has appeared again!!!!!!! |
Peter |
posted 12-06-2007 06:43 PM ET (US)
The SeaDoo use of Orbital technology is a throwback to the days before Bombardier (now BRP) bought the OMC outboard motor assets. OMC initially investigated going with the Orbital technology for outboard motors but the engineers rejected it in favor of the Ficht technology. The Orbital with its belt driven air compressor and extra air lines was too complicated in their view. Had Bombardier owned Evinrude at the time they were introducing DI technology to the 2-stroke PWC's, it probably would have been Ficht based. |
fourdfish |
posted 12-06-2007 07:03 PM ET (US)
Larry--Before you and your friend get your foot way deep in your mouth again. The Orbital engine technology used by BRP is ROTAX-- (which they have used since 1964) developed in Austria/Europe a real long time ago. It is in no way, shape or form the belt driven Optimax/Orbital belt driven technology from Australia. Why would anyone replace a simple, efficient fuel injector with a heavy,noisy complex belt driven system?? I know you have predicted the downfall of ETEC technology for the last 4 years, however it has not come to pass and you can't seem to live with that reality. |
Peter |
posted 12-06-2007 07:16 PM ET (US)
ROTAX is 4-stroke technology, not 2-stroke DI. BRP offers both ROTAX 4-strokes and the Orbital based DI 2-strokes in their PWC products. |
fourdfish |
posted 12-06-2007 07:32 PM ET (US)
Peter-If you look at the web sites, BRP optional 2 stroke engines are also (2-ROTAX) engines made in Austria. I do not believe that they have any Australia/Orbital licensed technology. They do in fact have electronically controlled exhaust valves unlike regular 2 stroke engines. If you find anything saying that let us know. |
posted 12-06-2007 08:54 PM ET (US)
A fundamental difference between E-TEC and OptiMax technology is that Bombardier owns the E-TEC intellectual property, while Mercury just rents their OptiMax technology from Orbital--the real name is the Orbital Combustion Process. One actual way to tell who has a patent on something is by the existence of licensed use of the technology. It is clear to me that Orbital owns the technology used in the OptiMax, which is why Mercury pays them a license fee. If Mercury owned this technology, they wouldn't be paying Orbital to use it. |
fourdfish |
posted 12-06-2007 09:01 PM ET (US)
I have not seen anything to show that BRP is paying Orbital to license that technology. |
XStech |
posted 12-06-2007 09:18 PM ET (US)
http://www.snowtechmagazine.com/articles/2002/parrallell.php ""Meanwhile Bombardier, responding to lesser but still real economic constraints, have had to decide what will power new snowmobiles and watercraft. This company is in a commanding position with respect to DI, not only having an Orbital license but having recently bought the US company Outboard Marine (OMC), who in turn own(ed) the Ficht DI technology."" |
posted 12-06-2007 09:33 PM ET (US)
That quote is five years old. |
XStech |
posted 12-06-2007 10:01 PM ET (US)
2006 MY ENGINE
posted 12-06-2007 10:26 PM ET (US)
This is just total conjecture on my part, but if ROTAX is using some Orbital Combustion Process in their engine, I bet the plan at Bombardier is to change those motors over to E-TEC technology. This fits perfectly with the unofficial news I mentioned at the start of this discussion. |
fourdfish |
As one looks at Mr XStech posts here one can see a real pattern. As a paid Mercury Rep who admits he does not even own a boat, he comes in on ETEC threads to purposely hyjack and derail them with posts intended to make BRP and the ETEC engines look bad. Does he add any help to those with Mercury engines? (NO)! Does he add any help with members boats? (NO) He blatently hyjacked this thread about ETEC fuel injectors as he has done before. His posts are advertising! Pure and simple! |
Peter |
posted 12-06-2007 10:29 PM ET (US)
Bombardier made an investment in Orbital technology long before it acquired the OMC assets. See corp.brp.com/en-CA/Media.Center/Press.Releases/1/1999.09.22.htm . By the time they acquired the OMC assets, they were already entrenched in the Orbital technology. It's quite possible that the license deal that Bombardier worked out with Orbital has them economically locked into the technology for some period of time through minimum annual royalty payments, for example. Fourd - You are correct about the Rotax conventional 2-stroke with the RAVE valve. |
fourdfish |
posted 12-06-2007 10:49 PM ET (US)
Something which stands out in this is the fact that BRP engineers designed the ETEC fuel injectors all by themselves. Unlike Mercury, they do not need to pay anyone for the technology. |
posted 12-06-2007 11:39 PM ET (US)
