ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Outrage 25 Re-power with SUZUKI 300
Author | Topic: Outrage 25 Re-power with SUZUKI 300 |
crow |
posted 06-12-2009 01:10 AM ET (US)
I have finally purchased an Outrage 25 after a year or so of looking. The boat is a 1985 with a notched transom and no t-top. I am repowering it this week with a Suzuki 300-HP. I was hoping someone might have some prop suggestions. I am also looking for suggestions on how high to mount the motor. I'm sure the dealer will make some recommendations, but I want to get some other knowledgable opinions. Thanks, Jamie |
Tom W Clark |
posted 06-12-2009 01:16 AM ET (US)
Jamie, I look forward to hearing how the Suzuki DF300 performs on your 25 foot Whaler. You will probably want to use either the 16" x 18-1/2" Suzuki three blade stainless steel propeller (part # 99105-08800-185) or the 16" x 20" (part # 99105-00800-20P) I recommend you start with the motor mounted two holes up. |
crow |
posted 06-12-2009 02:21 AM ET (US)
Thanks for your help Tom. I will definately tell the dealer to follow your suggestions. I plan on launching the boat within the next 7-10 days. I'll report performance numbers as soon as the engine is broken in. Right now I'm busy frantically ordering new cushions from Halls, a new leaning post from Birdsall, new decals from Magic Brush, front console rod holders, GPS, radio, ect. I think the Suzuki 300 will be a great match for the Outrage 25. |
NewportMe |
posted 06-12-2009 09:30 AM ET (US)
Crow I can't wait to hear your performance numbers. I have an outrage 22" whaler drive and I believe that our performance will be close. I am currently running an 1989 Evinrude 225 and am considering a Suzuki 300 for repower. Bruce |
John from Madison CT |
posted 06-12-2009 10:15 AM ET (US)
I think you'll be able to go up to near 21" pitch. I remember my 22' Outrage w/WD and a 250hp Yamaha was perfectly matched with a 15.25"x19" pitch prop. |
Tohsgib |
posted 06-15-2009 06:57 PM ET (US)
300 Zuki has a 2.08:1 ratio and redline is 5700-6300. You will ant it closer to 6300 and Suzukis like to be mounted high on the transom. Props available are 17-27.5 in pitch so the 18.5 might be a good choice to get 6K+. |
crow |
posted 06-15-2009 08:31 PM ET (US)
I currently have a Honda 150 on my Outrage 20. As I've said in the past, I've really enjoyed this engine. It has performed flawlessly. I wanted to repower my Outrage 25 with another Honda but felt that the Honda BF225 would not provide enough power. (I definately want to repower with a single engine). The Honda dealer that services my current boat just threw a curve into my plans. He informed me that Honda will be coming out with an "amazing" new motor in the 250hp+ range "fairly soon". (With in the next year?) I'm somewhat torn right now. Do I run my 'new' boat his summer with it's current set up (twin 2000 Yamaha 115 fourstrokes) and repower with a Honda next year, or do I repower now with a Suzuki DF300? Unfortunately my Honda service rep, who has been a pleasure to deal with, doesn't sell Suzuki. I'm not really 'sold' on the Suzuki dealerships in my area. |
Tohsgib |
posted 06-16-2009 10:12 AM ET (US)
I would think that 250hp would not be enough as well. I also think that the $$ difference between the Suzuki and Honda will be pretty good. I also KNOW you will be happy with the Suzuki as I have owned many, plus a 6 year warranty will guarantee it. |
Tom W Clark |
posted 06-16-2009 12:22 PM ET (US)
250 HP is just fine on that hull. If Honda is coming out with a 250, I am sure it will be a very nice 250 but I doubt it will be significantly better than anybody else's 250. * If * it shows up a year from now, you will be buying the first year of a new model. I would not bank on anybody's speculative schedule of new product introduction in this economy. It could be longer. On the other hand, if you wait to repower (with whatever motor) you will come to appreciate how much better the new 250 HP or 300 HP single is compared to the weight of the twin four strokes you have now. On yet another hand, the twin four strokes you have now have greater resale value today than they will in a year to two...or three or... |
Tohsgib |
posted 06-16-2009 12:30 PM ET (US)
You are correct Tom. I was going by the fact he posted that 225 would not be enough and I guess he is unsatisfied with the 230hp he has now. Therefore I assumed that 250 would not be enough as well. I agree on the whole first year thing as well. Down here you can get new 300's for dirt cheap. |
crow |
posted 06-17-2009 07:23 PM ET (US)
