ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Motor Pulls to the right
Author | Topic: Motor Pulls to the right |
gsull |
posted 06-30-2009 11:16 PM ET (US)
I have a 40 hp Johnson Tiller steering and it pulls really bad to the right at full throttle. Does anyone know what the problem could be? and how to fix it? |
R T M |
posted 06-30-2009 11:23 PM ET (US)
Simple, adjust the zinc fin under the cavitation plate the opposite way. rich/Binkie |
Tom W Clark |
posted 07-01-2009 10:28 AM ET (US)
No, move the trim tab in the direction of the pull, not away from it. Adjustment of the trim tab is described in the Boston Whaler Owner's Manual: http://continuouswave.com/whaler/reference/manual9-17/operations. html#trimTab |
Tohsgib |
posted 07-01-2009 12:12 PM ET (US)
Tom is correct and on a 40 Johnson it is not zinc. |
TransAm |
posted 07-01-2009 07:46 PM ET (US)
You're a funny guy binkie. Did you think this guy was a nascar boater and needed to be in a constant right turn? |
project13 |
posted 07-01-2009 11:08 PM ET (US)
I have a 40 tiller with power t/t on my 13. Pulls badly left when trimmed all the way down with too much throttle. I never tried adjusting the fin I just trim up. If you often haul (trailer) your rig, maybe adjust up one hole, and perhaps the boat will run better and pull less. |
Tohsgib |
posted 07-02-2009 11:11 AM ET (US)
Project...if trimming up fixes your situation then you are trimmed in too far. You should ALWAYS trim out until you get a neutral steering feel unless you need to be trimmed in that far for some reason like big seas, etc. |
R T M |
posted 07-03-2009 12:25 PM ET (US)
TA, boat racers only turn left, not right. My raceboat is set up to only turn left. Its the boat bottom, has nothing to do with the motor. Right turns could be hazardous to your health. BTW my post was not wrong. He didn`t say how his fin was set up. If it was making the boat turn right, it would need to go the other way. It also may be something else. rich/Binkie |
