posted 07-26-2008 08:44 AM ET (US)
SeaBaticalJust as a point of reference, I use a 13 X 19 inch stainless K series yamaha prop on my 17 BW. The prop turns the engine (90 yamaha 2 stroke) at 5200 RPM with a light load. Reads 42 mph on a gps. Will Turn 5000 with a heavier load (3 200lbs adults, 20+ gals of gas), trimmed out. Hole shot is pretty good. My engine is flush on the transom...
I use the boat for cruising, water sports, and fishing. If I were to try to pull a heavy slalom skier it would be a struggle with the 19. I would need to switch to my 17 spare. However, I did pull a 230+LBS wake boarder with not much of a struggle with the 19. I use the 19 almost exclusively.
I think you should be be able to squeeze more RPM out of your current set up. Do you have any thing else of significant weight, dual batteries, trolling motor etc... Are you trimmed out at WOT when you hit 4900?
With My 17p stainless the boat jumps on plane and will top out at 5700 RPM with 2 adults full tank trimmed out.
I am sure you have many choices.... I would stay away from props designed for a bass boat, these are designed to run close to the surface and provide significant bow lift. I tried a 19 inch Michigan Wheel Ballistic with only fair results... MAX 4900 PRM... Kind of a radical designed prop to begin with...
Good luck
