ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance OUTRAGE 25 Whaler Drive: Using Verado 225-HP Motors
Author | Topic: OUTRAGE 25 Whaler Drive: Using Verado 225-HP Motors |
cnorred |
posted 06-26-2009 10:17 AM ET (US)
I have a [1988--please use four-digits for years] Outrage 25 with Whaler Drive powered by [1988] 200-HP Evinrude engines. I would like to re-power with 2008 Mercury VERADO 225-HP motors. If anyone has done this, please send some comments. Thanks |
TransAm |
posted 06-26-2009 10:25 AM ET (US)
cnorred, I would be curious to see how your set-up handles 1,300 lbs of motor on the Whalerdrive, especially if it is not a cuddy model. Your current motors probably weigh 450+/- each now. Picture another 400 lbs on the Whalerdrive and that's what you would have weight-wise. Personally, I think it would be too much weight. |
posted 06-26-2009 10:32 AM ET (US)
Let's not limit the comments to only those who have repowered an OUTRAGE 25 Whaler Drive with twin Verado 225-HP motors. I think that would limit comments to an extremely low number of potential respondents. |
posted 06-26-2009 10:37 AM ET (US)
The duplicate article posted to another discussion on a different topic has been deleted. Please do not post your articles to multiple topics. |
cnorred |
posted 06-26-2009 10:50 AM ET (US)
Thanks for the comments. It is a center console cuddy and a great riding hull. It's the reason I wish to keep the boat, but the old Evinrudes are way too tired. Would anyone know if the mounting holes would line up, or is another Whaler Drive needed? |
cnorred |
posted 06-26-2009 10:52 AM ET (US)
Thanks for the delete jimh. I'm new to the blog, fist attempt, first mistake. |
TransAm |
posted 06-26-2009 11:00 AM ET (US)
I would not worry too much about the mouting holes issue until you resolve the weight issue. 1,300 lbs may be beyond the design limits of the whalerdrive unit. Get a couple of 200 lb buddies and have them stand on the whalerdrive transom with your current set-up. This will simulate the weight of twin V-6 Verados. This will likely send the swim platform areas underwater at static trim. In fact, when I stand myself on my whalerdrive (25' Temptation), my 185 lbs places the waterline almost at my feet. |
Tohsgib |
posted 06-26-2009 11:44 AM ET (US)
Mounting holes will not line up. Might also have a problem with power steering setup. Personally I would go with 175 Suzukis or small 200 E-Tecs for the weight. |
Buckda |
posted 06-26-2009 11:57 AM ET (US)
If you want to switch to Mercury, you should consider the 225 Optimax motors for the weight savings. Doesn't VERADO come in an L4 200 HP? That is a lighter weight motor and might be an option. Personally, I'd have my sights on either a pair of 225 OptiMax motors or 225 HP E-TEC motors if I was set on replacing the twins. At 500 lbs each, you're closer to the ballpark and will still enjoy increased efficiency and the power/torque of a DFI 2-stroke. Something to consider. I agree with the thought that the V-6 Verado may be too much weight, but understand your hankering for the DTS experience. Dave |
Buckda |
posted 06-26-2009 11:58 AM ET (US)
Also - doesn't the L4-Verado 200 have standard BIA mounting holes? Isn't it just the V-6 lineup that has the special 6 bolt pattern? One more reason to research OptiMax or E-TEC - standard bolt patterns - just plug and play on the transom. |
makoman310 |
posted 06-26-2009 12:29 PM ET (US)
verado mounting is the same holes as your evinrude just bolted my 250 in the same holes as the 225 oceanpro |
Tom W Clark |
posted 06-26-2009 12:56 PM ET (US)
All large outboards use the same bolt pattern which was established by OMC back in the early 1960s. It has been an industry standard for decades. There is one except: The Yamaha V-8s which use a six bolt pattern. |
cnorred |
posted 06-26-2009 01:09 PM ET (US)
I had heard about the OMC standard and hoped the Verados would work. It's good to hear from someone who has converted, thanks. The weight is obviously a large concern and I've heard about moving the batteries toward the bow for ballast. Does anyone know about the width clearance for twin mounts. The current engine mounts are 13.5 inches apart which gives the engines 5.5 inches clearance. I appreciate everyone's inputs. |
Peter |
posted 06-26-2009 01:44 PM ET (US)
Width should not be a problem for the Verados. However, I would be very concerned with the significant weight increase. You will be going from 900 lbs on the Whaler Drive to nearly 1400 lbs. Before I took that expensive plunge, I would experiment by putting 500 lbs of sand bags in/on the Whaler Drive and see how the boat handles with that weight, particularly when you come off plane rapidly and also into a significant chop or head sea. |