This is likely not complete or particularly authoritative, but my recollection regarding the E-TEC fuel injector is that its principal difference from other designs is its voice-coil control of the injector position. Most other injectors are just solenoids. When current is applied to them, they generate a mechanical movement in one direction, and a spring supplies return force to restore the injector to the original position. In an E-TEC injector the direction of current flow is reversed in the voice-coil to cause the injector to move in the opposite direction. This feature allows the injector opening and closing to be more precisely controlled. Further, by using some nifty electronics, the injector deceleration at the end of travel can be controlled. This takes out the clicking noise usually associated with electric fuel injectors. Bombardier developed and patented the E-TEC injector. They also developed and patented the electronic control circuitry they use. This circuitry is quite ingenious. It utilizes some of the energy stored in the magnetic field of the injector coil to power the movement of the injector in the returning direction when the field changes polarity. All of this was developed by Evinrude engineers and patented. Historically OMC looked at the Orbital Combustion Process for use in an outboard, but they did not follow through with it. Instead they switched to a different technology, the Ficht injector. OMC developed outboards with Ficht technology, which was owned by a German firm (named Ficht, obviously). Eventually, OMC bought the injector technology from Ficht, so they no longer had to license it. The E-TEC was developed in-house at Evinrude. It is a different type of injector than the Ficht, at least as far as the coil design. As for the precise details of the portion of the injector that actually move or pushes the fuel out of the injector nozzle, I can't speak to that. It might be related to the Ficht design--someone more familiar than me will have to elaborate. There has been a long standing effort by people who want to defame Evinrude as a brand to try to call the E-TEC injector just a "marketing" name change from Ficht. Apparently they believe that there is a lot of negativity about the name Ficht which they want to associate with the name E-TEC. We need to look at these attempts in two ways. First, is there something about Ficht which was so awful that it can pack a punch? And second, is there really no difference between E-TEC and Ficht other than the name? There is some history of engine failures associated with OMC era Evinrude motors with the Ficht injectors. These failures are often cited as leading directly to the demise of OMC. In the mind of some boaters, the name Ficht probably does have negative connotation. At least that's true among the mudslingers who want to paint E-TEC with the Ficht name. The irony in this is that many owners of Ficht engines built in the Bombardier era of production are very happy with their motors and have gotten years of fine service from them with no problems. Next, it seems to me be intentionally misleading to try to assert that E-TEC is just a Ficht engine with a name change. The E-TEC engine adds many new features which were never seen in a Ficht, and it uses a different fuel injector as well. In my opinion, an E-TEC is called an E-TEC because it is a significantly different engine than a Ficht, and there is no reasonable basis to try to claim the name is just "marketing" and nothing else. Anyone who tries to defame the E-TEC as "just marketing" is trying to spread FUD. Now to get back to the beginning, I think Bombardier is rightly proud of the E-TEC injector, and in its new design they're putting the E-TEC name right on the device. You won't really see it very much on an E-TEC outboard, because it will be under the cowling. And you won't need to take the cowling off the motor very often. However, if the E-TEC injector starts showing up on other products, it might be more visible, and hence the embossed name on the device. |
XStech |
posted 12-07-2007 08:07 AM ET (US)
At the risk of getting yelled at again for posting answers to questions and information relivent to discussions brought up by other posters, I'd like to share this link. The intro on the link is good, but if you really want to understand the E-tec injector, the SAE paper is well worth the money. Sorry to intrude again. http://www.sae.org/technical/papers/2003-32-0007 |
Peter |
posted 12-07-2007 09:50 AM ET (US)
If you really want to understand the technology, you need to also look at the following patents which appear to touch upon the E-TEC injector and system. 7,287,966 Fuel injector driver circuit with energy storage apparatus 7,164,984 Method and system for fuel injector time delay installation 7,136,743 Method and apparatus for identifying parameters of an engine component for assembly and programming |
XStech |
posted 12-07-2007 10:19 AM ET (US)
Good stuff. But patents are written by attorneys. SAE papers are written by engineers. Seems a lot easier to read the SAE. lol |
XStech |
posted 12-07-2007 10:25 AM ET (US)
# 7,113,862 is really interesting. They re-cal the ECU to match replaced injector time delays. Very hi-tec. |
Peter |
posted 12-07-2007 10:56 AM ET (US)
The attorneys that write the patents are also engineers. |
XStech |
