posted 04-11-2008 05:14 PM ET (US)
If you are "happy" with the performance of a 115 hp motor on your Nauset, you are very likely to be "unhappy" with the performance on an 18' Outrage. It will perform like a dog in comparison.
That said, when propped right, a 115 hp motor should be adequate on the Outrage, but it will not be a peak performer.
This should also be taken into consideration after you figure out if your current motor is too long for the Nauset or too short for the Outrage.
Finally, if you do in fact have a 25 inch 115, you will likely need to invest in a different, lower pitch propeller for the Outrage application.
Dave
