Topic: V- 20 Outrage prop help....again
28sstony |
posted 09-01-2008 07:51 PM ET (US)
I ended up with a 150 Johnson 25" mid section instead of a 175 Merc as I had posted a few weeks ago. The motor came with an old 14.5x21p aluminum prop that appeared to be in good shape so I ran it this weekend, the boat will not get on plane, the prop just blows out above a fast idle, I suspected a spun hub. I switched to an 21p stainless solid hub Merc cleaver off of one of my other boats and had the exact same results. Am I that far off on prop pitch, or do I need to start looking at jack plates with lots of setback?
Sal DiMercurio
posted 09-01-2008 09:15 PM ET (US)
21p is way to much. You need either a 15p or 17p depending on what you use your boat for. If you fish in heavy weather & pack a good size load of fuel, people & gear, a 15p will do it. A 17p will most likely be your best bet if your not carrying 4 people , 60 gallons of fuel & 200 lbs of lead Salmon cannon ball. A 21p on that boat wont reach 4200 rpms, & that engine wants 5500 rpms. You need to mount the engine up on either the second or 3rd set of holes, down from the top set. Sal |
28sstony
posted 09-02-2008 06:36 AM ET (US)
I figured it was too big, but thought it would at least get on plane.Thanks |
newt
posted 09-02-2008 10:16 AM ET (US)
I concur with Sal. On my former V20 Revenge with Johnson 150 I ran an OMC SST 15x17 stainless propeller. Max RPM were 5500 at 42 mph. The prior owner ran an aluminum 15x15 prop with good results also, but I raised the engine a couple holes and used the stainless wheel. |
28sstony
posted 09-03-2008 11:23 AM ET (US)
I will be running a heavy load of fish and dive gear, in snotty ocean water. On the low end with a 15p is that SS or aluminum? |
Sal DiMercurio
posted 09-03-2008 11:42 AM ET (US)
I only run stainless on all my engines over 70 hp. Sal |
Tohsgib
posted 09-03-2008 11:43 AM ET (US)
Does that boat use a 20" shaft? If so you need a jackplate. |
Tom W Clark
posted 09-03-2008 12:40 PM ET (US)
The Outrage V-20 uses a 25" shaft length single, but the motor should be mounted at least two holes up. |