posted 12-07-2007 11:01 AM ET (US)
Yea, I know, but they write like an attorney. lol |
fourdfish |
posted 12-07-2007 11:08 AM ET (US)
XStech--I didn't see anyone here ask you any questions in their posts. You just tried to change the topic of the thread to suit your agenda. It actually says on the engine computer to recalculate the ETEC injectors when replaceing them. I have the engine diagnostic software and it includes a specific program to replace the fuel injectors. the injectors are not to be moved from one cylinder to another. |
posted 12-07-2007 12:47 PM ET (US)
Each E-TEC injector comes with four coefficient values which are assigned to it individually. The coefficients are presumed to describe some aspect of the injector performance. I also presume that these are observed and measured on some sort of standard test fixture at the time of manufacture and testing. When a particular injector is installed in an engine, these values are entered into the engine management module (EMM) as parameters for that injector. In this way, the individual injectors are precisely integrated into the control system, and any variations among them are compensated for by the control system. I also believe that the engine management module tracks the age of each injector, and additional compensations are applied to the injector as it ages. The compensations are probably based on some algorithm of predicted wear based on testing. In this way, the engine performance can be maintained over a longer period of time, even though there is some inevitable mechanical wear in the injector. |
XStech |
posted 12-07-2007 12:52 PM ET (US)
""""I also believe that the engine management module tracks the age of each injector, and additional compensations are applied to the injector as it ages. The compensations are probably based on some algorithm of predicted wear based on testing. In this way, the engine performance can be maintained over a longer period of time, even though there is some inevitable mechanical wear in the injector.""" Now thats just plain impressive. |
posted 12-07-2007 12:54 PM ET (US)
Thanks for the citation of patents with actual numbers. Often in the past in these discussions certain features of outboard motors have been cited as being a "patented" device or invention, but no patent is ever offered to substantiate the claim. It is greatly appreciated that participants provide actual patent data which substantiates the true nature of a particular useful invention when they wish to refer to it as "patented." |
fourdfish |
posted 12-07-2007 01:30 PM ET (US)
I think many people would be impressed with the graphical interface in the diagnostic software. Not just a bunch of numbers! It shows each injector/cylinder and all of the different parameters being measured when the engine is running. The amount of information displayed for all functions is really significant. The software can also be used to change the engines software map and performance. I make sure I am careful not to mess with anything. |
posted 12-07-2007 01:37 PM ET (US)
Here is the abstract from the cited patent mentioning the various fuel injector coefficients: United States Patent 7113862 "State-of-the-art fuel injectors have an inherent time delay that is determined by an elapsed time from the time an electrical signal is received by the fuel injector from an ECU to the time that fuel is actually initially injected into the cylinder. That time is currently an average time and therefore the fuel injectors must be manufactured with very precise tolerances. The present invention includes a method and apparatus that allows the use of production fuel injectors that are more economical to manufacture by allowing wider tolerances. The invention includes determining the actual time delay for each fuel injector. The fuel injectors are supplied with a computer program and a data file containing the time delay determined especially for that particular fuel injector." |
posted 12-07-2007 01:42 PM ET (US)
The full text of the patent is also interesting reading, and not particularly obscured with legal jargon: http://www.patentstorm.us/patents/7113862-description.html |
posted 12-07-2007 01:54 PM ET (US)
This earlier patent also provides a great deal of interesting information about the complexities of manufacturing a modern fuel injector. I found this section most interesting: "The advanced fuel injector are very complicated and difficult to manufacture and therefore it is very difficult to have consistent operating characteristics between injectors even though they are intended to be substantially identical. Further, although varying pulse width of a control signal is used to vary the amount of fuel an injector provides to a cylinder (hereinafter referred to as fuel flow or flow rate), a performance curve of these complicated fuel injectors (fuel flow vs. pulse width) cannot be accurately defined by a second-order polynomial as can some older types of fuel injectors. Instead, the advanced fuel injectors must be defined by a third-order polynomial. Consequently, determining the pulse width for a desired RPM by extrapolating between sample data points does not provide satisfactory performance. By calculating the pulse width for each fuel injector individually for each desired RPM setting, substantially increased effectiveness of these advanced complicated fuel injectors can be achieved." |
