posted 05-15-2008 09:05 AM ET (US)
While not an expert, I have learned a few things.Manufactures give a 1000 rpm's as a range since it can depend on a number of variables. (air, fuel, boat, prop, elevation etc). If the engine runs below that range, at WOT it is considered "lugging". Think going up a steep hill in 4th gear, not 2nd gear. Getting to 5000 or 5200 lightly loaded would be very good.
As for your boat performance, there are 5 significant factors to determine good performance.
Model of boat
Engine mounting position (what bolt hole and where is the anti-cavitation plate in relation to the bottom of the boat)
Propeller size (i.e 13.xx by 15.)
Gear Ratio of lower unit
Weight of gear, persons and fuel
To help you set the boat up correctly, we need to know all of these. In addition, when doing performance trials, it helps running with 1/4 tank, light gear, 1 person.
When commencing a performance run, find a 1 mile section of calm water. Trim the engine all the way in (toward the transom). Accelerate to WOT. Trim the engine out till you start to see the speed fall off. If there is wind and current, do runs in opposing directions and average the results.To get accurate speed, you need to use a GPS.
Once we know all of the above, we can help
