ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Effects Of Propeller Which Limit WOT Engine Speed Below Recommendation
Author | Topic: Effects Of Propeller Which Limit WOT Engine Speed Below Recommendation |
bloller |
posted 09-06-2008 04:38 PM ET (US)
Will propping a boat and motor combination to operate at 5,200-RPM at WOT when engine manufacturer recommends 5,500 to 6,000-RPM WOT cause any damage to the motor? I ask this because I seem to get better cruising performance and identical top speeds if I use a propeller that gives 5,200-RPM compared to 6,000-RPM. These numbers are with the motor trimmed to optimal setting, no left or right steering torque. Trimmed out further I can probably hit 5,500-RPM. I also plan on using a lower pitched propeller whenever I take on any passengers. |
cooper1958nc |
posted 09-07-2008 10:21 AM ET (US)
Lowering engine speed increases efficiency, all other things equal. You get the same hull speed with lower engine speed, great. That can't be beat. Another data point validating my thesis about "over-propping" (a misnomer, call it "overdrive"). Don't listen to the old wive's tales. If it planes the boat, it's fine. |
posted 09-07-2008 01:23 PM ET (US)
I figure the guy who designed the motor has some input in this decision. You're only 300-RPM off the recommended range--that could be just the error in your tachometer reading. |
cooper1958nc |
posted 09-07-2008 07:40 PM ET (US)
Was not "designed" with today's fuel prices in mind. The specifications are to ensure best power, not best economy. |
Jerry Townsend |
posted 09-07-2008 09:28 PM ET (US)
cooper* - be assured that the engine manufacturers NEVER considered fuel prices in their designs. What is important from a manufacturer's viewpoint ? - power, performance, economy, weight, initial cost, time-of-life - and probably a few other things - but never fuel costs. They want their engines to out-perform and to out-sell the competition's. Now, I am not a engine manufacturer - or engineer - but I look at the WOT as being a "red-line" - as on a car/pickup/truck engine. Since the efficiency of an engine varies as the engine RPM to some point of maximum efficiency and then decreases - I also suspect that the WOT is not far from the point of maximum efficiency. In that same light - I don't see anything wrong with operating at something less than the WOT - other than one is then operating at a decreased efficiency - i.e. - it is going to cost more in fuel. ------ Jerry/Idaho |
wadams |
posted 09-07-2008 09:38 PM ET (US)
Maybe you can shed some light on my prop situation. I have a classic 17 Montauk with a 90 Etec. When I put a 13x19 prop on I turn up 4800 rpms and go 42 mph. At 3500 I'm doing 26 mph and at 3000 I'm going 23 mph. With a 13x17 prop I can turn up 5600 rpms and go 41 mph and at 3500 I make 23 mph and at 3000 I go 19 mph. The dealer told me I should turn up about 5000 but I know the manual says 4600 to 5500 for WOT so the 4800 should be within range without overworking the engine. I know I get a better power curve with the 17" prop but am wondering if the 19" prop would be more efficient since I can go 23 mph at 3000 vs 19 mph at 3000 with the 17" prop? Any opions? |
deepwater |
posted 09-08-2008 06:46 AM ET (US)
how much harder do you feel your working the motor turning the bigger prop vs the smaller one |
Tom W Clark |
posted 09-08-2008 11:39 AM ET (US)
If the manufacturer of the motor advises you to prop your motor to hit a certain WOT operating range, that advice should not be ignored. |
glen e |
posted 09-08-2008 12:21 PM ET (US)
"If the manufacturer of the motor advises you to prop your motor to hit a certain WOT operating range, that advice should not be ignored." absolutely correct - and since the ECM is recording RPM history at all times, you might have a a warranty issue down the road if the history shows you've never even been close to there....or operating in the proper ranges... |
wadams |
posted 09-08-2008 01:41 PM ET (US)
It was the dealer recommending the 5500 rpm, not the manufacturer. The manufacturer (Evinrude) states the acceptable WOT for the 90 Etec is from 4500 to 5500 |
wadams |
posted 09-08-2008 01:44 PM ET (US)
"how much harder do you feel your working the motor turning the bigger prop vs the smaller one..." I'm not sure I can really tell because the 19" pitch pushes the boat at 42 mph but only 4800 rpms which is within Etec's acceptable WOT range of 4500 to 5500. |