posted 12-07-2007 02:00 PM ET (US)
Here we see where the four coefficient plug into the injector personality classification: "Accordingly, each fuel injector is tested on a test flow bench by applying a signal pulse having a selected minimum width and then measuring the fuel flow rate. The pulse width is then increased a known amount and the resulting fuel flow rate again is measured. The process is repeated a number of times, such as 8 to 10 times, to obtain a series of data points which relate pulse width to a fuel flow rate. "These data points are then used to determine a third-order polynomial such as ax3 + bx2 + cx + d =0, which can also be used to define a performance curve representative of the fuel flow output of the fuel injector for any pulse width. The pulse width can then be correlated to the desired RPM. The degree of fit (R2) of said data points to the performance curve defined by the third-order polynomial is also determined within selected limits such that those fuel injectors which fall outside of the selected degree of fit are discarded. The coefficients of at least a portion of those fuel injectors which fall within the selected degree of fit are used to determine a nominal performance curve. Selected upper and lower limits are then set with respect to the nominal curve at each of the pulse-width values used to test the multiplicity of fuel injectors and then the fuel injectors are compared with the nominal curve to determine if the performance curve of each individual fuel injector stays within or exceeds the upper and lower limits of the nominal curve. Those that stay within the upper and lower limits are then used for assembly and replacement parts." |
Buckda |
posted 12-07-2007 05:40 PM ET (US)
Fourdfish - XS Tech has helped quite a few here with questions about their Mercury motors. While I read his posts with the filter on, given his predisposition to Mercury motors, I do value his numerous contributions; especially from a technical perspective. Other than some folks here calling each other names, etc. This has been an extremely interesting thread to read. |
fourdfish |
posted 12-07-2007 05:46 PM ET (US)
Dave--Although I do cover a lot of this site, I have failed to see these contributions. I have however seen most of his posts on ETEC threads. I have seen sosmerc help a lot of people here and respect his credability and help. For instance a couple of Merc threads are going on here now and XStech has not offered help! |
posted 12-07-2007 08:46 PM ET (US)
Please take the sidebar discussion on who gets to participate in what topic to the META-Discussion. Anyone who contributes information is welcome. |
posted 12-07-2007 09:26 PM ET (US)
Even ignoring the many, many improvements and features of the E-TEC engine which differentiates it from the older Ficht or RAM Injection engines, and just focusing on the fuel injector, these are some of the differences between the older Ficht injector and the 2003-era E-TEC injector: Compared to the Ficht Injector, the 2003-era E-TEC injector: --is smaller These are just the differences between the injectors in the older Ficht engines and the c.2003 E-TEC engines. Again, there are many other improvements and features in the rest of the engine system which further differentiate the E-TEC from the older Ficht motors. Please keep this mind the next time you read someone saying that the E-TEC is just a marketing ploy to re-name Ficht. Now there are some differences in the 2008 E-TEC injector from the c.2003 E-TEC injector. I am trying to get more information about the details. It appears that at a minimum the 2008 E-TEC injector: --has a different shape and angle of the nose which enters into the cylinder; this prevents it from being used on older motors. The cylinder head has to be machined for this new design in the injector. --has a check valve with a ball valve in the plunger which is supposed to improve the precision and consistency of the fuel delivery, particularly at higher speeds. Higher speed operation, by the way, may be related to applications other than outboard motors, which may need even higher crankshaft speeds from the engine. An engine speed of 10,000-RPM is not unusual in some applications in which Bombardier manufacturers engines and products. --has eliminated the castings for attachment of the spark coil. This is probably related to the coincident announcement of an entirely new inductive ignition system for the E-TEC in 2008, replacing the capacitor discharge ignition. Again, more details are being sought about this innovation in the E-TEC ignition system, and when this information is available it will be presented in a separate article. --appears (to me) to be slightly smaller and slightly different in shape. --has the E-TEC name embossed on the housing. |
