ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance E-TEC 300, 30-foot RIB with Stepped Hull
Author | Topic: E-TEC 300, 30-foot RIB with Stepped Hull |
nkrith |
posted 04-21-2009 06:20 AM ET (US)
I recently bought a E-TEC 300, and installed it on my 30-foot high performance stepped hull RIB. The engine seems to be significantly underpowered from what the manufacturer promises. There is no top end power, nor the strong feel of midrange torque that should be there since it is a two stroke. The same boat powered by a 300 Verado just goes so much faster through the whole rev range. I am greatly dissapointed by the performance. I am wondering why the manufacturer claims to have 300-HP since there is no way that 300-HP are there. BRP told me that there will be a new official EMM re-map [this] summer. Why advertise the new 300-HP motor when they only have 240- to 250-HP? It seems ridiculous for a company of this size. Does anybody have any experince with an 300-HP E-TEC? [Are there any after market tuning products for] E-TEC motors? Has anybody put a 300 E-TEC to the dynamometer? |
Peter |
posted 04-21-2009 07:10 AM ET (US)
Although this is a Boston Whaler site and we are unlikely to have any experience with a 30 foot RIB, it sounds like your motor doesn't have correctly pitched propeller and/or the motor mounting height is incorrect. Perhaps you could provide more details about your boat and its setup including: 1. Brand of boat 30 feet of boat powered by a single outboard is a rare site. If you could provide some pictures of your boat, in particular pictures of the motor mounted on the transom and the anti-ventilation plate relative to the keel that would be helpful. |
seahorse |
posted 04-21-2009 07:36 AM ET (US)
Wouldn't it make more sense to visit an E-TEC site such as etecownersgroup.com where there is worldwide expertise on different rigs from owners, dealers, technicians, and factory support folks? |
posted 04-21-2009 08:39 AM ET (US)
The E-TEC 300 has been tested on a dynamometer. You can be sure of that. In order to be sold in the United States all outboard motors have to be tested on a dynamometer while their exhaust gas emission levels are recorded. The data is published by the Environmental Protection Agency (EPA). The EPA limits exhaust emissions of outboard motors based on their power. So in order to determine the amount of exhaust emission per unit of power, the EPA has to have data about the amount of exhaust emission and the amount of power. The results of the test data are usually provided on a label affixed to the engine. Locate the label on your engine and you will see the rated power used in the EPA testing. It is given in kilowatts. To convert to horsepower you use the relationship: 1 kilowatt = 1.34102209 HP |
posted 04-21-2009 08:56 AM ET (US)
I am not aware of any aftermarket products which can be used to enhance the power output of any E-TEC motors. Each E-TEC motor family has been certified and tested for compliance with the EPA exhaust gas emission standards. In the United States it is against the law to tamper with the controls of an engine in any way that might alter the exhaust gas emission. As a result, since they are illegal,these products are rarely seen in the US. There is a loophole in the law that permits racing engines to be exempt, so E-TEC motors used in racing have been modified. However, since the racers are very competitive, they generally do not freely share the techniques and knowledge they have developed to enhance engine performance. I do not think you will be able to find much literature or technique has been published on this topic. Regarding experience with the E-TEC 300-HP, I can share my experience with the E-TEC 250 H.O. The E-TEC 250 H.O. uses the same engine block and displacement as the E-TEC 300. I tested an E-TEC 250 H.O. on my boat. You can read the results in an article I published: Evinrude E-TEC 250 H.O. With regard to the anticipated boat speed obtained with the E-TEC 250 H.O., the performance results exceeded all expectations. The speed increase that was obtained with the change to the E-TEC 250 H.O. motor was much greater than was anticipated based on the rated horsepower of 250-HP. Please see my article for the details. Regarding your performance, since you have given us absolutely no details about the boat's performance, it is impossible to make any assessment of your results. If you have data that you have published on-line, please give a link to it. In order to make any reasonable assessment of your results, we will have to know the total weight, the engine speeds, and the boat speeds, as well as details of the propeller and rigging. Also give some information about how the data was gathered, such as the instrumentation techniques, the sea state, and the environmental conditions. We also need similar data for the boat to which you make reference that was powered by another motor. I look forward to seeing your results. |
posted 04-21-2009 09:05 AM ET (US)
quote: As far as I know, the size of the manufacturing company does not affect how it is allowed to advertise its products in the U.S. The rules are the same for all manufacturer without regard to the size of their organization--or at least they are supposed to be! The rated horsepower of most outboard motors has historically been provided in accordance with the suggestions contained in ICOMIA 28-83. For many years the only place this document was provided on-line was http://continuouswave.com/whaler/reference/ICOMIA28-83.html You can now also download a copy of it from the ICOMIA website. A link is given from their page at http://www.icomia.org/library/library.asp?LC_ID=0&Page=12& sort=CT_Country&CT_ID=0&FT_ID=3&view=Type As far as I know, BRP is in compliance with the horsepower rating technique suggested in this document. This technique has been used since c.1984 by most all outboard manufacturers, as far as I know. |
Peter |
posted 04-21-2009 09:18 AM ET (US)
EPA certification data says 296 HP at 5500 RPM for the 300. Contrast that to Yamaha's certification data for their HPDI 300 -- 276 HP. I could not find any certification data for the Mercury Verado 300. The Yamaha F350 certification data shows 326 HP for 2008 and 335 HP for 2009. |
nkrith |
posted 04-21-2009 10:57 AM ET (US)
I chose the boston whaler forum in order to ask something like that regarding the etec since i found the topic regarding etec 300 on google. on top of that, all my questions regarded the engine only and not the boat.