Tohsgib |
posted 06-26-2009 02:26 PM ET (US)
I thought the big verados used a 6 bolt config. and brochure does not look like standard as well. Makoman would know though. At 635lb dry....I don't think that is gonna work. The 510 1-4 200hp seems a better fit. |
cnorred |
posted 06-26-2009 04:32 PM ET (US)
We just came back from putting 510 pounds on the Whaler Drive and the very aft only went down slightly less than 2 inches leaving about 4 inches free board. Apparently the cuddy cabin serves as good ballast. The local Mercury dealer is approaching this issue with great caution and wants me to make sure all the t's are crossed. |
Buckda |
posted 06-26-2009 05:04 PM ET (US)
If it can handle the weight, a twin VERADO 225 HP 25' Outrage Cuddy with Whaler Drive would be a sweet machine! I say do a quick test week with that weight on your current rig and if it's not a problem, go for it! |
L H G |
posted 06-26-2009 05:14 PM ET (US)
I would not do it,as I don't think the Whaler Drive and the boat transom can handle that kind of weight, combined with that kind of power. You might check rated capacities with the Gov Products division, which still sells 25's with WD's. I would do a pair of L4 200 Verados, or 225 Opti's. |
cnorred |
posted 06-26-2009 05:44 PM ET (US)
Great suggestions guys. 280 pounds of the 520 just left, so I'll have wait until Sunday for a back down and following sea test. |
posted 06-26-2009 08:27 PM ET (US)
This picture can give an idea of the weight carry capacity of a Boston Whaler 22-foot hull with Whaler Drive. It shows my REVENGE 22 W-T Whaler Drive with a single 225-HP V6 motor. The motor weighs 455-lbs dry. Add a few pounds for gearcase lubricant, 12-lbs for a propeller, another 10-lbs for the hydraulic steering equipment. That totals about 480-lbs. Standing on the Whaler Drive you have your author at 220-lbs, L H G at probably 180-lbs, and Buckda at probably 160-lbs, for a total of 560-lbs. The total weight on the Whaler Drive is about 1,040-lbs. The water line is somewhat obscured by the dock, but you can see a portion of the transom of the Whaler Drive at the lower right of the image. There are several inches of freeboard left on the Whaler Drive. My interpretation of this loading test is that the boat could easily carry 1,040-lbs of engine on the Whaler Drive. Again, this test was on a 22-foot hull with the REVENGE cabin on the forward part. Also the boat is loaded with full cruising gear in the cabin, so it has weight forward which might be helping to counter balance the load on the stern. The image was taken on July 3, 2005 in Sault Ste. Marie, Michigan. The water is from Lake Superior and is probably rather cold fresh water. I would guess the water temperature was in the high 40-degrees-F range. |
TransAm |
posted 06-26-2009 09:08 PM ET (US)
Here is a picture of my Temptation with 1,100 lbs +/- of motor on the whalerdrive transom. If you click the photo to full magnification, you can see about 5 inches or so of freeboard on the whalerdrive unit itself. When I stand back there on the platform, the freeboard is reduced by about 2". http://s299.photobucket.com/albums/mm314/77SETransAm/?action=view& current=BoatPics-Deale004.jpg Putting another 400 lbs on the transom, well, lets just say it's gonna be close to putting the platform in the drink. One thing to also consider is the thru-transom drains. They also may be below the new waterline making for a more submerged bilge area. |
Tohsgib |
posted 06-26-2009 10:49 PM ET (US)
You guys are soooo cute. Who has the upper hand here?? |
TransAm |
posted 06-26-2009 11:52 PM ET (US)
jim must have woke up quick and didn't have time to shed the PJ's |
posted 06-27-2009 12:08 AM ET (US)
In the Upper Peninsula I always dress like that--it helps you to blend in with the locals. |
R T M |
posted 06-27-2009 08:34 AM ET (US)
Jimh, that's a good idea, I do the same thing. It keeps the autograph hounds at bay. The local Goodwill is a good place to pick up local clothes. However, I don`t know about your choice in wearing sleepwear on the street(or on boats), but I`m thinking you were visiting a nursing home and just wanted to blend in while there;)) rich/Binkie |
TransAm |
posted 06-27-2009 09:37 AM ET (US)
I must confess that I own several pairs of those types of pants; I see them advertised as "lounge pants" and do take some liberties in where I wear them. I'll maybe throw a pair in the boat bag next time out. But, I wouldn't let it get out that you were "lounging" with LHG. |
