ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance OUTRAGE 22 Whaler Drive, Yamaha F250
Author | Topic: OUTRAGE 22 Whaler Drive, Yamaha F250 |
tgrobson |
posted 07-22-2008 05:25 PM ET (US)
I am in the process of re-powering my Outrage 22 with whaler drive with a single Yamaha F250. Give me a suggestion of the best propeller for fuel economy and overall performance. Thanks [Jump ahead to results.] |
Tom W Clark |
posted 07-22-2008 05:54 PM ET (US)
15-1/2" x 17" Yamaha Saltwater Series II 15-1/2" x 17" Mercury MIRAGEplus (maybe even the 15-3/8" x 18" size) 14-5/8" x 17" Mercury Revolution4 15-1/4" x 17" PowerTech OFS4 |
posted 07-22-2008 09:34 PM ET (US)
I think many will be interested in seeing data from your boat testing with the Yamaha F250 on a Boston Whaler OUTRAGE 22 Whaler Drive. Please give details of the test conditions and how you collected the data. |
crbenny |
posted 07-24-2008 09:55 AM ET (US)
It might be tough to predict a prop without knowing more. Does it have a T-top or bottom paint? I remember a while back someone else had a 22' Outrage with WD and T-top and bottom paint and with an OX66 250, he was turning a 19" up to 5300 rpm. Certainly the OX66 is lighter, has a lower redline rpm,and some believe is more powerful so this may not be an exact comparison. Mikejana bought an OX66 250 from me and mounted it on a bracketed, full transom 22' and hit mid 50s with a 19". Tom usually leans towards conservative with his recommendations. Less pitch is less load and less risk of overloading, so I'll agree that establishing a benchmark with less pitch is wise. I just think it's very possible that a 17' prop may not be enough. Chris |
crbenny |
posted 07-24-2008 09:58 AM ET (US)
Oops.. A 17' prop would most likely be plenty of pitch.. make that a 17" prop may not be enough. Chris |
TransAm |
posted 07-24-2008 11:36 AM ET (US)
I am moderately suspicious about a single Yamaha 250 with a 19" prop turning 5,300 RPM pushing anything mid 50's-perhaps with a good tail wind. As for the prop recommendation, with all the testing I have done lately with Yamaha 250's (two-stroke mind you), I think you may end up with a 19" pitch when all is said and done. |
crbenny |
posted 07-24-2008 09:10 PM ET (US)
Trans Am, I was referring to 2 different boats. John from Madison Ct had a WD 22' with T-top and bottom paint and topped out at 5300 rpms (44 mph). Mikejana was much faster with the same engine and prop but with the reduced drag of a bracket instead of the WD. I don't know Mikejana's RPM with respect to the mid 50s he referenced. Be that as it may, we both can agree that a 19" may be a better choice.. Chris |
Tom W Clark |
posted 07-25-2008 10:06 AM ET (US)
I disagree with Chris's assertion that my propeller recommendations tend to be conservative. They tend to be right on. I stand by my recommendations ;-) |
Peter |
posted 07-25-2008 10:43 AM ET (US)
I completely agree with Tom's recommendations. On my 22 Revenge powered by a Yamaha 225 Ox66, I ran a 15-1/2" x 17" Yamaha Saltwater Series II. I don't think that an F250 can turn more propeller than that on an Outrage 22 WD. |
TransAm |
posted 07-25-2008 01:45 PM ET (US)
As I am always eager to learn, could Tom or Peter elaborate on how they arrived at a 17' pitch? I have used the prop calculator here, as well as the Mercury Prop selector, and both are suggesting 19" or 20" pitch props. I'm wondering if I am using these selectors correctly. I assumed 4,300 lbs +/- total weight, 6000 RPM, 2:1 gears, top speed 52+/- and 6% slip. |
TransAm |
posted 07-25-2008 02:02 PM ET (US)