Expected performance with the 300 etec would be around 50+ knots. At the moment we are doing 43 and we are workimg to make it 46 with a more efficient propeller and a change in height of the motor
Thank you in advance. |
posted 04-21-2009 11:42 AM ET (US)
You can send a digital image of your boat and E-TEC 300-HP to me via email, and I will publish it in this thread for you. My email address is available in my profile. |
Peter |
You can post your pictures to a picture host such as Photobucket, for example, and then post links to the pictures here. You still haven't told us what brand your 30 foot RIB is or what propeller pitch is currently being used. |
posted 04-21-2009 11:47 AM ET (US)
Please give us more data about your tests. I suggest you collect and organize the data using this form: |
nkrith |
posted 04-21-2009 12:09 PM ET (US)
pitch 22, raker, 3-blade 5600rpm 43 knots pitch 19, 3-blade, 5750 rpm 43 www.ribeye.co.uk model ribeye 9.30 stepped hull |
Tom W Clark |
posted 04-21-2009 12:20 PM ET (US)
www.ribeye.co.uk I can find no "ribeye 9.30 stepped hull" on this web site. What is the length, width, weight and maximum horsepower capacity of the boat in question? |
fourdfish |
posted 04-21-2009 12:34 PM ET (US)
New member with a bashing post!!!! This is obviously a troll. No real credibility here! Sounds more like a commercial! |
Tom W Clark |
posted 04-21-2009 12:36 PM ET (US)
fourdfish -- Please take your exclamation points and go away. |
nkrith |
check the greek website www.elcohellas.gr even if you dont understand greek you can check the greek product list and see the boat |
Buckda |
posted 04-21-2009 12:38 PM ET (US)
http://www.ribeye.co.uk/documents/RibeyepricelistJan2009front.pdf Here is a price list for 2009. There is a 9.30 "S" series vessel. Max HP is 500, but is listed with a Yamaha F350. No performance figures. Interesting to note that on their homepage, the "S" series is only available in 9.60, not 9.30. I think they are a semi-custom builder and looks like they are still getting a handle on their Web presence. I don't know much about RIBs, but if the max HP is 500, it seems to me that 300 is not enough, no matter who the manufacturer is. |
Buckda |
posted 04-21-2009 12:39 PM ET (US)
Tohsgib |
Uh Dave...43 knots in a 30' is not enough for you? |
Perry |
posted 04-21-2009 12:40 PM ET (US)
http://www.elcohellas.gr/details2.php?lang=1&wh=6& searchttile=Ribeye%209.30%20stepped%20hull&thepid=585 |
nkrith |
posted 04-21-2009 12:44 PM ET (US)
maximum horsepower is 700hp not 500. designwise the hull is capable of approximately 68 knots with a pair of engines. anyway, i was wondering if anyone of you owns a 300 etec and thinks that it is not really 300. all the technical stuff is for the very technical guys.. in the end i might go for a pair of 200 or 225 ho to get arround 55+ knots |
Buckda |
Guys - this is a person who bought an expensive bit of equipment that is not performing as expected. It is a testament to the quality of information on this site that he found us via the WWW looking for information on his E-TEC engine. Let's work to help him rather than accuse him. There are really two possibilities here: Let's work to find out which it is. NKrith - have you been in a 300 HP Verado-powered version of your boat? You make this comparison, but I'm wondering if the power is too low to help the boat perform as expected. With a max HP of 500, you are 200 HP - almost 50%- underpowered. My 18' Boston Whaler (rated at 150 HP) would not perform well with only 100 HP on the transom. |
Tom W Clark |
posted 04-21-2009 12:46 PM ET (US)
As it turns out, I do not understand Greek. Again I ask: What is the length (presumably 30.5 feet?) width, and maximum horsepower of this boat? Is there any existing performance data for this boat? The reason I ask is that a boat over 30 feet that already does 50 MPH is remarkable. I do not believe there exists a 300 HP outboard that can propel most 30+ footers to over 57.5 MPH as nkrith asserts. This boat must be exceptionally fast. |
Buckda |
posted 04-21-2009 12:47 PM ET (US)
Good lord man! 300 HP on a boat that is rated for 700 HP? I think you are waaaay underpowered, which is your problem - if you put at 300 HP motor on a boat rated for 300 HP, the engine would perform as expected, but you're asking your motor to push around twice as much boat - you should have twin 300's. |
Perry |
posted 04-21-2009 12:49 PM ET (US)
If max HP is 700 and you only have 300 HP that explains why your top speed may not be what you expect. Why not put another ETEC 300 on your boat? |
Tom W Clark |
posted 04-21-2009 12:50 PM ET (US)
OK, let's look at what we've got: The boat is 30.5 feet long. It is rated for 700 HP. It goes 50 MPH with only 300 HP buit is expected to go 58 MPH with that power. What is wrong with this picture?! I still wonder what the weight and width of the boat is and if there is any published performance data we can look at. As to the question nkrith asks about the real power output of the E-TEC 300, that question seems to have been answered. |
Perry |
Dave, types faster than me :-( |
nkrith |
posted 04-21-2009 12:51 PM ET (US)
Thank you Buckda for understanding and stating my point.
if you have a pair of 250s (total 500) you have to multiply by 0.8 to get the equivalent power for a single motor installation which is always more efficient by many means (power to weight ratio, weight on transom, symmetry of drive etc). the length is 30.5 feet. expected performanc 50+ knots by a single 300 |
fourdfish |
posted 04-21-2009 12:53 PM ET (US)
That is a good observation! Have to see some pics first. Better idea, have the utube character post a movie! |
nkrith |
posted 04-21-2009 12:54 PM ET (US)
weight is 2000 kg with power and fuel width is 2.70 Dear Tom W CLark: still the etec 300 does not perform the expected |
nkrith |
posted 04-21-2009 01:03 PM ET (US)
Buckda when a manufacturer says that the maximum hosepower can be 700hp, that does mean that you go for 700 in a same sense the manufacturer gives you the minimum power which is 250hp single outboard. I have to add here that you must not compare the performance of a light weight high performance rigid inflatable boat to a heavier boston whaler boat since the purpose that each one is built is different. Bottom line is that anyway, all i wanted to know is the performance of the etec 300 |
Tom W Clark |
posted 04-21-2009 01:05 PM ET (US)
nkrith -- If the boat goes 60 MPH with the Verado 300 (which is so fast as to be hard to believe, in fact, I do not) and it only goes 50 MPH with the E-TEC 300, then you obviously have a problem with the E-TEC and it needs to go back to the dealer for servicing. To claim that the E-TEC 300 is merely a 240 HP outboard is absurd. If you've come looking for advice about how to improve the performance of your boat, we may be able to help you. If you have come here just to bitch, then you will have to deal with the knuckleheads above. |
Buckda |
posted 04-21-2009 01:07 PM ET (US)