elaelap |
posted 06-27-2009 08:03 PM ET (US)
What a trio! And I thought our three-way Strike3* partnership looked a little goofy when gathered together in solemn conclave. Tony *Clever name, eh? CW member, brilliant linguist, and all-around nice guy andygere thought it up when Warren/WT, Matt/placerville and I first hooked up. |
posted 06-28-2009 10:14 AM ET (US)
By the way, Tony and the guys on STRIKE THREE have made a few changes this year to the fishing gear they've fitted on the boat. The new gear makes it easier to handle bigger fish. Here they are coming back into Bodega Bay. Note everyone wearing life jackets--standard policy with these guys--and no lounging pants. They're serious about this fishing stuff. ASIDE: What happens in Bodega Bay, stays in Bodega Bay. |
posted 06-28-2009 03:08 PM ET (US)
Getting back on TOPIC, an OUTRAGE 25 Whaler Drive and how it might handle the weight of twin VERADO L6 motors, our initiator of the discussion, cnorred, sent along this image of his boat for consideration: And again here in a close-up of the Whaler Drive to better see the static waterline: |
Tom W Clark |
posted 06-28-2009 03:23 PM ET (US)
Whoa. That boat is already pretty down in the stern. Adding another 400-500 pounds is going to be a real problem. |
TransAm |
posted 06-28-2009 06:49 PM ET (US)
Indeed. I would want to be taking weight off that transom, not adding to it. With only 2- to 3-inches of freeboard to play with, another 400- to 500-lbs will place the Whaler Drive precariously low. Aside: It appears as though there is bottom paint at the bow of the boat, yet it seems to disappear quickly. If it is in fact a painted hull, it either was painted incorrectly (too low), or the static trim has lowered considerably since its painting. That may suggest the hull has taken on water. |
captbone |
posted 06-28-2009 07:48 PM ET (US)
L6 Verados would not be clear the transom like the 3.0 liter Evinrudes. A large portion of the gearcase would be in the water. I would vote for 175hp Opti's. |
cnorred |
posted 06-28-2009 08:13 PM ET (US)
We all know Mercury is the official engine for the Whaler line, but what about Yamaha's. What does the 4 stroke 200 HP's weigh? |
Peter |
posted 06-29-2009 07:09 AM ET (US)
Will an L6 Verado tilt up fully (enough to get the gearcase out of the water) without interference between the cowl and boat transom? |
TransAm |
posted 06-29-2009 08:14 AM ET (US)
My experience with clearance on [a Whaler Drive] with an engine of this size is that if the engine is mounted in [the fourth] hole, there will be adequate clearance. Anything less and the cowl will hit the transom when tilted all the way upright, at least with Yamaha motors. I have also found that in my case, the engine can tolerate an even higher mounting height than [fourth] holes, and that installing a jack plate would only help the clearance problem, if one exists. Having said that, the VERADO cowl does have a unique shape, and may present unique problems in this regard. |
posted 06-29-2009 08:21 AM ET (US)
The Mercury VERADO L6 engines use a very unique tilting mechanism which could allow the engine to be rotated after tilting up to reduce the clearance needed to the transom. By turning the steering wheel to one side, you could rotate the tilted VERADO and perhaps gain some room. |
Tom W Clark |
posted 06-29-2009 10:37 AM ET (US)
The Yamaha F200 weighs 583 pounds. http://www.yamaha-motor.com/outboard/products/subcatspecs/1/specs.aspx |
Peter |
posted 06-29-2009 10:45 AM ET (US)
I wonder if the rotation on the pivot axis is enough. A fellow has a pair of Verado 300s directly across the dock from me and they are probably a foot taller (when vertical) than my 225 Fichts and the Ficht cowlings are taller than the 225s shown on that 22/25 Whaler Drive. |
L H G |
posted 06-29-2009 06:53 PM ET (US)
In the photo, those old 25" Evinrudes are mounted too low on the Whaler Drive. They should be up in the 4th or 5th holes. Yamaha 25" 4-strokes weigh more than Tom indicates. |
Tom W Clark |
posted 06-29-2009 06:56 PM ET (US)
Nope, 583 pounds it is. 25" shaft is the shortest available for the F200 (or F225 or F250) I do agree that twins on a 25 Whaler Drive should be up on at least the fourth set of bolt holes. |
R T M |
posted 06-29-2009 09:30 PM ET (US)
What are the specs on where the Whaler drive is mounted. If you need to come up that many holes, the Whaler drive was mounted too low by the factory, and needs to be raised 5 inches, and then use an outboard with an extra long (30") midsection. rich/Binkie |