I went to the Suzuki shop today and ended up going with the Suzuki DF300. I will probably start out with the 18 1/2" prop. The boat is scheduled to go in the water a week from Friday. I'll post performance numbers shortly following. Thanks for your advice. |
Tohsgib |
posted 06-17-2009 07:30 PM ET (US)
You won't regret it. |
grizzly |
posted 06-17-2009 10:11 PM ET (US)
Thoughts on a single Yamaha 350 HP V-8 for this application? |
GTL |
posted 06-17-2009 10:54 PM ET (US)
I have a 1990 OUTRAGE 22 with Whaler Drive. I have a 300-HP Suzuki mounted two holes up; I just had the dealer move it up one hole last winter. The dealer initially tried a 16 x 23 pitch three-blade but dropped to a 16 x 21.5 three-blade. Last year I was getting around 5,600-RPM and running around 50-MPH. This year for a quick moment I saw 5,800-RPM and again around 50-MPH on the Garmin. I just haven't had the time to really run the boat hard. My wife doesn't like the bouncing, and when I get out, I'm more interested in fishing than making speed runs. My hull is approximately 1,000-lbs lighter and four inches narrower than a 25-foot hull, but has the Whaler Drive. I've found that the 21.5-pitch seems to work fine. I had the dealer raise the motor since I didn't see a big trim range where the trim helped. [The help from trim] seems to have improved some since raising the motor. Still not happy with the trimming, but need to spend time working with the boat to see if raising really helped. If my wife doesn't go, the grandson does, so not much time for performance testing All I can say is that the Suzuki 300-HP is perfect. [The motor is quiet] and very easy on fuel. I see the Suzuki gauge say 7.8-GPH when running 35-MPH. I never really check the gauge verses gallons used per distance. I need to do some investigation, but right now just enjoying the boat. I will be interested in which prop you end up with and the performance it produces. |
crow |
posted 06-17-2009 10:55 PM ET (US)
I think its sheer size would make [the Yamaha 350-HP V8] impractical [on a Boston Whaler OUTRAGE 25]. |
posted 06-18-2009 08:53 AM ET (US)
If a Suzuki 300-HP engine has a fuel flow of 7.8-GPH when pushing an OUTRAGE 22 Whaler Drive to 35-MPH, its fuel economy is 4.5-MPG. That is astonishingly good fuel economy. If we figure that the OUTRAGE 22 Whaler Drive goes 50-MPH with 300-HP, we can estimate the horsepower needed to go 35-MPH from the relationship that boat speed change is generally proportional to the square-root of horsepower change. 35/50 = (HP/300)^0.5 HP = 300 x (35/50)^2 HP = 147 With 147-HP and a fuel flow of 7.8-GPH, we can figure the brake specific fuel consumption of the the motor: BSFC = 7.8-gallons/1-hour x 6.25-lbs/1-gallon x 1/147-HP BSFC = 0.33 lbs/HP-hour A brake specific fuel consumption of only 0.33-lbs/HP-hour is astonishingly low for a gasoline four-cycle engine. Normally the only engines that can reach this sort of efficiency are very large marine diesel engines of many thousand horsepower, seen only in the largest of ships, or in direct-injection diesel engines such as the amazing TDI from Volkswagen. A typical value of BSFC for a gasoline engine is closer to 0.5-lbs/HP-hour. One source notes: "An excellent BSFC for a well-developed, naturally-aspirated, high-performance liquid-cooled engine at 100% power is in the neighborhood of 0.44 – 0.45. Claims of gasoline engine BSFC values less than 0.42 at max power tend to be suspect. At reduced power settings (in the region of 70% and below) BSFC values of 0.38 have been achieved, but they are not commonplace." http://www.epi-eng.com/piston_engine_technology/thermal_efficiency.htm |
Peter |
posted 06-18-2009 09:52 AM ET (US)
I think I would have the calibration on that Suzuki gauge checked. Suzuki's test reports show for two boats that are capable of 50 (+/- 1) MPH top speed that the DF 300 is consuming between 11.3 and 12.8 GPH at 36 MPH. In both cases the motor is turning 4500 RPM twisting an 18.5 inch pitch propeller. WOT fuel consumption for the DF300 is about 25 GPH. Assuming it produces 300 HP, then the BSFC is 25-gallons/1-hour x 6.25-lbs/1-gallon x 1/300-HP or 0.53 lbs/HP-hour If the boat requires 150 HP to move along at 35 MPH, then fuel consumption is estimated to be 150 x 0.53 lbs/hp-hour x 6.25 lbs/1-gallon = 12.7 GPH. This number seems to be in line with what Suzuki is reporting for boats capable of approximately 50 MPH at WOT when powered by the DF300. |
Peter |
posted 06-18-2009 09:53 AM ET (US)
Sorry, the formula should be 150 HP x 0.53 lbs/hp-hour / 6.25 lbs/1-gallon = 12.7 GPH |
Tohsgib |
posted 06-18-2009 10:49 AM ET (US)
GTL...if redline is 5700-6300 why does your dealer want you at 5500? |
Tom W Clark |
posted 06-18-2009 10:57 AM ET (US)