I still don't think you'd be happy even with twin 200's or 225 HOs. I'm impressed by the performance of this hull with reduced power on the transom. A Boston Whaler with less than half the rated HP on the transom would suffer serious performance losses. I'd want twin 275's at the least, preferrably triple 225's or twin 300's on this hull. I also think that you will be able to find similar performance between the Verado and the E-TEC if you find the correct mounting height and propeller combination. I would investigate several different settings and combinations before writing off the motor. It is difficult to believe that BRP would enter a weak contender in the ultra-high HP category, since there are a lot of "shootouts" done between competing motors in various magazine tests. Most shootouts end with very small, but measurable, differences in performance - but usually nothing that amounts to much to sway a recreational boater. To see significant differences at speed is interesting and leads one to wonder how the Verado-powered boat was set up. I truly believe that rigging can make all the difference in the world. So my advice to you is to continue to work with your dealer to see if you can get it set up how you want/need it. If not, then of course, consider changing things up. |
nkrith |
posted 04-21-2009 01:08 PM ET (US)
Om W Clark I only want some help the reason i entered your forum is that there was already a topic on the etec 300 and i was interested to know the experience of some owners i dont have time for knuckleheads |
Buckda |
posted 04-21-2009 01:12 PM ET (US)
Just read your reply to me above - I agree - there are major differences between Boston Whaler hulls and RIB's - which is part of the challenge that members here (myself included) are trying to deal with in an effort to help you. I still think that minimum HP ratings are just that: minimums. I realize that you do not have to put the maximum HP on a hull just because the builders rate it for that - but consider that the builders extensively test their hulls with various power levels - they put the ratings on there for a reason. 50 MPH seems "fast enough" for a minimum rating - which is what you're getting with almost minimum rated power. But....all of that extraneous information and calculating aside, I do not have experience with a 300 HP E-TEC to provide you with the information you seek: i.e: first hand knowledge of the performance characteristics of a 300 HP E-TEC. Good luck in figuring the problem out - I hope you can do it quickly and inexpensively and still get out on the water this season. |
Tom W Clark |
posted 04-21-2009 01:16 PM ET (US)
Let's look at it the claims: The boat with a Verado 300 goes 52 knots (59.8 MPH) The boat with an E-TEC 300 goes 43 knots (49.5 MPH) For the same boat to have such incredibly divergent top speeds, the power output of the motors must be different, this is what I think the original post suggested. However, the difference in top speed is so great, 21 percent, that it is not reasonable to believe. To achieve a 21 percent increase is speed, you have to increase the power by 46 percent. This means that if the Verado 300 is really 300 HP, the E-TEC 300 is only 205 HP. Conversely, if the E-TEC 300 is really 300 HP, then the Verado is really putting out 438 HP. I do not think anybody (except perhaps Larry & Glen), believes that for a minute. That is utter nonesense. |
TransAm |
Try this: http://www.plainsailing.co.uk/res/user/1370_s-series-930-brochure.pdf This 9.3m rib weighs in at 1,400 Kg or just over 3,000 lbs. Figuring a minimum of another 1,000 lbs for the motor, a captain and some fuel, 57 MPH seems completely do-able. Since a google search on e-tec 300hp lists CW 2nd, it seems logical for this poster to come here. I love it when conspiracy theories fall apart. |
posted 04-21-2009 01:23 PM ET (US)
I do not recall any reports of Boston Whaler boat which have been re-powered with an E-TEC 300, but there are several boats with E-TEC 250 or 250 H.O. motors, and it would not be an exaggeration to say that the owners of these boats have been very happy with the performance that has been obtained. If you don't want to become involved in a "technical" discussion about the performance of your boat, I suggest you take it back to the dealer who sold it to you and have him make improvements. In order to try to help you we need some information. A good start would be a pointer to a published report of the boat's performance with the 300-HP Verado that shows it reaches 60-MPH. |
Tohsgib |
posted 04-21-2009 01:24 PM ET (US)
I agree Tom. At the Sarasota boat show there was a 30' rib that was quite narrow with a step hull and a single 300 Verado. The boat was obviously light by the way it was bouncing around tied to the dock. The guy said it did roughly 50mph but only on premium fuel. With 87 it would only run 45ish. Now I do not know what kind of boat but it is very similar to the ones on the site he mentioned. Does the E-tec require 91 octane as well? |
Buckda |
posted 04-21-2009 01:32 PM ET (US)
Excellent link TransAm, and thanks for doing the due diligence on how a guy could land here with this question. I did not ever have any doubt that Google or another search engine is how this gentleman found this site. I still maintain that the Verado-powered boat was probably optimized in set-up. It is not uncommon for factories or dealerships to mount engines Òtoo lowÓ on the transom, or make other mistakes that might reduce the performance. Given the worldwide economy, I doubt that the dealerships are selling a lot of these boats in the first place, and then to have a customer request a different motor (the brochures say they come standard with Yamaha)Éall this adds up to strong possibilities for rigging errors. My advice is to make adjustments in the setup until you gain the optimal top speed coupled with top engine speed for efficiency. You have what I would call a Òmarginally poweredÓ boat Ð so small changes may make big differences. You and I differ in opinion about powering the vessel in terms of the relationship between the maximum rated power and the power you elect to place on the transom Ð even the dealer linked above is recommending 350 HP minimum on a 500 HP rated boat. You claim that your version of the vessel is rated to 700 HP Ð which means that it should be powered by at least 500 HP total Ð so you definitely need twins to see the hull perform as it was designed to perform. Beyond that, I can only wish you good fortune in solving this situation. Please disregard rude behavior of some members Ð but realize that there is a lot of critical thinking that happens here Ð Tom W. Clark is one of the most helpful members here Ð but he requires solid, substantiated and factual information to do what he does best Ð help people out. Best regards, |
posted 04-21-2009 01:37 PM ET (US)
Here is a digital image of the boat rigged with the E-TEC 300-HP: |
posted 04-21-2009 01:43 PM ET (US)
[I removed several sidebar discussions about internet conspiracies and how to search for information. Use GOOGLE to search for information. As for conspiracies, I am still working on the Kennedy assassination, so no time for new theories.] |
TransAm |
posted 04-21-2009 01:48 PM ET (US)
It looks like the transom bracket on that boat is only set-up for a single motor. |
Buckda |
posted 04-21-2009 01:51 PM ET (US)
Based on the information I've read, these boats are built to customer order. Twins seem to be an option, though I haven't yet seen one listed with triples...but to get 700 HP, you'd need triple engines.... |
TransAm |
posted 04-21-2009 01:52 PM ET (US)
I don't think 60 MPH is unreasonable for that boat with a nicely tuned and set-up 300 HP motor. In fact, I would expect it. |
Tohsgib |
posted 04-21-2009 01:54 PM ET (US)
That is VERY close to the boat I saw last friday. Dave twin Yamaha 350's = 700hp. |
posted 04-21-2009 01:58 PM ET (US)