posted 06-29-2009 11:07 PM ET (US)
The Whaler Drive is mounted where Boston Whaler wanted it; there are no specifications for mounting the Whaler Drive. It would be crazy to remove the Whaler Drive and mount it in a new location. The recommended length for motors mounted on a Whaler Drive is 25-inch shaft. |
R T M |
posted 06-30-2009 07:29 AM ET (US)
You may be right jimh, I have no experience with them, but weren`t they designed when motors were not as heavy as the current 4 strokers. In what year were they first used. Modifications might need to be made for the current heavyweights. Running the motors four holes up just to keep them dry should tell you something. Doing that on normal transoms would most times result in performance problems. Doing that on a Whaler drive boat with no problems should tell you something. There is alot of info here about transom heights on normal transoms and jack plates, but nothing on how to alleviate the problems discussed in this thread except find a lighter outboard. I believe if I owned a Whaler with Whaler drive I would take a long hard look at the mounting possibilities. Aren`t they just a bolt on apparatus? rich/Binkie |
Contender25 |
posted 06-30-2009 08:34 AM ET (US)
Just throwing this on the table for discussion: What if cnorred scrapped his current whaler drive and installed a new bracket? One with a larger chamber to counter the weight of the newer heavier motors at rest? There is a firm in Florida "Hermco" that fabricates custom fiberglass bolt on brackets so you could add more floatation a larger set back, and even match the gelcoat. Yes, there is an added expense BUT with the cost of new engines and rigging it is a relatively small cost. Here is a link http://www.hermco.net/brackets.html |
TransAm |
posted 06-30-2009 08:42 AM ET (US)
The Whaler Drive was offered as an option beginning with the 1987 model year. I'm sure it's placement was carefully computed. The hull in question here seems to sit low perhaps as a result of factors other than just weight. I have never seen a Whaler Drive model sit quite so low as this 25' Outrage. As for repositioning the Whaler Drive unit itself, I would agree that it would be an enormous effort for unknown results. The Whaler Drive is attached via a combination of 16-20 lag and thru bolts. In addition, up to 4, 2" thru-transom rigging tubes would need to be moved higher as well. By doing so all of this, the buoyancy characteristics of the Whaler Drive would be altered (lessened) perhaps negating much of the effort of raising the mounting platform. When we want greater performance from higher engine mounting heights on standard transom boats, the answer is not to build up the height of the transom. We simple add jack plates, and that would certainly be an option here. But I would want to know why the stern on this 25' Outrage sits so low to begin with. |
posted 06-30-2009 08:59 AM ET (US)
In order to compensate for the added weight of new motors by increasing the buoyancy of the drive appendage, the volume of water displaced by the drive appendage would have to equal the added weight. The added weight is estimated to be about 500-lbs. The density of water is about 64-lbs/ft^3. The added volume of the drive appendage which would have to be immersed at rest would therefore be 500-lbs x 1-feet^3/64-lbs = 7.7-feet^3 Since the maximum beam of the boat at the transom is about 8.5-feet, we can figure the bracket will be no wider than about 6.5-feet. This allows about one foot on each side. If we figure the bracket is 2-feet deep, we can estimate how much more draft we need in the bracket: 7.7-feet^3 / 6.5-feet = 1.1846-feet^2 1.1846-feet^2 / 2-feet = 0.5923-feet 0.5923-feet x 12-inch/1-foot = 7.1-inch The new bracket, if roughly 6.5 x 2 feet in area, would have to have 7.1-inch more immersion in the water in order to displace 500-lbs of water and create the needed buoyancy. You can see the arrangement of the Whaler Drive in this image: http://continuouswave.com/whaler/reference/images/propellerTest/ whalerDriveDimensions600x450.png As shown, the current configuration of the Whaler Drive only provides about 2.25-inches of offset from the keel. This means that if the Whaler Drive were extended downward by 7.1-inches to create the needed buoyancy for the additional 500-lbs of motors, the Whaler Drive would now extend about 4.85 inches below the keel of the boat. We would have to change the name