Tom W Clark |
posted 09-08-2008 01:52 PM ET (US)
wadams, Did you dealer tell you 5000 RPM or 5500 RPM? You have stated it both ways both. While the WOT range of the E-TEC 90 is 4500-5500 RPM the optimum RPM range (per Evinrude) is 5000-5200 RPM. |
TransAm |
posted 09-08-2008 02:12 PM ET (US)
Would it be appropriate to say that the optimum RPM range is where the engine first generates its maximum horsepower, presumably that of the engines rating? |
Tom W Clark |
posted 09-08-2008 02:19 PM ET (US)
No, I would not presume that necessarily. BRP sent a notice to its dealers with the Optimum RPM range recommendations. I do not know the precise technical reasons for it, but here is a thread where I reproduced it: http://continuouswave.com/ubb/Forum4/HTML/006093.html I was interested to see this chart because it fit well with personal experience with the E-TEC 90 which is a motor that does not seem to really like to spin all the way up to its redline. Attempts to improve performance by reducing pitch to gain RPM does not seem to bear much fruit above 5000 RPM. |
wadams |
posted 09-08-2008 03:36 PM ET (US)
Sorry Tom, typo on my part, the dealer said 5500 not 5000 as I stated earlier. I hear the Etec should loosen up a little after a few hrs of running and maybe turn up a few more rpms. If this is the case, a couple hundred more rpms would put the 19" pitch at 5000 rpms which would be at the lower range of the optimum range, I'm thinking this would be ok? I've run about 35 gallons of gas thru it so far, not sure how long it needs to run to loosen up if indeed it does. |
wadams |
posted 09-08-2008 03:40 PM ET (US)
I might mention, I rarely run over 3500 rpms, just don't see the need for it, not in that big of a hurry and rather save the fuel. Since I run 3500 or below (just on plane which is about 2800 to 3000) I'm think the 19" pitch might give me better mpg? |
cooper1958nc |
posted 09-08-2008 06:49 PM ET (US)
Sure, and a 21 if it will plane the boat. "I also suspect that the WOT is not far from the point of maximum efficiency." Well, not exactly. "Efficiency," as specific fuel consumption (fuel flow per horsepower for example) cannot be easily determined, except maybe at WOT. We have no real way of knowing how much power is produced at lower RPM and power settings without a dynomometer at hand. However, once two-strokes have come up well above idle, and are functioning as gas dymamic engines, efficiency is pretty constant, except, of course, for internal friction, which increases its power demand as the cube of the RPM. Furthermore many engines are calibrated to run rich at near WOT to help them cool themselves. For those reasons it is exceedingly unlikely that "efficiency" is highest near WOT. Nor, of course is the hull most efficient at high speeds. |
Jerry Townsend |
posted 09-08-2008 09:28 PM ET (US)
cooper* - virtually every internal combustion engine will increase efficiency (or specific fuel consumption - or any other efficiency parameter) with rpm - until at some rpm, the efficiency starts to decrease with rpm. As I mentioned, I am not sure as to the criterion the engine manufacturers use to specify the WOT. As I have not read the majority of the posts in this thread - I am not sure of the point you are trying to make. But, be assured that the prop designers are trying to get the most thrust (change in momentum) at a given rpm and as compromised by manufacturing costs. And be assured that a boat makes one hell of a poor dynomometer - given the difference in engines, the differences in hull design, the differences in loading, the differences in the water, the difference in ......... As such, the ONLY real way to evaluate the difference in a prop design and performance is via a properly instrumented dynomometer system. ----- Jerry/Idaho |
deepwater |
posted 09-08-2008 09:30 PM ET (US)
so you feel you can turn a bigger prop at a lower rpm and get a higher speed all the while working the motor harder than needed and still be with in factory specs for warranty protection/service ,,,,,that does not make sense,, |
Tom W Clark |
posted 09-08-2008 09:58 PM ET (US)