A very plausible explanation for the extraordinarily large variation in top speed that is reported for this type of boat with different types of motors is there is confusion about the units of measurement. It seems much more reasonable that the results are Verado 300 = 52-MPH (not 52-knots or 59.8-MPH) E-TEC 300 = 49.5 MPH (conversion from 43-knots) At speeds in this range, a small change in propeller or engine mounting often produces 2 to 3-MPH change in speed. It is my experience that many owners are confused about the actual top speed of their boats and often report it incorrectly. For some reason the error is alway on the side of stating the speed to be greater than actual speed. The modified data I present above also is congruent with Nick's anecdotal data from a boat show interview with a dealer for a similarly rigged boat. |
Tohsgib |
PS...I had a 2800lb(boat & motor) that with 300hp did 60ish. My 4000lb(boat & motor) w/400+hp did 65ish. I could imagine this 3600lb(boat & motor) boat doing mid to maybe high 50's with 300hp but 50 is not a slouch nor unreasonable. |
Peter |
posted 04-21-2009 02:15 PM ET (US)
Apparently the 9.30S is a new product. See www.ribsforsale.com/ribeye-ribs.htm . The advertisement in the link says the following:
quote: Thus they claim 75 knots (86 MPH) with 500 HP and so a 300 HP should push it to 66 MPH. Either way that is quite fast and makes me wonder whether that isn't a typo. Perhaps they meant 75 MPH (65 knots) with 500 HP. If that is correct, then a 300 should be able to push it to 58 MPH which is what nkrith's expectation is. To get 58 MPH with a single 300 Evinrude running at 5800 RPM and a 6 percent slip, you'll need a propeller with a 21 inch pitch. The 22 inch Raker is right in the ball park for correct propellers and based on the report the motor is turning more or less the correct RPM for that propeller so you should be seeing something close to 58 MPH. That leads me to suspect that either the speed reading is off or the propeller is slipping too much. I calculate a 17 percent slip at WOT. Slip should be in the 5 percent range. What is being used to determine speed? If the speed reading is accurate, I then think you have motor height problem. What does the back of the boat look like when running at WOT, lot's of V shaped spray all over the place? Can you see the anti-ventilation plate? Is it just getting splashed a little? The Raker propeller, a bass boat propeller, is meant to be run high. |
Tohsgib |
posted 04-21-2009 02:18 PM ET (US)
PS...don't E-Tecs "loosen up" after 10-20 hours so it might fetch another couple mph? |
SJUAE |
posted 04-21-2009 02:21 PM ET (US)
I'm confused now where did the Verado 300 did 52knots data come from ? nkrith obviously has first hand knowledge with the ETEC Sounds like slight exaggerations and not optimum set-up Else The Verado info is incorrect and/or the ETEC has a fault Regards |
posted 04-21-2009 02:36 PM ET (US)
According to nkrith: "weight is 2000 kg with power and fuel" and "the Verado did 52 knots (not MPH)" This is 4,400-lbs, or about the weight of 2009 Boston Whaler 220 DAUNTLESS when loaded up for a performance test with a Verado 250-HP motor. The 220 DAUNTLESS hull is not a particularly deep vee hull. With a 250-HP Verado it reached 51.9 MPH with an 18-inch ENERTIA propeller. This is a good reference point for performance. Now we add 50-HP and 8.5-feet of boat length, hold the weight to about the same, and pick up 8-MPH. That seems like a lot. Maybe this RIB has a hull pad. |
Peter |
posted 04-21-2009 02:44 PM ET (US)
The hull has steps. The steps will enhance performance. |
Tohsgib |
posted 04-21-2009 02:47 PM ET (US)
The 250 verado makes 250hp on reg gas. The 275 verado makes 250 on Reg gas. The 300 does what on reg gas? Again does the 300 e-tec require premium fuel to make 300hp like the high HP Verados? |
TransAm |
posted 04-21-2009 03:22 PM ET (US)
If we employ the Crouch calculator, plug in 220 for a constant (I would consider a stepped-hull as a race-type hull, so 220 is probably conservative), 4,400 lbs and 300 HP we yield 57.4 MPH. Making small adjustments like taking the hull factor to just 225 and the 60 MPH barrier is achieved. All of this seems quite reasonable to me. |
posted 04-21-2009 03:48 PM ET (US)
[Thread was closed briefly while some more sidebar discussions were deleted.] |
posted 04-21-2009 03:53 PM ET (US)
Perhaps the Verado set up has just enough extra power to push the boat onto the next step of the stepped hull. This could result in a big jump in performance. I imagine that a planing hull with steps might show a non-linear response in speed to changes in horsepower. |
Peter |
posted 04-21-2009 04:18 PM ET (US)
My hunch is incorrect motor height but what is really puzzling is that the Evinrude 300 E-TEC seems to be turning the correct RPM with the 22 Raker and if the slip wasn't 17 percent but in the 5 percent range, the performance would be as expected. If this motor has a fuel flow gauge, I'd like to know what the fuel flow is at the 43 knot WOT. Fuel flow gauges provide alot of information to help diagnose what is actually going on. On a 300 E-TEC, I'd expect to see something in the 26 to 27 GPH range. |
Phil T |
posted 04-21-2009 04:32 PM ET (US)
The original author says: quote: With respect to the prop/engine/performance guru's, I strongly urge the RIB owner to contact the manufacturer to address the claims of poor performance. Sheesh. |
L H G |
posted 04-21-2009 05:14 PM ET (US)
[Changed TOPIC to begin a discussion of the discussions. We are not interested in discussing the discussions themselves. Please contact the moderator to give comments about the discussions themselves. Thank you--jimh.] [Changed topic from the discussion of this boat to an oration on how Evinrude motors are inferior. Please start a new thread to discuss this topic.--jimh] |
TransAm |
posted 04-21-2009 05:25 PM ET (US)
[Changed TOPIC to begin a discussion of the discussions. We are not interested in discussing the discussions themselves. Please contact the moderator to give comments about the discussions themselves. Thank you--jimh.] |
Tom W Clark |
posted 04-21-2009 05:38 PM ET (US)
Larry [is] blinded to the facts.
quote: That is not true. What nkirith said was the his boat could go 52 knots with a Verado 300 but only goes 43 knots with an E-TEC 300. That is not credible, though as I predicted, you are one of two people gullible enough to perhaps believe it. |
posted 04-21-2009 05:40 PM ET (US)
AGAIN, Folks, there is no interest whatsoever in including amateur psychologists analysis about these discussions. Please stick to the topic, please do not change the topic, especially to voice your opinion about the discussion itself. If you have authoritative information about the actual horsepower of particular motors, feel free to present that information, and please point to the source of it, unless you conducted the dynamometer testing personally. We can all pull numbers out of thin air, it is a game everyone can play, so what is the point. Give something credible and it will be published here. |
posted 04-21-2009 05:55 PM ET (US)
Generally when a propeller is properly matched to the motor and boat the SLIP will be under 10-percent, and in really high speed boats the slip trends even lower. A SLIP of 7-percent is reasonable. We run the numbers given by nkrith for his set up RAKER 22 RPM=5600 This propeller is the problem. Much too much SLIP. Not the correct propeller for this application. Let's re-run the numbers with a SLIP of 7-percent: RPM=5600 Now we are within a fraction of the reported performance for another boat, another motor, another propeller, another test set up, another environment, and so on, and so on. My analysis: try different propellers. Check the engine set-up. Try to find the published reports that show the actual Verado numbers so we can compare the test conditions. |
Peter |
posted 04-21-2009 07:01 PM ET (US)