of this device to Whaler Drag from Whaler Drive. This is a simplistic analysis because we have not considered that the added structure of the new drive appendage will increase its weight, so we might need more volume to compensate for the extra weight of the larger drive appendage. We could also make the drive appendage longer, more than 24-inch setback, and this would reduce the needed depth of immersion. But moving the load back farther will have more effect on static trim, so at some point might make the problem worse, not better. Assuming we finally found some way to increase the immersed volume of the drive appendage to handle 500-lbs of added engine weight, we would then have to consider how this was going to affect the performance of the hull. It certainly will add drag and wetted surface, both tending to decrease performance. I don't know if anyone has actually fitted a pair of the big L6 VERADO motors on the transom of a classic Boston Whaler 25-foot hull. |
jamesmylesmcp |
posted 06-30-2009 09:13 AM ET (US)
Jim, this boat belongs to the Fire Dept. Huntington,L.I.,N.Y. Twin 250's. http://i212.photobucket.com/albums/cc91/71outrage/twin250.jpg |
Contender25 |
posted 06-30-2009 09:23 AM ET (US)
quote:
The whaler drive never lifts out of the water while the boat is on plane so the wetted surface creates drag through the entire range of running speed(correct me if I am wrong as I do not own a boat with a whaler drive and this is how it has been described to me) Other brackets running surfaces are only wet at slower speeds but while on plane the wetted surface is out of the water. I know this as I have owned boats with flotation brackets. it also gets the drives into cleaner water out past the edge of the boats transom. A newer style bracket should do at least 2 things: 1: increase buoyancy at rest, looking at jimh's calculations it may not be possible but with a 30" or 36" setback I think it is. 2: Increase performance at planing speeds as there is decreased wetted surface, compared to a whaler drive. now if I am wrong and the whaler drive does get out of the water at a plane, my apologies. Also how much buoyancy is the boat getting now from the current whaler drive? I have no idea, but I do agree she looks a bit heavy in the stern in the current configuration perhaps the whaler drive is compromised? |
Tom W Clark |
posted 06-30-2009 09:47 AM ET (US)
The Fire Boat linked to above is a 27, not a 25. The Whaler Drive is not just an outboard bracket but an extension of the hull itself. The Whaler Drive cannot be mounted higher or lower on the transom and perform as designed. This is completely different than all other outboard brackets including the one made by Salt Shaker marine for Whaler and (unfortunately) called Whaler Drive by Whaler. |
R T M |
posted 06-30-2009 10:13 AM ET (US)
Maybe the Whaler drive is like the OMC Sea drive, an innovation who`s time has come and went, although it looks normal on the 27` fire boat. If the drive runs in the water at plane, it serves no purpose other than to lengthen the boat, with no or very little added floatation. rich/Binkie |
cnorred |
posted 06-30-2009 10:46 AM ET (US)
Thanks for all the great input, I've not carried through with the purchase of the Verados. I think you will be able to find them on Ebay soon. They are owned by the Mattituck, N.Y. Fire District. If you know anyone interested in a terrific deal, contact the Fire District secretary. So now the search continues to repower the old hull with a reasonably priced option, or find an upgraded Whaler 25' or greater. |
posted 06-30-2009 12:05 PM ET (US)
If we make the length of drive appendage longer, and we add 500-lbs more weight at the end, we will increase the stress on the transom of the boat significantly. If we go to a 3-foot setback and increase the weight by 500-lbs, we add 1,500-foot-lbs of moment to the stress on the original transom, as well as 33-percent more stress from the original weights. When the boat is in the water some of this is compensated for by the buoyancy added, but when the boat is on a trailer we now have a very significantly larger load bearing on the original structure of the transom. Since the transom is now 21-years old, we should not expect that its strength is any greater than when new, and it might be prudent to expect that the strength may be less than when new. On this basis it does not seem like a good plan to compensate for added weight by discarding the Whaler Drive and installing a new bracket with increased set back distance. |
venicewhaler |