Jamie, Based on on GTL's performance report, I am going out on a limb and recommending you start with the 16" x 20" propeller. Though the Outrage 22 Whaler Drive is not the same as an Outrage 25, prior performance reports of the 22 WD and the 25 seem to suggest that the 25 is at least as fast, if not faster, than the 22 WD. If we assume your boat will be capable of 50 MPH and that the Suzuki three blade prop will yield propeller slip of about 12 percent, then the 20" pitch should allow the boat to reach that speed with the engine in the upper end of its WOT range of 5700-6300 RPM. The 18-1/2" pitch would be too short. |
L H G |
posted 06-18-2009 04:29 PM ET (US)
Here is Mercury's testing on the 300 Suzuki, on a boat that does just a little over 50. It shows 3.7 MPG. |
posted 06-18-2009 08:12 PM ET (US)
The Mercury data shows 3.7-MPG at 22.1-MPH for the Suzuki, which is claimed to be its "optimal" speed. The fuel flow is thus 1-gallon/3.7-miles x 22.1-miles/1-hour = 5.97-GPH The 300-HP Suzuki pushed the test boat to 51.2-MPH. We compute the horsepower at 22.1-MPH HP = 300 x (22.1/51.2)^2 BSFC = 5.97=gallon/1-hour x 6.25-lbs/1-gallon x 1/55.9-HP Not surprisingly, the Mercury test data shows the Suzuki motor to have about double the BSFC as we have computed from the data given above by GTL. I say not surprisingly because you would expect nothing less in a manufacturer sponsored comparison. The test data for the competitor's engine would probably be cooked to show the worst possible outcome. We have two extremes of data: a first-hand report from an owner which shows amazingly good fuel economy; a manufacturer's test report from a competitor which show amazingly bad fuel economy. Personally I think both data points are flawed. The owner is probably too optimistic. Mercury is disingenuous and has misled us by choosing a particularly bad point for the Suzuki. I don't think the optimum fuel economy for the same boat can occur at 22-MPH for the Suzuki and then at 27-MPH for the Mercury. I suspect that Mercury has cooked the books on this one. I would be more inclined to accept data that showed the Suzuki 300 had a BSFC of around 0.45-lbs/HP-hour. |
towboater |
posted 06-18-2009 09:22 PM ET (US)
Congrats Jamie, you are in good hands. 2500 miles closer, your 20 would be sold. mk |
crow |
posted 06-18-2009 10:13 PM ET (US)
Thanks Mike. Good luck with your search. |
crow |
posted 07-07-2009 01:02 PM ET (US)
I briefly ran the boat last evening for the first time. It was just an awsome ride! I'll be posting performance #s and info within the next week or so. I need to figure out the electronic gauge/fuel system on the boat and also make sure its calibrated correctly. Right now I'm considering switching the current 16" x 20" Suzuki prop to a 16" x 18-1/2". I ran the boat 3 different times @ WOT for 30 second intervals. I was by myself with 85 gallons of gas. There was a light wind and light chop. First run: 5450 RPM and 47 MPH on GPS trimmed up Second run, going in the same direction: 5500 RPM and 48 MPH on GPS trimmed up. Based on everyone's replys, I think that the 16" x 18 1-2" prop will get the engine to its redline 5700-6300 RPM. Let me know what you guys think. |
Tohsgib |
posted 07-07-2009 01:43 PM ET (US)
Yes I believe it will. |
crow |
posted 07-07-2009 02:10 PM ET (US)
Tohshib, I believe it will too. I guess what I'm trying to decide is whether I should switch it now or wait until I've run the engine for more than 45 minutes. |
Tohsgib |
posted 07-07-2009 02:22 PM ET (US)
Well I hope you read your owners manual. Not supposed to run more than idle for first 15 mins. Next hour & 45 is 3k max. Next hour is 4k max. Next 7 hours is ok to run but only short bursts. |
crow |
posted 07-07-2009 05:23 PM ET (US)
Thanks for the heads up. The boat was run by the shop before me, and I have followed their instructions for the break-in so far. Will definately be aware of my operating speeds though. |
Perry |
posted 07-09-2009 01:12 AM ET (US)
Crow, I'm not sure what you mean by "redline" but your motor's operating range at WOT is 5700 to 6300 RPM. This means you should be between these RPM at WOT. If you are currently running at 5500 RPM at WOT, you are overpropped and I would drop down to the 18 1/2" pitch prop. |
Tohsgib |
posted 07-09-2009 11:41 AM ET (US)
What is your mounting height? Suzukis like to be mounted real high. |
crow |
posted 07-14-2009 11:31 AM ET (US)
I did request that they mount the engine two holes up. I'll be checking to see if they did. |
zx29b |
posted 08-21-2011 07:52 PM ET (US)
[Revived this thread two years later and changed its topic.] |
Tom W Clark |
posted 08-23-2011 11:44 AM ET (US)
I suggest you start a new thread rather than resurrecting someone else's two year old discussion and dragging it off course. |