"Efficiency" is easy to determine. You can discuss theory all night long but of the many efficiencies that can be discussed, it if the fuel efficiency that concerns most folks here. It is not hard to measure. Distance travelled for gallons of fuel consumed is the usual way it is measured. Fuel efficiency is a big part of how outboard motors are designed and marketed today. But we are getting off track (as usual) in regard to bloller's original question. I just grabbed one of my Mercury factory Service Manuals to see what it says about propeller selection. This manual covers the 135-225 V-6s but is probably typical of the advice for bloller's smaller Mercury as well. PROPELLER SELECTION 1. Select a propeller that will allow the motor to operate at or near the top of the recommended full throttle RPM range with a normal load. Maximum engine speed (RPM) for propeller selection exists when the boat speed is maximum and trim in minimum for that speed. (High RPM, caused by an excessive trim angle, should not be used in determining the correct propeller.) Normally, there is a 300-500 RPM change between propeller pitches. 2. If the throttle operation is below the recommended range, the propeller MUST BE changed to prevent loss of performance and possible engine damage. 3. For better acceleration, such as is needed for waterskiing, propping up to 500 RPM above the recommended range is advised. Continuous operation above the recommended maximum speed, however, is not permissible. 4. After initial propeller installation, the following common problems may require that the propeller be changed to a lower pitch: -- a. Warmer weather and greater humidity cause an RPM loss. |
cooper1958nc |
posted 09-10-2008 12:13 PM ET (US)
"Virtually every internal combustion engine will increase efficiency (or specific fuel consumption - or any other efficiency parameter) with rpm - until at some rpm, the efficiency starts to decrease with rpm." Well, literally this could mean the peak could by anywhere above idle, but I don't think this is your intent. I think you mean efficiency is high at high RPM, until something happens and it eventually falls off. That sounds like you are describing volumetric efficiency, which is closely related to torque. VE climbs with icncreasing RPM, reaches a peak for typical 4 stroke engines around 75% of their max (like 3500 or so) then falls. Many people are confused with the relation between VE and fuel efficiency. Generally there isn't one. VE is the efficiency of the pumping; you pump both air and fuel together, so it does not make the fuel burn any more efficiently by itself. Generally, engine friction so seriously deteriorates efficiency that increasing RPM is almost always detrimental to sfc. If you want to experiment, try it on your car with overdrive gearing and instantaneous fuel flow. The results are quite dramatic. What is your theory on why s/f/c increases with increasing RPM? I have never heard anything like that. |
pglein |
posted 09-19-2008 07:07 PM ET (US)
The notion that an engine will use less fuel at WOT just because the RPM's are lower is ludicrous. You've still got the throttle wide open. It's still dumping in the same amount of fuel, you're just getting less RPM's out of it, due to higher rotating resistance. Not to mention it puts the engine's internals under a greater load. "Overpropping" is a bad idea and will NOT save you fuel. Do you drive your car around in 5th gear everywhere you go? |
cooper1958nc |
posted 09-20-2008 01:09 PM ET (US)
Yes, you do, pretty much, drive in top gear whenever possible,if you want maximum economy, minimum noise, and probably minimum wear. Possible means acceptable throttle response without detonation and acceptably smooth running. Car and boat engines don't produce much power under 1200 RPM or so, but if you watch your tachometer you will see that steady state cruise in your car at 1200 RPM in 5th or 6th is totally doable. Of course if you want to accelerate hard or climb a hill, you probably want to gear down, but most engines will take full throttle at 1500 RPM or so without problems (true they will accelerate slower than with lower gears, but it is OK to do it if no detonation, vibration, etc.) Your idea that fuel us used solely based on throttle setting is totally wrong. Both carburated engines and FI engines (using different mechanisms) meter fuel based on (a) manifold pressure, set by the throttle, and (b) RPM. The higher the RPM at any given throttle setting the more fuel is used. On FI engines the throttle regulates air, the FI system meters fuel based on