ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance REVENGE 22 W-T WD 225-HP Johnson
Author | Topic: REVENGE 22 W-T WD 225-HP Johnson |
Aquia Revenge |
posted 12-20-2007 05:11 PM ET (US)
I have a 1988 Revenge 22 W-T WD and am looking to buy a new prop for the original Johnson 225 VRO. Does anybody have any recommendations? |
Tohsgib |
posted 12-20-2007 07:48 PM ET (US)
14.5x17 OMC SST maybe a 15" but I ma thiking 17" if it is a looper and 6k redline. |
posted 12-21-2007 01:27 AM ET (US)
I recommend you read this article: Propeller Tests: |
posted 12-21-2007 01:34 AM ET (US)
Nick's suggestions are good. I have been using three propellers: --OMC SST 15-inch pitch --OMC SST 17-inch pitch --Mercury MIRAGEplus 17-inch pitch depending on the load on the boat and the sea state. For heavy loads and high seas, I use the 15-inch SST. It has been a good propeller but the fuel economy is not very good. For higher loads and calmer seas, I use the 17-inch pitch propellers. The MIRAGEplus gives the best fuel economy at 25 to 27-MPH cruise, but it does not allow much trim out and tends to ventilate in any kind of seaway. |
Aquia Revenge |
posted 12-21-2007 06:40 AM ET (US)
Thank you all for your responses, this helps alot. Hope you all have a great holiday. |
L H G |
posted 12-21-2007 11:54 AM ET (US)
Jim - Any bets that the Merc Mirage Plus 17" has the HIGHEST EFFICIENCY rating of the three? |