A bit of anecdotal data. On my Temptation, I run 23P on my twin 250's. Using only 1 engine, I can achieve 4,900 RPM and more than 45 MPH. Since the outrage in question is a good 2,000 lbs lighter, it should certainly be able to make 52 MPH. 23" Pitch is obviously not the correct pitch of a single on my rig, however, I would not think, given the reduction of 2,000 lbs in weight for the 22' Outrage, that it would take a 6" pitch reduction to make the correct RPM. If each inch reduction in pitch increases RPM by 200 (a figure put forth here before), I could make 6100 RPM with a 250 on my 6,300 lb Temptation with a 17" Pitch prop. |
Mobjack |
posted 07-25-2008 02:03 PM ET (US)
I don't know nearly as much as Tom about propellor calculations, but I do know that we had a bottom painted, T-topped OR 22 with whaler drive and twin 200 v6 yamaha 2 strokes for the better part of my childhood, and on its best day, trimmed right, with light fuel and a couple of passengers, it topped out around 55. I could be wrong, but I would be very skeptical of powering that boat with a single engine, much less a 250 four stroke. At its weight, I think it would be drastically underpowered. Just my 2 cents, from experience. |
Peter |
posted 07-25-2008 02:05 PM ET (US)
I think your top speed estimate for this combination is too high. If you plug in a more realistic 45 MPH the prop calculator comes up with 17 inches, right where Tom recommended. |
TransAm |
posted 07-25-2008 03:26 PM ET (US)
Peter, I can make 45 MPH on my 25' temptation with a single 250, a set-up that is 3' longer, 6" wider beam and more than 2,200 lbs heavier. Sorry, I can't 45 MPH as top end for a 22' Outrage with 250 HP. |
NewportMe |
posted 07-25-2008 03:42 PM ET (US)
I have a 22' outrage WD with a 225 evinrude and 15" stilleto that turns almost 6000 rpm at 42.3 MPH . My Guess is that Tom is probably pretty close and I would not expect much more than 45 MPH. Bruce |
Peter |
posted 07-25-2008 03:43 PM ET (US)
I don't know what to tell you other than what I have experienced with numerous Whaler hulls of various sizes. Based on that experience, I would not bet on more than 45 MPH for a 22 Outrage WD with 250 HP on the transom. 45 MPH means a 17 inch pitch to achieve the top of the RPM band. |
TransAm |
posted 07-25-2008 04:15 PM ET (US)
This thread has a similar ring to it. |
Perry |
posted 07-25-2008 04:34 PM ET (US)
Similar, but the 22 Outrage in that thread has no Whaler Drive so not really an accurate comparison. |
Peter |
posted 07-25-2008 06:23 PM ET (US)
Also, John's 22 Outrage WD in that thread was running a 250 Ox66 which is a "hotter" motor than the F250. As compared to my old Revenge 22, the 22 Outrage WD weighs the same but it drags the weight through the water. |
Tom W Clark |
posted 07-26-2008 01:07 AM ET (US)
I agree with much of what has been said above. An Outrage 22 WD is not going to do much more than 45 MPH with an F250. 45 MPH is what I used in my calculations. |
posted 07-26-2008 07:45 AM ET (US)
Boston Whaler boats with a Whaler Drive and a single engine tend to have a relatively high engine mounting height due to the arrangement of the transom relative to the keel and drive. (You can see the dimensions involved in an illustration in http://continuouswave.com/whaler/reference/propellerWDSingle.html The anti-ventilation plate will be about 2.5-inches above the keel. Also, the turbulence of the Whaler Drive tends to create a lot of aerated water. My experience is that propellers tend to run with more SLIP than usual. Those conditions suggest a propeller with blade design that can resist ventilation. I have found that the REVOLUTION4 propeller gave a good account in this application. |
posted 07-26-2008 07:51 AM ET (US)
The most speed I have ever seen on my 22-foot hull with Whaler Drive (a REVENGE 22 W-T WD) is 42-MPH, and that is with 225-HP. With 250-HP you should expect 42 X (250/225)^0.5 = 44.3 The OUTRAGE is perhaps a few hundred pounds lighter than a REVENGE, so this should boost the top speed another few MPH, so 45-MPH is probably a good target speed. |
TransAm |
posted 07-26-2008 10:50 AM ET (US)