I figured that Larry might like to know that I did a little more digging and was able to find emissions certification data for the Verado 300. The answer is.........[drum roll]........... 295 HP. See www.arb.ca.gov/msprog/offroad/cert/eo/2008/sime/u-w-001-0194.pdf . I was led to believe by Mercury that Mercury outboards didn't have model years but strangely the motors in that document were certified as 2008 model year motors by Mercury. They also have certification data for 2009 model year Mercury outboard motors. How can that be? ;) I'm fairly confident that if there is fuel flow data to be had, I will get it. |
Tom W Clark |
posted 04-21-2009 07:11 PM ET (US)
If the Verado is good for 295 HP and able to propel this RIB to 52 knots, then I guess we can conclude the E-TEC 300 is only good for 202 HP because it can only propel this boat to 43 knots. |
L H G |
posted 04-21-2009 09:21 PM ET (US)
I can easily accept Peter's information on 295HP for a Verado 300. Seems reasonable to me. Mercs simply put more HP in the water due to gearcase and prop design. Remember the lengthy discussion on the Bass and Walleye Boat 225 engine tests, where the Opti outran the Etec by 7 MPH top end. EVERYONE, including Evinrude promoters here, blamed the results on the inferior E-tec gearcases as compared to Mercury. I also remember a BOATING mag test where triple E-tec 250's got destroyed by same HP Opti's and Verados, even though the E-tec powered Wellcraft Scarab was the lightest boat in the test. So maybe that is what is going on with this RIB. |
Peter |
posted 04-21-2009 10:12 PM ET (US)
Larry -- The problem with your gearcase theory is that the the testing that you are referring to was a difference of 5 MPH on speeds in the 85 MPH range. Here we are talking about mid 50 MPH range with speed differences in excess of 10 MPH. You should also know, being the resident Mercury Cheerleader-in-Chief that the Verado is not equipped with the Sportmaster gearcase. Sorry, the gearcases aren't different enough and the speeds aren't high enough to explain what is going on. |
posted 04-21-2009 10:35 PM ET (US)
I think Larry just agreed with me. The difference is the propeller. There is no way the current set-up on this boat is optimized if the SLIP is 21.5 PERCENT. |
fourdfish |
posted 04-21-2009 11:15 PM ET (US)
If I remember that discussion correctly, many factors in the single test(besides the prop) could have changed the outcome and several other different tests by other magazines were cited which had different results. The Bass and Walleye Mag tests were not even close to conclusive. The results were not even outside the percentage error. |
seahorse |
posted 04-22-2009 12:44 AM ET (US)
[u]pitch 22, raker, 3-blade 5600rpm 43 knots
You might want to try a 21 or 23 Viper prop and make sure the anti-ventilation plate is about 1-2" above the keel as a starting point. The Viper props are good for top speeds but are not that economical at cruising. The Rebel prop normally works best as an all around prop with good cruise economy. Enlist the services of a trained E-TEC mechanic to make sure the motor is adjusted and rigged correctly and depending which year it is, that is has the latest software and that the anti-knock sensors are not activating for any reason. The fuel system should also be checked for restrictions and/ air bubbles in the lines. Post the serial number and complete model number of the motor so we can check for any bulletins on it. |
L H G |
posted 04-22-2009 01:21 AM ET (US)
Now I think I know why all E-tec owners are continuously looking for better props than BRP offers: to get more speed, whether it be Stilletto or most often, Mercury props. It seems that most E-tec owners here are using one of those two brands. So, yes we all agree, it's in the props, and the two engines put out identical HP. Question I have for original poster: why did you select an Evinrude over a Verado in the first place? Low price? |
nkrith |
posted 04-22-2009 04:08 AM ET (US)
I chose the E tec since as a mechanical engineer i believe in the "simplicity", low weight,and reliability of the two stroke design compared to the "complexity" of a supercharged, low engine size and highly stressed outboard. Plus i dont support complex propulsion solutions in the sea. Plus, the two stroke has much lower maintenace cost, and the maintenance it self is much simpler due to the simplicity of the design, fewer moving parts etc. Plus i wanted to say thet there is no issue on gas quality since in Europe the lowest you can get is 95 octane and the premium is 100octane. I have to agree with L H G that original BRP propellers are not as efficient as Mercury proppelers. We will work on the propellers and we are planning to try The Bravo and Hydromotive propellers- 4 blade- 22 pitch, with bow lifting characteristics since we want to lift the bow in order for the steps of the hull to work more efficiently since they are located at the back of the hull. I was wondering if the rpm can go higher than 5600 since the manufacturer states that the WOT range is 5-6000rpm. Can somebody give me the Formula for slip? |
Peter |
posted 04-22-2009 07:38 AM ET (US)
quote: Nik -- Your comments above are in line with some thinking I had yesterday about your problem. It seems that that Ribeye has an alliance with Yamaha and based on the description I read about the boat, it seems to have been designed to have something between 800+ lbs (single F350) and 1200+ lbs (twin F250s) and possibly as much as 1600+ lbs (twin F350s) on the transom bracket. A 30 inch shaft length (assume that is what you have) Evinrude E-TEC 300 weighs only 530 lbs so its pretty far outside the design expectations for weight on the transom bracket if my assumptions are correct. If there is not enough weight on the transom bracket, then the boat could be riding bow heavy and not taking advantage of the steps because the bow is plowing water. I don't think there will be any propeller that can provide bow lift to overcome that. The performance of a stepped hull with steps located near the aft part of the boat might be very sensitive to weight distribution. To connect this to Whalers, in the late 1990s, Whaler had a 23 Conquest model that was clearly designed for twin outboard motors weighing approximately 425 lbs each. So their design expectation was a total of 850 lbs on the transom. Sometimes the boat was rigged with a single outboard to save costs and when so rigged, the factory installed a lead ballast kit in the bilge at the transom to make up for the expected weight of the missing companion outboard. I am wondering whether your boat needs something similar to correct a weight imbalance. So in addition to experimenting with propellers and motor height, I suggest that you might consider also adding about 300 lbs of weight on or near the transom bracket to see if that helps balance the boat. It may be that when using E-TECs on that boat, it would be better to run twins to provide more weight. It seems strange to be recommending more weight because weight normally adversely affects performance but if the balance of the boat is off because there is not enough weight on the transom bracket, that might be a solution. Regarding slip, use the calculator at http://www.continuouswave.com/cgi-bin/propcalc.pl and plug in all the numbers you have except slip and it will calculate slip. |
posted 04-22-2009 08:47 AM ET (US)
In the PROPELLER CALCULATOR (see link above) there is explanatory material that derives all the calculations. |
SJUAE |
posted 04-22-2009 10:20 AM ET (US)
LGH