manifold pressure and air density and RPM. All engines are air pumps that use a fuel air mixture (about 14:1) regardless of RPM or manifold pressure. Increasing RPM pumps more air and requires, obviously, more fuel. At less than full power, the same power can be produced by increasing RPM and lowering manifold pressure, or by increasing manifold pressure and lowering RPM. Generally, IF detonation is not occurring, and if vibration is not a problem, you gain efficiency by lowering RPM and increasing manifold pressure accordingly. This works for cars, planes, and yes, boats, with piston engines. "Lugging" an engine is a problem that dates mostly from before the computer controlled engine management era. It describes operating at low RPM and high throttle, with detonation and/or excessive vibration. Lugging is not usually encountered today because the EM software prevents detonation, and because valve timing and other related parameters have allowed low RPM high throttle operation. So don't confuse reducing RPM in midrange with lugging. In the future you will see multi gear transmissions on small planing boats, to take advantage of the reduction in hull resistance at middle range cruise by allowing a higher (numerically lower) gearing, lowering engine speed, reducing friction and noise, and probably reducing wear. "The notion that an engine will use less fuel at WOT just because the RPM's are lower is ludicrous. You've still got the throttle wide open. It's still dumping in the same amount of fuel, you're just getting less RPM's out of it, due to higher rotating resistance." As I attempted to discuss above, there is so much incorrect with this statement I don't know where to begin. Plus, the author seems to think it is "ludicrous" to think otherwise. O well. It remains a mystery to me how people on this forum seem to know, with certainty, so much that is totally wrong, but whatever. |
Backfire |
posted 09-20-2008 09:38 PM ET (US)
Cooper, you certainly missed your calling by not being in the marine engine development segment. The Industry looks forward to your " multi gear transmissions " and other inovations. Backfire |
cooper1958nc |
posted 09-21-2008 05:42 PM ET (US)
Why do you assume I was (am) not? |
cooper1958nc |
posted 09-21-2008 05:46 PM ET (US)
Seriously, In 1968 middle size GM cars had a 2 speed auto trans. Fuel was cheap. Now, topend cars have 8 speeds. More ratios mean more performance AND more economy. More ratios allow the engine to run at the optimum speed for the requirements. Small planing boats do have a "hump" of high resistance followed by a "valley" of smaller resistance, eventually building back up. Increased economy could be realized by slowing engine speed in the midrange cruise. However, with only one speed to choose from, this results in gearing that makes the engine strain (sometimes) to get on plane, and at the high end makes the engine unable to reach full power RPM. So the time has come to use multi gear ratios on small planing boats. |
deepwater |
posted 09-22-2008 07:17 PM ET (US)
i hope were not going to compare car multiple trans gearing to outboard 1 gearing,,its always been the faster you go the more fuel you burn and the heaver you are the more fuel you burn,,turning a steeper pitch prop on a lighter weight boat may give you more push per gal at a lower RPM and save some fuel but it still puts more load on the motor,,is it still within factory specs and limits for wear and tear or not is what we should deciding |
cooper1958nc |
posted 09-22-2008 09:54 PM ET (US)
Well I can't really understand the last post, and we have beat this one to death I think, but suffice it to say this: Assume you are going any particular steady state speed under full speed. How much power does it require? Lets assume a light planing hull with a 200 hp engine goes 45 mph at WOT at 5000 RPM, and maybe 100 hp at 28 mph at 3200 RPM. (values just for illustration). Now, the engine can produce 100 hp at 3200 RPM, 23" of manifold pressure (you don't measure this in a boat, but it is there), OR 2300 RPM at 32" MP (you cant get there at sea level) OR 2500 RPM at 28" MP, etc. Now in general all IC piston engines will be more efficient at high MP, low RPM, for the same power output. This is assuming things are not so wierd as to produce detonation, overheating, or unusual vibration. If you have only one ratio, you must compromise between acceleration, getting to full RPM at WOT, and getting your RPM down and your MP up at cruise. Cars, airplanes, and boats all have this built in. Cars have gears, airplanes have (some) props that change pitch. Small boats, now, are stuck with 1 ratio. One day soon it will change, I bet, considering fuel costs. |