I think it is odd that with a single Yamaha 250 OX66 on my 6,200 lb Temptation, I achieved 45.7 MPH (starboard) and 44.5 MPH (port). This was with a 23P prop for my twin engine set-up. These OX66's must realy be "hot"! :). I wonder if the gearing can account for this (2:1 for the 4-stroke, 1.81 for the 2-stroke). When using the prop calculator and inserting my single engine data, I get a slip of 21% @ 45.7 MPH because the 23P prop is designed for the twin set-up. When the gear ratio is changed to that of a 4-stroke, the MPH drops to about 41. |
crbenny |
posted 07-26-2008 10:58 AM ET (US)
We still don't know if this boat is bottom painted with/without a T-top do we? For the record Tom, I didn't exactly disagree with your recomendation, I just believe that with low drag, a 19" is possible. If you took my input as doubt in your abilities, I sincerely beg your pardon.. You are the "Propellor Oracle" :) Chris |
crbenny |
posted 07-26-2008 01:06 PM ET (US)
Propeller.. And I am the spelling oracle. Chris |
Tom W Clark |
posted 07-26-2008 03:08 PM ET (US)
Chris, I put one of those winking smilie thingies at the end of my post. Both Propeller and Propellor *are* correct spellings ;-) |
mikejana |
posted 07-29-2008 06:23 PM ET (US)
I have a closed transom 22 Outrage with an after market bracket made to the whaler drive specs(ie same size, but aluminium). I'm running the matched ox-66 250 to CRBenny's. My prop came from Tom Clark. He is always a pleasure to deal with. His first recommendation was spot on. Trust him. I cruise around 3mpg in the mid to high 30s. Holeshot is great. Max speed is just over 50, mid 50s if empty and light load. Prop is 15 1/2 x 17 Yamaha Saltwater II. Mike |
mikejana |
posted 07-29-2008 06:40 PM ET (US)
BTW- no top, no bottom paint, clean hull with no water inside the hull; judged by weight when stripped last summer. Mike |
TransAm |
posted 07-29-2008 07:09 PM ET (US)
Even so, those numbers are quite remarkable for that set-up. I was unaware a 17P prop was capable of mid 50's. I have found the prop calculator quite accurate, however, in order to achieve such numbers, the calculator sugggsts slip would be more than -10. At a more realistic slip of say 6%, MPH would be just under 46 with a 17P, which are the assumptions made in earlier prop recommendations. That aside, I like your boat/set-up. I am looking for a similar 22 classic Outrage with either a closed transom or Whaler-drive. |
Tom W Clark |
posted 07-30-2008 10:01 AM ET (US)
The propeller I recommended and sold to Mike was a 15-1/4" x 19" Mercury MIRAGEplus, not a 17" Saltwater Serries II. The MIRAGEplus usually runs with very little slip, 5-8 percent is typical. |
TransAm |
posted 07-30-2008 10:50 AM ET (US)
The fog is lifting. |
crbenny |
posted 07-30-2008 04:04 PM ET (US)
That certainly makes more sense. When Mike and I loaded that OX66 250 on his truck, we briefly discussed with some certainty that the original 17" Saltwater Series prop the engine came with, would be too small. I remember in the post referencing his sea trials that 19" was his final choice. Tom, I knew you were kidding around.. a wave of sarcasm came over me and I couldn't resist ;) By the way Mike, I'd love to see some pics of your boat! Chris |
acseatsri |
posted 07-31-2008 07:49 PM ET (US)
My 22 Outrage powered by 225 ETEC spinning 15.5 x 17P Rebel prop, w/ large T-Top, heavily painted bottom, rear seat, 1/4 tank fuel, and me (200 lbs) tops out at 49 mph @5600 rpm (trimmed out for max speed). Throw in full fuel and 600 pounds of people and she tops out at 44-45 MPH @ 5500 rpm. |
Perry |
posted 07-31-2008 08:26 PM ET (US)
acseatsri, notched transom or Whaler Drive? |
mikejana |
posted 08-01-2008 07:11 PM ET (US)
Sorry, I went with Tom's recommendation. Works great. Work has kept me away from the boat (& family & water & home) more than I could have imagined. Mike |
dnh |
posted 08-02-2008 09:07 PM ET (US)
