posted 08-20-2008 03:14 PM ET (US)
There is no reason to assume that one RPM setting will be more efficient from a purely engine point of view, excluding idle and WOT.Peaks in mpg seen on performance curves are due more to hull factors than to engine factors.
Planing hulls exhibit nonlinear characteristics, including reduction of wetted area (sometimes) with increasing speed in certain speed ranges. This, not some mysterious engine characteristic, is the origin of the "sweet spot" heard, felt, and observed.
This falls near 4000 RPM because 40 mph hulls whose engines peak at 5500 RPM, are running in the high 20's, where optimum mpg occurs for these hulls.
Notwithstanding the above, some engines do sometimes develop unpleasant vibrations or sounds at certain speeds. This should not be confused with fuel efficiency, but it is a factor in selecting the best speed.