deepwater |
posted 09-23-2008 09:32 PM ET (US)
so much for clarity,,^@^ |
Tohsgib |
posted 09-24-2008 01:17 PM ET (US)
Putting a multispeed trans in a boat has been done on many occasions. The ONLY benefit is better holeshot. Top end is basically still the same if not worse. The main reason it is not used is due to cost and weight because the benefit is so small. Plus in order to get the multispeed trans you would need to use an automatic transmission which would add slip and hence decrease overall performance compared to a direct drive like we currently use. |
pglein |
posted 09-24-2008 01:51 PM ET (US)
The future of marine engine efficiency is in variable pitch propellers, not gearing. We had a variable pitch propeller on our sailboat back in 1998. I actually still have the $5,000 propeller sitting in my garage. It's a pretty amazing piece of engineering. As the price for this kind of technology comes down, you will start to see it adopted by the recreational boating community. It's already quite common on larger commercial vessels. An engine is most efficient at the peak of it's torque curve. "Overgearing" it so that your most common cruising speed is below that point will still result in it using more fuel per force exerted. I realize that both carbureted and fuel injected engines do meter their fuel input based on more than just throttle position. But if you've got vehicle that is under extreme load such that it cannot accellerate, and you open the throttle farther, it's going to consume more fuel, even if the RPM's do not increase. That's essentially what you're talking about doing. Now, boats are somewhat unique in that they have a very influential additional force acting on efficiency, which is the variability of the hull's resistance at different speeds. If your ultimate goal is to cover the greatest distance on the least amount of fuel then you would want to find the most efficient speed for the hull, and then build your engine/propeller package to be most efficient at that speed. But the reality is that most of us want to do more than just cover ground cheaply. If that was really what we wanted, we would all own displacement hull boats and cruise at 4 knots. Instead, we prefer to chose an engine/propeller pacakge that is a compromise, that allows us to accellerate quickly, yet still achieve the a respectable top speed. That's why we go with the propeller that allows the engine to hit the top of it's recommended RPM range, but no higher. It provides the best mix of accelleration and efficiency over a wide range of speeds. |
cooper1958nc |
posted 09-25-2008 01:37 PM ET (US)
"An engine is most efficient at the peak of it's torque curve." Not true, if you mean fuel efficiency. "Volumentric efficiency" does not determine fuel efficiency. Best VE, which occurs at or near peak torque, is simply the point where the most air is pumped. Why do you think cars have (today) such tall gears, sometimes keeping engine revolutions below 1600 at 60 mph? That is not where peak torque or peak VE is, far from it. It is because engine friction always subtracts from specific fuel consumption, and friction increases exponentially with RPM. A multi speed trans will offer superior economy at midrange cruise. In the past, this just was not important enough to warrant the complexity. Now it probably is. "But if you've got vehicle that is under extreme load such that it cannot accellerate, and you open the throttle farther, it's going to consume more fuel, even if the RPM's do not increase. That's essentially what you're talking about doing." Well, not exactly. If you increase manifold pressure by opening the throttle more, you increase torque and assuming you are at steady state (not accelerating) you will accelerate. Air and fuel are metered together. The throttle meters primarily air. Carburators keep a relatively constant fuel mixure, enriching for acceleration and sometimes for WOT. The more air the more fuel. Fuel injectors meter fuel depending (usually) on the air mass, i.e. the density times the volume. Other