quote: I think you are on the right track but for different reasons. I't's not so much there something wrong with BRP props it's just the lack or wealth of prop data available here compared to Mercury set-ups. I'm happy with my 200HO ETEC but when your dealer is not part of the prop programme or does not have a selection of props to try, at 550USD a go it's not cheap. (FYI outside US your rigging is included with the engine.) On my 210 with T-top 2 people and full fuel, cav plate just above waterline, I have tried 19" Viper and get 5200 and 42mph After reading many other posts I have concluded on our heavier Whalers and with the newer post classics with slightly deeper V hulls The 19 Viper, 17 Rebel and a 15 Cyclone are likely to give similar results in terms of speed and RPM's, but different handling, cruise and lower speed planning Only going up or down 2" with the same prop is likely to increase rpm's by +/- 200-300 This is why the prop calc is a good indication but not the same as actual test results. I have not considered the Raker as it's more for a bass boat or the Stilletto or other Mercury props as there is even less reference data for ETEC/Whaler set-ups. My third attempt and final 550 is on a Rebel 15 to give both higher rpm's and economical cruising or a 17" Viper over my 19" Viper to increase RPM's Regards |
Buckda |
posted 04-22-2009 10:35 AM ET (US)
Why are you paying $550 for each prop that you try? If your dealer won't let you experiment with props in the shop, you can go online to E-Bay or some other site and buy them for about half cost - meaning you can try twice the # of prop combinations. I find it a testament to "how good" we have it here in the states that most dealers will loan you a prop (perhaps with a strong deposit) to try until you find the correct one for your application and purchase it from them. |
Peter |
posted 04-22-2009 10:40 AM ET (US)
Unless you are running WOT all the time, I would go with a 15 Rebel. "when your dealer is not part of the prop programme" I get a laugh out of that because the Mercury Test Prop program is no better, at least in my experience. Several years ago Mercury's website showed the major local Mercury dealer as a participant in their test prop program. So I went down to the dealer looking to try some 17 inch Mirage Plus and then some 17 inch Rev 4 propellers on my 27 Whaler WD. When I spoke to the parts guy and explained to him that I was here to pick up some test props under the test prop program he laughed. When he stopped laughing he explained that the the dealer's test prop program consisted of me buying whatever propellers I wanted to try out at full MSRP and then if I didn't like them I could return them and they would give me my money back less a 20 percent restocking fee provided that the propellers were not damaged. I said, thanks but no thanks. |
L H G |
posted 04-22-2009 10:44 AM ET (US)
If you have a high performance stepped hull, you definitely want a Mercury Bravo I 4-bladed prop. They are highly recommended for those hulls, and almost every stepped hull I have seen with twin/triple big Opti's and Verados are running those. See Mercurymarine.com for detailed prop application descriptions, and you will see Bravo I's for stepped hulls. But they are high speed props, as indicated by the minimum available pitch at 22", all the way up to 30", and you need serious HP-to-weight ratios to turn them. A BRP Raker prop is similar to a Merc Laser II, which would be one of the worst applications for a hull like yours. But I'm still sticking with my first observation, and your observation, that a 300 Evinrude won't run with a 300XS Opti or Verado. I boat all winter in the land of HIGH PERFORMANCE outboard rigs, (SE Florida, Palm Beach to Miami)), and I don't see THESE boats (Fountains, SeeVee, Midnight Express, Donzi, etc) with twin and trip E-tecs. They are not considered a high performance engine. Mostly we see the big XS Opti's and Verados, plus a few Yamahas (F250's and F350's). You might also take your issue to screamandfly.com, a high performance, mostly 2-stroke, boating site, based in SE FL. They know their high performance outboards over there. Mercury people predominate, but there is an Evinrude contingent also. |
fourdfish |
posted 04-22-2009 12:11 PM ET (US)
Personnel observations from one small area in the entire US are not a valid example of the world or country as a whole. I boat and fish in FL all winter also and I have different observations than Larry. The state of Florida and the nation are obviously large areas. The scream and fly web site is right up Larrys ally! Good for sales! |
andygere |
posted 04-22-2009 12:36 PM ET (US)
quote: I had the same experience with all of the Mercury dealers in my area (a large boating region at that) when I re-rigged my Outrage. I had an excellent experience with the ContinuousWave Test Prop Program which was instrumental in providing me with a very good selection of props to test, and ultimately the purchase of the best performing of them at a great price. This is a rather interesting thread, and I have no doubt that nkrith is legit, but the numbers don't seem to add up. One simple and often overlooked problem may be the accuracy of the speed data. Variables such as wind, current, air temperature, GPS satellite reception, etc. may all play a part in the unusual data presented here. In addition, set up, rigging and correct operating performance of the new motor may be at play. For example, when I rigged my E-TEC 200 using a third-party throttle control, the Evinrude tech that commissioned it discovered that I was not reaching the full span of the throttle actuator on the outboard due to interference with the throttle lever on the binnacle control. Had this problem not been discovered, it would have been impossible to correctly prop the motor. |
andygere |
posted 04-22-2009 12:40 PM ET (US)
Final thought: One big difference between RIBs and our rigid Boston Whaler hulls is that there is an additional variable on the RIBs: inflation of the tubes. It would seem reasonable to assume that under-inflated tubes could allow more hull flex than properly inflated tubes. Since hull flex consumes power, it is conceivable that the hull tubes were not inflated to the same pressure when the tests were conducted with the different outboards, contributing to the disparity in boat performance. |
Peter |
posted 04-22-2009 01:37 PM ET (US)
quote: Looking at fuel flow rate and RPM at WOT would help spot that problem. That's why when have what appears to be numbers that don't make sense I always ask for fuel flow rate. |
posted 04-22-2009 02:03 PM ET (US)
There is no doubt that Mercury probably makes a propeller that will be a good fit in this case--they make 1,500 different propellers, so the odds are in their favor. Mercury also make their propellers with a generic hub that can be fitted to almost any outboard, so this again increases the likelihood you will see a Mercury propeller on a motor of a different brand. But I don't see anything intrinsic in a Mercury propeller that will make it better than other brands. In many cases there are (essentially) identical propeller sold by competitor brands, and, as you might expect, propellers that are identical tend to work identically, or even better. If the E-TEC 300 has the I-Command instrumentation, you can see the percentage of throttle position. If I recall this is displayed as LOAD. Check the documentation for more details. This will resolve any question of throttle opening. On my boat the throttle rigging showed 97-percent of throttle, which is considered within the tolerance for "wide-open." As for suggestions that this discussion be moved elsewhere, I think GOOGLE already informed us where the real information is to be found: here. If you want goofy graphic and NASCAR fans, seek alternatives. |