fourdfish |
posted 12-07-2007 09:38 PM ET (US)
Only heresay, However my mechanic was told by a company rep that the ETEC injectors have a very low failure rate. He also told me he has not seen one fail yet. That says something about the design of these injectors. Jim, have you heard anything along those lines? |
XStech |
posted 12-07-2007 11:04 PM ET (US)
One of the other big differences in the E-tec injector is the "swirl nozzle" . According to the SAE paper, this was one of the big changes that reduced the droplet size and helped decrease cylinder wall wetting. I think I read that the 08 injector has a new and improved "swirl nozzle" on it. |
Peter |
posted 12-08-2007 08:06 AM ET (US)
Regarding the swirl nozzle, see U.S. Patent 6,748,872 for a "Swirl-producing fuel injection nozzle and system and method incorporating same". With respect to wall wetting management, don't forget to mention the W shaped piston bowl, see U.S. Patent 6,892,693 for a "Piston for spark-ignited direct fuel injection engine". Then there is also U.S. Patent 7,267,533 for a "Plunger assembly for use in reciprocating fluid pump employing reversing polarity motor". This is a bit off subject but as I came across the above patents I also came across this.... U.S. Patent 6,964,254 for "Apparatus and method of conditioning an engine for storage". I guess we won't be seeing the E-TEC's auto-storage (winterization) method being used on an Optimax anytime soon, about 2024 by my calculation. |
XStech |
posted 12-08-2007 09:57 AM ET (US)
yep, the piston bowl was another big improvement. [Unattributed quotation follows, which appears to be taken from page 10 of the SAE paper mentioned above, "Optimization of the E-TEC™ Combustion System for Direct-Injected Two-Stroke Engines Toward 3-Star Emissions," by Sebastian Strauss, Yangbing Zeng and David T. Montgomery, Boats and Outboard Engines Division Bombardier Recreational Products--jimh]
posted 12-08-2007 11:01 AM ET (US)
The changes to the geometry of the combustion chamber, including the top surface of the piston and the mixing bowl shape change are, of course, outside of the E-TEC injector itself, but they are important refinements which occurred as a result of research and development in producing the E-TEC engine. One clear difference in the E-TEC and Ficht engines is the much lower emission output achieved in the E-TEC. The E-TEC engine has roughly just half the emission output of the Ficht. The more I read about the technology of the E-TEC the more I become aware of just how different it is from the Ficht era motors. When E-TEC first appeared there was some confusion about its legitimacy as a new technology. Initially there was not as much information available about the E-TEC technology as we have access to now. It is clear that the E-TEC was created as a result of some excellent research and development by Evinrude engineers who were able to make significant refinements in direct-injection technology, particularly with regard to exhaust gas emissions. For a historical perspective, the Ficht engines were first produced in 1997. We are now ten years from that epoch. We are on the doorstep of 2008, which is the final phase of the engine emission control regulations introduced by the EPA as authorized in the Clean Air Act of 1990. Outboard exhaust emissions have been reduced to one-tenth of their prior level. |
fourdfish |
posted 12-08-2007 11:06 AM ET (US)
I'm sure an improvement in the swirl nozzle and therefore an improvement in combustion would improve performance. However, will the improvement be significant enough to notice a difference? I have 3 yr old 3.3L ETEC and I have a hard time thinking that I would notice it running better. Mine is the first generation engine and even at very low RPM it does not skip a beat. It will be interesting to see what this means in terms of engine performance. Higher top end? Better fuel economy or lower emissions are some of the only things I can think of a this time! |
prj |
posted 12-09-2007 09:01 PM ET (US)
Would this redesigned fuel injector, an improvement over the previous design, make all E-TECs NOT equipped with it obsolete? How can we differentiate the now obsolete E-TECs from these new improved, GEN II, if you will, models? |
Buckda |
posted 12-09-2007 09:04 PM ET (US)
PRJ - Easy. Model year. :) |
posted 12-09-2007 09:32 PM ET (US)
Isn't that model year concept fantastic? It is so simple. And, yes, when a new model comes out, the old model is obsolete. Products evolve, and in most cases the manufacturers provide clear and easily distinguished designators which allow the consumer to unambiguously identify the product. |
posted 12-09-2007 10:01 PM ET (US)
Re the "improvement" in the new E-TEC injector, the only claim made in all of the above discussion is that there may be some more precise fuel delivery at high speeds up to 10,000-RPM. Since in the outboard application the motors are limited to 6,000-RPM, it is not clear if this has great effect on existing customers. |