I have a Merc Enertia 21p prop on my Outrage 21 w/ Yamaha F250. Works perfect. It will fly. I can't imagine an older 22 would weigh much more or require a 17p but who knows. |
Tom W Clark |
posted 08-02-2008 09:23 PM ET (US)
An Outrage 22 WD is nothing like an Outrage 21. It is three feet longer, weighs almost half again as much, has a 100 HP greater rating and a completely different hull design. Yeah, I think a 17" pitch prop is where it's at. |
SaltWater Warrior |
posted 08-03-2008 10:01 PM ET (US)
The 22 outrage in the beginning of this post has bottom paint and a T_TOP. We just picked it up from the rigger and are Really excited. We will forward performance info after we go thru break in , etc.. Thanks for the help... |
SaltWater Warrior |
posted 08-14-2008 10:32 AM ET (US)
[Apparently the Boston Whaler OUTRAGE 22 with Whaler Drive and Yamaha F250 being discussed here has a new owner, who now gives the following results obtaioned with a Saltwater Series 15-1/2 x 19 propeller.--jimh.] We ran the [Boston Whaler OUTRAGE 22 Whaler Drive with recently installed Yamaha F250 four-cycle motor] last night with a [Saltwater Series 15-1/2 x 19 propeller]. I asked for the 17 pitch but the Dealer rigged it with a 19, he said he could work with it better from a 17. This is what we did in a light breeze SW 8 knots, 3/4-FULL tank of fuel, 65 gallons, two men, 8 [beer bottles] with 8-lbs ice in cooler: 3,000-RPM 16.3-MPH I am going to try the 15 1/2 x 17 prop I have on order. Thanks again for the help and I will post results. |
Tom W Clark |
posted 08-14-2008 11:16 AM ET (US)
SaltWater Warrior, What is your relation to trobson, the originator of this thread? I am confused. Exactly what "19 pitch prop" do you refer to? Exactly which 15-1/2" x 17" propeller have you ordered? |
tgrobson |
posted 08-14-2008 12:31 PM ET (US)
Tom, Salt Water Warrior, aka "Game Hog" to those who know him, was my next door neighbor for years. I sold him my Whaler so that his two young sons could be raised in a safe fishing environment. I introduced him to continuous wave website as the end all source for information, as well as comeraderie second to none. tgrobson. (proud former whaler owner) |
SaltWater Warrior |
posted 08-14-2008 04:14 PM ET (US)
Mr. Clark, I have ordered the 15 1/2" x 19 saltwater series that you discussed in you origional reply. And as for the relationship to tgrobson Also know as the "BAG MAN " he was a member of Continous Wave before i registered and was so kind to post a prop recomendation for me. |
Tom W Clark |
posted 08-15-2008 10:20 AM ET (US)
Do you mean you just tried the Saltwater Series 15-1/2' x 19" and have ordered the 15-1/2" x 17" Saltwater Series? |
SaltWater Warrior |
posted 08-22-2008 02:34 PM ET (US)
YES |
posted 08-22-2008 08:48 PM ET (US)
To summarize, so far we have the OUTRAGE 22 WD reaching 42.5-MPH with an F250 using a Saltwater Series 15-1/2 x 19 propeller. I think you are about 2- to 3-MPH below your ultimate possible top speed. There seems to be a huge jump between 4,000-RPM and 4,500-RPM. The boat speed really goes up between those engine speeds. Do you have any accurate data on the fuel consumption? |
posted 08-23-2008 02:06 PM ET (US)
According to http://www.yamaha-motor.com/outboard/products/subcatspecs/1/specs.aspx the gear ratio of the F250 is 2:1. Using the propeller calculator we get RPM =5,500 Calculated SLIP = 14.1 percent That is a little higher SLIP than optimum. Usually on a single propeller you can get the SLIP down to about 10-percent, although on larger and heavier boats it is often harder to get to 10-percent SLIP. The 19-inch pitch propeller is probably optimized for a higher speed, closer to 47 to 50-MPH. Let's see what we predict with a 17-inch propeller, with SLIP down to 8-percent, and the engine wound up to its red-line 6,000-RPM RPM = 6,000 Calculated MPH = 44.4 |