posted 04-22-2009 02:05 PM ET (US)
LHG writes: "A BRP Raker prop is similar to a Merc Laser II, which would be one of the worst applications for a hull like yours." I agree. The RAKER or LASER II are not for 4,400-lbs of boat. |
andygere |
posted 04-22-2009 02:29 PM ET (US)
In my case, the Evinrude tech sea-trialed the boat while it was on-line with the diagnostics software on his laptop computer. The software indicated that the throttle position had not reached the specification for WOT. I have the first generation of I-Command gauges, and to my knowledge they do not display LOAD. That is a nice improvement on the newer gauges. |
SJUAE |
posted 04-22-2009 04:37 PM ET (US)
Buckda You would be surprised how accommodating my dealer is here in the UAE I agree they may not have the best technicians in the world but at 10USD an hour I don't care if they spend all week working on my boat/engine, but usually it's just a few hours and a probably a 20th of what it may cost you. I do have to keep an eye on them and a few have recently been on training courses in Europe at last When I first fitted my engine we had a overheat alarm fault we could not resolve so after 5 hours running he just put another new engine on for me. We later found that a software update would cure it, once they got the update cable. Also they took my unused Cyclone back in to stock but they won't do this every time for me. They would gladly let me use any prop they have and even take one of another boat to try but virtually every engine here with the same shaft size comes with a free 19 Viper, controls, gauges etc as standard they just don't carry any spares at different sizes. I can't order off EBay as usually they don't ship internationally or want to charge 200USD for FedEx to deliver, so it ends back to the same price. Regards |
Perry |
posted 04-22-2009 05:35 PM ET (US)
quote: Isn't Mercury the only company making propellers out X7 alloy? The Enertia I run is the best overall performing propeller I have tried and I have experimented with almost a dozen of them. The light weight material is very strong and allows for thin blades. |
Tom W Clark |
posted 04-22-2009 05:49 PM ET (US)
Uh, fellas? This prop talk is great but the fact remains we are (academically, it seems) discussing a performance difference of over 10 MPH from motors of the same horsepower. There is no way on Earth that can be explained away with just a propeller. As to propeller recommendations for nkrith, I counsel him to mostly disregard the specific recommendations provided above as they amount to not much more regurgitated ad copy. None of us here have experience with large high speed inflatables, that is not the point of CW. I do encourage nkrtih to experiment with any prop he can lay his hands on. He may be very surprised as to what prop really works best and it may be that it turns out to be one of the models already mentioned. As to who makes the best propellers, they all make great props. Mercury makes more different kinds of propellers than almost anybody else, except PowerTech who makes props as good or better than anybody's. However, the number of propeller models offered from a manufacturer in no way suggests they offer the propeller that is best for nkrith's boat. |
SJUAE |
posted 04-22-2009 06:22 PM ET (US)
Tom Appolls for going slightly off topic Have we actually got to the source of nkrith claims for the Verado 300 did 52 knots (Not intended for Merc vs Etec bashing) Else we will look a bit silly on a +90 thread on pure hearsay Regards |
posted 04-22-2009 07:54 PM ET (US)
Only a tiny percentage of the propellers made by Mercury use the stainless steel alloy which Mercury calls "X7" as a trade name. If a propeller made of that alloy works well for a particular boat, I don't see how it engenders propellers from Mercury that are not made out of that alloy with special properties. The alloy of stainless steel used by Mercury in a small percentage of their propellers and called "X7" as a trade name is not protected by patent, as far as I know. In 2005 Mercury said the alloy was "patent-pending," but a search around that time found no patents issued. If it does come under the protection of a patent, Mercury will have to reveal the formulation or process. For all we know at the moment, "X7" could be the alloy used in BRP propellers! |
Perry |
posted 04-23-2009 03:36 AM ET (US)
quote: Pick up a BRP prop and pick up an Enertia. You will know which one is made of X7. |
posted 04-23-2009 05:47 AM ET (US)
Perry--What will be the basis for discriminating between them? |
Tom W Clark |
posted 04-23-2009 09:39 AM ET (US)
Weight. |
nkrith |
posted 04-23-2009 11:12 AM ET (US)
Just to let you know, i am planning to test Bravo 1 pitch 22 and 24 by the end of this week and i am very curious to see the results. Hopefully if i alter the engine height position (it is a 30 inch shaft) we will get closer to the expected performance. Even if Evinrude claims that you have the full potential from the very beginning i believe that after say 20 hours i am going to get the maximum from the motor. |
Tohsgib |
posted 04-23-2009 11:13 AM ET (US)
That has been the norm from what I hear. How much you gain is minimal but 100rpms could mean 3mph. |
Perry |
posted 04-23-2009 12:26 PM ET (US)
Is the ETEC programed to inject a higher concentration of 2 stroke oil into the crankcase during the first 20 hours of operation which would reduce performance? |
nkrith |
posted 04-23-2009 12:39 PM ET (US)
That is only for the first 5 hours |
L H G |
posted 04-23-2009 07:01 PM ET (US)
OK, so far, the Evinrude armchair experts have not yet been able to figure out why the 300 E-tec is 10 MPH slower, on the same boat, than the 300 Verado. The following have been suggested, and all eliminated by this group: 1. As the threrad initiator claims, the Verado is simply a lot more powerful, but it is impossible for it to be THAT much more powerful. 2. the Verado has a better high speed gearcase design. 3. the Verado was running an appropriate Mercury propeller, while the Evinrude was running an unappropriate BRP Raker prop. Although the props could make some difference, and it has been speculated that Merc props might be better, but not THAT much better to result in 10 MPH difference. 4. The Verado was set up more professionally for speed, and the Evinrude was poorly rigged on the boat. Once again, not enough to account for 10 MPH difference, and we have no evidence to suggest that the Evinrude is poorly rigged. But what if each one of these conditions accounted for 2-3 MPH difference. The sum total could be 10 MPH, maybe. The final, and seemingly only answer, if all of the Evinrude group's discounting of items 1-4 is true, is that this brand new engine is defective, or a lemon. [Dredges up some obscure boat test conducted with different boats, different motors, different propellers, at different times, in different places, and presents this as evidence. The first time this was discussed it was dismissed as not indicative of much except the price of the boats. So out it goes here--jimh] So I guess the E-tec needs to go back to the Dealer for a checkup. |
Peter |
posted 04-23-2009 07:07 PM ET (US)
Getting any bites elsewhere? |
seahorse |
posted 04-23-2009 08:13 PM ET (US)
Perry posted: Is the ETEC programed to inject a higher concentration of 2 stroke oil into the crankcase during the first 20 hours of operation ...?