posted 06-30-2009 12:13 PM ET (US)
if anyone can tell me how to include .jpg in posts I'll shoot some pics of my temptation 2500 (2*225 johns) that may be of help |
cnorred |
posted 06-30-2009 02:34 PM ET (US)
I talked to the service representative at Boston Whaler. He states the Whaler Drive max load is 980 pounds for this boat. The 2 Evinrudes should weigh about 900, plus rigging, so it's overloaded when anyone of girth stands there. As I mentioned earlier we put an additional 510 pounds on it and it went down only slightly. There seems to be some flotation associated with the unit.Is there a way to check if water is standing inside the drive? |
Peter |
posted 06-30-2009 04:09 PM ET (US)
Those Evinrudes weigh 455 lbs each. So you've got 910 lbs on the transom. Whaler is telling you NOT to put a pair of 645 lbs each (dry weight) Verados on the transom. With regard to water in the drive, you could drill a very small hole in the bottom (when on land of course) and see if any water drips out. |
makoman310 |
posted 06-30-2009 04:44 PM ET (US)
forget the twin motors why dont you just put on a 300 verado it weighs 650 or if you dont like that they make a 350 it weighs 667 and next year the will have a 400 and 450 they tweek 300 motor to put out 400 hope this will help you and if i can figue out how to post the dam pictures on this sight i will show you my whaler with the verado250 she sits on the same waterline as my old 225 oceanpro and weighs 160more |
Contender25 |
posted 06-30-2009 05:29 PM ET (US)
quote: with thinking like that it would be hard to make forward progress, no? I would rather do my homework and have a better performing boat than deal with current inadequacies (who is to tell it is structurally sound now, btw?). It is not very hard to check for structural integrity of the boat and the transom. If there are issues one can easily overcome them with added structural reinforcement or abort the mission all together. There are plenty of lesser quality boats out there with larger setbacks and I do not hear about engines and their brackets falling off to frequently......niot saying it does not happen but lets be somewhat reasonable here. |
TransAm |
posted 06-30-2009 05:54 PM ET (US)
Contender, there are not too many, if any, 25' long, narrow beam (8') planing hull boats that can handle 1,400 lbs of weight sitting back in the transom. It's not necessarily an issue of structural integrity, but one of physics. The current 255 Conquest with an 8'9" beam and dry weight of almost 5,000lbs (1500 lbs more than the boat in question here)is only rated to handle a maximum of twin L4 200 HP Verados. That should tell you something, since higher displacement (and heavier) 200 HP Verados are also available. So I will agree with you when you say "lets be reasonable here". It's really pretty simple. The boat was not designed to handle it and ,well, it can't handle it. |
Contender25 |
posted 06-30-2009 07:08 PM ET (US)
Hmmm ok I will digress and give up here as I guess I failed physics..... but here are a few boats in the 25 ft range that I have seen in person with twin Verado 225-300's contender 25 older version bracketed sure they are all different but none are a far stretch from the subject boat
TransAm |
posted 06-30-2009 07:36 PM ET (US)
I'm sure there are structural considerations and other differences in the boats you describe and the subject Outrage. For instance, the Seacraft 23 (26'1" length) is a 4,600 lb boat, over 1,000 lbs heavier than the 25' Outrage, and carries a wider beam. I also suspect the designers were able to take into consideration today's heavier outboards when designing the transom area, especially as an integrated portion of the hull. The Regulator is a 5,100 lb hull also with a 8'6" beam. With a deadrise of 24 degrees, more horsepower is needed to achieve its performance goals. The Outrage was simply not designed for 1,400 lbs of weight-period. And without major/radical alterations, it would seem pointless to try and make it into something it cannot be. As for the Whaler Drive itself (and an owner of one), I have seen none of the performance inhibitors described in other threads. My personal performance numbers support this as well. |
posted 07-01-2009 08:35 AM ET (US)
quote: That is an interesting specification. I don't recall hearing that figure before. |
L H G |
posted 07-01-2009 12:14 PM ET (US)
A while back, that 25 Temptation seemed to easily handle the weight of 515# 300XS Optimax twins. This is only 50# over the Whaler specification, which seems about right. |