circuits monitor transient response, such as sudden acceleration, but at steady state the mixture, i.e. the amount of fuel per unit of air, is relatively constant,and the power output per pound of fuel per hour is also pretty constant. Taking from this power is engine friction, which is significant and very significant at higher RPM. Which is why, as long as combustion is occurring correctly (no detonation), you always get your best efficiency at the lowest possible engine speed that will produce adequate power and drivability. The auto makers fully understand this, as is obvious from any modern vehicle. Why people think that boats engines do not obey the same laws of physics as car and airplane engines, I cannot imagine, but the view is common on this forum. O well. |
mralda |
posted 08-23-2010 11:18 AM ET (US)
I am sorry for being a little bit slow, but I'm still having trouble with the concept. What engine damage can I expect if I run a prop that does not allow the engine to reach its wot range. I understand that there would be extra loading on the engine on initial acceleration (just like starting a car on 2nd. gear), but I cannot see what might be the cause of engine damage once you achieve planning speeds. The answers posted by cooper1958nc are probably the most comprehensive I've found so far and if possible, would like to get in touch with you; my email is mralda@hotmail.com. Thanks! |
posted 08-24-2010 08:27 AM ET (US)
Typically an internal combustion engine which is operating under a heavy load will produce more soot in the exhaust. Have you ever seen a large truck trying to accelerate up a hill? Or a freight train locomotive trying to pull a long drag of cars up a grade? In these situations you generally see the exhaust from the engine will contain more soot, which manifests as black smoke. If an engine is continually operated under those circumstances, the extra soot in the combustion chamber will tend to produce carbon deposits in the combustion chamber, in the exhaust passages, and on the piston, piston rings, and other surfaces. Eventually the deposits can harden and cause the piston rings to loose their flexibility. This leads to the piston rings scraping the cylinder walls or otherwise deforming the cylinder walls. The soot deposits also reduce the size of passage ways which then limit the flow of exhaust gas, or the soot build-up can block off small passages which were intended to help distribute lubrication. |
posted 08-24-2010 08:34 AM ET (US)
A boat engine is always trying to accelerate the boat when the boat is on-plane. Boat engines operate under a much higher average load than vehicle engines. Much of the time a vehicle is traveling on an even grade and the engine must only overcome air resistance and rolling friction. A boat on plane is continually climbing up its own bow wave, fighting air resistance, fighting the drag of the water on the hull, and fighting the drag of the propeller being pulled through the water. This results in a substantially higher load on the boat engine as compared to a car engine. For example, my quarter-ton truck can ride along at 55-MPH with its engine only turning about 1,500-RPM. For my boat to reach 55-MPH my engine would have to turn about 7,000-RPM--an impossible task. Instead, I typically run my boat engine around 4,000-RPM. If I ran the truck at 4,000-RPM I would be going about 90-MPH. I have never run the truck engine faster than approximately 3,000-RPM. The boat engine operates at much higher average load than the vehicle engine. To make an analogy, a truck would have to be continually driven uphill with a heavy load to simulate the boat operating on plane. |
posted 08-24-2010 08:39 AM ET (US)
Boats do not have a transmission which allows their engine to alter the gear ratio. The gear ratio is fixed. Vehicles have transmission, with some having as many as six different gears for passenger vehicles and as many as 18 gears for trucks. The gear ratio of a vehicle drive train is adjusted to match the load so the engine can operate in a region of its power curve where it can run up to normal engine speed under load. A boat has no such transmission. The gear ratio is fixed. Try driving your car with a heavy load up a steep hill with the transmission locked in its highest gear. You will put the vehicle motor under the same sort of loading that a boat experiences. |