Peter |
posted 12-09-2007 10:16 PM ET (US)
The original E-TEC injector (we'll call those without "E-TEC" cast into the housing "GEN I") has been described as being able to cycle fast enough to support engine speeds of up to 10,000 RPM. The old Ficht injectors could only cycle fast enough to support 7,500 RPM. There is nothing indicated that these GEN II injectors (with "E-TEC" cast into the housing) are internally different than GEN I injectors. |
fourdfish |
posted 12-09-2007 10:37 PM ET (US)
prj--Nobody has said anywhere that our ETEC engines are obsolete. I am sure I have not seen BRP say anything about a GEN II ETEC. As for the model year, BRP and most other companies are now using serial numbers not model years to determine all updates and everything else about their engines. As for example, computer updates which are free are determined by serial numbers. As for parts, My bet is that most or all new parts will be backwards compatible. |
posted 12-10-2007 09:42 AM ET (US)
Just to be clear on these two points: --the 2008 E-TEC injector cannot be retrofitted on older engines; this is due to the design of the injector head that enters the cylinder head. --the 2008 E-TEC injector has different internals than the previous E-TEC injector; there is a ball check valve in the fuel path which is said to improve the consistency and precision of the fuel injection at very high speeds. When a product is obsolete it does not mean that it suddenly stops working or suddenly loses the qualities and characteristics it possessed when new. Obsolete means "not current;" obsolete does not mean "discard due to failure." The current model of the E-TEC is the 2008 model. Like it or not, time marches on. Things change. Manufacturers continue to improve their products through research and development. |
Tom W Clark |
posted 12-10-2007 10:21 AM ET (US)
How does one know if they have a 2008 E-Tec or a 2007 E-Tec? Are there 2007 model E-Tecs with the new injector? |
Peter |
posted 12-10-2007 10:55 AM ET (US)
"How does one know if they have a 2008 E-Tec or a 2007 E-Tec?" LOL, you know the answer to that question. OMC used and now BRP uses the model year code system "INTRODUCES". This is a two letter code at the end of the model designation. I-N-T-R-O-D-U-C-E-S For example, the model designation of my 1985 Johnson 140 was J140TXCO. The "CO" at the end of the model code or designation stands for 85 as in model year 1985. The model designation of my 2003 Johnson 150 ends with "ST" The model designation of my 2002 Evinrudes end with "SN". A 2007 model code would end with "SU" and a 2008 model code would end with an "SC". Anybody can look at the model designation on the transom bracket and determine what model year motor they have. It takes all of 2 seconds once you know the coding scheme. |
Tom W Clark |
posted 12-10-2007 11:28 AM ET (US)
OK Peter, I get that. But where in the model number does it tell you if the motor has the new injector or not? |
Peter |
posted 12-10-2007 12:09 PM ET (US)
Obviously, the model designation doesn't tell you that. However, if you pop the cowl off of an E-TEC and see that the injectors say "E-TEC" as shown in the picture, apparently that E-TEC has the new injectors and any other modifications that go along with the use of those newly minted injectors. The prior representations made herein that the new injector is only found on 2008 model year motors is confirmed by looking at the on-line parts catalog. The injector for the 2008 E-TEC 225 has a different part number than the injector for the 2005 though 2007 model years. The drawing for 2008 is also different. Particularly noticible in the drawing for 2008 is that the housing says "E-TEC", which is not shown in the drawings for 2005 to 2007 model years. So with respect to the other question --"Are there 2007 model E-Tecs with the new injector?" -- the answer seems to be a fairly clear NO. There appears to be a nice bright, consistent line drawn down the 2007 to 2008 model year divide. |
Tom W Clark |
posted 12-10-2007 12:14 PM ET (US)
Peter, Thank you for clarifying that. When will the last 2007 model E-Tec be manufactured? When will the first 2008 model E-Tec be manufactured? |
Peter |
posted 12-10-2007 12:45 PM ET (US)
Given that model year switches typically occur in July, I'm guessing that anything that comes out of the factory today is 2008 model year. But there shouldn't be any doubts, all 2007s are clearly marked as such. There is no guessing, no need to look at the fine serial number line to determine what you've got. |
posted 12-10-2007 01:29 PM ET (US)
As I mentioned in a prior article, I saw 2008 model year E-TEC motors being delivered in late May of 2007. They had the newer style injector, although at that time they did not have the name embossed on the cover. The name embossed on the cover was a recent change which I think is probably only cosmetic, and, as I have repeatedly tried to interest others in commenting on, may be related to application of the injector in other BRP motors where it will be more visible. I am beginning to think I am the only person who thinks this might be in the future, based on the lack of any comments. |