fourdfish |
posted 04-23-2009 09:02 PM ET (US)
Now that Larry was one of your all around top commercials! Mostly all YOUR opinion with sweeping generalizations. None of which you can prove! This is just another one of your E-TEC thread hyjacking. It would seem that you will forever come in on these threads to sell Mercury engines. |
posted 04-23-2009 09:05 PM ET (US)
LHG writes: "The Verado was set up more professionally..." Actually, nothing at all is known about the Verado boat, nothing at all. |
L H G |
posted 04-23-2009 09:30 PM ET (US)
I'm just trying to help you all summarize the possible reasons here, that is all, on what has been SPECUALATED as to why there MUST be some reason why NKRITH believes his engine is performing 10 MPH slower than the same boat with a Verado. If anybody has any other possible suggestions, let's hear YOUR speculation also. As for now, we seem to be out of answers to explain the situation. Of course we know nothing about the Verado rig, what prop it was running, how is was set up, and even if it might have been a 350 Racing Division Verado in a phony cowling showing 300! The IMMEDIATE reaction of the this board, and probably a reasonable idea, is that there MUST have been differences, as I noted above, to produce the poor results on this persons RIB with the 300 E-tec. I summarized what the responders here think COULD be the differences, but nothing yet seems to explain it. That's why I concluded the engine must be defective and need work. |
fourdfish |
posted 04-23-2009 10:17 PM ET (US)
Why would the engine have to be defective? Just because this guy does not think it is pushes his boat fast enough? He did not say he had a Verado before and replaced it with a E-TEC! This just a chance for Larry to speculate with his opinions! Just fodder for a Larry perpetual Merc commercial and E-TEC bashing! As Tom so clearly put it: "This guy said his boat COULD go 52 knots with the Verado but only goes 43 knots with the E-TEC" "That is not credible" That says it all! The proof is in the pudding! |
L H G |
posted 04-23-2009 10:39 PM ET (US)
Fourdfish: Tom Clark said: "fourdfish -- Please take your exclamation points and go away. " nkrith said: "The same boat powered by a 300 Verado just goes so much faster through the whole rev range. " "the verado 300 did 52knots (not mph)" Now I'm not asking you to go away like Tom did, just to get your facts straight when you are quoting someone. I might ask you to quit stalking me, however. After all, it's only a Canadian outboard. Like any engine, they too can have problems. Don't take E-tecs so personally. So nkrith reports the Verado goes faster, for whatever reason, who cares. Look at all the trashing Mercury's get around here. |
fourdfish |
posted 04-23-2009 10:54 PM ET (US)
As said before, every time you express your opinions as fact, I will be there to call you on it. As for the E-TEC I have one but could give a s..t if anyone else buys one. I am not makeing a sales pitch that one should buy one because it is better. Only that I like it and don't appreciate so one lying about it. As for Tom!!!!! Oh well!!! |
posted 04-23-2009 11:25 PM ET (US)
Re the horsepower of an E-TEC 300, we have: --certified testing results for EPA = 296-Hp --seat of pants judgement by nkrith = 240-HP --analysis of data by comparison with Crouch's formula = 205-HP Everyone is welcome to believe what they like. All the people who think the reason the boat goes slower is because the E-TEC only makes 205-HP are people who would never buy an E-TEC in a million years, anyway, and they just want to stir the pot. They really are smarter than they are pretending to be, because they know there is no way an E-TEC 300 only has 205-HP, no matter what the anecdotal data might say. The people who think the E-TEC 300 has 296-HP are a bunch of government engineers and technicians who tested the motor on a dynamometer to make sure it met the emission guidelines. The lower they can rate the horsepower the better for them, because emission levels are based on horsepower. The EPA won't give the motor any extra horsepower it doesn't have. To do so would be to undermine their emission standard. The EPA is probably the toughest critic of horsepower. Curiously, they are the only ones to actually test the horsepower, and they find the highest rating. Our originator, nkrith, is disappointed the initial rigging of his boat didn't work out better. He's going to work with some different propellers. But he thinks the motor only has 240-HP because his boat does not go as fast as he expected it to go. Everyone is welcome to line up behind any camp. After you get in line, look around and see who else in the line with you. |
L H G |
posted 04-23-2009 11:50 PM ET (US)
Jim, we are both in complete agreement, as I said in my Point #1. Horsepower is not the issue. Peter has shown us that both engines have 295HP when running properly. Perhaps nkrith made a mistake by expecting his 300 E-tec to go as fast as a 300 Verado, but I don't think that's a mistake. Based on these identical HP ratings, anyone would make the same assumption, and from what I can tell, HP is HP and should give approximately the same speed. So we are still looking for some other variable. |
posted 04-23-2009 11:57 PM ET (US)
Larry--What do you make of the 30-inch shaft set-up? At first I thought it might be too long. However, considering the size of the boat (over 30-feet), that it is a single, that it has a set back bracket, and that the hull is probably a vee-hull with more deadrise than a classic Whaler, perhaps a 30-inch shaft is about right. |
Tom W Clark |
posted 04-24-2009 12:06 AM ET (US)
I think Jim deserves some additional financial support in running ContinuousWave. To that end I suggest that Jim implement an exclamation point fee: Use an exclamation point, pay Jim $10. That ought to nicely allow folks the use of as many exclamation points as they can afford but I suspect it will, in fact, reign in the gross over use of an otherwise perfectly decent punctuation mark whose value has been sadly diluted by absurd overuse in recent years. It might also have the added benefit of driving fourdfish away, something Larry and I *can* agree on. |
nkrith |
posted 04-24-2009 02:32 AM ET (US)
Gentlemen, lets just wait for the results with a different engine mount and different proppeler pitch before we make more assumptions. |
TransAm |
posted 04-24-2009 07:47 AM ET (US)
What is troubling about this particular scenario is that none of the existing data makes any sense, yet none of the usual areas (set-up, prop, etc.) that may offer some explanation of reduced performance make for a reasonable argument given the huge disparity in speed. The reported data on the E-tec all seems reasonable, except for speed. There is no way a 205 HP motor (and probably a 240 HP motor) could properly turn a 22P propeller 5,600 RPM. A 22P propeller seems like a reasonable choice for this boat, at least in terms of pitch, and 5,600 RPM is within the acceptable WOT operating range. And 57 MPH is certainly a reasonable expectation for a 4,400 lb boat with a performance hull and 300 HP on the transom. We don't know anything specific about the Verado data other than a representation of somewhere around 60 MPH, which also seems reasonable with an appropriate set-up. This gentleman seems to have been on the water a time or 2, so it would seem he know the difference between 50 MPH and 60 MPH, or even 57 MPH for that matter just by "feel". For me, there is a obvious difference between the two. Perhaps the difference is not so obvious in a 30' boat though, kinda like driving down the road in a BMW doing 100 MPH and a Toyota Prius doing 100 MPH (if it could). Traveling at the same speed would feel much different in these 2 cars. I would be looking at the instrumentation used to compute speed in both of these circumstances. Was it the same GPS unit? Or was it the factory supplied pressure speedos. Alternatively, perhaps the Tach on the E-tech was not calibrated properly. But looking at the set-up to get 20% more power does not seem reasonable. I think the error is in the data being represented on the E-tec.
fourdfish |
posted 04-24-2009 10:58 AM ET (US)
SJUAE |
posted 04-24-2009 03:26 PM ET (US)
As nkrith has still not offered any explanation on the source data/results for the Verado My guess: 1) nkrith thought the lighter 300 ETEC would give a similar top end to the 350 Yamaha that is listed with the Ribeye 930S UK price list. or 2)His dealer thought that the minimum spec 250HP extrapolated with a 300HP ETEC should give similar top end to a 350HP Yamaha/Verado. This would explain the disappointment IMO Else As we have already noted Regards |
Peter |
posted 04-24-2009 07:16 PM ET (US)
"Gentlemen, lets just wait for the results with a different engine mount and different proppeler pitch before we make more assumptions." I agree. When you report your results, if you have the means to report fuel flow at WOT, please include that. |
posted 04-26-2009 11:30 AM ET (US)
This is a good point to close off this initial discussion, now run on to over 100 replies. Please resume the discussion by initiating a new thread when the results of further testing are available.