Tom W Clark |
posted 12-10-2007 02:26 PM ET (US)
Jim, I think your reasoning about the applicability of the E-Tec injector is sound. It may well find itself in use on other pieces of equipment, say, snow machines. But because we talk about Boston Whalers here and, by extension, the power plants that propel them, I don't see (or have) a lot of interest in snow machines. That may explain the lack of comments about the E-Tec injector in use on pieces of BRP equipment that have nothing to do with Boston Whalers. Now, you say you saw a 2008 model E-Tec in May of this year? Peter said the model year change over was in July. Furthermore, he said he is only "guessing" that the E-Tecs being made now are 2008 models. Might they be 2009 models? I am confused. You also say the new E-Tec injector was originally manufactured without the "E-TEC" embossed on the cover of it? But Peter has said we can tell if the old injectors are on a motor by the lack of said embossed name. Now I am more confused. Can somebody tell me how one knows if they have an E-Tec motor with the new or old injector? Can somebody tell me what month and year this change occurred? |
Peter |
posted 12-10-2007 02:42 PM ET (US)
"But Peter has said we can tell if the old injectors are on a motor by the lack of said embossed name." -- Tom NO! That is NOT what I said. What I said was: "[I]f you pop the cowl off of an E-TEC and see that the injectors say "E-TEC" as shown in the picture, apparently that E-TEC has the new injectors and any other modifications that go along with the use of those newly minted injectors." Restated: If you see the "E-TEC" on the injector, you've got the GEN II injector. |
Tom W Clark |
posted 12-10-2007 03:09 PM ET (US)
But what if the motor has early "new" E-Tec injectors which do not have the embossed name? How do you tell? Does it say "GEN II" on it? |
fourdfish |
posted 12-10-2007 03:32 PM ET (US)
I am surprised and disappointed that the new injectors are not backwards compatible! However, no one would swap out the old injectors for the new ones as I'm sure it would neither be cost or performance effective. When ever I have talk to the BRP rep on the phone he has always asked for my serial number, NOT so much the model number. He knows who I am through that number, as I'm sure it tells everything about that engine. It was recorded when my dealer registered my warranty. I would suspect that it also tells model year etc. From the picture Jim posted here, I can see a distinct difference in the shape of the new injectors and the fact that the name is on the top. I do not think anyone will have a hard time telling the difference between the 2 types. |
prj |
posted 12-10-2007 04:58 PM ET (US)
There you go, you need to provide the serial number to the dealer in order to tell if you have an obsolete GEN I E-TEC or one of the newly improved GEN II E-TECs. |
fourdfish |
posted 12-10-2007 06:00 PM ET (US)
prj-Obsolete huh!!! Give me a break! I'll run my obsolete ETEC against anything you have anytime!!!!! It does not say GEN II ETEC anywhere! |
JayR |
posted 12-10-2007 06:22 PM ET (US)
Y'all are making a mountain out of a mole hill. Who cares? Really? Any of you think the changes are such you could tell a difference if you had a chance to operate separate boats with each injector? |
fourdfish |
posted 12-10-2007 06:31 PM ET (US)
Your right JayR! I guess it's just his poor choice of words! |
Tom W Clark |
posted 12-10-2007 06:33 PM ET (US)
fourdfish, Of course your injectors do not say GEN II on them, you have the old obsolete GEN I injectors. |
posted 12-10-2007 06:42 PM ET (US)
I think some Mercury owners are trying to pull some E-TEC owners' legs. |
JayR |
posted 12-10-2007 06:58 PM ET (US)
Bottom line is that one who wishes to buy an E-TEC with the new injectors, need only select a 2008 model year motor. Evinrude sure made that a simple task.... Refresh my memory now, how does one go about selecting the most up to date motor when purchasing an outboard from a manufacturer who has done away with the model year designations? |
JayR |
posted 12-10-2007 06:59 PM ET (US)
BTW Jim.... they are reaching for the "wrong" leg ;-) |
fourdfish |
posted 12-10-2007 07:07 PM ET (US)
OK! You got me Tom! |
seahorse |
posted 12-10-2007 07:22 PM ET (US)
>>>>>>Can somebody tell me how one knows if they have an E-Tec motor with the new or old injector? Can somebody tell me what month and year this change occurred?<<<<<<<< The older version injector had the ignition coil mounted on it. The newer style does not have any threaded bosses for it. Now that is simple, isn't it????
posted 12-10-2007 09:06 PM ET (US)
If you'd like to follow-up on a technical aspect of this discussion, please join us in this second thread on this general topic: http://continuouswave.com/ubb/Forum4/HTML/005854.html One hundred articles is a good point to halt discussion in this thread. |
